View Full Version : Generation III External Engine
  1. Which Alt Bracket
  2. 90mm install pics
  3. How do I bypass the power steering pump?
  4. newb w/ pacesetter question
  5. magnaflow i-pipe
  6. Question about Holley alum. intake manifold
  7. A couple of questions about y-pipes & loudmouths.
  8. New parts!!!!
  9. just finished header install
  10. 02 sensors stuck??
  11. Coil Pack relocation.....
  12. ORY problem
  13. Ignition wires
  14. Hey guys, need help with Header Collector Gaskets......
  15. suggestions, black smoke
  16. 02 sensor problems...
  17. quality of pacesetter vs mac
  18. Wholesale manifold gaskets and bolts?
  19. Anyone running sheet metal valve covers???
  20. video:macs, ory w/dual cutouts
  21. hooker LT
  22. ls1 electric h20 pump
  23. which LT's have the best ground clearance?
  24. Help >!
  25. Who makes the best dry cell battery
  26. Part # help...
  27. Borla Swap??
  28. HP/TQ gain?
  29. True dual exhaust setups?
  30. please help...ac problems
  31. Extending O2 Sensors
  32. Repairing a drilled TB
  33. Muffler?
  34. Header/ypipe question
  35. exhaust help
  36. Exhaust Pipe Fell Off!
  37. Can't get Damn Y-Pipe off!!!
  38. Optima Red Top Battery - doesn't fit :( ! Help !
  39. Why don't people fab up their own Dual systems?
  40. slp headers
  41. ?
  42. throttle body disassembly
  43. header install
  44. do they make oil filter relocation kits for LS1's?
  45. Need an exhaust change...unhappy
  46. important exhaust question
  47. squealing belt
  48. which headers to go with?
  49. In need of solid motor mounts for ls1
  50. hooker cat-back?
  51. Help! header install
  52. which TB with FAST 90mm LSX intake?
  53. what else for header install?
  54. Hedman
  55. EGR Removal
  56. Fast 90mm Intake ports?
  57. QTEC cutout on stock manifolds?
  58. ws6 hood baffles
  59. Offroad Y-pipe
  60. Thrown Codes after Header Install
  61. TB Porting
  62. New LS1 Owner Needs Help...
  63. SEARCH DID NOT WORK!! dynomouth vs. duels
  64. Discolered intake runner? Help
  65. LS1 Waterpump drawing for a Dyno????
  66. HELP A/F after dyno
  67. Which TD setup?
  68. New sound same car!
  69. LT's...HP/TQ Difference
  70. anyone do this?
  71. MAF? and REV limiter?
  72. Where to buy band clamps?
  73. Need Feedback On Dynomax Super Turbo Mufflers
  74. QTP headers install ??
  75. MAC or KOOKS ground clearance?
  76. Help Please!!!!!!!
  77. Has anyone with QTP longtubes lower thier car?
  78. Ordered TSP true dual's how much HP??
  79. Stripped header thread
  80. Do You Pass Emissions Or Not?
  81. horsepower question?
  82. gaskets
  83. Looking for feedback on the Dynatech SupperMaxx Header setup
  84. Difference between Camaro and Vette O2 sensors?
  85. True Dual question
  86. Meziere Water pump LS6 - Meziere WP319
  87. why pay $700 for GMMG...
  88. Fast 90 Vs TPIS oval 90 LS6
  89. O2 sensors/wires (possibly burnt wires?).......can i do this?
  90. Can an LS6 intake install cause pinging/knock?
  91. alternator only problem solved
  92. Source for bolt sizes for 6.0L and Ls1
  93. Throttle body blade air bleed hole size
  94. Ignition or Starter?
  95. Kook header gains over all others?
  96. Low Oil Pressure???Help!!!
  97. Can you get Mac's without emissions fittings?
  98. Spark Plugs/Gap
  99. Question about AIR system
  100. Caddillac CTSV intake manifold
  101. water temp gauge WTF threadsare these!
  102. true dual
  103. FIPK- I was just thinking...
  104. Battery power drops after Pulley ?
  105. GM Weatherpack Connectors
  106. ? about Jet Hot headers and Flowtech headers
  107. 90 mmTB confusion
  108. Flowtech LT's GO OR NO GO?!?!?
  109. alternator only
  110. O2 Extenders for Pacesetter LT's
  111. aftermarket coils
  112. Can you tell me what this is?
  113. headers on a blackbird
  114. Please help: what happened to my oil drain plug?
  115. quick electric cutout question
  116. GMMG install question
  117. why 90mm TB when 85mm MAF?
  118. Header clearance question...
  119. diameter of stock I pipe
  120. SLP CME, how well does it flow?
  121. alright I absolutely GIVE UP - HISSING
  122. Help, quick question
  123. vacuum schematic
  124. ATS 'Pitbull' Cat back
  125. Water Pump
  126. Removal of PCV piece on valvecover
  127. check valves, where are they located?
  128. Borla Stingers: How loud are they?
  129. CAI vs Factory Ram Air, or both?
  130. High flow y-pipe..
  131. header help!!
