View Full Version : Generation III External Engine
  1. Is the SLP Dual/Dual a cross flow muffler?
  2. how do i route PCV lines?? what parts?
  3. lsx 90mm Throttle-body help.
  4. Header swap out question?
  5. quiet TD's.....
  6. headers+y pipe + catback best combo
  7. Solid Motor Mounts
  8. Best Cut out...? Anyone had problems with there QTP?
  9. Changing plug with LT's
  10. Who has KBDD subframs and a QTY
  11. tach not working after motor/trans goes back in car.
  12. exhaust rattles, help
  13. GREDDY Catch can
  14. hooker header install
  15. Flowmaster vs. Magnaflow
  16. Noise under hood, can't tell what it is
  17. Just ordered TSP True Duals
  18. Does anyone make a smooth bore F-body throttle body spacer kit?
  19. What the hell is going on with my crankbolt
  20. pic of sweet thunder mufflers
  21. headers help asap
  22. Rasp problem. Anybody have SLP DD w/ LT's & ORY?
  23. bolt ons = 11s?
  24. My SS rattles nonstop!
  25. I need help!!! (broken studs)
  26. need help with headers
  27. Speedo No Go After Alternator Swap
  28. SLP DD without cats
  29. Is there anything to DISLIKE about GMMG?
  30. Stripped spark plug hole!!!
  31. Who is running NGK TR6 plugs?
  32. Considering Nascar Boom Tube
  33. Finally Installed my Harlan shift light and BMR SFCs
  34. HELP! kooks 1 7/8 header install 1998 z28 question, asap
  35. bbk throttle body quest.
  36. Know where to get center mount tips????
  37. 3" 304 Stainless Steel Duals inside
  38. Need Help On Exhaust Pipe Sizes
  39. whats the difference between lids
  40. Throttle Body Question
  41. Those who just bought Kooks Headers, I need a measurement.
  42. slp pullies..not a newbie question..i think
  43. ?'s about true duals
  44. Throttle body question
  45. Will 02 LT's work on a 99?
  46. Wooo Hooo, just ordered my first non-free mods today
  47. Sweet thunder
  48. Parts needed for custom catted Y pipe help!?
  49. Mustang Style Duals...?
  50. Poly motor mounts - pros/cons
  51. Anyone have tips for disassembling stock throttle body??
  52. What exactly are all the bolt-ons?
  53. Help me choose exhaust for WS6
  54. Quiet Exhaust – is it possible?
  55. Hooker Header Install
  56. LSX w/90mm TB on an Fbody - inside please
  57. A/C Compressor Problem
  58. Borlamouth
  59. Can an LS6 Intake come from a GM Junkyard?
  60. How to install autometer oil pressure gauge?
  61. another backpressure question...
  62. WS-6 hood mod
  63. LT Header install question...
  64. Stainless vs. Coated vs. Stainless and Coated
  65. Do the oil pressure sending units ever lose their accuracy
  66. did tsp get their true duals in today?
  67. borla/corsa
  68. headers
  69. How do you make the fans run at high speed all the time ?
  70. One quick maybe dumb question
  71. GMMG Exhaust owners... plz step in
  72. Effects of not running PCV?
  73. Trans vs Oil Coolers
  74. I need some help
  75. Borla Catback And Hooker Lt
  76. Shorty Headers
  77. LS2 Intake
  78. where can i get Mass Air Meters fot my2003 monaro?????
  79. Rumbler/Corsa Question
  80. y pipe issues again
  81. Cutout length
  82. which exhaust setup do you think is better
  83. !air vac lines
  84. Turn signal on solid???!!
  85. o2 simulator help!!!
  86. Cut Outs?
  87. What X-Pipe?
  88. Thunder Racing Adjustable Belt Tensioner
  89. My car wouldn't start
  90. Victors are ordered!
  91. Got My KOOKS, now quick question!
  92. Asp Pulley
  93. X or Y
  94. Which dynomax size bullet should i use?
  95. Kooks '01-'02 header onto an '00
  96. Is the EGR plumbing the same for all 98-00 models?
  97. NEW bang for buck header!
  98. FTRA help.....
  99. Is the stock tach off?
  100. Quetion about Shanner T/B
  101. full exhaust system
  102. Have you guys seen these? Hedman
  103. Stock manifold to y-pipe gasket part numbers?
  104. bbk intake
  105. Need info on location of sending units..
  106. Help with windows
  107. Reasonable cost for Cutout???
  108. Got a shift light, where can I find a switched and fused +12v source?
  109. is it an intake leak
  110. What is needed to make the Meziere race pump work?
  111. Shorty Headers ?, I Know..I Know...
  112. LS1 Throttle body Part numbers
  113. header bolt advice
  114. runing straigh headers
  115. Header Advice
  116. exhaust inspection question
  117. Can anybody tell me where I can get this?
  118. torquing header bolts???
