PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 [185] 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316
  1. Spark plugs for 402?
  2. poly motor mount bolts?
  3. cooling system pressure
  4. Poll: Have you heard any rasp from a TSP Rumbler (non X)?
  5. Bad Cat
  6. Qtp Open Appology.
  7. TSP TD with powerstick?
  8. True Duals$$
  9. Write up - How to remove your MAF
  10. any power gains with smooth....
  11. Fast intake install
  12. meziere water pump
  13. Information overload! Am I getting this right??
  14. air lid info
  15. Corsa Exhaust.
  16. At end of summer what should i do?
  17. Electrical charging problem???
  18. Where to get ARP header bolts??
  19. Ported TB
  20. Help! Quick!
  21. Questions before Install of TSP?
  22. Egr,air pump removal & power gains?
  23. How long should High flow cats last on header install with no dyno tune?
  24. Coil relocation guys step in
  25. firebird cats
  26. Underdrive pullys, which one?
  27. What is the little vacuum fitting on the back of the intake for?
  28. is 98 pcv system different?
  29. difference of headers
  30. Ported LS2 TB
  31. GMMG ordering
  32. cut-out question
  33. can you put an ls1 intake on an lt1
  34. ls2 intake on an ls1
  35. What exhaust is this?
  36. Need numbers for GM parts,Crossover tube and plugs for a LS6 Conversion?
  37. Passin the sniffer
  38. Corsa Tips?
  39. Anyone tried car chemistry inserts!
  40. HELP! LS6 Intake swap. Motor Revs High!
  41. Part Number for Brake Reservoir Cap
  42. how to remove dipstick for header install?
  43. What exhaust do I have??
  44. Bigger TB + Old Lid?
  45. Need Help With Headers!
  46. Any theories or ideas?? Area behind license
  47. Help picking and air cleaner
  48. LS1 Belt Questions LS1 NEWB
  49. My K&N filter has 40k miles on it....should I buy a recharge kit, or a paper filter?
  50. Modded my ram air
  51. Vette rear o2 sensor $180 each!
  52. High flow cats....
  53. Anybody seen those xs headers on EBAY?
  54. 18 inch bullets with turn downs
  55. Ok, now before I go out and buy this....
  56. Jethot Y Puipe
  57. What to do with the rear O2s ???
  58. tb spacer?
  59. offroad pipes for 02?
  60. Best sounding/performing exhaust with STOCK y-pipe and headers
  61. Qtp problem...need help please!!!!
  62. Intake manifold question
  63. I need a new Alternator?
  64. Will the Borla 14464 fit a 2000z28
  65. Headers
  66. how much?
  67. slp longtubes with y pipe
  68. Whats this
  69. will my 90/90 FAST NW set up SLOW ME DOWN??
  70. LS1 = Bolt on Badass????
  71. Which Slp Lm Is Louder I Or Ii
  72. Is it posible to take off the I pipe without cutting ?
  73. new muffler
  74. headers and y pipe will it be a big diff
  75. flowmaster vs. hooker
  76. TSP Catted Y
  77. Here's my Pacesetter LT's
  78. Converting a 78mm Fast Intake
  79. Raced 04 Mach 1 but..
  80. 85mm Granatelli MAF, I have a dyno tuning coming up, should I have got a ZO6 instead?
  81. PaceSetters for GTO's
  82. Longtubes for 69
  83. Piks of duals run out back
  84. Idle setting with NW90
  85. Water got up to intake. What now? ALL Diagnostic Trouble Codes (DTCs) INSIDE!
  86. What could be used to quiet down a true dual setup?
  87. Performance Shops in Central TX????? EXHAUST HELP!!!
  88. New intake bolts for FAST 90...
  89. Exhaust Setup in Progress...?Advice?
  90. Ok, hopefully my last exhaust question...
  91. lm exhaust pic
  92. GMMG or True duals?
  93. Thinking of Selling My Y-Pipe w/ High Flow Cats (What's it Worth)?
  94. cleaning MAF
  95. crank pulley problem
  96. Any one try these
  97. QTPs - standard vs. HVMC...
  98. cutout life
  99. Porting Pasesetter Y
  100. Finshed my new air intake!
  101. Just wondering is this is true about dual cutouts?
  102. Fitting Under Driven Pulley
  103. slp air lid install
  104. ??true Duals??
  105. hooker headers???
  106. slp lm vs tsp rumbler 3"
  107. Throttle body cable question..
  108. best intake?
  109. Figured out my exhaust isn't stock after all...
  110. Car is getting a lot LOUDER...why?
  111. Jet Hot emissions
  112. whats the difference b/w the lm muffler and dynomax
  113. Help
  114. whats the loudest exhaust
  115. when do you need bigger injectors?
  116. Need Some Help Quick
  117. Ls6 intake swap....plugged egr hose with JB ?
  118. Knock Sensor harness
  119. Ok for tips to touch bumper cover?
  120. Carb. Vs. LS6 intake on LS1...
  121. slp lm 1 replace resanator.
  122. Poll: Ever had or heard any rasp with a Magnaflow?
  123. Will tune get me past sniffer test.
  124. what bellow to use with FAST/NW 90/90?
