- How big to drill TB
- Why don't my fans turn on?
- is it worth it to upgrade ignition?
- Question on a SLP ported throttle body? Info please
- Destroyed my Header
- !o2's or o2 sims for the rear?
- Lsx Vs. Ls6??
- pics of my 90mm LSX and TPIS setup
- info on oxygen sensors
- F'n SLP LT's ...install question
- Will this work?
- My 98 SS exhuast...
- Magnaflow and cat
- 85mm Throttle Body
- are ARP head studs easier on the block
- ASP UD Pulley Install - Slight Vibration
- heating pully
- Has anyone NOT had a problem with their FAST 90mm TB?
- What else should I get w/ Fast 90 mm Intake?
- TB Fast 90mm or TPIS 90mm?
- Bellows for 90mm TB ?
- BOlt ons before cam and headers
- Quick question about air intake systems
- Intake Swap Problem C5. Help please...
- any1 use the ARP pulley bolt???
- what kind of gains?
- What all is needed for a true dual setup?
- side exit exaust pics
- Fans and spark plugs!
- Need help with hanger locations
- Sound Clip of my car with the Spintech Muffler
- Fast Toys Ram Air (FTRA) Review
- Pacesetter ORY review/install
- Exhaust wrap on uncoated headers
- Which exhaust: TD's or Mufflex?
- ls6 intake question
- Need help
- Borla Mouth
- The Ultimate short belt setup?
- Extra Mufflers
- Need Some Help with Exhaust! FAST!
- pasesetter
- 90mm LSX worth any hp on 346 h/c car
- Kooks vs. QTP Headers
- Cold Air Intake Piping Size
- Headers and Cut-out
- True Duals And Magnaflows
- Headers Wrap..Thermal..HELP!!!!
- intake manifold and throttle body
- Hooker Aerochamber is on
- SLP ported throttle body
- Old K&N vs New K&N
- ASP Pulley Install Questions
- MAF question??
- Please help me out. What is the diameter of the stock throttle body blade hole?
- Want to see some Pics of Tips...
- Open headers
- squeeling noise
- motor mount install
- TSP LS6 Intake Manifold?
- Prothane Polyurethane Motor Mounts
- Reducers
- ECM panel installed
- Sweet Thunder PICS
- LS2 intake as good as LSX 90mm?
- swapping corsa cat back for Hooker
- any1 using the ati super damper??
- true dual pictures?
- Duals Sound
- Headers...Should I stay w/egr & air or not?
- How to make a manual fan switch?
- Lid for an 85mm MAF?
- Installed FAST 90 TPIS 90 Tbody...got problems
- Stainless Steel Exhuast Cutouts Bling Bling
- K&N cai... slp lid doesn't fit with tnt kit
- Cat backs and sport appearance package
- Smooth Bellows....Need?
- Resonance / Drone - modifying tubing.
- pulley question
- Fbody Vs C5 oiling system
- Metallic "Ting" with very cold starts....?
- need help--car wont start
- true dual exhaust hanger?
- GMMG exhaust rattle due to hangar
- Speed Inc. "no name" SFI underdrive pulley
- Jet Hot vs Pacesetter LT's
- TSP exhaust
- BIG PROBLEM! Car won't start...need help!
- Which longtube header?
- Kooks vs QTP - ground clearance
- Which SLP is it?
- 78mm FAST vs. LS6 Intake
- has anyone used Bosch spark plugs. Gap ?
- Shorties and CAT Y-pipes?
- sweet thunder question
- What intake manifold for my H/C setup on a C5? LS6, LS2, LSX 78 vs 90mm?
- am I Just Being vain? (exhaust related)
- Need LT's and y-pipe suggestions!
- Different set-up--I think
- who sells underdrive pullies with the alt pulley?
- Aftermarket radiator?
- What is the diameter of the stock ls1 TB blade hole?
- neone running duals off mac mids.. how are u doing it?
- Cut-outs=Dual Exhaust?
- Dumb Question about band clamps
- Question about stock Y-pipe on 99'
- Driver Side header wont come off (hooker long tubes)
- FTRA SLP Ram Air Upgrade Kit?
- How many mm is a stock and a ported tb?
- The final exhaust set up...
- Kook 1 7/8 to 2 in stepped fitment
- Short Belt ??????
- Theory on Intake heat soak!
- Rumbler X with Flowtech LT's
- Is there a way to connect rubber line to metal?
- New C5
- Another Header Question
- SSI-SERIES INTAKE MANIFOLD bbk
- question about 90mm intake
- ceramic coated headers
- Catouts man they are pain in the ass !
