View Full Version : Generation III External Engine
  1. Edelbrock Victor series LT?
  2. ATI harmonic balancer needs to be rebuilt?
  3. What magnaflow cats to have welded into catted mac y-pipe?
  4. Anyone running true duals with UMI crossmember ?
  5. Corsa to Hooker
  6. Xpipe Or Open Headders (quick Help)
  7. catalytic converter question
  8. Harness help !!!!!!
  9. Short bullet mufflers???
  10. Problems after water pump replacement.
  11. Pics of Flowmaster on Z28s
  12. how to seal exhaust?
  13. Z06 Red plug wires
  14. When to get a 90/90
  15. What Should I have done?
  16. GMMG install possible on rhino ramps?
  17. No GC Syntec around here
  18. Exhaust
  19. Cats for Edelbrock ORY?
  20. Y pipe I here knocking or loose bolt?
  21. Did I get a good deal?
  22. Sweet Thunder Question
  23. which y pipe to go with?
  24. Stock 192 deg F stat or 160 deg F
  25. Bolt size for rear o2's??
  26. Cruise Control Cable
  27. tpis lts
  28. AIR and EGR removed?
  29. anyone have experiance on these headers?
  30. Quick question on fernco smooth bellow
  31. pacesetter install
  32. spintech muffler
  33. oil dipstick tube
  34. borla and headers info please
  35. listen to this
  36. Anyone with TD's have problems with thir torque arm?
  37. Is this TAC from a C5 or C6 vette?
  38. Mufflex BumpStop and bangin y
  39. need pic for catch can install. Install where?
  40. difference for 00+ lid?
  41. March pulley 10 or 25% underdrive?
  42. Vaccume line trouble.
  43. Anyone Have a Corsa & GMMG?
  44. AIR pump
  45. How In The Hell Do You Get The Alternator Off!!!!
  46. Heating System Delete
  47. Best Cats ??
  48. Cold Air Induction
  49. Ory And Ses !!!
  50. Dex-cool Coolant?????
  51. '00 Long Tubes for my '02 SS???
  52. ls6 install
  53. Anyone with Magnaflow, LTs, and a catted Y?
  54. Need Help!!!
  55. 5.3 v 5.7 valve cover differences?
  56. people with kooks catted y...
  57. running egr w/o cats question
  58. do i need 02?
  59. ASP vs SLP
  60. valve cover bolt part number needed
  61. Anyone rember seeing a pic of a dual TB LS1/LS6 intake?
  62. Can a 2001-2002 MAF be used on a 98'?
  63. Waterproofing goop??
  64. header bolt stripped... how screwed am i
  65. Which plug wires?
  66. just picked up car from shop I love it
  67. A/C Out!
  68. Header question....
  69. guys with tsp true duals please come in
  70. ? about Texas speed True duals
  71. header install ??'s
  72. Question on FLP headers
  73. Straight pipe to replace my LM resonator? Sponsors??
  74. wobbling crank pulley
  75. loudmouth II
  76. just got back from first drive...
  77. I need some advise?
  78. Blackwing Air Filter Cleaning??
  79. new coil packs
  80. Can i run without o2s?
  81. 04 GTO crank pulley
  82. Oil pressure guage pegged
  83. SUX2BU intake questions
  84. dual exhuast and lowered anyone??
  85. Just because Im dumb
  86. best headers
  87. Removing EGR this week a quick ?
  88. FAST INTAKE gasket part number
  89. BBK SSi ls1 intake
  90. QTP headers and tsp TD questions
  91. Cutout for a SLP Dual/Dual?
  92. Texas Rumbler????
  93. ls1 oil pan torque specs?
  94. Pacesetter life span?
  95. welded or slip ons?
  96. home made CAI??
  97. ory or catted y
  98. homegrown mods
  99. Pics of Z28s with Magna or Flowmaster Systems
  100. Silly ASP UD belt sizes..
  101. welding opening in throttlebody???
  102. Ported throttle body is now sticking...wtf?
  103. 90mm TB & 85mm MAF. Which lid and bellow?
  104. vital fluids
  105. free ram air question
  106. Any Hard Evidence on Value of Aftermarket Plug Wires
  107. Adding Headers Soon?
  108. headers on problems shifting into reverse
  109. Your opinion on FAST 78 or 90/90 w/ my set up?
  110. Crankshaft Threads Stripped..??..
  111. GMMG exhaust
  112. POLL: Catted TSP true duals or GMMG???????
  113. Morosomouth
  114. Electronic exhaust cutouts??
  115. A few questions on going from Volant intake to LID, Seriously help please
  116. starters
  117. Going to GMMP Intake and Carb
  118. just a thought
  119. Same price go with FAST 78mm or LS6?
  120. 370 ls1, intake ?
  121. dynomax bullet muffler help quick!
  122. stock thermostat mod?
  123. Air connections on manifolds
  124. I want a new exhaust. True Duals vs. y-pipe
  125. 1 3/3 or 1 3/7 steped to 1 7/8 for me?
