View Full Version : Generation III External Engine
  1. o2 sensor problem
  2. Whats needed to put Ram Air on a non WS6 TA???
  3. will 2000-2002 cats and y-pipe bolt up to 99 manifolds?
  4. Throttle body and intake manifold
  5. Crank Pulley Install Problems
  6. exhaust smells like a fart!!!!!
  7. For those of u who have Bassani street Comp need opinions...
  8. Backfire between 1000 1500 rpm's
  9. Critique my duals job? TSP DUALS w/ PICS
  10. Quick Y-pipe ?
  11. complete bassani exhaust system
  12. y pipe decision
  13. Lowered with Mufflex?
  14. Stock y-pipe, wow! installed slp loudmouth today, whats a great replacement y-pipe?
  15. Meziere electric water pump issues
  16. Summit x pipes
  17. Air Pump Diagram - 2001 camaro?
  18. Thoughts on the Texas Rumbler
  19. Building "Mamo-combo" - do I want an 85mm MAF?
  20. ls6 intake and pt body
  21. What PAINT can stand the heat?
  22. Cat-Back Opinions
  23. F.A.S.T Intake manifold gaskets, can they be used on a LS6 intake manifold as well?
  24. Does anyone have a chart?
  25. Which headers?
  26. Hooker ORP fits QTP headers?
  27. My custom air intake gains!! Dyno proven!!
  28. Better flowing LT's ?
  29. Lid, Cold Air Intake, Ram Air ?
  30. Look at my true duals over the axle!!
  31. Long tubes and ORY ?
  32. EGR System melting off then exhaust blowing off?? HELP..
  33. battery relocation kit and holder?
  34. Yet another "WTF is this thing" thread.
  35. cat delete code after header install, can I wait on it?
  36. Headers and Y
  37. Flowtech Headers
  38. Cheapest place to get jet-hot long tubes?
  39. Any pics of motor mount bolts?
  40. ls1 synthetic filters...
  41. fast 90/nw
  42. Y-pipe to fit MAC headers
  43. Smell after installing CAI
  44. my exhaust, the never ending battle
  45. How hard is it to install SLP Cold Air induction?
  46. pacesetter vs kooks
  47. installed pacesetter LT's and ORY this weekend
  48. I-pipe modification!!!?
  49. Which headers for a Daily Driver in San Antonio??
  50. How hard would this exhaust setup be to pull off?
  51. air bleed tube location...
  52. Any One Have QTP's High Vel. Header???
  53. plug wires
  54. Duel Bore throttle body
  55. problems after header install!!! Please help
  56. StreetPro or QTP
  57. Oil Pan-Gasket leaking?
  58. Y-pipe bumping floor
  59. exhaust guestion?
  60. Crack in coolant overflow, can't get it out.
  61. best way to do a free ram air or instructions
  62. Battery Relocation Pics
  63. opinion on backpressure??
  64. Exhaust 2xX's
  65. True Duals Or Catback???
  66. Installed MSD
  67. stock MAF help
  68. PLZ.....Help needed
  69. I installed water pump, but broke the thermostat housing...doh!
  70. Running Rich??
  71. Exhaust system falling off???
  72. Intake
  73. 02's
  74. mufflex 4'' exhaust
  75. Porting TB Question
  76. Whats the stock manifold primary tube size?
  77. You guys are either deaf...or liars
  78. will ASP pulley make my lights dim?
  79. 90mm TB
  80. Need help on exhuast setup!!!
  81. are cats only too loud?
  82. ws6 hood baffles
  83. Water Temp gauge acting up lately
  84. ANOTHER dual setup... DYI > you (pics + video)
  85. gonna be doing a header install here soon.
  86. Anyone using New Era Performance ported throttle body?
  87. Home ported TB and home made ram air...
  88. Ory
  89. Crank pulley bolt! I need to know how far the threads go up!
  90. oil pressure sending unit ???
  91. new setup
  92. Loudmouth Backfire
  93. Just got my cutout
  94. whats the difference between slp blackwing air lid and regular slp lid?
  95. if you have ram air from factory will you gain any hp with slp lid?
  96. Ported intake and 85mm for bolt on car?
  97. Lid Question, 98-99 or 2000-02?
  98. STOCK MAF question!!!!!?
  99. Need recommended O2 sensors
  100. Post Up Pics of Your Lid!
  101. borlavsgmmgvscorsa
  102. Hooker or TSP Catback???
  103. Edelbrock vs Hedman vs Pacesetters
  104. Ported TB vs Velocity stack
  105. MAC's are on!
  106. kooks catted-y
  107. Nice true duals..
  108. kooks ?
  109. Car won't start unless pedal floored??help?
  110. Header Bolts
  111. Quick question...
  112. will it hurt the car if i run two electric cutouts?
  113. Flowmater and Un-Modded Macs. :D
  114. Catted Y for Pacesetter LT's???
  115. Black Painted vs Ceramic Coating
  116. Crank pulley
  117. opinions on DUAL cutouts please . . . .
