- !fra / Ssra
- Installing Long-Tubes?
- Tach Signal for shift lite?
- will kooks for a 2000 fit a 98?
- What is this and where does it go to?
- SLP BlackWing LID
- Goofy Idle....
- SLP install ( LID - fuse )
- Loud Mouth 2 raspy!
- Exhaust Got Quieter???
- Put foam under my Weiand intake?
- Air EGR
- How to convert to 02 exhaust
- WTF.... Need Help?
- New!!!! LS1 Valve covers..
- Question on Battery Relocation
- exhaust sound
- Smooth bellow=cracked lid?
- Fast 90mm but what TB???
- Catch Can Questions
- Do mac midlengths bolt up to stock y pipe???
- Thinking about True Duals
- Water temp sensor location. Where besides lh front head.
- Are there any side effects to raising my stock A4 idle to 650 for a 25% crank pulley?
- Catch Can w/o PCV
- Which ORY?
- Removing the Air system?
- Borlamouth guys cmon in please, couple??
- lid & a good catback... improve gas mileage??
- LS6 Intake Questions
- 1-bullet No-Bullet?
- ls1 water pump experts come inside
- Long Tube Headers For Choice?
- Loud Vibration at 1900 RPM with new cutout
- O2's
- need opinions, best sounding bullet muffler with true dual exhaust
- Stock SLP exhaust qeustion
- What dimensions XR1 to get rid of rasp/drone?
- Lid fitment/sealing issue (yes, ANOTHER lid question)
- Are these real LSX inatake gaskets???
- ticking noise
- Anyone with LT's, cats, and magnaflow drop the cats?
- LS6 intake question..
- MAF BAD, 90mm check in please
- post pics of your homemade ramair or cai
- New exhaust setup.....sounds like crap
- Should i Get Cutouts?
- Idle question
- cut outs
- Question About Installing New Headers
- intake temp sensor??
- Oxygen Sensors
- QTPs HVM VS Kooks ????
- Tb Bypass why is it bad during the winter??
- SuperMaxx Long Tube Headers On Sale!
- Need Advice For Installing New Headers
- NGK install
- stock exhaust on SS's
- magnaflow muffler
- Anyone dyno the BBK intake yet?
- "Borlamouth" Question
- New plugs = SES light ???
- Universal X-pipe set ups
- Dual muffs
- Need Advice For My Installing Headers
- People With X-Pipes, Step Inside!
- O2 Sensors
- Good Muffler
- A/C belt came off today while driving....
- Intake Manifolds
- Do I need a dyno tune with a new exhaust ???
- 98 -> 99+ Valve Cover Conversion
- Reprogram computer with headers?
- Borla adj from '02 Z fit on 98TA?
- Car Got QUIETER After Headers?
- Pulley
- need help
- Question about returning my car to stock
- air control valve
- Does harness to rear O2 sensors pass through body?
- Anybody with true duals and BMR Extream Torque arm?
- Deleting the Cats...good idea or not?
- TB Bypass ?
- flowmasters, and hooker Both (long)
- pics of my true duals
- Slap me, pinch me
- ssra and tranny cooler PLEASE HELP!!
- Help : FLP LT's w/ off road Y
- Need Help???
- Stock Thermostat is...
- Billet LS1 LS2 Valve Covers
- borla? magnaflow? slp? corsa?
- Use one Catalytic Converter on Y pipe?
- victor series headers
- Well, no more BGRA
- Need a y-pipe for LS1
- Copy of Hooker cat back or the real source
- i cant find a thread!!!
- Header Question??
- People looking for the Coolant pipe and Coolant plugs (LS6 intake swap)
- PLEASE HELP! After LT Problems!
- anyone got pics of side exit exhausts?
- O2 sims LED light blinking, what does this mean
- Bassani cat-back/01 WS6 A4/3.23
- Loudmouth to Borlamouth Question
- walmart bags suck!
- Redline - Water Wetter - Coolant Additive ???
- Where to get True Duals??
- ASP Pulley
- LS6 Install
- **HELP**Car missfiring on all cylinders except 5 & 7
- Odd spark plug question...
- QMP Lid?
- Stainless Works Muscleflow chambered exhaust anyone?
- What does a flashing check gauges light indicate?
- Just did Prothane (poly) Motor mounts
- Need 1 longer ignition wire
- intake and throttle body.
