View Full Version : Generation III External Engine
  1. stock 6.0 horsepower and compression
  2. Where To Get Pulleys/belts??
  3. ls6 intake question
  4. Dremmel tool to port TB??
  5. What causes rasp??
  6. LS6 Intake question
  7. NEW 90mm Throttle BODY for LS2 Style intakes
  8. 1 cut-out or 2
  9. Stainless Works 'Muscleflow' or GMMG exhaust?
  10. Anyone try out the MTI 90mm thottlebody??
  11. Need info on exhaust installation......
  12. no exhaust = bad?
  13. What header gasket to use?
  14. what pulley to get
  15. exhaust question...
  16. Boy did I F&^% up.....
  17. March Pulley installation
  18. MTI Clear Lid I.D.?
  19. mas air flow sesor?
  20. Pulling Evap...
  21. My PCV solution.
  22. ground clearance with Kook headers?
  23. can you pull the cam off your TB?
  24. continual o2 sensor problem (multiple within two weeks)
  25. Finally went for a cruise with my Corsa.
  26. GMMG with LT's and cats..
  27. True Dual Gmmg Setup...?
  28. Second break... oil on spark plug threads
  29. Pacesetter w/ Stock Y and cats?
  30. Cat Selection
  31. jet hot long tubes with y pipe and cats
  32. Exhaust comparison (ad nauseam)
  33. First Break... Spark Plug question
  34. Linelock?
  35. ppl with sbc old school metal intakes
  36. Ported Throtle Body Problem....need help !
  37. 2000 WS6 with Borla...wanting headers
  38. !AIR without going catless?
  39. Emission Shorties...
  40. 78mm Fast intake problem
  41. I did it!!!
  42. Equus sending unit adapters...
  43. FLP's ground clearance
  44. My LS1 Has No Spark Please Help
  45. Can I make a True-Dual setup with pre-made mandrel bent pipe parts?
  46. MAF part number..
  47. ASP UD pulley, Shortbelt size??
  48. Thoughs on FIPK2
  49. is my speedometer off??
  50. Just making sure, 02 sensors
  51. anyone have qtp header pics
  52. switched 12v source?
  53. Can u port a stock ls1 intake?
  54. cut-out on!
  55. Coolant Issue:
  56. no tread sealer cause oil usage?
  57. Which Taylor ignition wires?
  58. Pacesetters any good?
  59. Vortex cone inserts
  60. cutout right before mufflr or GMMG
  61. Z06 muffler
  62. Will 01-02 headers fit in my 99?
  63. any body running a carbed lsx motor?
  64. kooks
  65. what is this black vacuum box
  66. Underdrive Pulley?
  67. clearance for headers
  68. Stainless Works?
  69. Emission Legal Exhaust Set-ups(IL)
  70. Header install during head swap?
  71. did u need all of this for a oil pump swap??
  72. waterpump gasket ID number
  73. What mods warrant a FAST LSX intake?
  74. im CONFUSED on cut outs help!!
  75. Whats the Difference
  76. will a lid for a 2000 work on a 98?
  77. Headers??
  78. Bosch 02's Shit?
  79. Can you hook up a BTM to the LS1 MSD controller?
  80. LT4 Dual/Dual on an LS1?
  81. CME with true duals
  82. o2 sensors
  83. O2 sensor identification....
  84. O2 Sensors (how many)
  85. need help with duals
  86. wiring
  87. Photos of MAFless bellows
  88. Pacesetter Headers
  89. Engine mounts
  90. LT's and ORY. O2 simms or exstensions?
  91. Will I feel a diffrence?
  92. o2 sensor messing up my VSS?
  93. headers and Y pipe
  94. REAL cold air intake
  95. Where to install the cut-out in the exhaust?
  96. which kooks headers 1-3/4 or 1-7/8?
  97. Please Help!!!!!!! Header Leak
  98. 1/4 mile gains on my shorty headers/ORY
  99. kooks catted y
  100. Stock C5 and F-body exhaust manifolds...
  101. coolant tubes & oil sending unit...
  102. drivers side header
  103. stock y-pipe Is it worth replacing?
  104. Guess who ported my TB (plenty of pics)
  105. anyone know how to wire a tach on an ls1 ?
  106. info.harlan 2 step on a 98 m6
  107. fipk vs lid and ssra
  108. Cats and Fuel lines
  109. What fuse for the Air Pump?
  110. MSD coils update
  111. is a 2004 LS6 water pump compatible with a 2002 LS1?
  112. Questions on Headers
  113. intake help for a newb
  114. Installing exhaust...Pain in the A$$
  115. C5 sidepipes
  116. HELP! headers, xpipe on, poping sound
  117. true dual setup
  118. different ways to install shift light?
  119. Has anyone gained power switching from Hooker LTs to Kooks/QTP?
  120. Head striped out from header bolt...help!
  121. magnaflow louder
  122. Removing O2 on Hookers?
  123. who makes a ypipe for pacesetters that fits better?