  119. Header differences.
  120. Does 93 to 97 LT1 have the same radiator design?
  121. Lid
  122. New TB for LS6?
  123. Belt length w/o pwr steering? help...
  124. Texas Speed's New Cat & Off-Road Y Pipes Pics-->
  125. Mac Mids Installed. Problems!!!
  126. Custom Flange Kit Carsound 941009?
  127. True Duels with Stock Manifolds
  128. AC fan replacement
  129. long tubes rubbing steering nuckle at idle
  130. Rumbler Catback Rev. 2 Pics!
  131. Idle searching...
  132. I-Pipe Cost
  133. anyone running spohn torque arm with the ts@p dual x pipe
  134. TR55 gap
  135. got headers in!
  136. Fan question/Oil pressure issue update
  137. Alternator problems
  138. Headers and Exhaust Question
  139. Can I run one cat?
  140. Mac Collector Mod
  141. Looks like rust inside my coil pack and wire
  142. slp loudmouth w/ gmmg muffler
  143. To get rid of PCV do I just need some breathers?
  144. Ever wanted to see a Pi-thon FireLock?
  145. which setup should i go with?
  146. charging system problems
  147. PCV direction
  148. 02 sensor and 02sim mix up
  149. intake parts from 4.8 to LS1 intake
  150. Pacesetter's Ordered!
  151. quick favor
  152. Best size cat for custom Y?
  153. Fitment problems and backpressure question, cutout, need some quick help
  154. help! where do these lines run to???
  155. Pacesetter LT's w/ Mac Y/ORP
  156. Which operating temperature with 180F thermo?
  157. LS6/90 LSX WOT MAP Comparrison & Install Info
  158. Headers question for camaro
  159. Will LT1 catback fit on an LS1
  160. Just got the qtps installed
  161. Jet Hots & single chamber flows
  162. Crap under intake
  163. wanna change my FLOWMASTERS but to what?
  164. mac header and ory pipe install?
  165. FAST TB - Any1 Else having problems
  166. Need Exhaust Advice...
  167. Another Pulley Question
  168. Pulleys
  169. Where to buy GM Melco Truck Coils online?
  170. Headers and Y-Pipe
  171. ? about powersteering pump removal
  172. What should I gap my TR55's @ for H/C Car?
  173. Need some direction on where to start
  174. Pulleys
  175. Header question
  176. Header Question
  177. Whisper Lid?
  178. 85mm MAF- Worth it? Cam only.
  179. What kind of C5 exhaust for my 408ci?
  180. OMG!!! Edelbrock Victors w/ y-pipe and Hooker catback = AWESOME!!!
  181. headers
  182. Exhaust scraping
  183. McCord Cutout Website?
  184. what do i torque the header bolts to?
  185. Have any vendors thought about making an adapter plate for the FAST 90MM?
  186. Header question
  187. LS6 Intake Manifold SOTP gain?
  188. Help!!! Car will not start.
  189. LS6 Intake Install Cost:
  190. Coil Relocation Brackets
  191. Ls6 intake part number
  192. flow tech y pipe
  193. victor drag header pic
  194. Will my intake leak if its missing 1 bolt?
  195. Denso Iridium plugs...
  196. lost track time with ls6 intake manifold and 160 t stat ?
  197. Need Y pipe for Jet Hot LTs
  198. Help,02 sensor circuit high volts?
  199. moroso spiral flow or dynomax bullets??
  200. need 90mm intake gasket asap
  201. Different Intake designs
  202. Where can I find the Torc Tite exhaust clamp.
  203. Need help, picking a muffler!
  204. how many CFM's do i need for fan so engine stays cool
  205. Has anyone accualy done a side by side???????????
  206. Header problem
  207. add cats to ory & magnaflow, or keep ory and get hooker cb
  208. How did this guy mount his coil packs like this??
  209. Advice On Cutouts
  210. 78mm or 90mm LSX intake for stock 346 engine?
  211. Headers installed... but
  212. weird noise on decel and gear changes
  213. When did they start making sfi approved asp?
  214. How do these match up?
  215. Motor mount tabs, up or down???
  216. Fast 90mm intake sealing problems?
  217. TSP's X-pipe kit
  218. SES and Header install. Do they go hand in hand?
  219. Quick Poll. JBA or Kooks LT's
  220. single inlet/outlet 3" muffler?
  221. Engine oil cooler kits for LS1/LS6 from LPE.
  222. Hypertech Powerstats
  223. Cut-out on Magnaflow gains?
  224. still need a muffler for the TD setup
  225. Finally got my intake totally done, but...
  226. Traction Control problem...
  227. header install, car runs like crap, PLEASE HELP!
  228. cutout question
  229. 02 sensor??
  230. More advice on installing Fast Toys Ram Air Kit...
  231. Fan On, Engine Off
  232. QTP catted Y ?
  233. GM Part # needed
  234. True dual dumped people inside
  235. 00' 3.8L V6 Exhaust.. and mods?
  236. Inake manifold to Throttle Body ???
  237. MAC Y-pipe fit?
  238. Header installation what did you
  239. Weird Car Trouble!!!
  240. Help with header install!!!!
  241. Where do I hook the cutout wire up?
  242. Hand porting a LS1 intake?
  243. Help, stumbling after spark plug change.
  244. pros cons of not running cats
  245. TSP true dual kit?
  246. How difficult to remove AIR and EGR? Help.
  247. Effects of cutout?
  248. Crank pulley is causing my car to throw belts...
  249. Swapping 99 LS1 Engine in a 98 T/a
  250. Header Question
