PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 [167] 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315
  1. CME pics needed!!!
  2. ported TB ?
  3. What is the closest alternative to GMMG
  4. Cut wires!!!
  5. Mileage with ported TB
  6. SLP ORY and Pacesetter LT's will it work
  7. Nick Williams 90mm installed... Awesome! Slight warning as well...
  8. Problem with Serpentine Belt....
  9. New F-Body Bassani True Dual Exhaust
  10. just ordered paceseters, tsp ory & mag cat back
  11. PCV question
  12. header question involving years
  13. C5 w/90-90 set up
  14. TR ported TB worth 2rwhp
  15. i need something to quiet my ass down!
  16. long tube headers = problems
  17. Valve covers ?
  18. Sponsor that ports Carb-style manifolds
  19. need a pic of inside of bullet muffler
  20. TSP catted y-pipe
  21. Bell mouth adaptors on true duals / flowmasters?
  22. Just installed headers and now the car is way too loud. What do I do?
  23. Headers & air/fuel ratio??
  24. BBK Intake Manifold
  25. True Duals...will they smog?
  26. Stupid ? about removing fuel rails
  27. SLP Underdrive Pulley Question #100221
  28. SLP Underdrive Pulley #100221
  29. Dart heads? Stock heads?
  30. exhaust help!!
  31. 6.0 oil pan swaps
  32. Headers And Starter Heat
  33. When should you change wires?
  34. what to use? plug EGR hole in intake
  35. custom Y with merge collector or complete piece
  36. Home made O2 sims, anybody done it?
  37. Sheet Metal Valve Covers
  38. gmmg install
  39. Your Typical Install...
  40. hooking up oil temp gauge
  41. Hooker Full Length Headers
  42. Updates on e-bay Y pipe?
  43. ebay stainless headers
  44. mid's Vs. longtubes. and how do true duals looked dumped on ws6
  45. ls6 intake coolant pipe gaskets
  46. Borla XR-1....Where?
  47. Alternator bad?
  48. How many of you guys DD with true duals?
  49. a/c delete question
  50. tuned headers
  51. Throttle voltage issue...
  52. Slp Headers Pic
  53. Need Deeper exhaust, true duals?
  54. for guys with husky catch can
  55. EGR Questions?
  56. Help tone down my exhaust.Please come in
  57. Want my car to sound deep!
  58. Hedman Headers
  59. New ls1 intake system!
  60. SES Light
  61. Which one to choose?
  62. what to expect out of a long tube header tune
  63. valve cover mod?
  64. P&P TB.. Is It Worth It?
  65. I have decided
  66. Does this look normal? *pic*
  67. How to Louden an Exhaust?
  68. LS6 Intake Question?
  69. 90/90 combo?
  70. pacesetters
  71. x-mas mods help
  72. Full Bolt-ons List?
  73. Anyone lowered with 3" TD's???
  74. LS1 exhaust diagram (or good under car pic)
  75. help porting throttel body
  76. Who has the highest flowing CAT's???
  77. Intake And Throttle Body question
  78. Check engine light.
  79. Exhaust hitting after LT installation
  80. Do you think its worth it. FAST 90/90 I have BBK SSI now???
  81. mti clear lid?
  82. for all the aluminum intake haters
  83. Whose fuel economy increased after installing an FTRA?
  84. QTP LT Header issue, problem?
  85. What works best to support engine/k member for removal
  86. Exhaust HELP
  87. Loudmouth II install: not too hard
  88. Why are only the tops welded.
  89. Lt's
  90. True Duals Or Muffler?????
  91. EGR removal ?
  92. What exhaust are you running w/ BMR Trak Pak?
  93. Kook's picts inside,,, 56K beware!!
  94. Low coolant light on, radiator is full
  95. Help!!!!
  96. SLP lid/bellow install...
  97. How well does B&B flow
  98. Magnaflow metallic spun-cat aftermarket catalytic converter
  99. Exhaust ideas...
  100. Changing Tips on Borla Exhaust?
  101. Cat Problems
  102. Torquer V.2 with gmmg exhaust clips???
  103. overheating problem
  104. Help with Maf or Mafless tune?
  105. coil pack relocation ??
  106. ported throttle body
  107. Ls1 To Ls6 Intake Manifold Swap Parts Question
  108. EGR set ups
  109. Water problems with debaffling/sealing the WS6 hood?
  110. quick question!!!
  111. underdrive worth it?
  112. Does anyone make a water pump stud kit?
  113. expansion plug for egr blockoff
  114. ? Ses
  115. *Probably the best headers money could buy for an LS1 F-Body!*
  116. New Warlock Mufflers for My True Duals...
  117. should i run tailpipes on my dual exhaust?
  118. What's this???
  119. search down agian?TB Question
  120. update on wilson manifold
  121. DID some LS1's come with LS6 Intake?
  122. Dynomax Collector/Muffler
  123. Ignition coils
  124. Help with under drive pulley install
  125. Fast 78 or 90
  126. WS6 and aftermarket Ram Air question, is this true?
  127. 4' exaughst sounds great
  128. Sweet Thunders vs. Single Chamber Flowmasters
  129. Crankshaft Position Sensor Code
  130. Oil Pressure Gauge Pinned to the Left
  131. # Needed for check valves
  132. C5 vs, F body water pump ??
  133. True dual vids!!! Over axle, 1 chambers w/ H-pipe
  134. Couple of questions about installing an aftermarket overflow tank...I searched
  135. which long tubes are easiest to install in fbody?
