- Battery Relocation
- 2.5" or 3" duals for MY application???
- Z is out of its coma!!!
- Advantage of corvette oil pan
- Who is it safe to buy TBs from now?
- 3/4 inch hole on top of header tube...
- weird exhaust noises.. please step inside
- installed slp lid and now...
- 98+ plz leave pics of Exhaust tips
- coated or uncoated
- I am an idiot, please help
- Underdrive Question
- exhaust manifolds
- From headers to exaust tip what do I need?
- Remove 4" Spintech Dual Muff and lose less than 1hp? Can it be true?
- Want opinions on my theory about intake pressure at WOT.
- 1&3/4" vs. 1&7/8" Longtubes.....
- vette to f-body exhaust manifold?
- pacesetter lifespan....
- A Few Question to be Safe.
- edelbrock headers
- Mods on my exhaust
- True Duals
- Does Anyone Other than Mufflex Offer a Nice Y for Hooker LTs?
- Is this an LS6 intake?
- Does this Weld Look OK?
- need advice on installing SLP long tube headers
- Dyno'd the Hooker LT's and True Duals today....
- banging on hard acceleration?
- cleaning holley powershot air filter...
- Which water pump dealer or bosch
- Throttle Cable Nightmare
- does the autometer guages include right adapter to fit head?
- True Duals Set Up
- Where To Buy True Duals
- new pacesetters=8+ codes thrown???
- oil leak and shreaded belts
- New Pacesetter ORY
- air conditioning compressor probs
- Egr/air Blockoff/removal?
- Got rid of RASP from BORLA + LT headers/ORY
- True Duals X-pipe dumped on slammed f-body*PICS* (56k Take a nap)
- Cut out exhaust? is it worth it?
- billet grill and airlfow
- What Gap for Plugs?
- Cruise Control
- header installation
- Flowtech headers
- Pacesetter problem
- Why won't my car start on the first try anymore?
- Pacesetters Headers K-Member Trouble?
- True duals(idea)What you think???
- LS6 vs. fast LSX intake
- Who else has LT's + ory + LM or any exhaust w/ no mufflers....
- cutting the dip stick tube, read inside...
- broken speedometer?
- finally got my coated headers
- How thick is the K-Member? Need to drill through it...
- Sweet Thunder 3" True Duals all the way over the axle....
- Is the ARP crank pulley bolt worth getting?
- Dual Vs. Catback (More Power?) (How much?)
- BIG thumbs up to corsa...
- Anybody know how to clean a MAF?
- Happy B-Day LS1TECH!
- firing order
- Troubleshooting: Any help would be appreciated.
- 02 simulators?
- pics of rear-exit under axle true duals
- valve cover and coil interchange
- High Idle with TB - Next step?
- loudmouth muffler on Borla?
- air pump removal
- Engine running at 210 constantly, normal?
- Fipk2
- QTP vs Kooks?
- LSX 78mm = how much power?
- dex-cool
- exhaust and NC inspection
- What is this part officially called?
- Lid without AIR fitting?
- Which Exhaust
- how to check cam sensor?
- what spark plug wires would you recomend?
- TSP true dual question
- wtf is with my asp pully
- kooks catted y
- Could this be my TB?
- EGR/intake questions
- Alternators
- AMW now making a bracket for there catch can.
- pacesetter race longtubes
- Corvette 02's
- removing the brake booster
- Cheapest O2 simulators...
- what pulley is upper left looking into the bay?
- Header and Mid-Section question.
- Looking for a header setup that don't leak. ><
- My Ported Throttle Body
- Does placement of the cats affect sound?
- stepped headers????
- Vibration At Low RPM
- Heads up: New LS1 products in Jegs
- crank problems
- help 95 3.4L raw fuel smell
- Just got AMW catch can
- power steering delete
- P0121 In-Range Operating Throttle Position Sensor circuit failure
- Intake upgrade for 5.3
- PCV Rubber Boot
- Hooker Catback Fitment
- Need guidance on removing AIR & EGR for Race Headers
- Is Flp Outta Business?!?!
- QTP Lts + TSP duals...video
- Gmmg exhaust with LTs
- who can do the epoxy on my TB?
- Problems after intake install, please help!!!
- Valve cover connections?
- Burnt oil smell, blue smoke???
- taking off the A/C, what to do??
- 90mm TB: Have You Checked Your TPS Readings?
- Help with smoking at idle only problem, after LT install
- Car wont start?
- 235.00 true dual pics
- T/A Wont start... Ticks
- Anyone had this happen to their exhaust mount?
- true duals sound clip
- kooks stainless headers question
- think i fucked my throtle body!!!Help..