  118. Catch can mod
  119. New exhaust installed!!!!!!!
  120. Maf?
  121. are these longtubes on ebay good ones
  122. PCV Boot
  123. 02 sensors and rough idle
  124. TSP True Dual kit clearance, Fuel lines, and more
  125. What is a resonater for?
  126. Help Me Beat This Guy!
  127. Question about pullies
  128. BMR lid
  129. Difference Between Corvette and Camaro (V6) Intake
  130. Any evidence as the BBK intake perfromance?
  131. C5 catback gasket question..........
  132. question about coated pacesetter
  133. Anyone with a Fast 90?
  134. Intake problem
  135. Colroado emmisions and kooks headers?
  136. Re-use exhaust gasket?
  137. stock muffler on 2002 z28 stripper model
  138. afterthoughts auto-corsa tips
  139. 85mm lid?
  140. Best place to get throttle body ported and polished?
  141. Who ports MAF housings?
  142. LOG type headers
  143. Cost of shipping a short block
  144. Gen 3 single plane intake
  145. Breather filter for Lids!!!
  146. where can i get a catted y pipe for dynatech longtubes?
  147. Bigger Cats Fit?
  148. whats the best header bolts (locking bolts)?
  149. FAST 90 install question...
  150. Flow Tech LT's = CRAP
  151. Canton oil pan??
  152. QTP dumps
  153. SLP TCS Lock Module?
  154. ASP Pulley - What bolts for puller holes?
  155. Magnaflow exhaust opinions
  156. Header Leak
  157. Jet-Hot Cats
  158. Few LS6 intake Q's
  159. spark plugs
  160. HOw much easier will plug change be w/o air & egr?
  161. SLP DualDual ... is that a Dent in the Over the Axle Pipe?
  162. Whats the most restricitve part of my WS-6 exhaust?
  163. Spark plug install...misfire!
  164. Header decision
  165. Battery Relocation Tray, where to buy??
  166. Did the fernco
  167. Are dynatech longtubes good headers?
  168. Post your painted FAST intake Manifold
  169. Should i get a tune?
  170. cats or no cats
  171. 3 inch cut-out
  172. need a O2 sensor pigtail
  173. Cutout? long term effects
  174. Need input on selecting pulley
  175. Non-Oiling Air Filters to replace K&N?
  176. Stainless Works says thanks with money for you!
  177. Does the Kooks catted y match up with SLP
  178. FAST 90mm Intake w/o 90mm TB??
  179. flowmaster for a 2001 ss
  180. TDs or not
  181. Loud Mouth?
  182. tsp y pipe leak
  183. Can someone explain pulleys to me.
  184. Problems with new intake manifold
  185. Magnaflow Fitment help
  186. Header Question
  187. 99 T/A Borla Exhaust **VID**
  188. What do you think?
  189. Plans for headers on A4/stalled FBody....keeping stock cat-back w/ cut-out
  190. Harmonic balancer/ pulley
  191. side exhaust question
  192. Will Kooks clear oil cooler adapter and lines (see attached pic)
  193. what pully do i need?
  194. spark plug color
  195. Kooks header owners... question
  196. Borla adjustable plates??
  197. New long tube headers for the LSx??
  198. Stock Exhaust MOD
  199. I just got an LS6 intake for 75 bucks
  200. Wait for TB to tune?
  201. Muffler swap??
  202. crackling sound!
  203. Problem after header install
  204. U/D Pulleys, anyone use CAT products.
  205. rear O2 extension harness
  206. FAST Intake w/78 mm Throttle Body?
  207. exhaust set up ?'s
  208. FlowMaster
  209. Header bolts??
  210. waterpump gone bad
  211. Fast 90/ NW 90 ??
  212. need help with headers
  213. lowered car need more clearance
  214. 98 to 99 engine swap
  215. getting wires through the firewall
  216. fix my lid
  217. Help me with headers
  218. kooks 17/8 headers
  219. straight pipe or gutt cat?
  220. header question
  221. poly motor mount insert hardware?
  222. OK, I have a question about O2 sims.
  223. GMMG users inside!
  224. Anyone have any clips of a Borlamouth setup?
  225. X pipe
  226. is this normal?
  227. lose more clearance w/ SLP's or MAC's?
  228. pacesetters & extentions?!
  229. flowtech vs hooker
  230. mac header system
  231. Nick Williams Thottle body problem?
  232. Water Pump Impact on CR & Power?
  233. QTP Headers ground clearance pictures?
  234. ignition wires
  235. Exhaust Bracket won't stay in place
  236. electric water pump question
  237. Spohn TQ ARM with X pipes
  238. Who's running cats with AIR deleted?
  239. Intake Mods Lower MPG?
  240. Swapping LS intakes - is this possible?
  241. Slp cats
  242. Accel 8mm Superstock wires????
  243. cat back from an auto to a manual
  244. Help picking good spark plugs.....
  245. 80MM BBK TB or PORT STOCK TB??
  246. newbie pulley questions
  247. Those with home-made true duals....come inside
  248. throttle body stacks
  249. Need to get my headers coated
  250. Electric water pump leaking!
