- will a tik get louder with headers?
- flowmaster "race" muffler - bullet
- longtube question.
- hex or 12 point for ls6 intake
- AIR delete, just need a little help.
- SLP Cold Air Intake
- Getting black specs on my bumper
- Would this fit?????
- Intake manifold question
- True duals with stock manifolds
- Throttle cable length?
- Broken return spring on tsp 95 mm tbody
- TSP SS Headers + Magnaflow
- Cat Replacement - Ran into a little problem
- Fast Intake expanding
- rockers issues
- Cleaning Intake??
- Recommended OEM size ORY
- Egr freeze plug
- RPM gauge drops and H/C car dies, any thoughts?
- Fel-Pro or GM Exhaust Gaskets?
- Just got my Texas Speed Headers
- Difference between these GM MLS head gaskets??
- How to not get rasp?
- high idle after intake swap
- Flowmaster Super 44 Single??????
- Need one runner for LS1/2/6 Fast 102 intake
- stock heads
- The horrible rasp
- Slp
- PCV help please!!!
- stupid me 80 series flowmaster
- lid or fipk
- header bolts
- Radiators Laid Flat????
- ls1-ls6 post install electrical problems need some help
- Question about catalytic converters I pulled off my car
- Want to upgrade to gm 5 wire maf, what vehicles are then in .
- Disconnect Battery when putting on SLP Lid?
- coolant crossover pipe bolt sizes
- kooks 1 7/8 kooks ory and magnaflow catback
- Texas Speed Catted Y-Pipe
- What's next
- fast fuel rails leaking
- Stock exhaust piping?
- Check out my new 4" exhaust
- cam degree quesiton (quick)
- truck alt relocation ?
- Cruise Control Cable
- engine
- LS1 1 7/8 header gasket?
- mods let them beggin
- New Flowmaster Muffler came in today
- coil packs mounted to strut tower brace
- FAST 102 Intake Install
- My new Headers/exhaust....Kooks stepped headers :)
- What diameter/length muffler for dump?
- exciter wire - 98 z28
- LS6 intake and PCV help!!
- Gauges
- Fatty Injectors on the 102 can be done!!!
- What intake is best for Ms4 cam
- Signs of an exhaust leak
- simple but urgent fuel line question.
- Lids?
- Installed CME exhuast, better tone and look!!
- 102mm TB, throttle cable problem
- spliced o2 wires? quick question
- Throttle body question
- Vic Jr intake help
- Lets see those chrs1313 HVAC ram air install 1/4 mile gains
- Stock ls6 manifold and tb limiting 1/4 e.t.'s?
- LT's installed but still another Y-pipe question. Also butt dyno data from LT's
- Passenger bank no firing
- Ram Air please help
- 98 Engine & Trans harness with a 2002 ecu?
- 101mm or 96mm TB? Time for a MAF?
- 2 step installation?
- timing twister car want start
- Benefit of running truck coils?
- Cat bypass???
- Too bad someone doesn't make an alternator/motor conversion
- Bigger ipipe? Benefits?
- No more O2 sensors
- LM1+ Longtubes+O/R Y SUCKS
- Any horsepower gains with thyphoon intake
- Another ORY with manifolds question?? just a little advice
- ***Best Resonator??***
- Longtube install, removed steering linkage...key stuck?
- Best/Accurate 85-90 MAF sensors?
- Stepped Long Tube Headers?
- wanting to do an LS6 intake..
- 98 LS1 stock bottomend
- H/C car combo
- Alternators
- Will Nick Williams 92mm throttle body fit my FAST 90mm manifold?
- Oil filter adapter?
- I need to find a good exhaust shop in stl area
- Engine Build
- Cheap Stepped Headers while supplies last
- tranny mount
- Which 85mm throttle body?
- any news on texas speed headers
- JBA Shorties to TSP Long Tubes
- Poly Motor Mount question
- help with pulleys
- How do you think this happened?
- Who's running a WS6 Lower box on a NON WS6 car?
- Duralast ls1 maf >????
- Throttle bracket on FAST Intake bolts/nuts help
- trying to decide what to with ls6 intake
- best bolt ons
- "New Exhaust Set Up With Vid"
- How to remove engine?
- Pacestetter headers
- MAP sensor wiring
- ctsv balancer?
- pacesetter longtube tip
- help please
- Fast intake install help!
- Just insyalled LT and ORY
- ebay valvecovers issue
- What the heck did i just find in my throttle body?
- New crank has long key installed
- Anyone ever add dual mufflers onto an LM1?
- I need some advice on an ory.
- Alternator question.
- Power steering question
- Whipplecharged LS6
- O2 Sensor position
- Quick help with a cut out please?
