- Removing Oil dipstick for Headers
- will the sound be different
- Will porting my TB void my warranty?
- Nitrous header gaskets
- Interchanging LS1 Throttle Bodies?
- New bracket and pulley, still squeaking...
- 1 7/8" headers on a 346?
- Is a small header leak at the manifold a big deal ?
- !EGR and !AIR
- drill crank bolt to get puller on center?
- SLP lid fitment?
- Tested another Hooker Aerochamber.
- Finished my exhaust...wow.
- TSP Dual install question.
- At what point do cats become a major bottleneck?
- 7-0...for now, but need some advice..
- over axle bends
- Free Magnaflow...
- Help
- Cammin Beasts Throttle Bodys!
- Does the spark plug gap need to change as you build more power?
- Borlamouth Soundclips
- GMMG or DUALS?
- Help with Engine Temperature Please
- codes
- crank pulley problem
- White smoke on start up
- Header Questions...new guy
- help please! setting tdc on 97 tahoe?
- headers and cutout
- Pacesetter Longtubes
- exhaust question
- How can you tell if cats are clogged or bad?
- O2 Sims and MAC headers
- Need some info on headers.
- Wish I knew before hand!
- weird behavior after header install..
- Dynatech supermaxx headers
- How Do You TroubleShoot Starter and Solenoid?
- Key Fob Programming (Keyless Entry)...
- Dr. Gas side exit duals
- magnaflow race mufflers for duals?
- True Dual Help...
- Pics of Corsa tips on an SS
- F@*KING 02's and SLP extensions!!!!!
- Do i need o2 sims??
- thanks Lee at ASP pully.
- High flow cats on a H/C car
- TPIS Oval Tb and Intake?????????
- Cam+Corsa+LTs+ORY =
- will Ram Air lid fit Non ram air car?
- Exhuast Options
- hood shocks!!!!!!
- Best Budget Mods to get started
- looking for new ORY to fit QTP...
- Cut out question
- Questions on Longer crank pulley bolt
- Strange looking EGR pipe
- Hearder Install?
- I need a Ported T-Body
- exhaust fitting question
- LS6 intake on gto same as f-body??
- 1/4 mile gains with LT's/TD's
- Delete PS and AC
- SLP 85mm MAF vs. Granatelli 85mm MAF vs. Speed Density tune.
- Question about Tunning and TB
- Ture Dual Fixing
- Bolting a NW to the fast intake
- True duals with bmr xtreme torque arm
- Anyone use a V6 K-member w/ LS1?
- My Pacesetter LT's and ORY install experience..
- GMMG w/ or w/o cutout???
- sheet metal intake
- True duals over the axle out through a CME...
- What are good o2's to run.
- TR belt tensioner
- Installed Poly Motor Mounts
- Electric water pump myth?!?!?
- clunking noise!
- Cutouts
- how much rasp..?
- tsp y pipe
- which is better?? (pics)
- headers frm 98-99 fit 2000 + ls1 f-cars !!
- Port matching on FAST 90mm intake worth the trouble? What's involved?
- which is better (pics)
- what size is the resonator in the LM?
- bassani true duals?
- TSP Catted Y Pipe Q?
- Newbie spark plug question
- tq specs for the valve cover bolts?
- camaro LS1 A/C compressor
- Mystery LS6 manifold?
- asp pulley, now or later?
- ASP Pullies, 3 years old
- Magnaflo 4'' round 14419
- EGR fittings swap
- questions about cutouts.....
- PerformancePac™, 2000-02 F-Car "Loud Mouth™" Exhaust w/ 3.5" Slash Tips 350HP
- GMMG exhaust
- Hooker or TSP with LT's?
- I finally got my Pacesetter headers installed
- help! back of my ls6 intake.. )pics)
- Headers VS. Dipstick
- Water Wetter question................
- 100mm MAF for the LSx engine..............
- Wierd rattle!?
- Anyone block off PCV Tube using the AMW Can?
- curious?
- Strange, occasional stumble!?
- exhaust diameter
- O2 sensor Q
- Any Difference in X pipes??
- replacing ignition key cylinder
- urgent help
- msd ford wires for coil relocation?
- MTI or SLP Lid?
- LM and LM2 Questions
- catalytic converters
- Need instructions!!!
- What actually makes the sound....
- Air lid rubbing on hood?
- Can stock LS1 intake be ported?
- Whoever ordered TSP catted y-pipe enter
- Ftra
- What headers to get?
- gto vs fbody exhaust manifolds
- Just had bullet and Qtp cutout installed!!
