- TSP Dual owners what TA are you using??
- Pacesetter+ORY ripping off on curbs/etc. got any ideas?? Need help asap
- FRC's causing fuel flow trouble with ignition?
- need help asap with a/c removal..
- dissapointed with my new exhaust setup!!
- EGR hookup
- TB bypass
- Cold air mod questions
- plug for EGR?
- Dual Cutouts Question
- TSP Duals+torque arms?
- Is it possible to have "quiet" true duals/X?
- Holley/Weiand intake users, inside please......
- Would this work?
- Throttle body adapter
- K-member removal write up.
- magnaflow only flowing out one tip
- IAT and MAF 2001 camaro z28
- header install
- LS6 intake & nice gains
- Mass air flow sensor ????
- Question regarding A/C dryer.
- Broke 2 header bolts...advice needed
- Jet-Hot header problems
- [Yet another] ASP pulley install story
- Anyone with a CORSA cat-back
- backfiring???
- 02 simulators
- 1995 Pontiac Sunfire timing marks???
- Sound clip
- Flowmouth?
- polyurethane motor mount source?
- bad tsp x clearance
- Flp
- SLP vs Spohn vs BMR
- TSP True Duals... Drone? Clearance?
- Misfire Still
- side exit exhaust?
- Dynatech, QTP, FLP any issues or feedback
- Borla question???
- My new exhaust is on!!!
- AZ Power & sound / Pro Dyno true duals OVER axle (PICS)
- Rear 02 sensors
- Opinions on either one of these exhaust systems
- Which x-pipe position gives the most tsp dual clearance?
- MAF Screened or Unscreened
- Do it yourself header kit
- Advice on Spark Plug Heat Range
- FTRA question
- Bullet Mufflers
- EWP race version !!
- Where to find flow data on High Flow Cats?
- opinions wanted for upcoming setup
- Electrical Problem (Maybe Alternator?)
- stripped thread in head
- 1999 TA header installation...02 extensions
- now part of the infamous club...
- 2.5" into 3" cat
- Postup some 90mm Fast results please
- Ported stock TB to an MTI 75mm TB
- NGK TR55 - V Power or Irridium?
- TSP true duals
- TSC/ASR Cruise Module behind battery
- 02 sensors/extensions/simulators?
- Slp Maf Question !!!
- Has anyone tried the new Hooker stainless headers?
- Help me out...GMMG or LT and catted Y???
- tsp catted-y fitment
- 90mm LSX vs GMPP efi converted intake? and questions on it
- SLP LS6 EGR hookup help
- X-pipe w/ cutout
- Anyone got a B&B catback?
- Ported TB for LS1...best deal?
- z28 exhaust tips?
- TSP Rumbler Catback Info: Info Please!
- Meziere Electric water pump worth Getting and what do I need?
- Differences in TB
- Pacesetter longtube headers w/catted y-pipe
- Installed LT's and ORY- Can't get crossmember on
- Qustion on smell with true duals
- Calling All True Dual Owners !!
- Will a Flowmaster AT kit for LT1's fit LS1's?
- Part No for 1998 LS1 Waterpump?
- SLP EGR Provision? Can't find it
- Can I benfit from a new Y pipe, TB, etc?
- Texas-Speed ported throttle body
- Misfire
- Engine vs lsx intake
- picture of where is pcv valve on 98 z28
- Need some help diagnosing the trouble with ignition
- Need help finding exhaust dumps
- How does my oryp look?
- What are these devices/sensors?
- Exhaust question
- Pacesetter icluded o2 wires
- Running with an open Y-pipe?
- Help separating stock Y for cat-back!!
- under drive pulleys
- Pics of Corsa tips.
- making custom ORY? HELP!
- Coated vs. uncoated hedders
- Gmmg + Lts
- Which Electric Cutout To Buy With Price Value????
- carb on a ls1/ls6
- SLP Harmonic Balancer/Underdrive Pulley
- ASP pulley leak?
- does anyone make a 90mm exit airlid?
- To those of you wondering...
- open cut with all the rain?
- ORY or Catted Y-Pipe?
- Do Hooker LT's and Jet Hot LT's line up the same?
- PLZ help TB P/P ?????
- 78mm FAST LSX?????
- Recommendations please;;;;;;; 85 mm MAF
- O2 sensor Problems need help!!!!!!!!!
- Need pics of race Version EWP
- Need to identify sensor that I broke during intake swap.
- holley aluminum manifold Question
- TSP weld vs clamp
- Do you guys re-use the intake and coolant line gaskets...
- Do I need to replace the intake manifold gaskets...
- Squealing from engine bay!!
- Stainless Works Headers on '01-2 F bods?
- ls6 intake installed and now.....
- QTP y-pipe is hangs LOW..... too low.
- Race vs Street Electric Water Pump ?
- 2004 truck coil packs
- leaking gasoline?!~!
