- What headers?
- Torq Specs For Header Bolts - Collection Pipe
- headers.. ne good?
- 2 cut-outs!!!
- Electric Cutout installed with powerstick
- Poly Motor Mount problem....
- Bassani and Corsa Mufflers!!!
- Has anyone used this exhaust?
- SLP - LS1 radiator???
- Folks with duals...
- Any reason not to get pacesetter lts?
- headers LT's!
- ASP vs. SLP
- Anyone want to trade a Borla Xr-1 #40085 for a LM2 bullet
- Question on header install
- LS6 Intake Swap
- Porting the Throttle Body....
- HEI Type ignition for going carbed?
- Oil Pressure!?
- Spark plug issue on my 317 heads.
- need location for cutout
- I got my catch can in :)
- Fast intake & rails
- Stainless W Exhaust Clips?
- New 408 is overheating! Air Pocket?
- is this a real LS6 intake
- Think i messed the threads on my passenget side head!
- rocker arms
- catalytic converters
- Red sticky fluid leak, UGHHHH!
- Sanity check on header install list?
- Corsa Vs Magnaflow w/ LT's???
- Need help making a decision!!! LongTube Headers!!
- I live in apts. Thinking about TDs
- Need some help with modding my LS1
- Need Help!
- ordering pacesetter lt's
- Throttle bodies, bang for the buck?
- 85mm MAF. Do I need harness and where to get it?
- Motor Mount Orientation
- what can i do for a catch can with carburetor?
- Pully Question ?
- Harrop intake with individual TBs
- 02 sensor question
- Catback at home or Custom True Dual?
- Simply In AWE of Nick Williams' Throttle Bodies (PICS!)
- ls1 temp?
- soild motor mount pros/cons?
- QTP/KOOKS Question
- Ive Had Enough!
- Edelbrock LTs vs. Pacesetter LTs
- MAF(98-02) same?
- Longtube headers and catted y pipe
- Just got the LT's and TD's on!
- how long is the intermediate pipe?
- Any one else ever have this problem? (intake swap)
- Quick Q - Quick Answer - Lid?
- Wreck Question
- How hard to pass inspection with cut-outs (cut-out owners)
- Mac Pics Please
- fitment issues with pacetters?
- cruising in 6th is loud
- True dual muffler choices
- 1st try......failed
- Underdrive Crank Pulley
- Header installation guides
- The guy at the local speed shop says.....
- which exhaust
- Are front and read o2's the same
- Need help...
- shane s3 ported
- Backpressure
- Cutting the Frame with QTP's
- Oil Pressure Switch Bullshit
- Port-Matching FAST Intake to Heads
- A Noise I Can't Seem To Figure Out
- Hooker Aero Chamber Catback Install!
- Lowest price on Hooker cat-back?
- Dynomouth vs Rumbler
- flowtech longtubes....cats, y pipe questions?
- The real deal on headers and associated error codes?
- Dad thinks i should pay someone to install headers because "it will be too hard"
- underdrive pulleys
- how much hp did i gain
- FAL fans?
- Quick Question, Hope To Get An Answer
- LM1 Squeaking
- steering linkage
- Is it worth a Fast Intake/TB 90/90 setup
- Another Exhaust Question? What do you think
- Well maybe im an idiot
- Anyone tried these headers?
- What size cutout do I need?
- Brisk Spark Plugs
- EGR Mod?
- NW 90 - TB cable question
- Duals with a tourqe arm
- Help me decide
- oem plug wires $165??????
- SLP exhaust guys i need your help
- 99+ valve cover/ coil mounting ?
- O2 sensor question
- ARP Crank Bolt Specs.
- o2 Bung question
- threw a code after header install?
- best radiator for 2000 LS1 camaro?
- FActory SS & Firehawk Muffler Flow #'s
- What size for custom dual setup?
- 4' electric cutout ?
- Headers
- 78 or 90mm fast
- Loud Exhaust
- quick question about pacesetters o2 extensions
- Leaving the exhaust stock?
- TB porting
- Help with coolant problem!!!!!
- o2 sensors bad?!
- FLP headers collector size
- Corsa Rattle w Pics
- what all will I need? (header + True Duals install)
- Could this break welds or headers
- Headers
- air/egr help
- Porting the FAST Intake around the Injector
- Bullet Mufflers
- tools pt. 2
- Y pipe question...
