View Full Version : Generation III External Engine
  1. Pacesetters installed (pics)
  2. Replacing Flowmaster w/ Hooker question
  3. FAST 90\90 Combo vs Stock LS6 Intake and TB
  4. Spark Plugs
  5. 160 degree thermostats w/ housing @ $19.99ea
  6. 90mm Bellow what are you guys using?
  7. To Descreen the MAF or not to descreen the MAF..that is the question
  8. Ebay Headers - Sponsor Review
  9. GMMG video going through gears, not just idle and rev
  10. Underdrive alternator/crank pulleys...
  11. Single tips or Dual tips on T/A Valance? Would these dual tips be restrictive?
  12. Charging problem
  13. magnaflow quad exit.
  14. LT Headers for 2002 on 1998
  15. Need Help!!
  16. turn-down question
  17. PCV conversion???
  18. true duals with ebay headers
  19. A mysterious rattle...
  20. slp underdrive crank pulley what BELTS?
  21. Thinking about putting cats back on!!!
  22. ls6 with EGR provision ?
  23. Tach Wiring Troubles.
  24. I need pics of SW SS LTs from the guys who have 'em.
  25. Good deal on GMMG??
  26. Please help....
  27. Whatcha Think?
  28. magnaflow is sick!!
  29. Sea Foam Help PICS
  30. Replacing resonator
  31. How does the Volant cai stack up?
  32. cut out is now in! mccord going on tonight.
  33. Should I wear a raincoat?
  34. Pacesetter Question
  35. Are 12" O2 extensions long enough?
  36. Coil relocation???
  37. FAST 90/90 Peeps, Trouble With the TPS/Throttle Cable?
  38. Trapping 110 in a mildy bolted on car?
  39. Coolant pipes? ("H" looking hardlines under intake mani)
  40. New Era Ported Throttle Body ?'s
  41. Time For a Cat Back system
  42. Pacesetters Versus Kooks
  43. is this pic an ls6 manifold
  44. TSP rumbler and cut out
  45. quick exhaust questions
  46. will this fit?
  47. Exhaust Opinions
  48. how much restriction on the stock ws6 muffler?
  49. Crao coming from beneath Intake?????
  50. pacesetter exhaust leak
  51. What spark plug?
  52. what should i get?!?!?!
  53. Cats
  54. QTEC Wires
  55. Porting the mass air flow.
  56. Help!!!! Mod List Inside
  57. LS6 install Question.
  58. Help...Im leaking
  59. TD question
  60. QTP Y-pipe
  61. Bad to run open cutout?
  62. 95 db limit
  63. Bad Vibration and noise??? WTF help me out guys!
  64. header install what do i need?
  65. Dumped?
  66. Remote Thermostat Housing Available?
  67. A.I.R Delete Finished
  68. Finally getting my headers
  69. QTP headers,
  70. pulley question
  71. Exhaust gurus in here please!
  72. how much $ to have a Y pipe modified?
  73. Exhaust dilema
  74. where can I find this kind of breather cap?
  75. Header Size??
  76. coolant leak....
  77. serp belt size for pulley
  78. LTs/ORY/Magnaflow Catback??
  79. Drag Cars post pics of your exhaust setups
  80. x pipe and cam lope
  81. True Duals or Y-Pipe??
  82. ls6 intake
  83. SLP Double-Roller
  84. PCV...replacing hose
  85. catco direct fit
  86. SLP clearance????
  87. LS6 Manifolds
  88. Header Confusion! Please Help!
  89. B&B, Mecham or GMMG? Hmm....
  90. Installed QTP HVMC headers and ORY-pipe
  91. starter motor adjustment
  92. Aftermarket wires bad for your car?
  93. Flowmaster or borla pro xs????
  94. banks catback?
  95. Electric cutout installed..check it out!
  96. where do these vacuum lines go?
  97. Y-Pipe: That much more power?
  98. deleting rear o2s?
  99. 02 sensors keep going bad!
  100. Using Cold Welds on Exhaust...
  101. best 85MM MAF to buy...and where
  102. TSP Lid
  103. Underdrive Pulley
  104. Has anyone tried o2 sim.
  105. Installing a Loudmouth after a stock
  106. Lakewood safety loop question
  107. maf translator ?'s
  108. Part name please
  109. My Car Is Running Rough
  110. Electric cut-out on a Borlamouth
  111. HELP cant get rear header bolts in
  112. My thoughts on the FTRA
  113. MTI Throttle Body???
  114. Throttle position sensor issues?
  115. 2-step question
  116. Trying to install Autometer oil temp sender
  117. Exhaust questions
  118. cutout help
  119. Needing QTP instructions/wiring HELP!!
  120. ac
  121. slp thermostat questions
  122. edelbrocks headers with a/c anyone? or kooks.
  123. Just installed the LS6 w/ EGR
  124. Pacesetters and ORY completed :)
  125. blank lid
  126. Loudest Borla Setup ?
  127. QTP cutout switch pics?
  128. F-body loudmouth vs. Corvette borla sound levels.
  129. Polyurethane motor mounts...where?
  130. broke a balancer tab....
  131. How restrictive is a CME exhaust on a camaro SS
  132. Trying to track down coolant leak?
  133. 80mm throttle body
  134. How did you guys wire your e-cutouts?
  135. Need help on picking new muffler!
  136. turn downs or not
  137. what size band clamp to use
  138. Bad luck or no luck!!!
  139. 98-99 vs 01-02 headers
  140. Header Gaskets
  141. LQ9 ex manifold vs LS1 camaro ex manifolds
  142. true duals with, chassis mount torque arm?
  143. V6 Header install
  144. Y pipe for stock manifolds
  145. Tubular LS1 Solid Motor Mounts...get em or no?
  146. Mufflex or Duals?
  147. True dual exhaust
  148. Just ordered!!
  149. HELP!!!!!!!! Car is running horrible after header install...??
  150. Jet coating headers question...
  151. where to get a zo6 maf for a good price and will it fit on slp air lid
  152. Got some bolt-on dyno figures...
  153. Need Help With a Muffler Decision
  154. Exhaust for a 5.3 truck?
  155. Borlamouth question
  156. Coated or Header wrap????
  157. How To Remove The AIR Pump
  158. A\C compressor help
  159. 3 inch cutout right?
  160. Y Pipe problems
  161. Which Series Flowmaster Do Yall Recommend?
  162. Exhaust System Questions
  163. Anyone have TPiS headers or Gale Banks Catback?
  164. I've been bit by the modding bug!
  165. Best cat-back with stock manifolds?
  166. Coated pacesetters and catted-y from TSP
  167. What happened???
  168. LS6 Intake
  169. Question on Cats??
  170. Stupid header question...
  171. Cooling issues?? help...
  172. Header install
  173. Anyone running hooker 1 7/8" headers? Plug wire issues
  174. How big of a part does the cat-back play in emissions?
  175. please help!
  176. Possibly a bad cat?
  177. NEED HELP ASAP...Intake Install Problem (PICS)
  178. thermostat question
  179. What Headers
  180. Just got my Pace Setter LT's Today!
  181. z06 MAF connection
  182. Oval tips on camaro GMMG knock offs?
  183. alternator connections LS's & LQ's
  184. sweet thunder or magnaflow for td's
  185. Issues with cutout.
  186. why do people not like flowmasters on ls1?
  187. Where Can I ?
  188. Spark Plug Question???
  189. P&p Tb Pics
  190. Moroso spiralflow is the ****!
  191. WIll these mods be daily driveable?
  192. Sound level with cats? Bullet muffler?
  193. H pipe owners please come in
  194. Energy suspension motor mounts or prothane
  195. ORY&Borla muffler!
  196. what air intake system works the best ?
  197. LS2 intake
  198. anyone using the professional products intake?
  199. anyone with qtp's?
  200. Going back to stock, need to UN-INSTALL headers, any advice?
  201. Dynomouth and TSP rumbler
  202. Hooker muffler
  203. O2 Sensor Plugs?
  204. Any power from ORY w/stock man.
  205. need to borrow F-body longtube headers for fitment testing of hot rod
  206. true dual exhaust...will one designed for a 00 LS1 fit my 93 LT1?
  207. Fan blade physics... need info...
  208. headers
  209. longtube install problem
  210. Anyone run into starters breaking off
  211. Any interest in new SLP CME tips and valence?
  212. headers and y-pipe w/ stock cats?
  213. Cutout Plate sucked back up in exhaust or impossible?
  214. Best Throttle body NX, FAST ?
  215. Ported Throttle Body- now having slight sticking problem.
  216. recharging AC, how many #'s?
  217. running like crap
  218. Help me make my muffler decision.
  219. passeneger side rear spark plug wire??
  220. Angle turn-downs towards each other??
  221. pcv valve system
  222. LT1 Rad Coolant Level Sensor Plug?
  223. Best way to keep shit from shaking like a 6-4 rumble pack?
  224. How to clean maf ????
  225. Will the Kooks catted Y Fit my QTP Headers???????
  226. is any catback 3in in and 3in out?
  227. Car Tunned
  228. Whats your experience with Magnaflow?
  229. Need a belt for ASP pulley
  230. Dynomax ultraflo ss muffler
  231. which shaner TB ?????
  232. problem with Pacesetter LTs
  233. header banging i think
  234. How would this sound???
  235. SD tune maf question
  236. benefits of getting a new Catted Y?
  237. 99 tb on 2000 TA
  238. What's better for ram air hood?
  239. missfire
  240. blocking off erg
  241. Rocker Arm question?
  242. anyone use the PTM t/b from texas speed?
  243. OMFG the vibration
  244. okay, educate me on pulleys
  245. Best Exhaust for 1 7/8 LTs?
  246. installed my pacesetters!!
  247. Clutch chatter/headers hitting k-member
  248. A Good Deal
  249. True Duals
  250. Are these dents bad enough to replace headers???
