View Full Version : Generation III External Engine
  1. A4 guys with UD Pulley
  2. need some long tube techs
  3. O2 Extensions For Jet Hots??
  4. Hows this for an exhaust
  5. Headers, period.
  6. Ported throttle body
  7. Do I need a PCV valve with a catch can???
  8. O2 sensors Q...
  9. Finished the Throttle Body
  10. Holley 90mm throttlebody....
  11. exhaust
  12. ?'s about dissasembling throttle body???
  13. Post pictuers of your exhaust tips on your Formula.
  14. Can a functional hood scoop and an FTRA or SSRA work at the same time?
  15. headers a must
  16. high flow cats
  17. 2.5'' vs. 3'' ypipe
  18. Slp Bullets??
  19. Pacesetter Q's?
  20. 02 extension routeing with long tubes
  21. FAST Manifold w/ stock heads + cam?
  22. Exhaust
  23. Where to get EGR and AIR blockoffs
  24. Y pipe question!
  25. magnaflow cat-back vs magnamouth
  26. is hedman worse than pace?
  27. ORY vs. Catted vs. ORY w/bullet
  28. how is everyone doin longtubes
  29. Synister Power Steering Pump Pulley Question...
  30. SLP LM + ?Headers
  31. Has anyone done this?
  32. Spark Plug Question
  33. TB Spacer???
  34. Alternator Installation please?
  35. custom cat placement? pros/cons?
  36. Spark Plug Read
  37. Problem installing new idler pulley
  38. LS2 stock bellows for LS1 90mm
  39. Help with high rpm!!
  40. oil pressure sensor
  41. ngktr55's
  42. Mufflex Y-pipe Feedback.
  43. Forced induction, Macs vs. Kooks?!?!?!
  44. Buying GMMG cat-back, owners come in here
  45. Nick Williams 90mm TB
  46. SLP Cold Air duct
  47. Cats removed, Why does it run like crap??
  48. slp y pipe
  49. Mufflex install has begun...
  50. MAF Sensor
  51. WTF...can't find a damn part anywhere
  52. FRA with SLP HO Hood, do it or not?
  53. imco muffler on a fbody
  54. nick williams 90mm tb replacement blade
  55. O2 sensors
  56. AIR & EGR removal
  57. Oil in Throttlebody
  58. Pacesetter Problems
  59. Y-pipe question
  60. BG Ramair parts?
  61. MAF question....
  62. Z06 Maf
  63. Sleeper Exhaust for a 02 SS
  64. Longtube Question
  65. Temp sensor in the drivers side head.......
  66. tsp rumbler vs. loudmouth
  67. help!!!
  68. Weird Exhaust Question????
  69. bottom pics of fast intake
  70. WOT activated cutout??? possible...
  71. loud pop
  72. Rotten Egg Smell After Catback And Lt Install
  73. I need TD Pics, parts info, etc
  74. intake manifold valve
  75. Quick Help Pls? Header bolts broke in head
  76. CUSTOM CUT-OUT - Sweet
  77. ARP Header Studs??? Really Worth It???
  78. Dynomax race bullet vs twisters
  79. Horrible squealing!!
  80. True duals on ebay??
  81. !AIR... what are the benefits???
  82. FAST intake install problem
  83. are fumes a problem w/ the tsp td's
  84. Napa gold /WIX part# plz
  85. anybody know where I can get cats that have gone bad to hollow out?
  86. GMMG anyone???
  87. Does anyone have installation instructions for a BMN window switch
  88. Solid motor mounts????
  89. FAST intake result
  90. one final queston be for buying LT headers (air/egr)
  91. Just Ordered True Duals
  92. Removed Air System...issues?
  93. Suggestions on making my SS' sound ROAR
  94. Exhaust Question involving SS SLP Package
  95. Oil breather for the valve cover...who sells them
  96. carb set up
  97. long tube install :(
  98. looking to quiet down the exhaust..
  99. Heater cap off....
  100. Ported throttle body
  101. Header Bolt Size !!
  102. Exhaust
  103. Got rid of my cats today
  104. Mid-Length Headers....need some help?
  105. What do you notice after LTs?
  106. Anyone using Tranzaman00s air intake?
  107. Plug Gap
  108. Tell me what this is Please....
  109. turn-downs or no?
  110. Pass. side heat shields
  111. Best/Largest throttlebody for an LS6 intake?
  112. Part Number Please
  113. Side Exit Exhaust???
  114. anyone ever get rattling after poly motor mounts
  115. Who else sells the LS6 intake collent pipes and plugsfor the ls1 to ls6?
  116. Just bought duals, major question... input please
  117. gains from a cutout or cutouts...
  118. QTP Header Question.
  119. SLP headers, y-pipe and cats...
  120. need maf that will handle 750hp
  121. sweet thunder?