- LS1 airpump removal and catalytic converter function?
- Got my LT's in the mail. Got some dents in them. Added more pics.Update w/ more pics
- 90+ mm TB w/ 100 mm MAF Set ups...
- Muffler options/ideas
- Balancer to water pump alignment issue
- I need some assistance
- Anyone running DR GAS Freq Mod Muffler?
- Anybody have a frame mount torque arm and TSP true duals?
- My True Dual Exhaust 3" over the axle
- SLP LM install, somethings F'd up
- Intake swap question!
- 360rwhp possible?
- What Lid for 02 w/o AIR
- What's Next?
- AIR Delete
- Mangaflow tips
- Funny o2 Sensor Issue
- 404 stroker w/ 76mm front mount which intake?
- Relocate my battery? Yes or no
- heads
- G5x3
- Mission to reduce/eliminate rasp!!
- moding valve covers?
- Random Tech Catback?
- Loosing Vaccum when Brakes applied.
- Any word on TSP Headers?
- Fast 102 intake question(egr and map)
- Which Magnaflow muffler?
- Will I need different coupler from TB-MAF with my new Fast 90 TB?
- help me decide.tired of thinking!
- MS4 Cam Help
- Best Bolt-on's
- Koolsox Question
- Lower Air box - is there a difference between regular and Ram-Air?
- High flow cats (Strange)
- Catback with best compromise of quiet cruising but loud at WOT?
- FINALLY fired motor eps/TSP2.5
- Clear lid melted and warped
- New exhaust
- L33 Knock Sensors With E40 ECM
- What is this?
- Guess 1/4 et/mph gain with added fast 90/90
- alternator where AC goes?
- any good exhaust shops by the stl area?
- Little Upset w/ Corsa
- Does anyone make an egr block off for truck manifolds?
- maf sensors
- LS1 flexplate?
- Best heads for RAPTOR Cam RAPtr Cam
- What screw on LS2 MAP sensor do I get for an LS3 intake?
- New tsp y-pipe
- where to buy ls6 intake manifold
- can a bad coil destroy an ECM?
- Spark plug on #2 cylinder not wanting to thread
- direct drop in ??
- American Racing Headers/Y w/tunnel brace tq arm -- anyone have this?
- got my throttle body today
- how do i remove AIR from 02 ws6
- need the idler pulley bolt size
- 02 ws6 lid- air hose plug
- Mast 275 Cathedral port exhaust port?????
- How much power am I leaving on the table? 1 5/8 Headers to 1 3/4's
- texas speed headers
- Thought or Recs???
- ls6 or tpis ls6 intake
- Calling those with dumped Y pipes
- got some questions about longtube instal
- check engine light on cat delete help!!!!
- Mass Air Sensor
- Im looking for tim aka (408trans_am)
- Just got a new fast 102/102 setup but I have questions
- 427 with 1 Probelm...wont start HELP!
- o2 sensor question
- new header questions
- Katech's new VISION, LOGO, and 100-PAGE WEBSITE + secrets revealed!
- Do these headers look to be in good condition?
- race header
- trying to figure out an alternator issue...random voltage drops
- Issues with it being hard to turn right or left after header install
- Questions on QTP E-cutout install...
- QTP headers 1 7/8th?
- average price to be paid from recycling place for stock cats?
- best throttle body mass air combintion for ls6 intake?
- Quick cutout question
- Header bolts
- electric cutout question
- LS2 to LS1 head/cam question
- New to LS putting the rest of the motor together
- 2002 Trans Am ws6 WANTING 400+ rwhp
- How do i get this clamp off?
- Starter bendix occasionally hits new flexplate/flywheel
- my 2000 camaro SS build
- header questions for my 408
- What 92mm throttle body for fast 102
- Help with y pipe
- is my block trashed??? see pics :( HELP
- K&n FIPK Precharger
- Converting to new style MAF
- Future upgrades-any imput
- Weekend project:Kooks longtubes,ORY and Magnaflow ,LS6 intake
- Modded thermostat anyone?
- calling all north carolinians
- oil pressure switch question
- LS1 Heads/Intake on a LQ9
- Ls1 spark plug leads
- 6 codes no matter what i change, bad computer?
- Valve covers that will work with shaft mount rockers???
- Great deals new on Edelbrock Victor Jr / MSD 6010
- Starting to mod
- Thinking of ditching ory for cats
- New P/P TB, P0507, Idle problems
- 2" or 1.75" Primaries???
- 2001 SS. 425 HP goal...help.
- Mufflex 4" cat-back
- Gains with fast 90 and 90 throttle body over ls6?
- lg tube or shorty?
- pulley?
- what coils do i need?
- :::sigh::: question about egr LTs =\
