- Question about LG pro L/T's w/ out Cats...
- amw catch can post-installation question
- Hooker LT header EGR connection blew off hole the size of Quarter in Header Now what?
- Just bought Bassani True duals, what headers should i use?
- tsp true dual x pipe
- Does a ported TB actually increase power or just give sharper throttle response?
- Sheet metal intake questions
- Exhaust Suggestions?
- Anymore engine before 12-Bolt.
- HELP! i need pacesetters!
- Spal fans
- Long tubes going on my Z06!
- Are NGK Double Platinum spark plugs worth it?
- wiring harness
- which one is the loudest ?
- ASP Pulley question...Tried to search, but no luck
- EVAP, is it needed on a conversion?
- I could really use some help ASAP. I may be in trouble.
- Header install ?'s, Gaskets, bolts, jacks and stands
- Does GM cover this?
- New Radiator?
- rebuilding a belt tensioner
- Need a new muffler... Advice needed.
- exhaust tips sound?
- Hooker LT's & O2 extensions?
- mid length headers?
- If you get a cut-out what's the point of ....
- IAT Sensor in TB
- Difference in Y's
- Will any LS1 Balancer work on 98?
- poly mounts
- Ls2 coil install onto LS1/6 writeup, anyone have one?
- MAC Header/Y=pipe gain?
- volant or slp?
- O2 code
- Looking for catted y-pipe...
- Poly engine mounts for a daily driver?
- pics of cutout installed.
- GMMG..gettin a hold of the muffler setup
- Random Technology vs. Car Sound
- How much $$ 4 engine mount install?
- Headers,ory and only one cat anyone
- Harmonic balancer
- LS1 SLP radiator = LT1 radiator??
- Stuttering/Hessitation....???
- Co2 Intake?
- flowtech or hedman?
- Long tube headers
- A few pics of the lates mods...
- TSP Xpipe questions
- headers=louder
- just installed rumbler and wow
- Bo White Ported Throttle Body
- New MSD Coil packs
- quick dumb question.
- cold air kit?s
- just ordered my new exhaust parts
- Free mod concerns... :confused:
- Various single plane intake pics..... (BIG pics)
- K&N FIPK or MTI?
- Air check valve question
- FLP LT band clamp problem...input?
- Bucking and Surging: Bad Gas, O2 ?
- X-pipe vs. H or I-pipe...
- Car is runnin' like a bat outta hell!
- wanting true duals
- Heat wrap???
- Header Question
- backfire when A4 shifts?
- Putting An Air Filter In The Oil Cap
- custom dual exhaust setups, couple of questions >>
- pictures.....please tell me if this is causing extra engine heat
- Catch can on vent line?
- how do you quiet down exhaust for the street?
- TSP true Duel
- motor mount problems
- Rear Main Seal Plate Help
- Air bridge question
- LS6 Intake
- Hooker AeroChamber's on duals
- Header Install...Backfiring..Misfiring...Help!!
- LS1 Oil Cooler
- LS1 intakes??
- who makes custom headers or do anyone a set lying around
- Aftermarket...radiator and fans
- Header install yesterday, HELP
- Free Mods
- 921 and 918
- Which set of headers for serious FI?
- post pics of pcv mod/ catch cans
- 3" cutout on stock exhaust
- Need To Dump Loudmouth
- Stainless Works Headers
- flowmaster hushpower II
- To those with the Flowmaster merge
- Single chamber flowmaster.........
- how much will longtubes and ory help!!!!!
- bad converters and o2 sensors
- A4 guys + asp/ quick intsall ???
- How to Install Headers...
- Installed Cutout Today - BEST SOUNDING CAR - WOW!!!
- Well I got my LS6 Intake on
- AC pulley noise!!!!!
- Cold air
- coil packs....all the same for the gen III GM motors?
- SLP or Hooker headers w/tsp true duals
- LS1 Motorsports Lid
- LGM vs. Kooks headers?
- Borlamouth...yes i searched
- BGRA installed IAT temps lower
- O2 sensor connector type: Flat or Square?
- DR. GAS Boom Tubes
- exhaust leak help
- Which catback for my Z?
- Magnaflow owners inside...
- Problem with Power Steering after Cam/Intake/Headers/Oil pump etc.
- Who makes the Shortest, high flowing cat
- Emmisions
- volant dual intake dimensions?
- v6 questions!
- I need to quiet down my H/C/Kooks/LSX90/Corsa set-up
- Which intake manifold ls6 or weiland
- Exhaust, Rusting, and Rustoleum???
