View Full Version : Generation III External Engine
  1. Is the LS2 Intake an upgrade fro the stock ls1
  2. My Car has Ran Like Poo ever since.....
  3. 1 3/4" or 1 7/8" Headers?
  4. Coolant lines ?'s
  5. Switchable exhaust? (Crazy)
  6. Custom headers
  7. headers advise
  8. stock exhaust manifold question
  9. NGK Plugs Suck - AC Delco Iridiums Solve all Problems!
  10. Deleting AIR, revisited....
  11. Throatier Sound Please...
  12. LS6 engine question, which intake and tb to use?
  13. TSP 85mm Lid & SLP 85mm MAF
  14. Long tubes
  15. When to add 90mm intake mani and t/b?
  16. Will it help??
  17. Is this the right cat?
  18. Help Decide
  19. Need a new MAF.
  20. Oil Temperature Sender Install
  21. input
  22. throttle body bypass leaking
  23. How do PaceSetter Headers compare to Jet Hots?
  24. Safe way to lift LS1 with engine hoist?
  25. Difference between 00 and 01-01 kooks LT's headers?
  26. Kooks LT's pics and ??...
  27. which catback sounds best with deleted cats
  28. SLP Air Lid
  29. mezmeriz electric water pump?
  30. Suggestions on header, exhaust set up
  31. LS6 intake and 90mm T.B.?
  32. LS2 tb and intake
  33. What Ya know bout L/T headers
  34. anyone know approximately how hot header collectors get?
  35. has anybody made a TD exhaust with bmr trak pak yet
  36. Power steering Pulley can be replaced?
  37. good catback
  38. Single cat?
  39. Lanes true duals?
  40. HELP!!! Seafoam treatment problems!
  41. LS2 IM on LS1? brand new member!!
  42. I'll be fabbing up my own true duals...few questions
  43. Ported & Polished TB
  44. Question regarding M.A.F. sensor
  45. How to quiet it down????
  46. throttle body or longtube headers
  47. Best Plugs and wires for LS1?
  48. Thoughts on Stainless Works LT headers...
  49. exhaust clearence
  50. Texas Speed True Duals - IN!
  51. X-pipe
  52. LS6 Intake
  53. Crane's FireWire
  54. water pump wear
  55. 2 weeks after headers
  56. People with True Duals
  57. Poly mounts installed...GOOD
  58. Temp gauge not working
  59. Where can I get a 75mm to 85mm MAF adapter plug?
  60. lid question
  61. Any power gain with QTP dual cutout ORY?
  62. Cam lope with y-pipe setups
  63. Flowmaster Muffler/Exhaust
  64. anyone have these?
  65. What to replace my flowmaster with?
  66. MAF Ends
  67. Ls1 Water Pump Removal Help!!!
  68. jet-hot headers '01 ws6
  69. Is a K&N Worth it?
  70. Will 2002 AIR system fit a 1999?
  71. Exhaust is DONE, Money can buy happiness! LOL
  72. pics of the rumbler exhaust...
  73. Best Cat Back?
  74. alternator
  75. true duals with edlebrocks?
  76. Cheapest place to get o2 extensions
  77. Need An Answer Real Quick
  78. Afterfiring?
  79. What are the same from 4.8 to LS1????????
  80. Relocated PS pumps
  81. header question
  82. Difference In AIR Systems
  83. Cold Air Induction??
  84. True dual systems?
  85. 2001 F-Body LS1 Hose Function?
  86. Having detination problems as well as cooling
  87. Cutout
  88. Few header questions
  89. Shop F'd up my oil pan, How to replace?
  90. Help pulling motor!!!!!
  91. what acceseries with fast 90/90
  92. Looking for a ORY
  93. Gonna modify cutouts... Anyone try this?
  94. PN for 2001 MAF
  95. What does MAF sceen look like (pics?)
  96. can i go no cats?
  97. Got Exhaust Modified
  98. Engine stand bolts
  99. LS1 intake on LS6
  100. Car Won't Start - Help
  101. Need Advice
  102. header/exhaust ?'s
  103. AC Problem on a car I sold...
  104. Diff. between LS1 & LS6 intake manifold?
  105. What does the air box hose do on 00-02 fbods?
  106. tip suggestions.......
  107. Exhaust Question
  108. Fast 90?
  109. A quick question about the exhaust crossmember
  110. custom y-pipe / stock I pipe what size flowmaster y collector
  111. where's the best place to buy magnaflow cats
  112. cut off muffler?
  113. Throttle body bypass
  114. Help fast with QTP electric valve
  115. WMRA vs. FTRA...
  116. AIR removal questions
  117. Ordering today ... cats vs mufflers.
  118. High Flowing Quiet Catback
  119. Electic cutout - how to do wiring?
  120. Need help with headers
  121. Where did you put your cutouts?
  122. Going LT's, keep Borla or go True Duals?
  123. Loudmouth with Dumps
  124. Prothane motor mounts, impressions.
  125. slp air lid
  126. Name This Sensor
  127. which band clamps to get? (pics)
  128. TSP Y-pipe
  129. Looking for anyone who has H pipe on their LS1
  130. Anyone have sound clips for H pipe with sweet thunders?
  131. New urethane mounts bad engine vibration
  132. Problem with TSP catted y-pipe?
  133. AMW catch can users in here... I have a Q?
  134. Weiand intake on LS6 crate engine?
  135. Exhaust change ... which Borla mufflers????
  136. Best Ory? Qtp Or Kooks?
  137. header flange possibly bent..