- How to know if I have an exhaust leak at header?
- Help with Air Condition
- Need Help!!!!
- best plugs?
- ls1 power steering
- Any gains going from open cutouts to open headers?
- Need to be quieter...
- maf
- loudmouth with off road y pipe
- mods w/o voiding warranty?
- NX intake manifold?
- gettin magnaflow
- Big crank pulley problem. PLEASE HELP!!!!
- Need a catted Y for Flowtech headers
- pacesetterrs
- What do you think about this?
- What air lid do I get?
- IAC Valve Questions...
- 01 SS on a 98 T/A
- Where to get a flowmaster merge?
- U-bolted
- differences in 1998 and 2002 headers
- True Dual Exhaust System
- I'm mad, I need some help!
- Ticking Noise
- Need your help to make www.ls1sounds.com a better site
- pulley problem
- OK I dont wanna sound dumb but....
- Got a delivery last night :)
- Poping Noise In Exhaust!! Help !!
- asp pulley install
- coolant level sensor plug?
- Really stinks!
- Unistalled LS6 intake, installing FAST 90mm tomorow, have some questions.
- Lid power gains?
- low coolant light, but its full.
- Coolant Overflow
- I'm Scared.
- smooth bellow question?
- I hate my car.. ORY realated
- Anyone actually going to buy the MSD coils?
- QTP y-pipe finally fixed!!!
- If our TBs were rated by CFM.....
- MAF and IAS
- pinging and smoking?
- loudmouth 1 or loudmouth 2 or what???
- Aftermarket Bellows Pics
- mids vs. longtubes.....
- Do I have to replace BOTH O2's?
- 02 sims install
- are you guys really using that much torque?
- BMR track pak torque arm w/ true duals
- FAST LSX 90mm question
- 3,000 rpm noise from up front
- Rear seal..write up?
- Please help with 02 sensor......
- True duals size question.....
- PS fluid change - now looks like coffee?
- what airbox do i need?????
- 90mm tb on a LS6 manifold (not TPIS)
- PPC Headers... need Y-pipe
- how bad will a stock catback choke my car now
- How many oxygen sensors 01 Trans AM LS1
- Which Denso O2 sensor to get?
- Small Leak in Kooks LT's
- how many of you 10 and 11sec cars still have the stock crank pully on?
- cheapest place to get a muffler for my LM..
- Stock fan CFM?
- LSX 90 intake problems??????
- quick! is there a way to get that last passenger side coil pack bolt off?
- What kind of MAF?
- LS6 intake guys please HELP QUICK! In the middle of a swap!
- 6.0 stat fit 01 LS1
- SLP air box lid question
- What 85mm MAF w/90mm FAST intake & 90mm Nick Williams throttle body?
- Deleting egr????....
- Those w/85mm MAF and 90mm throttle body, what bellow?
- best exhaust: Loudmouth, Loudmouth 2 or the GMMG?
- Flowmaster 1-chambers or Sweet Thunders
- Flat copper braided wire from O2 harness
- How does a QTP Cutout work?
- Intake to match 80mm BBK?
- My Asp Pulley Is Coming Apart!!!
- Poly motor mounts driving me crazy..
- Changing spark plug question
- where to get longer crank bolt for install?
- how do i pull of my pully system
- Funny noise from exhaust after spark plug change (sound clip)
- Loud Exhaust
- does the throttle body need to be next to the intake?
- 160 Thermostat Q?
- AIR/EGR/Rear O2 Sensor Deletes?
- Covering the exhaust
- Which intake???????
- Another name for bullets
- Just installed slp long tubes and hooker catbalk system and slp cats
- What guages?
- New coolant level sensor problem
- FAST 90mm intake & Nick William TB on the way, upgrade lid & MAF or not?
- ThE NOISE IS GONE! FIXED! FINALLY!!!!! :) :) :)
- crank pulley keeps falling off the car(HELP)
- Raptor Shift Light question
- 25K miles and water pump needs replacing..
- Question for 2OTL owners or whoever knows
- X-Pipe VS. H-Pipe
- exhaust performance ?s
- ca header lt/shorty?
- a/c belt off = okay?
- Alternator WOT cut-off switch...
- exhaust ?
- Is the LS1 intake a wet design?
- Where do I get...?
- F.A.S.T. q's
- 160 Thermostat
- true duals or ory/cut-out/catback
- Idle
- tunnel brace
- Is there an Oil Pressure sensor on the LS Engine?
- first time to post
- Exhaust Question