  126. pulley
  127. Putting on LT's, How do i remove the steering shaft?
  128. Accufab 75mm throttle body?
  129. Removing the A/C belt for the track??
  130. O2 sensors
  131. Who can port FAST intakes
  132. SLP Underdrive pulley
  133. headers with lowerd car?
  134. tip size?
  135. Gas mileage questions
  136. Does Nick Williams have a web site???
  137. A.I.R. tube/system differences from year to year?
  138. LS2 intake manifold swap???
  139. Any ideas for me exhaust problem??
  140. gmpp and victor guys inside
  141. How much co2 emissions
  142. quieter muffler than magnaflow?
  143. Installing tsp 3" true duals on a lowered car?
  144. poly motor mounts
  145. Smooth Bellows, MAF and Cold Air: Worth it?
  146. Current GMMG owners
  147. Homemade Camaro Ram Air Pics...
  148. corsa owners...
  149. anyone running a FAst 78 TB on a stock ls6 intake?
  150. Left Over Wire Hook Up.....???
  151. S3
  152. TPS Y pipe fitment?
  153. Accufab 4barrel TB
  154. Belts for Underdrive pulley??
  155. Difference in Pacesetter LT's
  156. Will a Mac Y-Pipe fit on stock manifolds?
  157. Fast 78MM throttle body?
  158. which underdrive pulley? ASP or SLP
  159. what size throttle body should I get?
  160. my loudmouth...isnt as loud?!? guys is it jus me or?
  161. Secondary AIR system
  162. Home Grown Ram Air for T/A?
  163. Rattling in the cutout?
  164. Lower airbox clamps...
  165. not another exhaust post!! (no, seriously though...)
  166. Jet-hot catted y- pipe
  167. which bullet
  168. What catback is the most quiet? srry dont mean to ad to the mass of catback polls?
  169. FAST 90/90 Combo Intake Tubing
  170. Underdrive Pulley
  171. 2-step for LS1/LS6 w/factory computer besides Harlan?
  172. Help me pick a catback....
  173. clearance issue when doing a ravin-mouth? pics please!!!
  174. header sizes eplained?
  175. GTO LS6 Intake work on FBODY?
  176. fast78mm vs fast90mm
  177. New Hooker Headers
  178. Plug wires with headers
  179. stuck between QTP and Pacesetter lt and cat y pipe
  180. What flows more, GMMP Carb Intake or Edelbrock Victor Jr?
  181. Ory?
  182. Finished up Catch Can install WOW(pic)
  183. catback advice....light and quiet
  184. Flo-Pro Twisters?
  185. need a muffler for my loudmouth....what size?
  186. Any bad things about using a 105mm Accufab tb?
  187. need some header advice
  188. Need Advise On Exhaust
  189. New Cut-Out Idea, Would it Work?
  190. LS7 / F.A.S.T. 90mm
  191. lingerfelter/weiand intake quetion
  192. Service Engine Light/new Intake
  193. 75mm or 85mm lid?
  194. Anyone using the MSD 6LS ignition?
  195. What LS6 intake to get?
  196. Harrop Intake ?
  197. Who's Z06 is this?!
  198. fast 78mm intake with 90mm TB
  199. making an alternator 1 wire??
  200. ws6 lower intake
  201. band clamps... haha, this never ends!
  202. Need a vacuum pump setup... where to go?
  203. dumb problem.
  204. How Can I Add An Extra Exhaust Hanger?
  205. Removing ATI Super Damper?
  206. O-ring on throttle body missing, revving high!?
  207. hp difference in crush bent vs. mandrel
  208. Professional Products LSX intakes throttle bodies and fuel rails good cheap stuff!!!
  209. Brand new dented y-pipe
  210. Need some MAF help n a hurry...
  211. headers, need advice
  212. missfire help
  213. Thoughts on FAST vs Nick Williams 90mm TB
  214. catch can questions
  215. TSP Y-pipe hard to fit
  216. TB shaft allen head screw
  217. headers, o2 sensor question
  218. Plug up AIR hole in lid??
  219. Who has ported the LS6 intake manifold?
  220. electric water pump
  221. Blackwing High Flow Air Filter or K&N
  222. i need a muff, where and make
  223. best way to clean used headers??
  224. Spark plug heat range?
  225. Header System advice?
  226. 3" cutout caps!!!!!
  227. What headers?
  228. Torq Specs For Header Bolts - Collection Pipe
  229. headers.. ne good?
  230. 2 cut-outs!!!
  231. Electric Cutout installed with powerstick
  232. Poly Motor Mount problem....
  233. Bassani and Corsa Mufflers!!!
  234. Has anyone used this exhaust?
  235. SLP - LS1 radiator???
  236. Folks with duals...
  237. Any reason not to get pacesetter lts?
  238. headers LT's!
  239. ASP vs. SLP
  240. Anyone want to trade a Borla Xr-1 #40085 for a LM2 bullet
  241. Question on header install
  242. LS6 Intake Swap
  243. Porting the Throttle Body....
  244. HEI Type ignition for going carbed?
  245. Oil Pressure!?
  246. Spark plug issue on my 317 heads.
  247. need location for cutout
  248. I got my catch can in :)
  249. Fast intake & rails
  250. Stainless W Exhaust Clips?