- Removing ASP Pulley, What tool and bolt length?
- my y-pipe is knocking
- Oval exhaust tips
- Cammed...Do I need a TB???
- how far back do true duals go?
- B&B Tips
- pacesetter headers???
- mods in the sig.. pulley or what else next?
- arp harmonic balancer torque spec???
- borla CB, kooks headers/ory sound clips???
- How many tr. dual f-body car owners have been pulled over because of your ex systems?
- Engine noise, metal on metal, sound clip inside
- Fast LSX runner length
- What is a used stock ls1 air box worth.
- What mods now??
- MAF thread. Do you have a MAF? Ask them here.
- Easy way to tell if cats are history?
- FLP headers - Cats blown???
- Anyone have the new Edelbrock headers
- Intake Manifold : Vacuum Outlet Location
- need some advice, kinda tricky
- Oil pressure going crazy!!!!!!
- true dual 3" or dual 3" into single 4"... which one? Quietest best flowing muffler?
- Is the extra money worth it?
- quietest muffler on the market but low restriction too?? best electric cutout??
- Does GMMG have a web site?
- Oil pan pickup tube distance from base of pan?
- FloTech Headers? Y-Pipe??
- Need some "been there, done that" advice!
- 02 sims?
- Stock TB C5
- underdrive pulleys...
- LS6 intake questions?
- Best Exhaust
- Who runs or has run the ZO6 Maf? Come in!
- Banging issue with MACs
- Went from SLP to Kooks
- Kooks Headers Have Arrived!
- ? about my Cut-Out
- Why does a new cat-back system get quieter after a week or so???
- true dual in-car video
- intake manifold questions
- Pulley for 6.0
- Question for people with Kook's and GMMG...
- straight vs xpipe
- New Tr55's What to gap???
- Latest on QTP Y-pipes??
- jethot lt clearance ?
- triing to decide about a pulley
- Longtube Horsepower
- Headers, untuned, make you run richer?
- Cheap mod question
- What would you do with $700?
- Pacesetter Headers, where and how much?
- O2 rear bungs
- Do front 02 sensors go out often when you have long tubes?
- Y-Pipe Problem
- H/C guys! What MAF are you running?
- having my TD's installed today
- Power Difference - Dumped Duals and Out the Back Duals
- TSP true dual people, i need help!
- Tensioner Pulley
- pulley help please!
- Custom cat-back ?
- Source for OEM Bolts/Nuts
- Help Please!!!!!!!!!!
- odd smell
- Am I hitting the rev limiter
- can I weld a 1 chamber flowmaster in the I pipe for a cutout?
- Considering Gutting Cats... Opinions Please
- Car starts then stalls on a cold start!!
- ARP Header Studs
- Can we rebuild our water pumps?
- QTEC cutouts
- What size dual exhaust for 440HP motor?
- What holds heat better?
- starter engaging when battery is hooked up?
- Help Please
- serpentine and cold weather
- Part #'s for you true dual guys
- Kooks Headers......good and bad?
- Stock catback???
- Shift Light Question.
- LS6 Intakes
- Any one with a 2OTL catback
- Any idea whereto get 3.5" exhaust pipe?
- Best Headers Around
- broke sensor what sensor is this?
- B&B Performance Exhaust Systems?
- MAF sizes...
- Free Mods...I Know I know
- Pully help????????????
- Ported TB - who's is best?
- I LOVE my MAC's ... anybody who doesn't?
- ASP web sight Address???
- Sweet Thunder Guys Come in
- getting rid of headers....
- C5 TAC Module Pinouts for ETC
- Wheres the best place to get new O2's from?
- Put the Jet-Hot LT's in!!
- getting duals soon...
- True dual guys.......
- Hooker catback
- Finally got the GMMG
- Stupid newbie question
- SAMCO Silicone Hose Kits for LS1 F/B, T/A, Camaro, Vette Still Available Here
- Kooks catted y-pipe with Borla
- What does your March pulley look like?
- ngk problem
- Does This Price Sound Okay?
- 3 inch exhaust too big?
- what intake will best fit my setup.. i am on stock intake!
- Kook's SS Vs. Kook's
- Pipe Air flow chart needed
- Do I need o2 extentions for mac mids
- TSP with mac mids headers?
- corvette borla stinger exhaust
- jet-hot "Y"???
- Edelbrock TES exhaust
- mufflex & cutout ?
- big cube cut out question
- Loudmouth with Sweet Thunder
- Getting ready for Header Install...
- Interesting Sight as I came home from school...
- Quick coolant question
- Brisk plug info PTII!!!
- Intake comparison
- LS6 intake swap Q's.