- Do exhaust tips have an effect on exhaust sound/tone?
- Need info on Hooker LTs
- Whats wrong with my exhaust??
- FTRA owners...
- change plugs when dropping t-stat?
- FAST intake size question ?
- Used borla pricing
- borla electric cut out?
- Noises (Video Clip)
- impressed w/ FIPK
- Damn Emmissions
- Filter for SLP Blackwing Lid??
- Spark plugs for a 402ci
- Help
- Texas-Speed ORY?
- 01 tb vs 98 tb
- Blew hole in header
- intake comparisons
- Will I need to re-tune?
- Need a straight answer on sending unit adapter...
- A/C removal ?'s
- ASP Pulley culprit?
- going to buy headers
- Cheapest place to get XR1's
- LSX Ignition coils
- Is this a for real LS6 intake
- EGR and AIR system removal
- What acces. brakets for Iron block in F-body
- Accessories???? waterpump/alt only...
- Are Hooker Headers any good?
- Hookers Vs others.
- Please stainless Y.....
- What is the part number for these bolts or correct size?
- Installing tsp catted y pipe please help asap
- LT/ORY guys please come in
- How hot do my exhaust pipes get?
- TA / Formula owners with TD dumps.....
- loud ticking after serp. belt popped off....?????
- Header install finally complete
- electronic vs regular cut-out $
- header nightmare continues......
- F.A.S.T ls6 intake
- Just installed the Corsa
- Rounded torx bolt in TB blade
- spark plug replacement on a ls1
- FAST hardware kit Question
- Exhaust Idea
- 02 sims..
- What will give me better times?
- ? on exhaust for future
- Borla install?
- Do I need a LS6 intake before a cam or no?
- Thanks LS1-Tech !!
- gmmg...cutout?
- true dual
- Hole in header....
- sound clips for you guys, TSP Rumbler vs Sweet Thunder on stock manifolds >>> *VIDS*
- Long tube troubles?
- TSP True duals, stock manifolds, gutted cats
- Do true duals rattle your interior?
- will a '01 TB work on my '99?
- FAST intake install
- FTRA, pretty good.
- help....just installed hooker long tubes....
- true dual setup
- Car Running W/ Vacuum Leak vs No Leak
- Should I get a dyno-tune after headers ASAP so my richness won't ruin my spark plugs?
- manual fan switch
- header help
- ATI 10% Balancer Help - Belt
- Dual cut-outs behind the headers?
- Belt walking off...
- Jet Hot headers
- glue on tips?
- Need Help Asap!
- Stock Bellow Part number please?
- which cold air system is best
- Quick fly by of my car
- ls6 intake vs. ls1 vette intake
- Air Box Question (probably Stupid)
- Will Volant intake work with ASCD hood?
- AC Problem
- ac delco iridiums
- Is a cooler thermostat worth it?
- QTP LT Headers - Good or Not?
- Mac Headers with catted Y Pipe
- U/D Pulley
- 01' detonation issue, Been told it's the MAF...
- cats with true duals
- Cut-out or SLP LM???
- #6 plug tool
- SLP LT's
- what size cutout do i need??
- Ahhh... the sanity of a stock maf.
- should i change my EXHAUST
- Best price for a magnaflow tru X-pipe?
- Free Mods?
- miss the lt1 sound BAD !!!!!
- burnt up altenator
- X pipe
- ASP vs. March
- Lsx?
- Lingenfelter ported TB.
- Intake Question
- Intake seal question............
- just got my hooker headers and Y-pipe...questions...
- need something quiet
- Volant CAI Help
- Bassani TD w/Pasesetters
- Flowtech Warlock Exhaust?
- cutout pics??
- ATTENTION: Hurricane Rita & LS1TECH
- muffler
- x-pipe or y-pipe
- Vic jr/GMPP Carb Valley cover
- Hooker Soundclip
- Tuning after Pacesetter LT, ORY and catback
- 3" pipe
- 24/7 open cutout?
- Installed 2.5" duals / Ported TB noticable power loss??
- Help w/throttle body and IAC
- TSP True Dual Owners - Drone?
- ls6 intake...direct bolt-on for 98???
- What size cutout do I need for my stock c5?
- Finding parts...
- flowmaster only help...
- macs/ory/bullit...
- Hooker Exhaust...need help
- did i kill a cat?
- Borla---keep it or ditch it?
- HELP!!!:confused:
