View Full Version : Generation III External Engine
  1. Header install
  2. spark plug debate
  3. Teach me about spark plugs.
  4. Quick Header Questions:
  5. Vibration after TR55's and Mounts
  6. QTP vs Pacesetter
  7. Jet Hot Long tubes w/cats and Y-pipe????
  8. idler pulley ?
  9. DS coil packs are not firing
  10. Has anyone ever tried running a cutout capped with spacers?
  11. What do you all think?
  12. Trouble with my Corsa muffler...PLZ help.
  13. AIR valve...Oh no!!
  14. operation loudmouth quiet down?
  15. back pressure?
  16. QTP Headders installed... info for others
  17. Need help on stripped valley cover bolts
  18. headers exhaust..SES light?
  19. mulfflex y nightmare.
  20. Borla vs. Corsa
  21. Exhaust Manifolds...
  22. Exhaust Manifolds...
  23. headers
  24. Dialetic grease on sparkplug wires
  25. Hooker Header Install Help Asap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  26. corsa waaay too loud....cat/ resonator?
  27. Random Tech's or .......
  28. those with Ebay catch cans...inside?
  29. keep or ditch flowmaster?
  30. what size is the PCV tube that goes into the intake(catch can)
  31. Front 02 sensors same as rear?
  32. y-pipe question
  33. Flowmaster for the C6
  34. Cats, o2 Sims, or o2 delete from PCM
  35. This is how I fixed my Y pipe banging... *pics*
  36. VIDEO! You asked...here it is. Burn em up!
  37. Smooth Bellows
  38. electric waterpumps
  39. pacesetter nightmare!
  40. Header/Ypipe install major problems
  41. Borla non-adjustable cat back...
  42. Under the axle true dual guys, come in
  43. Headers Leak !!
  44. throttle body and intake question
  45. Mufflex Y-Pipe
  46. quiet exhaust, plus cutout.
  47. Possible to repair ls6 composite intakes?
  48. hooker y pipe help
  49. how did you get the silicone gasket out of the fast intake?
  50. Resivour Stud
  51. What do you think of the Magnaflow Y-collector?
  52. slp and pacesetter lt's
  53. Does running an open cutout hurt anything?
  54. Exhaust for my bird?
  55. MTI TB question!
  56. stock unported VS Ported flow (CFM)?
  57. best spot for cutout
  58. bellows
  59. Coolant Temp Sensor Location
  60. Slp Lid...
  61. For The Love Of God!!!!
  62. Headers 02 question
  63. Header bolt size please.
  64. smooth bellows
  65. air box lid o2 sensor wires pulled HELP
  66. electric cutout questions
  67. Does anyone make an exhaust like this? Or has anyone tried it?
  68. No clue how to wire DMH cutout
  69. need ory for slp longtubes
  70. ls6 horse power.is it worth it?
  71. Small fitting on rear of intake
  72. Mufflex bump stop hanger.
  73. Spark Plugs
  74. DIY True Duals
  75. Exhaust clamps
  76. Best Headers for the Buck
  77. "Urgent Part Needed"
  78. Mufflex Y
  79. Spark plug question
  80. MSD wire ?
  81. Where to get a hooker catback
  82. TB question
  83. What ORY to go with HOOKER LT, and BORLA CB?
  84. NE1 Sucessfully Used a FilterMag on T/A's????
  85. header install w/ jack question
  86. are all stock LS1 mass air meters the same
  87. Magnaflow or Corsa?
  88. what size cutout????????????
  89. Just to make sure Im not crazy (CEL light Question)
  90. muflers
  91. So i broke a header bolt.....
  92. Just got a Hooker catback put on my LS1, very quiet! What went wrong?
  93. Problem with under pulley.........
  94. How to remove front bumper
  95. are these cats good..
  96. SLP Dual Dual guys come on in
  97. Truck PCV. is this the one
  98. Oil Pan Gasket
  99. Air lid install help
  100. !AIR! Question How to block vacuum line?
  101. Doing my FAST 90 tomorrow....
  102. Quick ? on LS6 Intake
  103. borla exhaust 3"?
  104. should I get rid of the AIR and EGR?
  105. need some help..
  106. those with custom built y-pipes come in
  107. Pulling out my motor Help!!!
  108. headers and ypipe install
  109. Catback
  110. Spark Plug Wires
  111. What kind of Cats in the TSP cat Y-Pipe?
  112. which oil catch can kit ???
  113. port your throttle body yourself
  114. pacesetter long tubes and ory
  115. BBK intake manifold guys were you at
  116. LS6 dual or single exhaust?
  117. TD newb question
  118. Please help the exhaust dummy (me)
  119. coating on tsp true duals
  120. Loud Mouth 2!!!!
  121. Squeaking Belt? Maybe Idler Pulley?
  122. Which Spark Plugs
  123. Sound clip of my Trex & SLP Dual/Dual
  124. Used SLP LongTubes???
  125. How I MOSTLY fixed my banging Y-Pipe
  126. T-stat Size?
  127. Headers and Ypipe installed but there might be a problem
  128. Need Pics
  129. GMMG Chamber Exhaust
  130. How does Dynomouth+LT+ORY sound
  131. Cut-outs (did you pass inspection)
  132. how much torque do the motor and tranny mounts get?
  133. Thanks QTP and NW!!!!!!!!
  134. chambered exhausts
  135. Lid Question
  136. TSP duals
  137. Stock MAF vs. SLP 85MM
  138. 02-00 intake swap
  139. PICS of completed True Dual (over-axle) exhaust w/ Edelbrock LT's
  140. reuse intake gaskets?
  141. 78mm vs 90 mm intake
  142. Dynatech SuperMaxx System A++++
  143. Should I replace the motor mounts
  144. Cooling Fan question.
  145. few ?'s about the fast 90mm intake
  146. Need some information on what to do for throttle body?
  147. DMH cutout... where to install switch and what's involved?
  148. Finding exhaust leaks
  149. Starter and 11.75 to 1 compression?
  150. Slp Dd
  151. New Lt's + Service Engine Soon light = Bad? Why is my light on?
  152. installing headers very soon....just a few ?'s
  153. Need Information on Edelbrock Headers
  154. headers
  155. Header and exhaust questions
  156. diferent years ported throttle body
  157. Radiator Upgrade?
  158. Done with exhaust 3" to 2.5" true duals over the axle (lots of pics)
  159. TSP doesnt fit together??
  160. No one makes the exhaust I want?
  161. Pacesetter LT,TSP ory, Mangamouth pics
  162. how to adjust the throttle body cable?
  163. Hooker
  164. arp harmonic balance bolt on backorder for a month??
  165. Help Locating Squeak
  166. pacesetter y bang?
  167. cut-out cap!!
  168. timng cover
  169. Descreening stock MAF?
  170. Cats off, running rich?
  171. Throttle Body Spacer on a LS1...Any reviews?
  172. Oil on outside of spark plug?
  173. Anyone running a dumped Y-pipe?
  174. water temp sending unit adapter
  175. stock LS1-Ls6 intake mouth size?
  176. Stock LS6 intake mouth inlet size
  177. Shorty headers y-pipe recommendations for a california car
  178. One man LT installation?
  179. Is the NW throttle body supposed to be like this?
  180. Do your true duals fit?
  181. FIPK guys inside! K&N part # help!
  182. Spark Plug Indexing / Pencil Torching
  183. Throttle Cable?
  184. Timing chain and pulley question
  185. Help me decide...
  186. LTs w/ 2.5in y question
  187. flowmaster cat on 98 ta
  188. Installed my motor mounts. (summary inside)
  189. tick and squeek
  190. QTP's any day now...
  191. flowmaster vid
  192. K&N filters
  193. Mufflex single exit with Spintech muffler....pics or info??
  194. SLP LT's??????????
  195. Ported and painted FAST 90 pics
  196. mounting the FAST 90
  197. Ory Hooker Vs Pacesetter
  198. X-pipe
  199. Got my Magnamouth done
  200. Where to buy the clips that hold the lid down?
  201. Catted Y-pipe rocks ! - disbelievers come in !!!
  202. Thoughts about Magnaflow catbacks
  203. coolant temp sensor
  204. help please trying to relocate battery
  205. airlid=problems?
  206. Torque spec
  207. Katech valvecovers, powdercoated metallic blue
  208. Gmmg Day!!
  209. True Duals...
  210. How to seperate pipes?
  211. need some info on porting a fast intake.
  212. Car's dying after header install....
  213. new custom catback is on...(PICS no 56K)
  214. Fast 78mm throttle body?
  215. Whistle
  216. 10% underdrive
  217. Help, anyone running a proform adjustable shiftlight on there 98 t/a-camaro
  218. To do a cut out or not to do a cut out
  219. SLP Lt's?
  220. Fuel rail assembled how?
  221. truck intake
  222. Exhaust for 427 small block
  223. Stock y-pipe diameter
  224. Anyone complain about NW90 TB?
  225. Kooks Vs. Brocks
  226. FAST 90/90 vs. ls6 & ported TB
  227. 85mm lid vs. FIPK, did some calculations
  228. Exhaust leak...help!
  229. Valve Covers (pcv hook ups)
  230. Short belt mod ?
  231. Will exhaust leaks hurt performance?
  232. 90mm Nick Williams question
  233. Flowpac with Ram Air
  234. Maf?
  235. Kooks ORY......
  236. Pacesetter Longtubes / TSP ORY / TSP Rumbler
  237. header bolts, and tsp bolts
  238. egr block off kit to fit slp ls6 intake
  239. Getting rid of td for y/cb.
  240. QTP LTs...What catted Y pipe?? Jethot LT?
  241. phase 1 complete
  242. Pacesetter Headers(probably been asked)
  243. header install front 02 code?
  244. Jet Hot headers and Pacesetter Y-pipe.. will it work?
  245. my vic jr conversion pics/thoughts
  246. Coil relocation for ET Heads??? Anyone?
  247. Easiest install, pacesetters or ls6 int
  248. Lt's,ory, Magnaflow And Rasp?
  249. I want to quiet down my exhaust...
  250. O2 Question - Heat protector boot on wire