  136. 4th gen camaro stock exhaust question, other
  137. Anyone use MSD coil packs??
  138. just wondering about Throttle adjst screw
  139. !muffler w/ tailpipes vs. !muffler turned down
  140. stock exhaust w/ cutout?
  141. ? about NW 90mm TB...
  142. my new exhaust~
  143. Bumpstop mod
  144. LPE 100mm MAF
  145. Granatelli spark plug wire users inside
  146. Who has a bullet off ypipe and has a cam
  147. lts/ory/cutout...what should i do?
  148. Slp Lm I
  149. Please Read!!! Asap
  150. who ports fast 90
  151. question about headers and cutout...
  152. Using convertible switch to power QTP electic cutout
  153. need to grind that little peice off my block, can anyone help me
  154. Gains in H/C car with header change or FAST 90 over LS6 ???
  155. what would you guys expect from this setup...
  156. Need QUICK help! Where to wire cut out??
  157. HOOOOLD EVERYTHING! Don't even THINK about a cat back!!
  158. Jet Hot/ 02 ext's? what's the deal?
  159. MAF code question
  160. Pics, is this a good true dual set-up??
  161. header install
  162. Battery Draining...what is causing this?
  163. Lid or FIPK?
  164. Exhaust crushed...
  165. Stepped header 1 3/4 to 1 7/8 on an AFR 205, 224/228 car?
  166. Car is still acting crazy in rain
  167. HELP! Did something dumb!
  168. what should I expect
  169. for the searching gurus
  170. Header "XPERTS" need opinions please
  171. Dumbfounded
  172. Who has the Dynatech Supermaxx?
  173. Wow!!!!!!
  174. Quick question before I buy coated Pacesetters.
  175. Full Exhaust Change
  176. Cutout Gains on Modded Cars?
  177. OK can a bullet have a 3 inch inlet/outlet and work with 2.5 piping?
  178. Edelbrock/Lingenfelter Heads and Comp Cam Package
  179. ? about running straight off the LT's
  180. How much gain from full exhaust, air mods?
  181. gains from goin 2.5 in. to 3 in.?
  182. no spark and cel blinks...
  183. Magnapaks
  184. slp-DD or slp lm
  185. wet exshast??????
  186. stalling question
  187. 1/2 drive breaker bar
  188. B&B LS1 exhaust
  189. How much power would I lose swapping to the stock cat-back?
  190. Bending Fuel Lines for dummies
  191. O2 sensor life in a long tube. Who's got the most miles?
  192. i broke something, what is it?
  193. Taking off a/c belt?
  194. Pacesetters on the formula...
  195. TPiS Oval LS6 intake and TB
  196. Is the ceramic coating on headers worth the $?
  197. ls2 intake 90mm
  198. LS2 GTO - How you make a Fast 90 Fit...
  199. Bleeding the radiator - overheating and no heat
  200. 98 LS1 to LS6 PCV Conversion...
  201. What kind of times can I Expect???
  202. Fast 90/PTM 90's Back In Stock!!!
  203. what plugs for a 408
  204. Question for those who have installed the SSRA
  205. Looking at Jet Hots -What do you think?
  206. Diiference in years in exhaust
  207. Good Ole Y-Pipe Beating The Floorboard Issue
  208. Billet water pump pulley
  209. '04 z06, egr or no?
  210. Getting ready for TDs
  211. Gains from ported TB?
  212. New goodies for my 400whp 35TH LE
  213. EWP type of relay ?
  214. ls1 vent tubes/ fast 90
  215. What does WS6 mean?
  216. I need pics of H-pipe setups
  217. exhaust question
  218. Whirring from engine-normal?
  219. Kool Heatmaster Tunnel Shield Work?
  220. Installation Crap
  221. Mounting tips on true duals
  222. how soon do you benifit from exhaust?
  223. 98 ls1 to 02 z06 heads, cam and intake?
  224. I know im boing on a limb for this but maybe you have it?
  225. Buying used headers
  226. Another header question
  227. new water pump
  228. warm ac after waterpump
  229. Spiral Bullet Mufflers?????????????????????????
  230. ABS DELETE BLOCK & BLOCK OFF PLATE FOR A/C
  231. filter-like oil caps?
  232. Maft
  233. pulleys
  234. Borla exhaust
  235. GMPP and Vic Jr. clearance ...
  236. 2 exhausts
  237. Mellings high volume oil pump
  238. 90/90 on cam only set up
  239. Custom Header Tube Size??
  240. Just installed Hugger Orange Katech valve covers - pics
  241. Bye Bye Lm Hello Magnaflow
  242. FAST 78mm vs. LS6 Intake
  243. Steering shaft rubbing headers?
  244. egr/air block-off plates
  245. How are QTP/KOOKS ??
  246. exhaust change
  247. So... Why doesnt meziere make an installation kit?
  248. Eliminating BLAAATTT sound from TD's?
  249. Advise: Volant systems do they add or hurt performance?
  250. Some quick help please