- MSD aftermarket LS1/6 coil packs....
- Help with exhaust tubing
- Which 3" off road y pipe would work best with Kooks headers?
- SLP Radiator Porblems?
- Compatibility of vette engine vs. Camaro engine.
- Pulley bolt from hell.
- sounds a little weird
- PS cooler and SLP CAI interference?
- Annoying exhaust rattle at idle (Broken Cat?)
- Oil Sensor is not wroking right.
- Changing to True Duals REAL soon
- Stock Exhaust
- This all I need for ASP pulley, or do I need a Balancer bolt?
- gmmg exhaust considered a street legal cat back?
- H/C Install, which injectors to upgrade to?
- Car wont crank help
- Best Bolt on Mods for 2001 C5
- electric exhuast cutouts
- Welding for LM
- I'm giving up on my Blowmaster...
- installed my bullet muffler today
- Evap Problem
- Exhaust and Steering Column
- Could a makeshift 85mm airlid be made...
- Are the foam Pieces on the bottom of the intake really nessasary?
- LT's to stock exhaust?
- pricing on kooks?
- belts jumping
- New Bbk Ssi Intake Info!!
- LSX FAST intake leaking... help
- My SES light is on.
- scraping
- Sold the Borla and got some ?'s
- Where can I get the silver foam pieces that are on the bottom of the ls6 intake?
- Race Hose Sizes
- Do I have to have O2 sims?????
- smoke out the front after header install?
- What gains with Kooks on stock motor??
- Headers,True Duals, weird 1/8th times??
- True duals and bmr extreme T/Q arm
- How do you like your catted y-pipe ?
- 98 Y pipe same as 2000 Y pipe?
- FTRA install......
- TSP True Duals are on.....ho-ly-shit (few questions also)
- Idea for ORY 3'' dump
- LG headers & catted pipe,is tune a must???
- Engine noise at and above 2000 rpms
- Smog on Macs w/ Vortec
- BGRA guys, whats your experience?
- Exhaust flow for big HP?
- Anybody looking for AIR and EGR block off plates come on in
- True Duals
- Headers ORY-pipe + what catback for no rasp/drone?
- doing my intake swap, need to know what this port is?!
- fast 90mm tb issues fixed?
- plug wire againest header
- Help Please! SS Won't Start
- which headers are right for me
- True-duals to a cat-back?
- Bolt ons and SOTP difference
- do i need new injectors??
- True duals ???
- can someone please help me on these part numbers?
- Shaner Tb
- 1 cat instead of two
- How much clearance at your lowest exhaust point? 4 fingers w/TSP ORY here.
- cutout install location question
- Anyone Removed Their Baffles?
- SS SLP stock exhaust better than z28 stock exhaust for a 2000z28??
- Grotyhan Headers?
- Best Cheapest Underdrive Pulleys?
- Self-Circulating catch can.
- Header people Quick Question?
- under the axle duals
- How much power to be gained?
- Those with HEADERS & LOUDMOUTH
- Headders - will I need o2 extensions?
- LS1 in a TVR
- AMW catch can install location
- squeaking at start up, then disappers..
- this will be interesting
- Jethot Catted Y pipe
- Who does custom exhaust work?
- TSP duals vs. Y-pipe w/ cutout - power ??'s
- oil filler cap
- tune after headers
- Need a little help
- Bad 02's?
- Help with Headers On FireHawk
- Stock y-pipe ( pics )
- preping edelbrock stepped headers
- New O2's Worth It?
- Electric water pump, worth the money?
- oil still in the intake after catch can
- MTI & TSP Clear lids??????
- Problem after the track today.
- Do I need to replace the intake gasket during ls6 swap?
- Lid and SSRA installed, liking both.
- header question
- Cylinder head grounding bolts
- help.car is tweking wth asp pulley install
- Car is in smog mod: ( How slow am I )
- Pullies cherping like birds!
- lt headers question
- True duals and CA
- Dual 2.25" exhaust too small for 450hp?
- Part # request
- Can This Intake Setup Be Setup Without A Headache?
- LSX90MMT/B & INTAKE vs PORTED STOCK T/B & LS6 INTAKE
- hooker catback??????
- FLP Headers how do they compare
- Gto T/b Size
- EGR Valve
- Help with pulley install
- One quick question
- Just ordered TSP Duals, what mufflers do they use? TSP dual owners inside....
- I'm thinking of putting the cats back on
- Please HELP,Does anyone have a close up pic of their Catch Can?
- should i bother...
- Rumbler-LM comparisson please
- What are good type headers
- LS6 Intake + Ported TB = ????