  124. Header Interference with SLP SFC's
  125. Header install in progress
  126. 3in Collector to 3in Pipe?
  127. Want hi-flow cats??????????
  128. Need help with tach install
  129. post pics of you duals over the axle
  130. LT headers back to stock question
  131. 02 simms not working!
  132. question bout true dual setup
  133. lose torque with ASP?
  134. TB spacer?
  135. Torque Control Switch???
  136. Stupid cats...
  137. Headers or Cam
  138. high fow cats
  139. Cylinder 7....which one is it......DUH
  140. Flowtech vs. QTP Stainless Steel Cutout
  141. Totaly confused / What Wires
  142. true duals over the axle
  143. no cats and gas mileage
  144. anyway to test a coil?
  145. Firstgen with Pacesetters.. Collector to X pipe questions...
  146. Worth Swapping LM for a Sweet Thunder?
  147. Buy TB or Port?
  148. x-pipe owners i need info
  149. Alternator quit, is there a fuse?
  150. question about powerstick mufflers, pwrstk peps inside!
  151. Need Header/EGR/AIR Help
  152. Options for reducing rasp
  153. I got my Kooks today have a few ?'s
  154. Summet X pipe
  155. Bad ground clearance help!!
  156. Exhaust setup
  157. header set up
  158. How much power can a 2.5" Ypipe handle
  159. Metco breather under BMR STB.
  160. victor jr intake on a car?
  161. cut-out on stock set-up...
  162. Headers Install
  163. does the jethot catted y pipe actually fit pacesetter longtubes
  164. is there actually a noticeable hp difference between longtube header brands?
  165. starter tab on block broke off
  166. More pipe = less power?
  167. cut-out gains on big cube motors
  168. I've Got A Simple Question!
  169. where can i get a new oil pump O ring
  170. Catted Y-Pipe doesn't fit into Cat-Back
  171. Thoughts on Sweet Thunder
  172. lights dim and flicker
  173. true dual feedback needed.
  174. true duel prices
  175. headers
  176. removing CAT Question?
  177. Could this be my problem? Pic included
  178. Anti-seize on header bolts?
  179. LT and ORY install gone wrong???
  180. just ordered pacesetters plus y-pipe
  181. Do the LS1 and truck motor alternators bolt in?
  182. MSD coil pics
  183. Header gasket question
  184. header question??? velocity merge like kooks
  185. LT install problems/ steering shaft
  186. 130+ Iat
  187. Slp Headers... scrape The Floor??
  188. Intake system and MAF for a Ram Air hood??
  189. Cat Removal?
  190. LS1 jacking points
  191. What is this sensor?
  192. Moroso wire feedback, now that they have had a chance to mess up...
  193. QTEC cutout open/close switch...
  194. LS1 MSD coil goodness
  195. what does the EVAP sylenoid do??
  196. headers and cats questions
  197. Loudness of TD's VS open headers
  198. changing stock muffler?
  199. headers and high flow cats question
  200. SFI Approved ?
  201. Stock Cat Restriction
  202. OK, what options are out there for plug wires?
  203. bad O2 = bad MPG?
  204. my GMMG cat-back review ( an other one !) (ls1sounds.com vids coming up !)
  205. How much am i missing out?
  206. Ported FAST 90 Intake
  207. SLP's LS6 intake manifold
  208. Got my pacesetters in have some ??'s
  209. Race Gas and o2 sensors, please help
  210. manifold gasket
  211. easy question
  212. Need some suggestions on quieting down my exhast
  213. Y Pipe Hitting Under Hard Acceleration
  214. Placing little spring on Y-pipe?
  215. MSD Digital 6 on '01 Z?
  216. I want your oppinion!
  217. Backpressure
  218. Torque question ...
  219. gmmg catback
  220. questions about headers
  221. Stainless Works Exhaust - Anyone use it?
  222. You wanted proof, here it is...
  223. Converter/O2s warranty question
  224. muffler
  225. Back fire
  226. Dynatech headers opinion?
  227. 85mm TSP Lid?
  228. bad miss
  229. bad miss
  230. Help Please?
  231. what will i need for this install
  232. 2.5" or 3" cut-out for 01ws6 i pipe?
  233. how much horsepower from all these
  234. best wire/plug combo for nitrous use
  235. Anyone hear of Accufab?
  236. A/C Removal question...
  237. Does anyone sell just the i pipe without a muffler?
  238. Enough Power to Warrant True Duals
  239. What Are Xr1's
  240. O2 sensor adapter rear sensor to front plug
  241. Exhaust Help!!!!!!!!!
  242. I'm lost. Please help
  243. is it safe?
  244. Check this out before spending $$$ on a catch can!
  245. Cheapest place to by 3in borla catback
  246. after a run, coolant pours out from reservoir
  247. cut out: electronic vs. regular. . and some other questions
  248. Hp/trq Gains From Long Tube Headers?
  249. can't figure out the problem
  250. how does a GMMG resales? keeps its value?
