- Is my motor fubared please advise
- Which muffler?
- Guy who takes Cat converters
- compression question
- When is a Dual Catch Can needed
- dual mode exhaust to attach to slp dual tip setup?
- headers
- Quick Question Headers install
- Bullet for an I pipe?
- painted pacesetter headers
- LS1 Air lid
- What is the thread pitch and length of exhaust manifold bolts?
- I hope this alternator will work???
- electric water pump worth it?
- LS2 Intake Porting
- Fuel Rail Question.
- What engine?
- fipk idea
- Want to purchase the 4" Mufflex kit or the Hawk kit
- 45 degree plug wires
- Anyone ever regrease their mccord power plate? How do the gears...
- what intake is best
- Heater not heating
- Good/reasonable electric water pumps?
- stock ls1, i have questions.
- afr heads
- Voltage drop at high rpm accel or decel...not the alternator
- need help
- Factory 02 SOM Z..exhaust headers to bumper
- compression and heads question
- Question About PCV
- spintech exhaust on stock ls1?
- A/C Delete?
- bbk ceramic headers and ory vs. tsp
- What is this connector for???
- How bad are these headers damaged?
- Give me a list of everything I will need for fast 102 lsxr on ls1
- Seeking Advice on what Y-pipe/headers to purchase.
- Anyone tell me what header bolt this is? Pics inside
- PCV Catch Can...
- Hooker Catback - Is This Rasp?
- What kind of gains by jumping up to 1-7/8 TSP LT
- 04 gto throttle cable
- Gains from changing exhaust setup?
- ls1 true duals with stock manis, no muffler, cats or not cats??
- what diameter exhaust cutouts do i need 2002 camaro z28 ss
- What Spark Plugs Should I Run?
- Tsp new ory pipe-install problems
- 2002 camaro z28 ss
- Volant cold air intake Fit
- strange exhaust
- Remove stock catback?
- anyone ever ran 2 x pipes
- I miss my Flowmaster 80 :(
- Larger intake manifold bolts??
- New L76 (LS3) conversion project - runs for 2 seconds and then dies
- Got to thinking?
- Texas-Speed True Duals
- Catch Can location NOT off pass side head
- PCV question..
- Placement of cutout with catted y...
- carbureted ls1 pros and cons.
- Magnaflow 3.5" in/out oval mufflers, who's running one?
- 30lb injectors w/ bolt-on's
- DMH Cutout rattle!solutions? dmh but wont reply back!
- New TSP 1 7/8" LT Headers review!!
- LS6 intake w/runners cut back 1.5"
- Running Open ORY?
- Throttle body not opening all the way..no where near it
- LS1 Stroker (i need inspiration...lots)
- gas mileage loss with 228/228
- Header/Ypipe options
- What tb and intake manifold after cam/heads?
- 02 Z28 won't idle/run
- Restriction?
- Stock cat replacement
- need help on headers
- High velocity merge collectors worth it?
- Decent setup?
- PTM 92mm throttle body broke return spring
- Intake piping size and power
- another vacuum leak question?
- Vote for Wich Muffler/Bullet???
- Fbody vs GTO starter??
- escalade coils?
- Injectors
- Another Duals Muffler Pick Thread
- Transam Need HELP ASAP
- Any one with kooks lt and kooks true duals
- What cat back is this?
- Starting noise coming through the speakers
- rpm input wire for Auto Meter gauge?
- Normal Operating Temps
- 3" Y pipe vs 2 1/2" Y pipe???
- TSP: how much longer on yor new SS Y Pipe?
- SS Muffler replacement
- Anyone have a pair of Sweet Thunder bullets laying around?
- looking for an exhaust
- Car dies then wont restart......
- Intake
- Which do you recommend?
- RX Performance CNC Ported TBs & Single/Dual Valve Oil Catch Cans INTRODUCTION
- BBK Headers or LS6, Which First?
- Blackwing Lid Question
- 2.5" tru duals
- Which pulley puller for power steering?
- T56 starter compatibility?
- power steering pulleys....
- TSP Y pipe help
- Switch Panel help
- Rear main seal in 2000 trans am
- Need help
- How much do ported Mac Mids/TDs give up over LTs and TDs?
- Plug wires with angled spark plug boot?
- Opinion needed on custom swap exhaust
- Cats and Header Combo
- Quick header question - 2" Primaries?
- New bolts with headers?
- Hi-flow cats w/ h/c and emissions
- nolonger charging after craddke drop??
- Please help this broke on my fuel line...advice needed ASAP!
- fluid in throttle body?
- fuel rail leak, does year matter?
