View Full Version : Generation III External Engine
  1. Best place for flowmaster?
  2. Headers And ORY
  3. need help
  4. TB and MAF question
  5. intake swap
  6. Help me decide. QTP or Kooks.
  7. Ported TB intall question
  8. question on my exhaust
  9. FAST Intake manifold and 90mm NW TB or just keep stock ported TB?
  10. Intake setup
  11. XS LT Headers Came In! *PICS*
  12. Something looks off???
  13. Motor mounts when doing headers...
  14. Synergy All in One product line....
  15. Anyone shaved their stock valve covers?
  16. dipstick tube
  17. sweet thunder exhaust
  18. lost one of the boys today
  19. Need help on EGR bypass
  20. QTP stainless steel cut-out
  21. dumpin slp loud mouth
  22. Cut-out size
  23. Probably a stupid question...NW tb on a LS6?
  24. what is the cause of a Vacuum leak?
  25. Are Headers A Good Idea?
  26. painted headers smoking after install?
  27. Opinions on valve covers please.
  28. How much power are ported TBs worth?
  29. white plug?
  30. Corvette AC pulley and tensioner?
  31. Loud Whining On Warm Start
  32. True duals idea, tell me what you think
  33. exhaust leak question
  34. shorter dipstick?
  35. traction control question?
  36. True Dual Questions
  37. Broken Super Sucker Ram Air??
  38. camaro tips (or lack thereof)
  39. Good shop that installs and tunes headers
  40. header clearance on ls1 blazer
  41. traction control stays off
  42. What lid fits an 85mm MAF and 90/90 setup well?
  43. What part is this?
  44. Motor mounts = pain in the butt IF
  45. Cats 02 Ls1 On A Lt1
  46. Best price on SLP LoudMouth
  47. underdrive pulley ???
  48. Gauging interest TB group buy
  49. MAP sensor problem
  50. Need Header Advice
  51. New 3" TD's Under axle with Powersticks Pics and Video inside!
  52. TB, MAF and Bellows worth it??
  53. Need Help Asap....
  54. Flowmaster Drone??
  55. Drilling into steering column??
  56. True Duals vs X Pipe
  57. cut out with no exhaust
  58. do STB's fit over the FAST 90's???
  59. need help with my lid/bellow selection
  60. Jet Hot Y-Pipe
  61. Call Out To Oxidizr! (MagnaFlow Metallic-Cats)
  62. cats or no cats?
  63. cutout location
  64. cats
  65. Bullet mufflers/resonaters
  66. worth the price?
  67. install
  68. Best cheap set of long tubes for LS1?
  69. ls6 intake???
  70. Retarded Catch Can Question
  71. Oil filler tube...
  72. O2 Sensor Bungs?
  73. Shorties or Longtubes?
  74. Im lookin for a cat back true dual exhaust
  75. sweet thunder with y pipe...
  76. Part # question
  77. Ls6 intake on and now noise?
  78. throwing a misfire code. help me determine the problem
  79. did any of u find ??!
  80. lumina ss headers
  81. Ls1 headers fit different years?!?
  82. Those with Flowmaster 1-chamber true dual set-ups, have questions about fitment...
  83. Are SLP LTs Really Crap?
  84. no supercharger, now what
  85. XS Super Competition Headers(Stainless steel)
  86. best y-pipe with QTP LTs
  87. TSP TD, Sound is awesome but, now its gone, please read
  88. Anyone know which Magnaflow muffler will fit my dual/dual
  89. good ignition for a 402?
  90. Which catch can?
  91. HELP!! cutout ?s
  92. Corsa vs. Magnaflow
  93. flowmaster merge collector?
  94. Flowmaster
  95. Water Pump leaking
  96. what is gc oil? What does it stand for?
  97. Intake options?
  98. eXHAUST CUT-OUT
  99. removing 02 sensors easier when exhaust is hot or cold?
  100. ported LS2 intake questions
  101. Options for different mufflers only...
  102. Puff of Black Smoke?????????
  103. AC belt on LS6/7?
  104. slp vs. k & n
  105. Descreen MAF??
  106. I take back everything bad i said about QTP...
  107. Ignition coil connector
  108. Typhoon Intakes
  109. How to contact Shaner for ported TB?
  110. hp
  111. SLP Air filter clasp
  112. Emissions question??
  113. Tach problem
  114. Egr Hole
  115. how much power loss with flowmaster...
  116. intakes and throttle bodies
  117. Intermittent skip
  118. Anyone seal Airbox to hood & !belllows?
  119. problem with car after installing ls6 intake and fuel pump
  120. ATI damper. 10% underdrive or stock?
  121. quick stupid question
  122. ground kit
  123. Best Headers for gains besides kooks and QTP
  124. ses lightbuld went out
  125. Stainless steel
  126. Cats vs drone
  127. about to get headers...cats or no cats??
