PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 [206] 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316
  1. what problems with headers?
  2. Dr. Gas X-pipe?
  3. Cut out issue
  4. WTF is wrong with my damn raptor shift lite!!!!
  5. thinking of cutouts
  6. anyone make a 'race' version EWP?
  7. What is your thought on...?
  8. Help me not get ripped off (getting a true dual put onto my SS)
  9. anyone running a Magnaflow Bullet muffler? or Borla XR1?
  10. slp loudmouth and header install?
  11. fast 90/90 issue on dyno.
  12. lsx intake???
  13. What is this part called?
  14. SLP daul dual, SLP 2otl.
  15. Hooker sound clips
  16. Magnaflow or Hooker?
  17. when installing longtubes should you put silicone on the gaskets tohold them in place
  18. 98-99 vs 00-02 air box
  19. flo pro vs dynomax bullets?
  20. What to make exhaust pipe gaskets with?
  21. Bermuda Triangle Found!!
  22. Exhaust tips change sound?
  23. How loud would this custom system be?
  24. Electric or Mechanical Gauges?
  25. Victor Jr. Fuel Injection Kit ???'s
  26. Do the QTP and Kooks 1 7/8" headers have the same total length?
  27. Damn EGR code!!!!
  28. How much was your NW 90MM TB?
  29. BBK vs. LS6 (Intake Manifold)
  30. TSP True Duals
  31. Pacesetters
  32. will cats throw off A/F ration??????
  33. Header, Y-Pipe question
  34. Manual Cutout Pull cord thing?
  35. Why do cutouts have to leak????
  36. Header question
  37. flowmaster,is it that bad??
  38. hooker or corsa
  39. bellow for LS6 MAF?
  40. People Who Have True Duals Does The Exhaust Smell Burn Your Eyes When Your In The Car
  41. underdrive pulley
  42. Borla I-Pipe Length
  43. school me on intakes for a ws6
  44. Headers, Xpipe, Mufflers?
  45. stock exhaust size, and what sounds better?
  46. Where to buy a 12" dynomax bullet muffler?
  47. Formula owners...post pics of your exhaust
  48. Who's running shift lights?
  49. Porting Stock TB
  50. will TSP ypipe clear aftermarket torque arm?
  51. Fast 90 question?
  52. 90mm TB gasket
  53. hooker aerochamber or 10 series single chamber flowmaster
  54. Gmmg owners future and present inside.
  55. GM Vented Oil Cap vs. Breather
  56. exhaust system questions
  57. Carburated 5.3L ?
  58. Should I make more intake changes??
  59. Qtps or Kooks on my 02 SS
  60. Can U Use 98-99' SLP Rad in 00' Car - Differences??
  61. need new exhaust
  62. ack - Spohn Engine Stands / Solid Mounts
  63. valve covers
  64. 160 Stat Question
  65. True Dual Photos
  66. Gmmg owners present and future inside.
  67. Need Tsp Dual Pics
  68. ahh exhaust change agian
  69. Too loud?
  70. Installed Hooker catback....
  71. Pics please of TD's
  72. GMMG or True Duals
  73. Kooks y with qtp headers
  74. Edelbrock Headers
  75. Stock TB won't bolt onto FAST 78mm
  76. Kooks vs Hookers
  77. Cant decide.
  78. Headers for my 02 SS
  79. SLP Performance Pacs
  80. High Flow cats
  81. My exhaust setup
  82. wierd squeal
  83. Why!!!
  84. Headers stuff
  85. what size hanger do i need???
  86. Advice needed Broken header bolt :(
  87. Slp headers....
  88. Water Pump
  89. Got done with exhaust install
  90. Edelbrock headers.
  91. MAF Question???????
  92. best fit on slammed z28???
  93. FAST 78MM intake install Qs, (searched but no info)??
  94. X-pipe oem fitting?
  95. everyone with true duals can you use dummy tips
  96. Pacesetter Y-pipe
  97. bad ignition coils?
  98. sweet thunder cat-back?
  99. true duals smoge legal??
  100. Throttle Body
  101. What can i do when i get LTs?
  102. which gasket is better???
  103. Stuck on manifold removal...heat shield?
  104. 1 3/4 vs 1 7/8 qtp longtubes please help
  105. Spark plug question for experienced tech.'s or racers please
  106. LS1/LS6 Exhaust flange
  107. Underdrive Pulley
  108. Headers on an 02 ss
  109. Intake
  110. Installed the Corsa today....feelings are mixed
  111. Opinions needed...
  112. ORY rattles against floor BAD
  113. GMPP Intake VS Edelbrok Victor JR (LS1)
  114. Coated or painted?
  115. Please check out this poll
  116. Anyone run a Borla XR1 with 4" Exhaust?
  117. QTEC owners inside.
  118. Take out stock exhaust without cutting?
  119. Kooks worth the money?
  120. LT vs MAC pics?
  121. Header Bolt Question?????
  122. Fast 78mm Questions???
  123. urethane motor mounts?
  124. Why does my alternator keep going out??????
  125. TSP Sweet Thunder X Duals (pics inside)
  126. attn: all of you who run 11 secomds and quicker 1/4 na?