- Adding a pair of FM10 or 40 race mufflers in the Y-pipes = quieter exhaust?
- ASP underdrive Pulley (PICS)
- True Duals
- Bad Catalytic Converter???
- ls1 diagram with sensor locations?
- common problem with 317 heads
- Will this Header to exhaust set up rasp???
- Bye Bye cats?
- should I switch to true duals?
- Different plates for manual cutout?
- Help- Car Won't Run
- Fast or Vic?
- TSP True duals...Where did you bolt the exhaust hangers?
- 5.3L Intake question???
- advice on some heads i found
- Center Exhaust
- ls1 Alternator & Power steer Bracket HELP!!!
- LS6 intake, 04+ valley cover, LS1 4-1 coolant lines. Fit?
- are truck plug wires longer then f body?
- Redoing COMPLETE Exhaust - Few Questions
- Jegs Headers?
- Looking for DMH contact info
- Help me find an exhaust thread or Ill just do my own.
- Faulty Cruise Control?
- 2002 motor in 1998 dash not working
- 235 heads on ls1?
- How to replace map sensor
- LS1 intake manifold bolt size?
- Which oil pressure switch?
- Got my cutout
- Random Misfire after power shift....ODD
- going to junkyard - need help ID'ing
- WHo can Port and Polish TB??
- True dual question. (not the normal question)
- Does anyone know how to make this exhaust noise?
- Coils
- 4" y-pipe cutout
- Opinions Please
- Intake manifold drama
- QTP Switch pics?
- what plug and gap do you run?
- Is there an agreed upon best TB for ls1 stock cubed, h/c with the 102 yet??
- Exhaust Advice
- Best prices on gaskets and misc.
- need help fast
- Bought used lid for trans am. Missing something.
- Where does this go (pic)
- AIR removal
- Lost Bolts Help!!!
- Cutout placement
- Need pix of passenger side Oxygen sensor
- Headers: Ls1 Camaro vs Ls3 Camaro?
- Where to connect Guages
- Is a SLP air box lid worth it?
- Should you use a catch can (answer) YES!
- Which tips come with the Magnaflow quad kit?
- ??header clearence???KOOKS,ARH?
- Worth buying 92 fast intake
- LS6 manifold gaskets
- bank 1 sensor 1 code
- PCV delete
- American Racing Headers
- MPG after LS6 install
- YSi Installation
- McCord power plate replacement motor?
- Hooker build a good set of headers? (and check out my set-up)
- Is this cam too much?
- 408 Hot start and idle problems - with video
- bbk y pipe
- Arp flywheel bolts?
- TSP rumbler and ory sound video.
- bad balancer (vibration @2500)
- Rust problems :(
- manifolds
- Tsp dual sweet thunders help
- First ever GMMG GTO!!
- Fast question
- Best inexpensive long tubes for 2002 Z/28???
- News about the 92 FAST intake manifold
- How much did you pay for your Kooks headers and dual exhaust??
- Dampner Question?? Pics inside!!
- 98 LS1 TB issues with LS6 intake swap..
- Some Food For Thought!
- #4 Spark Plug
- Lightweight/Mini Starter Options for LS1?
- Best Manual Belt Tensioner?
- Custom ORY
- My Exhaust slips backwards--Bandclamps slipping!
- 1 7/8 LT's on a SI LS1?
- Kooks 1 7/8 Installed
- Poly MM install question
- LM7 vs L33
- People with true duals on stock manifolds with flowmasters come in
- Loudest Legal Exhaust
- 1998 HVAC hoses/lines, how to route and connect?
- Urgent Help Please!!!
- More horsepower after changing fuel filter?
- intake help
- gmmg cat back
- Heads...
- texas speed header fitment and install
- Blackwing lid for Fast 92 TB transition?
- Can someone ID this, please?
- poly mount problems
- Camaro picks up speed with out any throttle... HELP
- Question for Kooks users
- Plugs and wires
- Bad harmonic balancer?
- run an alternator backwards?
- Cutout on stock manifold and catback
- Air pump problem??exhaust smell in car??
- No AC after ls6 mani swap
- Just did ls6 mani swap
- LS1 alternator weight Vs. Race unit?
- $300 for exhaust
- Anyone know the width of a LM7, valvecover to valvecover?
- BBK UDP kit questions
- Who ports ls6 intake manifolds?
- Aftermarket Valve covers for F body
- Shorty, mid, longtube headers
- Catch can routing check
- EGR vacuum line?
- EGR port opening
- Y with gutted cats
- Post your Custom Intake manifolds
- Car going dead and recently not running well????
- Headers on lowered car