  128. Alternator U/D Pulley
  129. cold air intake worth it...
  130. Magnamouth Muffler
  131. what headers to get?
  132. e3 or brisk performance plugs
  133. Headers under the axel?
  134. Which Headers Jet Hot,Hookers,QTP???
  135. XS Headers air pipes removed
  136. What other bolt ons can i do?
  137. Where to buy exhaust hanger?
  138. Will ls1 pacesetters fit ls6 heads?
  139. Possible to buy just I Pipe?
  140. air filter
  141. Cutouts?
  142. How The F***
  143. Hooker Header o2 sensor Clearance issues
  144. Exhaust Manifold Bolts??
  145. O2 Sensor
  146. LT's and ORY installed now the car runs like crap
  147. Headers 4 lowered car.
  148. exhaust to quiet... help
  149. My Headers are on !!!!! My Check Engine Light is not??
  150. ordering my pacesseters this wk
  151. 160, 180, or stock thermostat?
  152. Finally Installed TSP Duals!!
  153. corsa and cut-outs
  154. Egr
  155. which headers for my ls1?
  156. Cutout benefits?
  157. How do I.....Remove a March Underdrive pulley?
  158. Anyone with Jet Hot headers
  159. Fast 90/90 Falling on it's face:(
  160. exhaust piping size...
  161. 1 question and I'll leave---y-pipe
  162. Radiators
  163. Code P0160
  164. ported MAF gains...yes i actually had some
  165. TSP y pipe question PLZ help
  166. x pipe fab up
  167. e cutout vs. manual cutout
  168. header gasket ?'s
  169. wats the diffrence between a 98 and 01 t-body
  170. Where to buy
  171. post install gains?
  172. Where to put cutout?
  173. Headers
  174. electronic turbos?
  175. TSP TRUE DUAL guys inside PICS!!!
  176. NGK TR55s Q.
  177. 135* angled spark plug wires
  178. LS2 TB question
  179. Intake Material?
  180. Woot! Just ordered true duals...
  181. What do you think about this?
  182. What to do???
  183. Are LS1 injectors longer or shorter than LS2 injectors?
  184. TSP duals torque arm?
  185. Typical gain of LS6 + Pacesetters?
  186. flow tech
  187. 1-3/4" headers or 1-7/8"?
  188. Lid install problem....
  189. o2 sensors with LT's not hot enough. Tips.
  190. FAST 90 with heads and cam??
  191. Broke oil pressure sending unit
  192. pacesetters
  193. PCV System Question
  194. Flowmaster Single Chamber.....
  195. Headers for a 402ci LS2 ....
  196. Catalytic converters fried?????
  197. What is the difference?
  198. BG ram air w/ lower air box mods?
  199. slp MAF
  200. Advice: Everyone with a VOLANT cai system please come in.
  201. Hooker
  202. UD pulleys
  203. went to hell.....
  204. where can i get a flat alternator tensioner pulley??
  205. How bad is this? crack in timing/front cover seal *pic*
  206. LS1 to LS6 Intake Swap
  207. gap in rear of air lid
  208. New GMMG is awesome! Even passed "the neighbor test"....
  209. heat shields
  210. Are Hedmans long tubes or mids?
  211. Pulley Squealing?
  212. Success!
  213. How much does Cutout really change sound?
  214. What color wire am i looking for on new bosch o2 sensor
  215. quick question, quick answer
  216. 93-97 F-body exhaust?
  217. coated pacesetter headers?
  218. TSP catted Y pipe and adjustable torque arm fitment?
  219. Which Header gaskets ?
  220. Small K&N needed for lid install?
  221. FLP offroad tubes
  222. Vids of TD systems wanted
  223. Headers + true duals = too loud, opinions on quieter exhaust?
  224. Headers and gas milage !!
  225. Help! What intake do I have might of gotten ripped off?
  226. I'm fixin' to give up, here.
  227. advice about taking off intake
  228. heat shield problem
  229. Tensioner Problems?HELP!
  230. Help, What The Hell Is This
  231. Dynamax Super turbo or Flowmaster
  232. Accuseal Exhaust Clamps - FYI
  233. Fast Toys ram air upgrade.
  234. Did I do something wrong? (header install)
  235. Post your spark plug wire brand and resistance here...
  236. Clearence Issues
  237. Cats robbing power
  238. Would 98-99 Lt's Fit A 2000?
  239. tired of the loudmouth, which CHAMBERED muffler?
  240. going for LOUD
  241. I think I'm going with true duals...
  242. starting up problem
  243. Any problems reusing the stock header gaskets?
  244. ls6 intake question
  245. Newbie ? I searched :)
  246. What sealant on coolant temp sensor?
  247. Just got my headers today but have a ?
  248. how to port a stock tb?
  249. throttle body question?
  250. z06 maf question.