  122. slp optioned center mount catback
  123. Cam before Headers?? Need your Opinion
  124. How Loud is the Borla Adjustable cat-back compared to others?
  125. Header Problems...
  126. O2s on long tubes
  127. QTP vs. Pacesetter
  128. please explain the coolant flow of the water pump to me
  129. What should be next after FLOWMASTER?!?!?!
  130. dumps question
  131. Throttle Body, Which one to get?
  132. 99 or 2000, its a close call.
  133. Ceramic coating
  134. Need plug for o2 port in Header
  135. Coolant Level Indicator On ??
  136. SLP smooth bellow and NW 90mm????
  137. K&N FIPK vs. Air Lid
  138. dual cuttouts vs. single cuttout
  139. backpressure w/ Open Ypipe? Or straight pipe after !muffler work?
  140. do i really need new header gaskets?
  141. anyone have tsp true duals with slp lts?
  142. would this make a decent setup?
  143. Shipping exhaust
  144. Will a SI car gain swapping from 1 3/4" to 1 7/8" headers?
  145. Quick help on removing intake
  146. pacesetters LT's, TSP ORY and flow masters
  147. Headers?? what do you suggest??
  148. Did the SLP dual/dual cat-back come stock on SS?
  149. mods after tune
  150. Spark plug wire touches header. What to do?
  151. Jet-Hot Headers!
  152. new exhaust setup
  153. Header Gasket
  154. electric water pump for stock 02 z
  155. Camaro Ls1 Throttle Body VS. GTO LS1 Throttle Body?
  156. New prothane motor mounts in
  157. did i lose power?
  158. Miscellaneous Pieces
  159. Is there much point?
  160. help with 160 thermostat please!!!
  161. Edelbrock Victor Race headers.
  162. spark plug wire set for remote mount coils?
  163. Too loud for my son
  164. 180, 160, or stock thermo??
  165. which is louder
  166. a TD's question
  167. LS6 Intake or Catback?
  168. ORY Question
  169. fuel line bracket
  170. What's the best bullet style muffler?
  171. electric cutout reliability
  172. Are Budget Long Tubes Worth It?
  173. What brand power steering fluid in LS1?
  174. What is it?
  175. Will TSP duals fit Kooks headers without modification?
  176. Will I lose power or Noise?
  177. which is louder: cutout, duals
  178. Power Difference Between Borla And Ture Duals
  179. Any thoughts, ideas, or solutions?
  180. Ram Air?
  181. Tru Duals
  182. Be cool or hypertech thermostat
  183. What is the "new style" asp pulley??
  184. QTP Headers Kooks Catted Y
  185. Can I fix this exhaust leak?
  186. making electric cutout
  187. Starter rebuild?
  188. Intake Question
  189. 2 3/4 or 3 inch pipes
  190. 4bbl throttle body for carb'd intake
  191. tb voltage at wot?
  192. Flexplate and starter
  193. bullet muffler flow numbers?
  194. Would a worn throttle cable hurt power?
  195. Would a worn throttle cable hurt power?
  196. ls6 install ???
  197. Header design info please??
  198. Question about SLP Blackwing
  199. Sweet Thunder or Stainless works on a Loud Mouth
  200. elec. cutout question
  201. Whats your Opinion?? Tell me your thoughts old LS1 guru's!!!!
  202. Another ram air thread! (pics)
  203. Do i need a catch can?
  204. Porting TB HELP!
  205. Oil Problems ..
  206. catback
  207. Hooker Headers...? Advice
  208. Doing a Ls6 intake swap
  209. What if I went with this.....
  210. Ported TB and throttle blade?
  211. possible melted plug wire
  212. Exhaust Clamp bullshit.
  213. rear 02s
  214. SBC Chevrolet XS Super Competition Stainless Steel Headers
  215. Underdrive pulley
  216. Jet hot headers
  217. Running Rich???
  218. Protecting fuel lines with thermal tape?
  219. Quick catylitic converter ??
  220. Gutting my Cats
  221. Header Question
  222. Aftermarket engine mounts
  223. Exhaust Question??
  224. Anyone have an A/C Delete Writeup
  225. SLP LT Header install
  226. NEED HELP Alternator/Battery, I have no Idea..
  227. T/A and X-pipe clearance
  228. egr block off plate
  229. What should my stock gm spark plug wires read on a OHM meter?
  230. Anyone know the belt part #
  231. Throttle body spacer Good or Bad
  232. LS6 Install Help Needed
  233. Louder than expected
  234. seen this before?
  235. Free Lid! Pics Inside!
  236. What years did the LS6 intakes come on TA's and camaro's?
  237. Catalytic Converter
  238. Edelbrock Victor series LT?
  239. ATI harmonic balancer needs to be rebuilt?
  240. What magnaflow cats to have welded into catted mac y-pipe?
  241. Anyone running true duals with UMI crossmember ?
  242. Corsa to Hooker
  243. Xpipe Or Open Headders (quick Help)
  244. catalytic converter question
  245. Harness help !!!!!!
  246. Short bullet mufflers???
  247. Problems after water pump replacement.
  248. Pics of Flowmaster on Z28s
  249. how to seal exhaust?
  250. Z06 Red plug wires
