View Full Version : Generation III External Engine
  1. 2003 LQ4 Tach Output Pulse
  2. Cammed LS1 Borla Adj open & closed
  3. Code P0420, use rear o2 anti foulers?
  4. T/A Borla Owners....HELP !!!!
  5. LT ory and bullet.
  6. Question about pulling a complete wiring harness out of a camaro.
  7. Tsp 421
  8. Airraid UBI
  9. Need header-back exhaust! Help!
  10. question about exhaust fitment.
  11. LS6 Intake ID Help
  12. LSx Engine Mount bolts Thread pitch and count??
  13. Volant CAI filter change
  14. cat-delete/bullet muffler question
  15. Y pipe for eBay headers ??
  16. I have a CAI problem.
  17. For those of you using German Castrol
  18. 500Hp goal to the wheels Need Help!!!
  19. Oil filter question...
  20. I want to install my new longtube headers????
  21. Are catbacks from 93-97 F-bodys able to bolt right up to my 2000 Trans Am?
  22. pacesetter y-pipe opinions
  23. thermostat???Opinions please.
  24. What size headers to use?
  25. belt tensioner
  26. Chrome vs ceramic coated
  27. ok to plug ALL valve cover ports after ls6 valley cover
  28. How does this setup sound to you?
  29. long tube o2 sensors? mine got stolen....
  30. LPE or TSP 100mm MAF?
  31. SLP Air Lid: Before and After
  32. Hooker headers, tsp catted ypipe, slp loudmouth 2 catback
  33. Best/cheapest place to buy ARH headers
  34. Doing the LS6 swap on 2000 SS but need help...
  35. Just picked up a Corsa :)
  36. Oil Consumption
  37. Help! Exhaust decisions are driving me nuts!
  38. Just got ARH but undecided on catback
  39. Exhaust Help
  40. Catalytic Converter placement on ORY
  41. What size pipe to run? From Y-pipe to dump after axle
  42. Need some help with some ses codes
  43. Who makes tall baffled valve covers?
  44. highest HP true a 3" cathback
  45. Painted valve covers and coils...surprise inside
  46. lq4 with ls6 intake
  47. ported90/90or102 ported
  48. 98-02 Trans Am Camaro Stainless Steel AIR LID w Nitrous
  49. Knock and oil sensor
  50. 42lb Bosch injectors?
  51. Headers question
  52. Show Everybody Your Custom Y-Pipe/Exhaust
  53. BBK Underdrive Pulley - Which belt?
  54. ls1 starter off ebay?
  55. can i bore headers bolts out to 10mm ??
  56. Exhaust Setup Plan
  57. exhaust questions
  58. 160 degree thermostat without tune?
  59. Intake manifold problem
  60. What do ya think about my exhaust plan 1 7/8 LTS merge to 4" to 4" cb
  61. shift light help!!!
  62. HELP! Cam Position Sensor Code
  63. Does ANYONE sell clear 104mm lids?
  64. Sounds like Exhaust leak under load. But can't find one?
  65. changing oil pressure sending unit
  66. longtube headers and ypipe are illegal? and what is the best set
  67. Stall converters what do they do? And what do i need to get it installed?
  68. Best Cold Air Intake for C5
  69. TSP 1 7/8 vs Kooks 1 7/8
  70. If i get longtube headers will i have replace gaskets all the time
  71. Bad Vibrations After LT's Installed?
  72. HELP! Header Identification...Please
  73. What are the best bolt ons for ls1
  74. What bolts/nuts for this y-pipe bracket?
  75. HELP!! How to fix this??
  76. Hooker Aerochamber
  77. powerbond ud pully pin
  78. Cut-out placement
  79. TSP 1 7/8 LT's, meets True duals, meets Borla. Pics!
  80. Hooker y pipe
  81. Do BBK headers come with a catted Y pipe option?
  82. Exhaust gaskets
  83. Accessories
  84. 02 Valve Covers
  85. Engine miss firing.
  86. Deepest Sounding 2.5" Bullets???
  87. BBK intake: coolant steam/crossover tube
  88. getting REALLY pissed!!!!!
  89. Water Pump, 160 degree Thermostat?
  90. Grotyohann Headers hitting everything on install
  91. How do you install your LT headers?
  92. I need help with a MAF for my set up??
  93. What Y pipe will work with Kooks LTS?
  94. BBK headers
  95. Just got a full exhaust
  96. ls6 coolant crossover?
  97. LS6 mani for cam only
  98. pcv fitting help
  99. Is ram air lower box worth any hp gain?
  100. Missing a Few Header Bolts...
  101. Some part identification & some questions
  102. Time on Open Headers
  103. Breathers?
  104. Getting to the exhaust shop after headers with no O2'S
  105. How to reinstall stock a/c on camaro Z-28
  106. 243 heads stock on 2007 5.3L suburban?
  107. quick intake/fuel question help!!!!!
  108. Ebay Knockoff 1 Chambers
  109. 821 castings bolt on to 98 LS1 ??
  110. Anyone use Schoenfeld muffles On TD?
  111. Mpg problems after header install
  112. P0420 & Best MPG Yet...??
  113. Need Help: Voltage drops, light dim at WOT- Alternator checks out fine
  114. Which 02 sensors to buy?
  115. e-cutout not working
  116. Flowmaster merge?
  117. Cylinder head thread size question (Urgent)
  118. pcv delete help
  119. patriot performance heads/trickflow top end kit/afr and a vindicator
  120. Cam swap on 300k mile truck?!
  121. 102/102 stock motor automatic + more inside results inside !!!!