- Making custom headers, which cylinders to pair up together 4-2-1's.
- gains from fast lsx&90mm t-body? 1-company says 0 hp,other says 20hp?
- Best air intake?
- bassani dual exhaust
- LS6 intake throttle mount
- Electric cut out?
- Pulley is squeeking.........
- Belt Tensioner
- Proper procedure for refilling coolant?
- A quick pic of the NEW EDELBROCK Victor headers ceramic coated
- Broken Fuel Injector Wiring Socket
- Header size question !!!!
- Intake part # 12556333
- LS6 intake manifold
- Easy one .. how to change belts
- Dual cutouts with Bolra type adjustable plates?
- Help :(
- How to get some sound!!
- Dumb questuion Header install
- MAF for 01?
- New Stainless Headers?
- Cold start-up noise
- Question for all Engineers (or just smart folk)
- O2 Sensors interchangeable front Vs. rear?
- Anyone with an ASP pulley???????
- MAC Midlength Questions?
- People who have had bullet muffler based duals for awhile.. inside please!
- Which is louder Flowmaster or Aerochamber?
- best intake manifold and throttle body??
- ???to buy or not to buy???
- Gonna get TSP true duals, should i wait fot LTs first or just put them on?
- Y-Pipes?
- Normal header noise, or exhaust leak?
- Need parts list 4 LS6 intake on a 98.
- Metal rings around o2's making noise...
- Anyone Using Brisk Plugs?
- Edelbrocks Carb conversion kit is out?
- Help me with squeaky engine
- True duals+convertible.
- Checked catch can after 1500 miles
- Quietest Exhaust?
- Header Help!!!!!!!
- ? track times after LT install
- I may have a new free mod
- Built my own exhaust.
- TSP True Duals installed this evening
- x-pipe?
- Corvette exhaust manifolds
- Should I buy a 90mm FAST intake, a LS2 intake, or wait & see what happens w/the LS7?
- poly motor mounts installed
- sucked water into the engone and blew it up, getting new one...suggestions?
- Is the fitment any better between the older style and newer style SLP bellow?
- Eliminate EGR and AIR?
- TB or MAF first? Your input needed
- Ls6 intake install question..
- LG Headers for C5 ZO6--Worth the cost?
- Searched already ... mac vs pacesetter
- A4 w/LT's place cats were?
- Mojave Heater Install
- surging!
- Weind Holley manifold on 99ls1...what all do i need??
- Metco breather
- Exhaust Leak Help
- How to remove the oil filler neck
- question about MSD 8.5 wires
- march pulley does work with double roller chain
- tsp true dual problem?
- Mod Questions
- Boramouth owners come on in
- what yall think.... Headers
- How i ran my catch can
- Egr ?
- Holley Lingenfelter Aluminum Intake Manifold
- Direct-Flow Airlid Purchase... WHERE CAN I GET IT???
- MSD LS1/LS6 blaster coil....
- Ordered my exhaust. What do you think?
- long tube headers with sts system
- Will 12556450 gm coils work on ls-6 engine
- Transmission Oil Cooler used as Engine Oil Cooler?
- Header Bolts
- SLP LOUDMOUTH vs FLOWMASTER
- Funny Noises?????
- Thirdgen exhaust on a LS1 Camaro....
- Fuel Rail Covers
- Problems w/ FAST intake and tb?
- **Need help**Heater Hose control valve???
- Ticking after Mac Header Install?
- lt1 vs ls1 borla
- LS6 intake Manifold From ZO6 to C5
- kooks lt install
- Anyone have pics of offset magnaflows for X-Pipe
- I got my TSP X-pipe true duals today!!!!!!!!!!!!!!!!!
- Those w/ZO6 85mm MAF, what did U use 2 connect the lid 2 the MAF & the MAF 2 the TB?
- motor install
- Corvette and Camaro starter motors the same?
- Anything else I can do?
- Swap catted y for ory. Worth the trouble?
- f-bodys rear end pics w/ SLP loud mouth
- TD's setup on stock manifold and cats?
- Long Bolt for pulley install is stuck...
- LS6 Maf? will it work?
- ASP vs March! About to order...need advice
- A/C compressor help..
- Engine Vibration...
- How difficult is it to change the pulley? Which set do I need?
- QTP rasp
- Dying o2s. Denso f-body or Bosch vette rears?
- Those With GMMG Exhaust
- LT Headers and emissions sniffer test
- Hardest job on an LS1
- Good True Duals Setup
- PICS of Catted AND Dual Cutout Y-pipe
- Headers
- Battery Relocation
- 2.5" or 3" duals for MY application???
- Z is out of its coma!!!
- Advantage of corvette oil pan
- Who is it safe to buy TBs from now?
- 3/4 inch hole on top of header tube...
- weird exhaust noises.. please step inside
- installed slp lid and now...