  127. Exhaust ideas
  128. best bolt ons
  129. How to get motor to take water?
  130. Spark Plugs ??
  131. What's a breather filter?
  132. Should LT's and Catbacks be bought at the same time?
  133. ORY question
  134. lts , catted y , and rumbler. anyone runnin this?
  135. Why not port a ZO6 MAF?
  136. PIC's inside, Making my own tu-duals over the axle
  137. True Duals Kick ASS!
  138. Zo6 Maf Sensor On 02 T/a
  139. ASP Pulley ? Think it is seperating.
  140. Power Steering Pulley Replacement????
  141. Magnaflow won't fit Pacesetter ORY
  142. Who makes a 3" ORY for TTS LT's
  143. does year matter?
  144. opinions please on bullets mufflers
  145. Meziere or Evans Electric Water Pump
  146. y pipe
  147. QTP Anybody use a Diff. ory pipe then flow master
  148. Mac Midlengths & X pipe modification
  149. Header Install Question
  150. What does this connector go to?
  151. asp pulley
  152. borla plates
  153. x pipe,is there really a difference?
  154. Double Roller / ASP Pulley ?????????
  155. Exhaust & Headers
  156. GMMG or Borla
  157. 1 3/4 or 1 7/8 primaries for headers?
  158. LM vs Rumbler vs Flowmaster 80
  159. Differences in the design of the Smooth Bellows
  160. What else do you need to run true duals out the back? Were talking everything.
  161. How do heads change the ls1 exhaust note?
  162. removing stock header?
  163. Exhaust Hanger Question?
  164. Pacesetter Headers
  165. ? about SLP LS6 intake
  166. Where can I get a stock throttle body blade?
  167. Anyone else not notice much MPH gain with headers?
  168. True Dual install question
  169. Anyone try these headers?
  170. Egr
  171. electric cut out
  172. Is LT's, ORY, and Loudmouth too loud???
  173. Will my exhaust sound good without tips?
  174. Short belt mod!!!
  175. All guys with solid motor mounts, how bad will it shake?
  176. Whats the deal with runnig maf less
  177. torque setting
  178. ls6 motor swap! need PVC help! asap! please!!
  179. P0300 Ugh!
  180. Everyone with lanes true duals please check this out
  181. dumps or run the pipes out back
  182. cutout=the best
  183. Spark Plug Wires
  184. Just rebuilt the top of motor
  185. BorlaMouth Owners Please Comment!!
  186. FM13/AFR 205s/No Cats, Mufflex 3.5 Spintech --- LOUD as Sh*&
  187. removing asp pulley...
  188. Who has this setup: LT's,ORY, and Loudmouth?
  189. Inside the BBK SSI manifold
  190. I *$@#ed up
  191. ***Shift Light Wiring***
  192. looking for the stock appearing CME and fascia
  193. Big tube headers
  194. Plugs and Wires
  195. Newby ?? about Water Pump Pulley
  196. Is it worth a swap from Macs to long tubes?
  197. Interesting Question!!! Will dropping my exhaust and driving like thataffect my motor
  198. Short vid of my exhaust
  199. Ory
  200. Thinking of ditching the ever popular B&B tips..
  201. opinions, how to get out broken bolts
  202. Everyone with true duals please come inside
  203. stripped
  204. BBK throttle body blade replacement
  205. Ways to kill drone on a SLP LMII Cat-back
  206. true duals, exhaust ? using a spohn body mount t-arm
  207. Problem with Kooks 1 7/8 LT's on a Vette.
  208. Pacesetter Headers Failed
  209. Where to find titanium exhaust tubing?
  210. how long will they last?
  211. which one do you like the most with LTs, ORY
  212. Exhaust Noise Troubeshooting Suggestions...?
  213. Sound diff between 2.5 and 3"
  214. need help with tsp ory
  215. Arr these true duals and longtubes on ebay any good?is this a good company?
  216. Can anyone name what brand of longtubes these are please?
  217. Best Headers For My 02 T/a
  218. would there be any hp difference between 1-3/4 kooks and 1-3/4 qtp longtubes?
  219. New ZEX Plugs??? Anyone using them Good or bad
  220. Bassani exhaust using universal mufflers?
  221. Exhaust questions
  222. Stock wires...heat shields?
  223. high idle plz help
  224. Who makes a direct high flow cat replacement for LS1s
  225. New Alternator?
  226. 99 to 02 TB
  227. Those with unpainted FAST intakes-
  228. Pacesetter LT's (help)
  229. gutted cats, now using oil? WTF?
  230. seafoam??
  231. Autometer air fuel ratio gauge,will it work off of factory o2 sensor?
  232. Collector bolts...
  233. Please, in need of quick response ASP pulley I.D.?
  234. I can't get my Corsa tips straight...pics please
  235. 2.5" or 3" Y-pipe with LTs?
  236. Would like your opinion.
  237. if i keep my air but dont have cats will it hurt anything?
  238. Position Sensor
  239. LS6 intake install help needed ...
  240. Anyone make exhaust tips like this?
  241. cermic coating necessary?
  242. Stock Looking Catback
  243. Pacesetter header and ORY ground clearance
  244. what kind of pulleys 2 get?
  245. exhaust cut outs????
  246. ceramic coated headers
  247. Bad vibrations???
  248. synthetic oil
  249. crank pulley identification..
  250. Headers can't bolt up!!