  122. tune after headers?
  123. NEW from Tick Performance: Knock Sensor Upgrade Kit (for 97-98 LS1 Engines)
  124. POLL: Muffler options- 'rasp' is annoying
  125. Intake opinions?
  126. FAST 102 swap, what does this plug into?
  127. Maf???
  128. Need waterpump help ASAP PLEASE!!!
  129. Slow to start??
  130. Pre-cutout muffler recommendation
  131. Anyone got these JEGS silicone RAD hoses?
  132. Smashed A/C aluminum line
  133. What's my LS1 worth?
  134. loud grinding noise when startup, starter??
  135. Starter problems
  136. Simple Cam Swap
  137. Dynomax Ultraflow installed...now lots of rasp :(
  138. Water pump and T stat question
  139. Lids and Low End Torque?
  140. Ls6 intake install
  141. Header/Exhaust Fit
  142. PLEASE HELP, What is this pulley?
  143. CHRS1313 Ram Air Installed
  144. Couple of things not right after TB swap..
  145. fuel rail removal question
  146. Dual plane EFI intake?
  147. TSP Rumbler catback???
  148. What are splayed valves
  149. Just got a good deal on wires.
  150. 85mm Maf
  151. Best Fitting ORY?
  152. Wiring diagram request - instrument cluster
  153. mis firing issue
  154. QTP y-pipe vs TSP y-pipe
  155. FAST 92 on mostly stock?
  156. Water column testing on SLP CAI
  157. 2 Cutouts Better Than 1 Cutout??
  158. weird vibration after headers
  159. How to tell if the egr solenoid is good?
  160. underdrive pulley belt length
  161. Alternator Keeps goin bad HELP!!!!!!!!!!!
  162. How can I make my exhaust LOUDER!!!!!!!!
  163. Y pipe/ OR pipe recomendation
  164. Intake leak or?
  165. Unhappy with exhaust...ideas?
  166. Alternator charge problem
  167. New woes, ranting again
  168. Battery relocation plan
  169. Coolant Crossover Tube Question
  170. Stock pipes vs 3 inch
  171. Oil in coolant :/
  172. tsp ypipe
  173. 3 Gauges for A-Pillar - A4 H/C Car
  174. Fans, With a stand alone painless harness
  175. SS 3" to 2.5" Pipe Adapter
  176. Intake Manifold / TB Swap For Dummies
  177. Pulleys
  178. Broke a TB mounting bolt
  179. Broken intake bolt in head. HELP!
  180. fans not coming on. did before cam install. now they arnt the car is Untuned. HELP
  181. Opinions with Super vic and 4150 tb
  182. Damaged LS6 intake - take a look
  183. 1 3/4 vs 1 7/8 header?
  184. New Exhaust
  185. yanked air/egr w/intake swap. vacuum question...
  186. Question bout true dual exhaust
  187. check this out
  188. Do I need a tune?
  189. 2.5 cutout?
  190. QTP New Wireless Electric Cutout Remote Controller Kit
  191. Bank 1 02 sensor.. is it hard to get to?
  192. WSQ Ram air
  193. SLP Lid-MAF
  194. Can i make it to the dyno ?
  195. 02 sensor question
  196. ported stock TB question
  197. what is needed for 2001 LS1 Fbody to crank without PCM..
  198. Putting in a Holley EFI System... Car wont Crank with key..but I can 12v start it
  199. Glass Packs with True Duals??
  200. PlEASE HELP. Hesitation after Header Install and Tune??
  201. My first attempt at a Y-Pipe
  202. show me your accessory drive routing/setup for alt crank & wp only.....
  203. Question about removing knock sensors from cover.
  204. street car build
  205. Fast 90mm Gaskets
  206. Heeeeeelp!
  207. Corvette C5-R valve cover ID
  208. exhaust question?
  209. What Exhaust is this?
  210. p/v clearance issues with this EPS cam/AFR heads?
  211. Tsp rumbler cat-back
  212. Crane Cam Dual Spring ?
  213. Summit/Jegs Cutouts???
  214. electric cutout
  215. Best catch can?
  216. Throttle Body???
  217. Magnaflow merge review
  218. A PCV delete I havent seen so wondering if it works
  219. Slp header and y pipe ?
  220. header y pipe to lm1 problem
  221. Loudmouth question
  222. top end build need opinions
  223. Bellows for speed density?
  224. 2.25 Borla?
  225. I need intake descriptions and advice
  226. aluminum foil inside of the lid......
  227. tsp catted y-pipe?
  228. pro flo intake on 5.3
  229. Anyone have a TSP Rumbler catback?
  230. Corsa FTMFW ***VID added***
  231. ls6 vs ls1 headers?
  232. What throttle cable do I need ? Fast 102 TB and converting to NON Traction Control.
  233. 2 1/4" True Duals
  234. Headers, LS6 Intake & U/D Pully worth it?
  235. Cutouts
  236. starter/front 02 sensor harness
  237. S/S LT Headers
  238. Header install, possible problems?
  239. 243 Head install question
  240. Weiand Intake install question
  241. dual exhaust
  242. 98 T/A Exhaust (just a section of it)
  243. How to pass emissons with Longtubes & 604 lift cam
  244. Quick question about crank damper
  245. Will an LQ9/LQ4 MAF work on an LS1?
  246. LS6 intake missing vacuum ports
  247. 1998 PCV Replacement
  248. Power Steering Cooler - Why?
  249. need ls1 torque specs
  250. 85mm MAF ???