- new muff
- True-duels and cutouts?
- Stainless Y-Pipe
- How can you tell if your getting false knock?
- !cats and gas smell
- is Exhaust interchangeable between L98, LT1, and LS1?
- magnaflow
- Who has TSP Rumbler + LTs & ORY + Cam
- getting ready to install headers few last minute questions
- How Bad are Mac Headers w/ there catted Y Pipe.
- !AIR lid hole plugs
- ASP Underdrive pulley Question
- Dynomouth vs magnaflow muffler
- Clear smooth bellows?
- Nitrous and header combo?
- Stupid Header Question
- I got a question about my 99 SS
- 02 sensors..
- Sweet Thunders on a newer Silverado
- Its been said before: LTs+ORY+LM=No No
- temp gauge sensor bung
- my idea for an exhaust help?
- v10 plus exhaust...
- flowmaster vs magnaflow merge?
- O2 sensor how to tell left or right?
- L-O-L Shop story:
- Gutting Cats
- is it safe to drive
- Sidepipes on my camaro Z28
- Chambered Mufflers
- What are a good set of headers...
- Anybody have the JetHot Ypipe (Catted)?
- BGRA alternative?
- how much power do hooker long tubes and y-pipe add
- people with TSP rumbler...
- Quick question???
- How do I get my headers coated.
- Options for Catted Y-pipe
- Edelbrock Victor JR Intake (Pics and specs)
- Pulley or not to pulley?
- Xr-1 or Cats???
- Hotwires!!!
- Which torque arm w/ True Duals
- Need some help please!
- cutout or LM resonator loudest?
- part numbers needed
- ??Belt Size??
- true dual vs. Y
- ls6 intake price
- Slp performance pac
- Used vs New
- lt install 02 procedures?
- LT, Cats, Dual/Dual users inside
- Do you need the foam things on the bottom of the intake?
- FAST intake and Forced induction?
- Removing Cats.
- Fabricated exhaust vs Brand performance exhaust
- how much will this help
- Porting the FAST 90MM intake?
- Well I tried to get the intake install done but SNAP!
- Fixed my exhaust leak, basically for free
- Did the Sweet Thunder Swap
- My Own Custom Exhaust!!!
- DRONE - what causes it? Converters or Cat-backs?
- My home ported TB
- How can I make a quiet true dual?
- Another dynomax bullet question
- Has anybody had.....
- Removed aluminum plug insulators - bad idea?
- running like crap after new wires.
- LS2 intake manifold
- Flow Tech Headers...
- Exhaust FELL OFF!
- Who here is running with a TRex cam?
- stage 8 header bolts?
- Corvette intake, LS1 or LS6?
- Gmmg???
- Performance Pulley
- Someone has to have something to say...
- Cut stock system?
- True Dual Owners - Heating/Rattling/Knock/TQ Arm
- exhaust tips
- need help
- where to get plug wires
- oil between header gasket and head?
- Odd Air Conditioning Problem
- magnaflow vs spintech
- y-pipe for SLP Headers?
- Which one should I get?!?
- Borla guys in here. MPP?
- Fipk?
- stainlessworks y-pipe
- Mac Headers and Loudmouth Exhaust
- sounds like a supercharger under the hood
- Will a Gatorback belt fix my slipping problem?
- LT's, OFY, and stock catback
- oil being sucked into intake will small breather fix this?
- Blow Off Sounds
- Flowmaster 40 series
- Problem w/ intake swap
- O2 sensor wires
- Turn one pump
- Which one to do next??
- Flowtech Headers??
- best way to go about deleting EGR
- Cheaper?
- what is the loudest duynomax to replace the stock muffler
- passenger poly motor mount worth it?
- "X" or "Y" Pipes
- Small exhaust leak...problem for a few days?
- stock I pipe and bullet muffler?
- Which length Sweet Thunder to replace LM?
- Engine vibration at 2k-2.4k...I think it's the ASP pulley
- resonator exhaust tips
- Need some quick help with !AIR
- ory-p question
- slp exhaust's
- power steering free mod question?
- slp dual duals
- will x pipe made for dynatechs work with hooker LTs?
- Installed my Cut-out! Vid inside...
- Borla vs. GMMG
- LS1 to LS6 intake
- where to get dmh cutout
- What hardware is required to do a ls1 to ls6 intake manifold swap?
- Need Help with cutouts
- I think I there's a problem with.....
