- how would !mufflers sound on an LS1 vette?
- Lid Size??
- Wanted Center Mount exhaust Pictures on Blue SS
- Battery relocation kits
- would this pass emiision...
- another intake question
- Ported TB and MAF!!! Now have problems...
- rksport lid
- Why have EGR and AIR?
- Gains from LS6 as last bolt on....
- Trans tunnel brace
- Power gains
- Header Install Voiding Warranty & question
- Is this good enough for bolt ons?
- LS2 plugs wires better fit?
- 02 sensors
- Oil temp gauge question
- couple quick ?s
- Accufab 4150/Victor Jr. Throttle Body what do I need?
- BOTCH Platinum plugs?
- best LS1 headers?
- Which tips?
- Who's running a 90/90 setup w/ stock MAF?
- Bolt-Ons for an 408
- Pacesetter Mid Lengths
- true duals piping question
- 02 sensors
- what mass air setup are you guys runing with a fast 90/90 and strokers?
- Best Place to Buy Mac Mids
- Plug change... now problem!
- pacesetters and tsp ory
- tips on header
- Help!!! Advice needed!
- Amazing!!!
- My paceheaders came in but now having problems
- exhaust
- HPE Electric Cutout Question.
- snapped bolt on cat flange
- appreciate some help
- wheelie
- Post if you have MAC MID LENGTHS and your car makes blue smoke!!!
- help with radiator
- Exhaust hitting Crossmember
- How to tell if its a LS6 Intake Manifold
- SLP Lid Owners Please Come In.
- lg lid question?
- 2.5 y-pipe hp capabilities
- Standard cast headers / cat positioning
- Quick Question
- wiring dual post coils
- LS6 intake question
- What size of bullet with Pacesetters?
- Could my TSP catted Y be restricting me?
- Scanned - not a misfire, need help.
- Running hot. Please help
- 7mm wires too small?
- pulley removal
- where can I get 3.5" ID pipe?
- electric water pump.
- PCV systen setup for Ls2
- Belt keeps walking off?
- TB Help ASAP PLEASE...car starts but throttle cable only moves when off
- hypertech fan settings?
- XS Super Competition Headers(Stainless steel)
- Which Y-pipe?
- TSP duals
- Edelbrock LT's are Here.. w00t
- Volant cold air intake
- what does slp do to the manual fan switch?
- Which Bullet
- Hollowed out Cats on ls1
- getting oil filter off with long tubes
- Opinions on a few mods...
- just got my pacesetters in!!! Are they the right ones??
- Question on edelbrock shorties
- Question Kooks Headers
- Magna-mouth or Powerstick!
- Throttle body choices
- McCord powerplate wiring/install???
- Help PLEASE!!!!!! Pacesetter question???
- installed some new goodies today...Katech/K&N
- No spark or fuel, whats wrong?
- Bosch Platinum Plugs
- flowmaster muffler w jet hot headers
- i need pix of exhaust over axle, but on both sides
- How important custom exhaust be mandrel-bent?
- Header Bolts
- Oxidizr's new cats are MIA. Second best option now?
- Belt Squeak
- help me pick my exhaust
- Help Me Install My Catch Can Please!!!!
- Will a TSP Y fit QTP LTs?
- how much coolant
- Best fitting Catted Y pipe ?
- Help with O2 sensors
- Whats the best for my setup + will pass California emissions visual?
- Loud noise after spark plugs
- Cutout placement
- Stainless Works Headers???? Anyone runnin them?
- Diagnose THIS problem, exhaust ringing/vibration at the y-pipe
- installed o2 sims, now erratic idle and misfire
- So if 1 7/8" is overkill what will 2" do...
- What Cat-Back with MAC headers/Y-Pipe??
- LS1 intake vs LS6 intake
- Question about Kooks Headers
- Electric cutout
- Does SLP's Flow Pac Eliminate the SS Hood?
- Cutout
- Best Y Pipe and High Flow Cat Coverter?
- Looking for Feedback on Dynatech Supermaxx Headers
- Where can i get these hangers?
- Exhaust hang points on Magnaflow
- MSD's and Kooks???
- Exh ????
- edelbrock headers ?
- anyone know how this sounds?
- Anybody running solid motor mounts?
- Header bolts......
- AHHHH...I just ordered them...
- Engine service light, help!!
- how much ps and ca compressors/pumps cost
- header???? w/o sensors help inside
- New cats supposed to smell?
- Can I expand this y-pipe outlet
- Electrical problem please help!