  125. Borla vs GMMG w/ H/C
  126. Corsa Dual Knock off's vs SLP Original CME?
  127. GHL exhaust for 99' Camaro???
  128. headers for a 383
  129. Installed loudmouth, now SES light
  130. Header capped itself a hole in the runner tonight!
  131. a little help please
  132. What size of O2 extensions for Header install ?
  133. exhaust cutout on my tahoe
  134. SD people, talk to me
  135. swap plugs- then misses/surges at idle??!
  136. Mounts for transmission and motor
  137. Do I really need the SLP header Install kit? SLP LT Header owners inside please?
  138. Hooker catback sound (noise level mostly)
  139. QTP/Y-pipe/Cutouts
  140. 90 Fast/90nw + Lt Ory Pacesetters + Tune
  141. HELP THIS LOOKS DIFFERENT THAN my stock ls1 intake is it the ls6??????
  142. ram air box is it ok to cut out for cold air????
  143. Headers vs starter
  144. Installed the Magnaflow...
  145. flow master's and headers
  146. pacesetter headers and y pipe?
  147. TB cable problem
  148. who makes this......
  149. will these work together ?
  150. New mods!
  151. BIG THANKS to QTP
  152. Aluminum motor noob?
  153. Vette and F-body Starters
  154. Wow Come Inside!!!!
  155. how easy is it to port my TB
  156. kooks or QTP?
  157. Rusty Exhaust
  158. TSP Rumbler 2.5" or 3'?
  159. Need a good heat shield (cutouts too hot)
  160. True Duals with 3" Borla
  161. Exhaust Manifold Gasket Part Number
  162. Read O2 sim & header FAQ, but still have ??
  163. ABS INOP light came on after header install...
  164. has anyone used these?
  165. Side-exit duals...
  166. Harmonic Balancer
  167. What's the catch?
  168. TSP y-pipe: cats or no cats
  169. I need CME tip demensions, help me out
  170. Couple of questions about what the guy at the shop said / Exhaust options. *Merged*
  171. kook's Header's and O2 sensor's ??
  172. pacesetter headers
  173. limits of stock manifolds?
  174. Is there a way to monitor whether an elec.H2O pump is operating or failed?
  175. my used headers
  176. 98 Camaro Intake in a Vette?
  177. Cme
  178. Possible to run rest of piping for TSP Duals?
  179. Will TSP TD work with UMI trans mount adj. torque arm ?
  180. Are opti spark plug ends the same as LS1 coilpack ends?
  181. PS Headers and Kooks Y-pipe, compatability?
  182. after o2's
  183. Header gasket question
  184. You can stone me, but dont hit my car!
  185. how do u knw if ur motor mounts are going bad
  186. What does everyone think of hooker headers
  187. X and H-piping
  188. SLP loud mouth 2?
  189. Exhaust advice
  190. where to find ls1 mani. bolts
  191. What's The Difference Between 2otl and Dual/Dual
  192. Pics pics pics
  193. Front of engine oil leak, what seals should I replace?
  194. LS1 Header questions
  195. OEM Formula Exhaust??
  196. Can I pass smog with bad cats?
  197. Connecting xpipe to headers?
  198. header pics please!
  199. Headers and lowered can dont go together
  200. TSP Rumbler noise level?
  201. hooker LT'S and TSP TD's needing installd
  202. What muffler to substitute for LM1 resonator (don't want the normal response)
  203. intake manifold
  204. TSP ORY and SLP LTs
  205. I can fit 1 finger between tire and fender...am I screwed for exhaust clearance?
  206. Help with slight confusion
  207. Question for Borla Adj CB Owners...
  208. Pacesetter vs Kooks pic
  209. How much is a MAF gonna cost me?
  210. Header question?
  211. Headers installed!
  212. Exhaust pipe kinked from clamp
  213. Poly Motor Mounts
  214. Tranny removal with longtubes
  215. Question - What is this part?
  216. Header and steering linkage... i think
  217. cheapest true Dual
  218. Intake manifold question
  219. Best Combo with SLP LM Cat back
  220. idle issues please help
  221. Best exhaust setup (with sound please)
  222. Can stock fuel rai be used on Wieand Intake?
  223. removing engine?
  224. Flowtech Cuttout
  225. Do I need to get my fast 90 intake ported?
  226. How to clean O2 sensors?
  227. Dr. Gas 3" X 2..5"..........
  228. LS2 vs. LS6 intake manifold
  229. Alternator Pig Tail
  230. Debating on going with duals...need some opinions
  231. Y Pipe hitting, what rubber cushion do you use?
  232. could i port my own tb?
  233. Solid Motor Mounts on 6 liter Block?
  234. I'm Sam1 from the middle east 700Hp is my target
  235. I'm sick of hearing this....
  236. Plug wire and header clearance...
  237. Exhaust upgrade?
  238. More power??
  239. 160 degree thermostat increase speed?
  240. hand ported TP turned on check engine light
  241. Who here has installed SLP LT Headers? Any tips or info appreciated!
  242. Best headers (1 7/8 ) for lowered f-body
  243. Do I have this cutout on right??
  244. Starter Problems
  245. Kooks vs. PaceSetter ~ Installation and Fitment question
  246. Book time for motor mounts/exhaust.
  247. Has anyone actually had a FAST 90mm TB work as advertised?
  248. guys who sells oval piping?
  249. noob buying lt headers
  250. What Metal for X-Pipe?
