- SLP radiator
- Another NW TB up and running!
- Power Steering Leak
- pulley is chipped...can i use it
- Is Running without a catback ok?
- pulleys
- AC Delete
- 90mm intake?
- MTI lid
- asp: belt size vette vs. fbod, same??
- Stock exhaust removel
- SLP LT Headers question...
- Is a cutout worth it?
- Anyone have any write ups/pictures of removing A/C?
- Filing an insurance claim?
- Guys with LTs and ORY and hooker cat back, come in!
- egr/air
- how are you guys running open headers?
- Dyno Tune?
- Nasty Performance valve cover pics
- Replacing flowmaster with magnaflow
- Headers and tuning
- Torque specs on LSX intake?
- Where can i get bolts?
- need to block off egr on "slp" ls6 intake
- LS6 + dremel tool
- HELP! My 180* stat won't fit, my stock one comes out of its housing?!?!?!
- Dyno test with Hooker Aerochamber
- A.I.R. Delete (yes, I searched)...
- AIR tubes?
- Headers and ORY w/ Loudmouth..Bad Idea?
- 90mm TB Bellows Option - Using Metal Exp./Flex 4" duct from Home Depot
- Nick Williams 90MM TB on and running smoothly!!!
- Headers or no headers
- Rapid Motorsports will be Offering NW 90mm TB's
- can you place a cutout on the driver side?
- Borlamouth : Round or oval xr-1?
- Throttlebodies?
- White Smoke
- exhaust problem
- which headers?
- LS6 valley cover - what is the difference?
- LS1 motor mounts
- will splicing the crank pos sensor wire give a false reading
- My car is kicking my ass...
- question on true duals?
- 01-02 headers on a 98-00 car???
- 85mm MAF to stock lid?
- FAST 90mm & TPIS 90mm TBs *PICS*
- LS6 intake
- Dynatech Supermaxx headers- discontiued ?
- Descreanig the MAF
- Flames coming out of my tailpipes
- DYNO results LS1,LS2,LS6, FAST intakes and TBs
- Loudmouth 2
- Who makes a 1 7/8" Fbody Header
- is this TB worth it?
- Help, running horrible
- Pacesetter LT's Pic's
- Aftermarket water temp sender placement?
- locating tach wire.
- QTP Electric Cutout Rebuild ...
- Dual Mccord install locations
- Need help, fuse box
- fastest car here
- muffler
- Drivers side fuse box!
- 2otl questions???
- wow.....love my new sound!
- Engine Fuseblock Question - What's Hot Key-On??
- Open Headers?
- LS1 Edelbrock TB's
- Help with Exhaust Choice...
- Paint my aluminized ORY pipe?
- If Your FAST TB Sticks, Come Inside
- Mufflex 4" exhaust or TD's
- FAST 90mm TB - *Fix Pics* Voodoo semi completed.
- Headers
- FAST 90mm and NW 90mm TB Arrived!
- Mufflers: bullets vs sweet thunders vs xr1
- Idle problem
- closest elbow on passenger valve cover
- A/C delet questions
- header question
- Need new lid.
- 85 mm lid/MAF on 90 mm LSX 346
- Nick Williams 90mm TB arrived today!!!
- Which cats for Mac ORY?
- My LS1 sounds like a ricer. HELP!!
- Took off the Mufflex/Spintech 4" and put on Bassani Duals (out the back)
- Which 18in. sweet chamber muffler with duals?
- Exhaust Install
- Replacement cats for FLP LT headers
- Nick Williams 90mm TB's
- What is the best electronic cutout?
- Tr6
- Need some advice...
- Do You Liek Your True Duals?
- Getting hookers installed TODAY (i hope)
- part number # magnaflow carsound cats
- Header Gaskets
- LS6 Intake vs. Z06 Intake
- SuperMaxx Diameter Question
- Those of you with a Hooker catback come in!
- Best 90mm TB FAST or TPIS
- Where to get bellows for 85mm MAF to 90mm Fast Throttle body?
- So what do I need ???
- How loud would Longtubes w/TD's be compared to a Longtubes ORY w/ cut-out...
- LS6 intake install
- Best place to buy Kook or OTP headers!
- headers
- Is this normal.. header question
- Borla Exhaust plate
- exhaust manifold question
- pugs and wires
- Intake leak or Maf?
- ticking sound on acceleration after LT's installed?
- Post header install blues...lend me your brains!
- FAST Intake???
- Tach install
- my cool new exhaust
- EGR VS. NO EGR...Wat are the Pros and Cons?
