- Final word on Pacesetter headers?
- True Duals?
- 3" too much??
- Anyone make a Y-pipe for Dynatech race headers?
- What bolt-ons can you use after 408?
- Need a part number
- Just bought the AMW Catch Can
- header ground clearances
- got rid of RASP
- thermal plenum
- How long is the C5 smooth bellows
- Need 4" ID Bellows for 90MM TB's.
- test pipes
- Spark Plug wire install problems
- Removing the MAP sensor from intake
- **Sound Clip** 3" Magnaflow True Duals
- Cold Air Intake???
- brake booster line into intake
- Help! Power steering leak
- NEED HELP ASAP. intake swap something broke
- Denso Oxygen Sensors?
- Where to buy 4" Spintech Muffler
- 'Hows a borlamouth?'
- Exhaust fume smell
- 01' SS Help with Exhaust Sound -Anyone have any suggestions?
- anyone looking for a quiet muffler
- Z06 intake manifold
- LS1 Airlid design
- torque arm stud
- MAC Header questions for my 2000 Z28
- Battery cable off after catback install?
- Fuel presure sensor LS1/Rx7
- Non-LS1 app: -quietest- small-diameter muffler?
- Ypipe w/o cats, any gains?
- TPS Voltage/TB opening and affect on vacuum at WOT ?
- TSP Rumbler X True Duals with tail pipes???
- Will a GTO intake manifold work on an F-body?
- magnaflow sound
- Sound CLips plz
- Exhaust! Bolted or Welded?
- WOT Then boom??
- Noise after Oil Change
- Cleaning oil gunk from intake manifold
- Long Tubes
- Edelbrock Victor install afterthoughts.
- Question for Magnaflow owners
- LS1 Y-Pipe "Bump Stop" Hanger?
- LS1 Which is best U/D crank pulley?
- Where to by FLP style exhaust clamps?
- from homemade to AMW
- Muffler? Resonator?
- What would I gain?LSX90mm,TB,Kooks 1 7/8!
- Sea foam- where to buy it & how to use it
- Voltage Gauge Fluctuation (Please help!)
- How much RWHP/RWTQ will I lose?
- what do you think of this exhaust idea
- Headers....which ones are better
- Help car is too loud.
- LS6 intake modification?
- LSX Revisions
- how do 01-02 ls1's pass emmissions since they dont have a.i.r. and egr?
- will i lose any hp or hurt performance if i make a.i.r. restrictor plate?
- y-pipe install on auto. trans
- explain Resonation
- Edelbrock victor install started.
- flowmaster?
- slp y-pipe
- 90MM TB gasket and bellow???
- qustion...best place to mount....
- 02 bungs on edelbrock victors?
- True Duals Without X or H pipe
- Engine vibration??????
- Polyurethane motor mount bushings installed!
- Need pics of the back of intake manifolds
- Cheapest place and cost to get o2's
- advise on exhaust gain/losses
- ASP Pulley and Balancer
- New Mods should be here Friday
- Hows a dynomouth?
- OBD2 code P1133 02 sensor but which one
- slp lt headers
- !EGR & !AIR question...
- LM has to go ORY going on Stock Cat-back?
- Thought you GTO, Corvette, and CTS owners might like this!!!!!
- intake ports - tar-caked - UHK!
- AMW catch can leaking...
- Header install question on 2002 LS1
- Urgent, need responses on QTP headers fast
- Do ported TBs have larger blades?
- MAF Question
- Eliminating EGR???? LS6 or LSX??
- another o2 question
- ls6 headers
- I found this over on camaroZ28.com about the SSRA
- Windshield fogging up bad!
- What was included with your 78MM Fast Throttle Body
- Slp U/d Pulley
- Underdrive Pulley???
- Which headers give the most ground clearance on a lowered car?
- intake manifold question!!
- Does TSP true dual fit with spohn tq arm and kooks
- What size exhaust?
- rough idle...gas smell
- Coolant Bypass Mod bad for the winter
- QTP's are in!!!
- ->Video - TSP MS3 w/Pacesetters and Rumbler X TD's
- FAST 90mm intake?
- Restrictor on SLP Dual Dual.
- SLP Lid Rubbing
- MAF Housing/Porting
- ASP pulley owners in here
- Help me pick my next mod
- SLP LM, need opinions
- Cutout Question/Stock exhaust
- HELP!!!!!!!!!!!!!!!!!Bronke Flange bolt
- Fluidampr - worth spending $350?
- *pics* LS2 TB on a 00 vette
- Kooks Finally installed!!!
- Cats or No Cats on new Y-Pipe?
- Hypertech Power Stat
- What's the best performing headers for a 408?????
- MAF problem?
- ypipe question
- Spark plug question
- Cutouts. yes or no
- free mods?
- need some hose size info
- Buy headers with or w/o emissions?
- Oil Bypass Filter
- Power Steering Fluid Reservoir
- TD's going in on Monday..
- Magnaflow installed
- Do I Have To Use Air Restricting Plates For My Longtube Install?
- LSX manifold and TB too much???
- Used Headers.
- 2 1/2 in Y pipe??
- What muffler to get? Quiet, Durable, High-Flow, Single Outlet
- for the record about Borla
- No Cats
- Cutout in I pipe?
- What has to be done to fit 02 headers on a 00 SS
- Which Do You Think Would Make More Power?
- Kook header Question
- will qtp electric cutout hook up to flowtech cutout???
- where to buy threadlock or locktight
- Pacesetter LT Install...
- Why does the SLP Loudmouth exhaust sound so grunty?
- part numbers for center bolt valve cover conversion?
- Do Slp Longtubes Suck?
- Fast Toys Parts!
- What would YOU do (re: exhaust)
- Q-tec or StreetPro?
- lid question?
- Info on ls6 intake swap please?
- Installing a mechanical water temp gauge
- Engine temp gauge at 0
- 2nd power steering pump...still leaking.
- Header coating
- Open element airfiler or box?
- have an AC leak...
- Report Air Lid / SSRA / Lid Seal Effectiveness
- intake bolt size?
- bbk 80mm th-body worth it over stock ported?
- Headers on a Lowered Car
- Anyone using the Stainless Works CAT Back's??
- Whisper Air Lid rubber seal?
- can't put on smooth bellows [SLP] because..
- SES light on???
- What is better 2.5'' or 3'' for y-pipe?
- Where to get cut to fit LS1 plug wires?
- Exhaust Idea
- Taylor Thundervolts vs. 409 Pro Race Wire
- Help me choose an exhaust
- funny noise(well its not really that funny)
- looking to get headers
- Where to find ORY for stock manifold
- Dynatech LT's..anyone??
- need help diagnosing problem
- Host some pics for me of catch can install??Anyone??
- Uhmmm.... Anybody had a Hooker Header do this????
- y pipe ?
- 1 header?
- Borla catback questions...
- Why can't anyone bend stainless pipe?
- Anyone have this combination?
- Tensioner pulley torques specs
- O2 sims?
- Swapped the ultra flo mufflers for super turbos in my duals
- Whining and Lost Air Conditioning
- help with throttlebody porting....
- Hedman Headers Initial Impressions
- headers, what all do i need?
- LT + hi-flow cats + y-pipe into SLP D/D
- new pvc
- Header Install / Needs
- Really Strange Sound
- !EGR & !AIR Question
- Different sound?
- Anyone that has installed MAC LS1 Header, I need help?
- crank pulley alone or crank and alt?
- How much will X pipe help
- custom y-pipe with cut-outs and cats
- Louder? Old or New???
- driver side exhaust clearance
- Got true duals on the 408!!!
- Problem with trip meter! Help!
- Ac problems! Help me out guys!
- How to check if coil packs are bad, and where to get new ones (aftermarket?)
- who makes these valve covers?
- Y-pipe for Mac midlengths
- Couple FAST 90mm TB questions
- Cleaning o2 sensors and do they go bad from sitting.??
- Meziere EWP Died
- Next project....maybe this weekend
- Flowmaster American Thunder
- Rasp
- Gmmg Exhaust
- Best air filter set up?
- TSP 85mm Lids - when?
- ls6 manifold help!!!!!
- Side pipes with x or h pipe?
- Those with a FAST intake and 90mm TB?
- Will taking the AIR pump off harm the cat's?
- How much gain?
- So Cutouts after Collectors are bad... what how about this?
- bad to mix PSF?
- How much exhaust CFM is necessary?
- Anybody know about the Window regulator Rivets?
- Stock Header Bolts OKAY for TTS LTs?
- Need A/C Line Part # quick
- O2 sim ??
- heades with removable cats
- macs vs. pacesetters
- ASP or SLP underdrive pulley?
- Temperature gauge.....
- Best Bang for the Buck Headers
- Belt size for Power Steering Underdrive Pulley
- Ground clearance issues?
- Installed new toys, want to share my opinions
- I need front 01-02 style coolant bypass pipe #12578838!!
- Sweet-Thunder (vid)
- asp crank pulley owners inside-->
- 78mm or 90mm ?
- Any PICS of TSP Catted Y-Pipe?
- Will these headers fit an '02?
- GM electrical connectors
- Dual pics...
- 2 spark plug questions
- Installing ls6 intake, questions.....
- 90mm LSx owners question...