- What ORY to get for Pacesetter/Corsa Combo?
- Look what the UPS guy dropped off today!!!
- Huge Prob!!!
- How much do resonators help?
- Magnaflow bolt on?
- Miss - pop - backfire - hesitating - surging - confusion!
- front air dam effect on cooling...
- Edelbrock LT??
- KATech Tensioner Install. (already posted in conversion page no luck)
- Throttle cable and TB ??
- Check out this clearance!!
- Worth it to tune???
- SLP Lid, MAF, and Smooth Bellows Install Questions
- Off-Road Y-Pipe questions
- Just ported TB
- where to find triangle exhaust flanges
- Who has ARP assembly lube (in stock)?
- Broken Y Pipe Bolts
- Loud mouth to loud what to do?
- Problems with Pacesetter LT Header Gaskets?
- Confused...Egr and Air Removed
- need new front 02 sensors
- Billet Bank
- header bolts
- Buddys exhaust so loud!!!!
- Running motor w/out egr/air blockoffs?
- Any one had any experience with....
- Finally it arrived... my bassani true X duals!
- coil relocation/ longer plug wires
- header question
- At a loss here...
- Question concerning airflow into manifold via TB and MAF..look
- LS6 v.s. FAST intake manifold
- normal to get some noise from LS6 intake?
- MTI Lid 02 Z28
- Got my catch can today. Pics.
- Pully deal on TSP
- LS1/6 Power Steering Pump/Pulley Install
- Ported TB Swap
- 98-99 vs. 00-02 headers on LS1 Z28
- LS1 experts/technicians suggestions
- Gutted cats, how much louder?
- dynotech headers
- knocking noise?
- stupid exhaust!!!
- **Bullet compared to Catted Y**
- if YOU fabbed up YOUR OWN true duals...
- Ignition Coil
- Hooker Exhaust Users
- LSX 90mm TB Flange for Sheetmetal Intake
- port and polish MAF?
- vid of new duals
- Loud belt... good replacement?
- PCV Venting to Catch Can
- Header ?????
- Jet Hot Long Tube Headers
- Need help with Bassani y-pipe setup (w/cats)
- Looking For Exhaust Tips
- which manual fan switch, SLP or Caspers?
- Cam or Chip . . or both
- Cutout setup to loud?
- SLP Loudmouth on c5, SOUNDS ??!?!?!
- Where to find Injector 0-ring & retainer
- Quiet down damn it !
- Preventing Rust when Welding Exhaust components???
- TB whistling
- underdrive pulley question
- EGR pipes
- o2 extentions!
- FAST 78 or 90 Setup for me?
- TR6 spark plugs
- Porting TB in ILLINOIS
- Magnaflow Exhaust Tips
- time for duals
- ses light after installing headers and o2 sims
- a/c tensioner crooked??
- still missing
- slp pulley?
- Help with ls6 swap
- LS6 Manifold question (need some opinions and facts)
- My Paceheaders and Tsp offroad y-pipe came in today
- What Size Is The In And Out Ofmy
- Port a BBK TB???
- BBK intake help
- Cutout question
- LS1 underdrive balanacer
- Porting and Polishing TB!!!
- Help me identify whether this is a SLP/ Dual Dual
- anyone besides mufflex make a single exit?
- Power steering pump puking fluid
- 3 inch true duals
- Howto: Quite exhaust to pass inspection?
- SLP powerflow
- Difference between LS1 & LT1 Magnaflow Catback???
- Pacesetters with TSP Catted-Y Pipe?
- Damn popo ruin everything
- Dynatech Supermax Headers??
- Getting LT's...what else do I need??
- can it be done? anyone?
- Just bought a 99 Z28, What mods?
- want to paint my I-pipe...what temp paint do I need?
- whats the best exhaust?
- Anyone ever tried this? (ctusom TDs)
- Shorty gains over stock??
- Which fuse?
- older qtp collector ?
- 160 degree thermo for a 02 z
- help please...exhaust question
- slack in the throttle cable?
- Air conditioning questions
- cat bac for 02 z28, what kind and
- What the heck is this part?
- Removed EGR&AIR Emissons and my exaust got deeper
- Oxygen sensors
- couple questions
- anything else for UD pulley
- power steering pump pulley removal ???
- Is this a good $60 find?
- best new induction setup on my SS???
- plug for IAT hole?
- LS1 crank sensor type?
- thinking of getting duals run out the back
- Routing O2 sensor wire?
- Swap back to stock exhaust - Help
- Best way to access header bolts...