- how to remove washer fluid reservoir?
- Help!! Rattle!!!
- dual setup?
- Noob Belt Questions
- which pulley for a cammed auto? which lsx intake?
- Loudmouth vs loudmouth 2
- Driving 3000 + miles
- coolant temp sensor
- WTF! cooling problem
- March Pulley
- header installation questions
- exhaust help
- Alternator pigtail, 99 Formula
- Pacesetter Y-Pipe
- Edelbrock carb manifold?
- Which Headers
- HELP!headers..no egr fitting...wat do i do?
- problem with qtp cutout???
- FI ....Stock Exhaust manifolds?
- Truck Coils
- which headers?
- LS1 mods....with warranty?
- is this worth while??
- Oil temp gauge - where to get sending unit?
- Tsp Y-pipe Question
- tsp y-pipe/elec cutouts
- dynatech headers?
- QTP's are in
- NO Air through front vents
- LT Header Install....??
- need help.. how to get rusted pipes unconnected?
- New LS1 guy.....
- Ok, I have a question and need an answer...
- Polishing my TB
- Question about ngk tr55 sparkplugs
- Meziere Street Version Pump with no Thermostat?
- QTP catted Y pipe
- 60000mle 5.3 coils or 26000mile 5.3 coils?
- belt issue with asp pulley....
- 02 sensors
- Jet Hot LT's & TSP Dual Setup?
- Cheap exhaust mod -- no muffler?
- Stepped?
- "Mother of All Bolt-Ons Swap" driving impressions...
- FAST Intake/TB
- Just Changed my Fuel Filter!
- got the flowpro on
- smoking exhaust
- Which would sound better?
- Dual Dual's with FLP headers??
- Daily-driver guys, has your Jet Hot coating held up on your headers?
- SLP's offering a new style "Dual/Dual" catback....
- What headers whould I choose?
- Raven Exhaust
- Jet Hot Warranty Question
- Keyless Entry Problem
- Bought used electric cutout, need assistance with the toggle
- When Cold, engine sputters ...
- What Catalytic Converter Does Kooks Use?
- SES Light + High Fans on Full Time = ???
- Spark Plugs
- Gains from ported LS6 intake?
- Pacesetter LT / TSP ORY install
- TB question
- hooker or flowmaster
- Dual cutouts vs. single cutout on OFY
- Mac header mod pics please??
- Just finished my exhaust setup and I am very happy
- cut out?
- Shaner S3 Rocks!!!
- Anyone with Dyntech headers...opinions?
- Who has gone Cat-Less with the exhaust?
- Kooks/GMMG or Hooker/Magnaflow
- Issues with QTP catted Y and SLP SFC's?
- post true dual pics
- Throttle Bodies by years?
- Gasket for FAST....GM, FAST, or Felpro?
- N/A high 10s-low 11s plug gap?
- Stock gasket with new slp headers?
- borla or loudmouth
- Loudmouth hiss?
- wtf is this?!?! do i need it?! help!
- FLP V clamps
- Oil Pan Questions
- WOT Issues
- pacesetter install Q's
- dynomouth w/ carsound cats??
- SLP 85mm MAF caution
- Know Of An Out Of Sight Catch Can?
- Idle problem after plug change, Drives great though.
- Tax money mods:)
- Whats Louder
- QTP Stainless Cutouts
- add 2 mufflers to a rumbler/LM?
- LS1 Air Pump and EGR valve
- why ory or cats?
- Stock LS1 Intake's
- Hooker Headers Blocked off plates
- anyone have LS6 MAF w/ 75mm lid
- Shop installation question
- Race headers
- Restricted Intake Motorsport Conundrum...
- Cut-out cap blow off! Where can I get another one???
- Mac Y-pipe Prob!!!
- Supercharger Sound From Air Lid
- FLP headers and cats/ TSP's x-pipe
- cut out
- Exhaust Leak!
- dumb question: port exhaust manifold?
- Full exhaust at home
- Stainless bolt kits junk or not?
- Gates Belts
- getting ready to weld on the new exhaust!
- SLP Exhaust Question
- Sound clip of my duals
- Qtec electric cut outs
- ahhhh! help me with this rattle!
- First drive: Fast 90/90 - Hmm.
- Cats for my ory???
- FLP headers to True Duals
- ASP UD Pulley Question
- Corvette exhaust on a Camaro.... can it work?
- QTPs Installed
- going to install long tubes need a bit of advice
- Stupid Question , but I got to know
- What do I need with headers?
- Weight reduction?
- electric cutout wiring - accessible power?