- Exhuast problems
- LS2 coils swap ?
- Keep Throwing belts these last 2 weeks
- Spintech Question NEED HELP
- 6.0 intake manifold?
- Headers
- who has the supermaxx system?
- Difference between 98-99 and 00-02 F-boy radiator
- universal x-pipe
- 5.3 intake maifold?????
- Y Pipe Install Probs
- Post pics of you catch can
- headers w/ egr/air
- Map sensor on Fast intake
- Taylor Wires?????
- QTP electric cutout question
- header install pics
- Where are the 3" Cat Back Exhausts?
- New Individual runner intakes?
- Is this the correct drivers side window motor?
- Vinci- Bassani tru dual
- manifold instal... need help asap
- Make Your Own !AIR Block Plates
- Oil catch can....????
- Throttle body porting issue....kind of.
- what underdrive pulley?
- headers for my firehawk
- Wires reroute help
- PaceSetter install?
- headers and clutch
- Which of these to get? Or another option maybe?
- How much exhaust do I need for my 408?
- Manifold malfunction, part question...
- Who makes the best Borla E-cutout?
- Shopping List for headers
- paper air filter
- Question about the Weiand intake...
- BEST exhaust note yet.....
- Flattening Pipes
- Going true duals..a simple ?
- exhaust questions
- poly motor mounts your opinion?
- Got my dynatech supermaxx system today!!
- SES after installing Pacesetter LT headers
- gmmg to slp dual/dual
- AIR Removal (not usuall questions)
- cant get my mac mids installed
- header install
- Hard wiring fans........
- Who makes a nice Y pipe to fit pacesetter LT's
- ls1 intake manifold EGR Block-off plate?
- TSP lids are out...what's your 2nd choice?
- My new Sweet Thunder catback!
- Oil Filter thread size
- couple questions about my new pacesetter LT's set up
- Getting o2 Simms, need help
- underdrive pulley
- quick but dumb LM question
- for an head and cam car? Worth it to get fast setup or ported ls6 intake?
- 1 7/8" Kooks headers
- True duals
- thinking about buying this intake manifold...need your insight
- Gas Mileage
- HOW TO: Poly motor mount install
- ported MAF?
- fast 90mm T/B
- S&B air filter
- another lame exhaust question
- Manifold/Header Bolt Anti-Seize or ThreadLocker?
- Quick Answer on Headers
- Belts
- Autometer Gauge
- Underdrive pully
- Looking for how to !AC, or any pictures u guys have
- Where to get OEM parts (other than dealer)
- Manifold install... broken sensor
- what do i need
- 105mm Throttle Body
- DIY Coil pack relocation??
- Electric cut out dimensions
- B&B Triflo catback or Corsa
- is edelbrock victor jr intake better than fast 90
- which exhaust do i want?
- banging noise please help
- Any TB porting horror stories out there???
- Do pacesetters bolt right up??
- !air, !egr, and tb bypass?
- How Loud is Loud?
- headers causing trans problems....help
- Pic of stock exhaust from DS?
- best intake
- Who Makes a Mini Starter for the LS1/LS6?
- new exhaust installed: Pacesetter LTs, ORY, Sweet Thunder "Rumbler" *CLIPS*
- Plug wire problem!!!
- pulley offset on GTO/Vette/Fbody Ls1/2/6
- headers just in....
- Cold Air intake with Ram Air on an SS?
- Broken Header Bolt? Fixed mine w/o Removing Head
- Does this seam right for an X-pipe?
- Throttle spacer
- Odd stumble at low RPM's... Help!
- They have a purpose!
- LOL Header install idea
- Pacesetter headers question.
- Tsp Catted Y
- Any way to know if my front O2s are going out?
- I am buying a bullet muffler for LM2 (dont know which one yet) HELP!!!!!
- Are front and rear 02's the same other than length of wire?
- Dirt Under My Ls1 Intake?
- Magnaflow tips too close to my bumper.
- Clean the MAF?
- where to can i find these parts for the ls6 intake conversion?
- Which reaches full temp first, coolant, oil, or engine block?
- How much air does the smog/AIR pump put out?
- vette MAF on F body ?
- Question about O2 sims and extenstions
- Loudmouth vs. Used Borla
- Balancer bolt
- Borla Exhaust Help
- How screwed am I? (codes included)
- carb intake
- Vented Oil Cap
- Exhaust backfire