  138. correct placement of rear O2 sensor on custom catted y-pipe
  139. side exit exhaust
  140. Instead of sweet thunder duals, for y-pipe folks?
  141. pully
  142. WS6 Hood - 3 Options - K&N FIPK, Lid & Plain Lower, Lid & WS6 Lower - Help?
  143. '99 Ls1/'01 Ls1 Maf Queston...
  144. Flowtech cutouts...poor quality
  145. Difference in 98-99 Lids versus 00-02 Lids
  146. Need help with headers
  147. Weird Startup.
  148. Keys Won't Come Out
  149. Need Advice/Help Designing CAI for LS1
  150. Thermostat question..
  151. coolant crossover tube?
  152. Is the vertical PCV mod any better than a catch can?
  153. Greddy catch can-15mm or 9mm
  154. bottom part of fast intake
  155. Ls1 To Ls6 Intake
  156. Sqeeky at start up
  157. True duals
  158. Which lids will work with a 85mm MAF????
  159. yes ive searched
  160. misfire / hesitating... could be fouled o2 sensor?
  161. true duals or y pipe?
  162. Ok Im sick of true duals now, what can I do??
  163. First header install (pending) in 20 years, LOL
  164. what type of wrench...remove solenoids star headed bolts from starter??
  165. Electric WP on a 430whp TA? What increase?
  166. FAST LSX Question about EGR connection
  167. Which one or maybe more (exhaust) ??????
  168. K&N and MTI sealing
  169. new mufflers(Borla TD's)
  170. LS6 intake install
  171. LS2 -vs- edelbrock intake
  172. Does Donaldson make a replacement air filter or CAI for the Fbody?
  173. Can o2's cause this much of a problem?!
  174. Exhaust Manifolds?
  175. Help! What the hell is this sound? (video clip)
  176. 1st Spark Plug Change Report
  177. Any shorty header track results?
  178. How bad will this sound..
  179. MTI lid vs. Others
  180. installed catch can wrong
  181. Bassani True Dual 99
  182. loudmouth 2
  183. BG ram air
  184. Need to change maf
  185. How can you check which model year Ls1 you have?
  186. This might be a dumn question but I'll ask any how.
  187. cleanin the maf
  188. diameter of stock y-pipe?
  189. Installation of Pacesetter midtube shorties for my 98
  190. Cat questions
  191. Different CME options?
  192. how much to ask for stock exhaust?
  193. how smooth should a ported throttle body be?
  194. Anybody got the Hedman complete exhaust?
  195. Duals under the axle guys...
  196. How do I get my oil fill neck out of the valve cover?
  197. quick 02 sensors question
  198. LS1 with no cats
  199. Took Off My Y Pipe Today
  200. GM Perf. vs. SLP LS6 Intake?
  201. FTRA kit and SLP Lid??
  202. Maf?
  203. WTF Plug wires !!!
  204. Will I be OK?
  205. O2 extenders
  206. Air Removal?
  207. Exhust Question
  208. ??? Nick Williams TB?
  209. Y-Pipe hi flow for Stock Exhuast
  210. QTP catted y woes/question.
  211. XR-1 Loss of power!!
  212. better tune after longtubes????
  213. Hooker headers or Pacesetter?
  214. exhaust headers
  215. intake help!
  216. Need help with duals, X or H pipe.
  217. LS2 Exhaust Manifolds vs LS1/LS6?
  218. Anyway to simulate the EGR or make the computer think it is functioning?
  219. big problem please help
  220. Floorboard knock, A/C compressor, and exhaust Qs
  221. header gaskets?
  222. Any 1-7/8" 32" Primaries Headers for C5?
  223. mti clear lid vs voolant air intake
  224. '00-02 Exhaust Manifolds Better Than '98-99?
  225. Help!
  226. ORY and MPG
  227. Spintech
  228. help with o2!
  229. best cheap cats for gutting
  230. Electric AC compressor
  231. Z06 MAF..No MAF???? Can't decide! Need help!
  232. exhaust
  233. Best Headers & Y: LT/ORY
  234. Radiator work if hoses are switched?
  235. Muffler length question
  236. Which exhaust flanges seal the best?
  237. 160 thermo
  238. o2 sensor (delete or sim)
  239. what headers and y pipe
  240. O2 sensors went bad helpp???
  241. Would you recommend this?
  242. PORTED MAF questions
  243. Open Headers
  244. LT's+ORY or LT's + TD set up.. power potential
  245. Straight duals
  246. Electric cutouts?
  247. Header Cons?
  248. HI-Flow Cats Worth It?
  249. what mufflers after x pipe....
  250. Alternator charge voltage
