View Full Version : Generation III External Engine
  1. Will WS6 ram air lower box fit under Raptor Hood?
  2. Will WS6 ram air lower box fit under Raptor Hood?
  3. Wire Harness Relocation
  4. where to get slp dual/dual at?
  5. Losing or Gaining power? (open longtubes)
  6. Header install ?
  7. Halfway and scared...
  8. will an aftermarket lid make me lose power since i already have ram air?
  9. problem with wraped headers?
  10. throttel body porting- should I?
  11. exaust stain
  12. Catted Y-pipe
  13. Headers in!
  14. difference betw ls6 intake and ls1
  15. My Favorite Sound Clip
  16. 2.5" vs 3" Y-Pipe
  17. Stock Manifold problem...
  18. Dual cutouts on the Y-pipe, Pros & cons?
  19. Sound clip: TSP Spiral Flows
  20. What plugs should I get?
  21. what exhaust should I get
  22. Sound clips!: Duals w/1 chamber flowmasters
  23. What Kinda Times Yall Think??
  24. waterpump
  25. Intake Plenums Alum Vs Plastic??
  26. what angle should my cutout be welded in?
  27. Installing Hooker Headers, what all will i need
  28. Dont use this mod!!!! Free Ram Air is Bad
  29. Hooker, Pacesetter LTs, TXSPD ORY startup/driveby
  30. which catback system
  31. Smooth bellow question?
  32. Beffy AC compressor?
  33. What to do about LS6 coolant tubes?
  34. Next mod ?
  35. Need exhaust help.
  36. What are the chances my aftermarket pulley is causing KR?
  37. Need Help Fast
  38. most hp gain from a cat back
  39. magnaflow
  40. Removing AIR and EGR, will I still pass obd scan?
  41. What is your favorite LT, and why??
  42. drone or rasp with true duals?
  43. Header installation
  44. EGR Block off plates
  45. What kind of pipes?
  46. What Throttle body?
  47. Loud Mouth 2, Pacesetters and Ory
  48. Emission Flange on my QTP header fell off. Is there enough room to weld the flange...
  49. Vibrations @ 1800-2000rpm after headers
  50. Stock W/ Cut Out Vs. Lt/ory
  51. fiiting blew with or wthou block-off plates?
  52. Convert Electric TB to Cable HELP!!!!
  53. Where do you guys gets headers coated?
  54. borla question
  55. Car Won't Start!!!!!!!
  56. Free Cold Air Mod Pic Needed
  57. LS2 intake to 02 LS1?
  58. Header keeps burning my plug wire!!!!!!
  59. kooks?
  60. Spark Plugs
  61. Help! Anyone have their engine currently out??
  62. Need assistance ID'ing headers ( pics w/in )
  63. Need quieter mufflers
  64. Before I do it? No not that! :)
  65. Need some help finding 4" tubing
  66. All the emission parts??
  67. header and y-pipe q's
  68. Cut-out
  69. ORX dumped vs over axle
  70. Catted True Duals
  71. Help Asap!!
  72. aftermarket tempature sender??????
  73. SLP FLow Pac
  74. bad water pump or not??
  75. No Cats and Corsa=Rasp???
  76. clunking noise..
  77. Best FRONT 02 Sensor replacements???? anyone need help asap
  78. Magnaflow/Carsound Cats
  79. X pip cutout question
  80. magnaflow exhaust
  81. SLP Camaro Firebird Cold Air intake?
  82. BG ram air
  83. SLP keeps popping off with SLP bellow
  84. LS6 Intake Vacuum Fitting removal?
  85. How would Mac headers, ORY, SLP LM sound?
  86. People with WS6 air box and FTRA/SSRA
  87. question about heads
  88. Free Ram Air Mod
  89. 160 Degree Thermostat
  90. look what my car did
  91. bad header leak
  92. Buying Headers Need some help
  93. Will i feel a difference with headers in power
  94. Wire Harness Relocation
  95. Help On Where To Put Missing Parts After H/C Swap
  96. anyone have this exhaust 93-02 camaros
  97. Exhaust Hanger Help Please.....
  98. new Hooker COMP
  99. car running hot
  100. quieting duals
  101. Just installed my headers today!
  102. anyone have powerstick install
  103. Passanger side cat glowing red hot after TC install
  104. QTP catted y ground clearance
  105. Outlaw True Dual!!! (PICS)
  106. How to get pulley off of pump
  107. Any downsides to an Electric Water Pump (EWP)?
  108. 2 Catch Can Concerns
  109. Headers
  110. Strange Wistle Noise
  111. QTP 1 7/8" To big?
  112. How hard is it to do headers
  113. Quicky Engine Removal Question...
  114. Firehawk Headers Are In - Dynatech Supermaxx
  115. need help!
  116. Throttle Body Cooler
  117. Loudmouth exhaust, is id any good?
  118. Almost done with the QTP's
  119. mac mids
  120. Oil Pressure
  121. do i need to unplug the battery for these mods?
  122. thermostats?? differences?
  123. Ls1 Carb/distributor
  124. Exhaust Pipes
  125. Stock Tips
  126. New guy with a few longtube ?'s
  127. Who sells Lanes True duals
  128. Just installed SLP dual dual
  129. the neighbors are gonna love me
  130. How Long did your stock rad last?
  131. Header question????
  132. Pacesetter Headers installed (sort of)
  133. Trying to get part # for exhaust hangers
  134. B&B Exhaust Problem
  135. Can I pass PA emissions by using O2 simms?
  136. Request:Pictures of Magnaflow and Borla exhausts
  137. are these stainless headers as good as the top brand?
  138. Exhaust pipe suggestions
  139. Anyone running no O2 sensors on LT's with ORY?
  140. what should i do?
  141. Poly motor mount drivers side only???????
  142. Motor Vibrates at Certain RPM. Confused
  143. removing power steering cooler?
  144. Bump Stop Mod?
  145. Another header thread..install tips needed
  146. Porting the header flange
  147. Keeping it Legal in CA.
  148. Help with my throttle body
  149. truck throttlebody on a ls1??????
  150. Can anyone help me identify my intake and motor??
  151. Air Pump Questions
  152. random tech cats how good are they?
  153. New style of sheet metal intake manifold (pics)
  154. Smoke coming out of exhaust...
  155. Holley Stealth Ram!!!
  156. having some trouble deciding on some LT headers
  157. Autometer adapter?
  158. rear o2 sensors..
  159. these look like qtp but cheaper
  160. Normal or Racing Headers
  161. How Do I Unclog My Catback? (Slammed my cat on curb)
  162. Help installing throttle body lol
  163. o2 simulators?
  164. opinions on this cat back set up?
  165. Ouick Question!!!!!!!!!!!!
  166. LT's ORY Mufflex?
  167. Can I trust this exhaust guy?
  168. Steering shaft problem
  169. Magnamouth installed....
  170. Has anybody not had clearance issues with the new QTPs?
  171. Trying to quiet it down
  172. Joined catted y pipe?
  173. 98 mac headers
  174. ? XS Super Comp Headers
  175. header leak
  176. 1 chamber flows after axle
  177. custom ram air
  178. Have some Pulley ?'s
  179. 02 sims
  180. Catback swap out queston
  181. What is the purpose of the evap system?
  182. Stock crank pully ?
  183. Pacesetter LT's,ORY ,Dynomax
  184. Air lid causing P0171 & P0174 codes
  185. qtp ypipe and driveshaft loop?
  186. Gear Drive for LS Engines
  187. finaly got my LTS a tsp duals on
  188. air induction question?
  189. FLP custom true duals
  190. 3" True Duals too Big??
  191. Broken header bolt in head
  192. Free Ram Air...
  193. true duals w/ stock manifolds...let's see em!
  194. Using LT1 poly mounts....where to put washers?
  195. Going from standard ORY to custom ORY
  196. Missing a FAST 90mm Gasket!
  197. headers
  198. My review of Spark Plug wire & Plug install.
  199. kooks headers
  200. Cat and Y with stock manifolds
  201. how much is this manifold?
  202. Is it worth it to move my cutout??
  203. Got my ebay headers today
  204. is this an SLP 85mm MAF???
  205. Problems with my Hooker L.T.s
  206. How to hook MAP sensor up to vic jr intake
  207. exhaust guy said that my car won't run without cats
  208. why can i not find a 85mm airlid anywhere?
  209. heeeeaaaaaderrrrrrz
  210. Cleaning MAF screen
  211. ? relocating battery to the rear
  212. why does an ls6 make rear run lean
  213. What do you guys think about Flowtech headers
  214. LT's/TD's - rasp from 2700-3000 RPM
  215. Poll: To reuse or not to OEM Spark Plug Heat Shield
  216. $17 Fix For 6800+ Belt Throwing
  217. TB: What direction to go?
  218. True Duals worth it over catback?
  219. LS6 Intake swap - Oil pressure jumpy
  220. New QTP LTs Installed
  221. Question about headers and ORY Im gonna get
  222. pulley questions
  223. LS1 water pump pulley
  224. AIR Question, doing headers
  225. SLP air temp module
  226. dyno gains with headers
  227. line lock
  228. balancer/crank pulley
  229. painted my FAST and installed rails *pics*
  230. Hows the easy way of getting more air
  231. Results of my port and polished TB
  232. tsp catback to raspy
  233. Headers
  234. bbk intake
  235. question about your !pcv (people runnin breathers)
  236. tps voltage @ idle and wot?
  237. Help! Can I run with the EGR hose disconnected temporarily?
  238. installed LS6...Problem now!!
  239. Any sealing or welding nec.????
  240. March underdrive removal help...
  241. Headers? ORY? CATS? CHECK ENGINE LIGHT?
  242. How long did u go?factory plug/wire change
  243. Dmh Or Qtec Cutout.
  244. would a cat from 2001 TA fit a 2000 TA?
  245. Please Post Pics of Corsa k/o's on Camaro
  246. throttlebody swap
  247. Stock LS1 crank pulley diameter
  248. O2 Sensor Extensions for LT's
  249. Exhaust
  250. Convertible tunnel brace