  132. Best Priced Kooks Headers
  133. TSP come in
  134. will slp loudmouth, made for a 98ta fit a 02z28?
  135. Random Tech Catback
  136. NGK TR55 gaps???
  137. Just purchased a ported throttle body. Is there a adjustment on the sensor to make?
  138. Corsa
  139. AC condensor tube?
  140. whats the best spark plugs?
  141. LSX 78mm info? any new solid gains?
  142. what are all the bolt-ons???
  143. Another Weiand vs. LS6 Intake Thread
  144. Neighbor wrecked his 5.3l tahoe and will let me have engine parts.What should I take?
  145. what year did vettes get the ls6 intake?
  146. Building custom FIPK for 85mm maf???
  147. EGR/AIR delete, how to?
  148. A.I.R question
  149. Exhaust sounding abnormal
  150. B&B Triflow Question (yes i searched)
  151. Battery Connection Questions
  152. LQ4 80mm Throttle body swap to F-Body?
  153. Flowtech LT's and y-pipe?
  154. LS1 to LS6 Manifold
  155. new cats or y-pipe?
  156. Part Number Help???
  157. TB drill mod on stock application?
  158. keep current or use lid
  159. Lower box??
  160. which intake lid do i have??????????
  161. Dyno..............?
  162. Sweet thunder, bullet, or flowmaster single muff on the end of my ofy pipe?
  163. Pacesetter ground clearance
  164. Slp Hi Flow Cats Legal In Ca????
  165. ASP Pulley replacement belts - new vs. old
  166. Flowmaster Question
  167. I need some input on borla xr1 users
  168. LT's & ORY and Eibach Sportline Lowering? Issue?
  169. Any word yet on the Edelbrock headers with the new Ti-tech coating?
  170. MTI billet TBs any problems
  171. Magnaflow Exhaust
  172. Coil Bracket removal
  173. GMMG Chambered Exhaust
  174. Show me pics of your Mufflex single exit "hideaway" exhaust....
  175. Will high flow cats add power to my exisiting set up??
  176. High pitch squeak
  177. Changing plugs wires
  178. ASP pulley question? Need both or 1?
  179. Right headers?
  180. Interesting pics: Some Aussie CAIs I found while surfing around.
  181. serpentine belt
  182. anyone gone from true duals to a good Y-pipe setup?
  183. Rear Main Seal Replacement
  184. Duals with MACs
  185. what muffler can I get just to replace the stock muffler and be as quiet as stock?
  186. Pipe material.......?
  187. Just about to get a tune, can I add a pulley later?
  188. washed motor, now wont start!
  189. Air lid broke, how much hp loss?
  190. Keep A/C or chuck it??
  191. Valve cover??
  192. Guys with just extensions off of their collectors inside please....
  193. Vaccum Hose from Brake Booster?
  194. how much hp loss?
  195. How is this list of parts that I bought today?
  196. AIR removal????
  197. serpentine belt size
  198. idler pulley
  199. How big to drill TB
  200. Why don't my fans turn on?
  201. is it worth it to upgrade ignition?
  202. Question on a SLP ported throttle body? Info please
  203. Destroyed my Header
  204. !o2's or o2 sims for the rear?
  205. Lsx Vs. Ls6??
  206. pics of my 90mm LSX and TPIS setup
  207. info on oxygen sensors
  208. F'n SLP LT's ...install question
  209. Will this work?
  210. My 98 SS exhuast...
  211. Magnaflow and cat
  212. 85mm Throttle Body
  213. are ARP head studs easier on the block
  214. ASP UD Pulley Install - Slight Vibration
  215. heating pully
  216. Has anyone NOT had a problem with their FAST 90mm TB?
  217. What else should I get w/ Fast 90 mm Intake?
  218. TB Fast 90mm or TPIS 90mm?
  219. Bellows for 90mm TB ?
  220. BOlt ons before cam and headers
  221. Quick question about air intake systems
  222. Intake Swap Problem C5. Help please...
  223. any1 use the ARP pulley bolt???
  224. what kind of gains?
  225. What all is needed for a true dual setup?
  226. side exit exaust pics
  227. Fans and spark plugs!
  228. Need help with hanger locations
  229. Sound Clip of my car with the Spintech Muffler
  230. Fast Toys Ram Air (FTRA) Review
  231. Pacesetter ORY review/install
  232. Exhaust wrap on uncoated headers
  233. Which exhaust: TD's or Mufflex?
  234. ls6 intake question
  235. Need help
  236. Borla Mouth
  237. The Ultimate short belt setup?
  238. Extra Mufflers
  239. Need Some Help with Exhaust! FAST!
  240. pasesetter
  241. 90mm LSX worth any hp on 346 h/c car
  242. Kooks vs. QTP Headers
  243. Cold Air Intake Piping Size
  244. Headers and Cut-out
  245. True Duals And Magnaflows
  246. Headers Wrap..Thermal..HELP!!!!
  247. intake manifold and throttle body
  248. Hooker Aerochamber is on
  249. SLP ported throttle body
  250. Old K&N vs New K&N
