View Full Version : Generation III External Engine
  1. SLP dual/dual...
  2. Exhaust runner length?
  3. NEW (i think) SUPER INTAKE FOR LS1
  4. Lowered with LTs
  5. Cheap GMMG?
  6. Should I Change?
  7. Street Pro Cut Install
  8. Quick header help...how do you remove the O2 sensors from the stock y-pipe?
  9. New LS1 Intake
  10. what muffs for duals?
  11. How Much H.p. Does An Exhaust Add??
  12. ASP pulley question
  13. Anyone ever tried this.
  14. no matter what setting air is on, it comes out all vents
  15. Please review my laundry list
  16. Wish me luck....header install
  17. Best spark plugs
  18. Exhaust question
  19. March underdrive Crank w/ Alt Overdrive Pulley Combo ??
  20. My gauges look like the 4th of July when I floor it
  21. DOES A 2K1 OR 2K2 "WS6" OR "SS" HAVE LS6 INTAKE???
  22. Why would anyone select less than a 90mm TB for their motor...read this!
  23. What sensor did I break?
  24. What to get next -- goal of 400rwhp
  25. Plug/Wire change
  26. Best Electric Cutout
  27. Pacesetters/ TRUE duals
  28. LS6 intake question
  29. Wanted, Smooth sounding exhaust
  30. question about center mount exhaust????
  31. ASP Pulley?
  32. Question regarding Kooks Y-pipe
  33. Edelbrock Victor Headers
  34. SS/WS6 Exhaust Tips
  35. Modifying dynomax bullet meffler - more staccato?
  36. Custom duals with cats - who's done it?
  37. SLP y-pipe diameter
  38. hooker or manaflow muffler
  39. ? About Plug Wire Problem
  40. Will the TSP duals bolt up to my stock exhaust manifolds?
  41. headers
  42. question about borlamouth? dimension for cutting up LM?
  43. Magnaflow Muffler
  44. LT + hi flow cats + new y + SLP D/D
  45. Vacuum pump in stock AC location
  46. TB Bypass - 1/4" splice ok?
  47. Loudmouth on a 408, 2 loud?
  48. power steering jacked up
  49. Headers and Offroad Y
  50. Borla
  51. under drive power steering pulley
  52. True duals, here I come!
  53. Over axle heat shield+ silicone=?
  54. car go boom!
  55. My QTP header/y-pipe experience..
  56. Please Help Me Out
  57. Catch can bracket
  58. header install ???
  59. Got My LS6 Intake On...
  60. Pacesetter Headers Worth $399.99 Or Not???
  61. 75mm or 85 mm zo6 maf
  62. Longtube headers on lowered car
  63. gaskets
  64. i need a good muffler
  65. LS1 intake to either LS6 or FAST 78. Can someone make up my mind for me ?
  66. asp pulley spun on crank
  67. What do you guys think about true duals turned into side pipes?
  68. True dual battel with buddy's
  69. What LTs with GMMG ?
  70. Slight whistling at 1200rpm accel
  71. Kooks or hooker long tubes Vs. Mac midlength:dyno and track numbers?
  72. No cats=No torque?
  73. What colors are the available paper air filters?
  74. BBK 80mm vs 78mm ported stock TB?
  75. oil temp and tranny temp guage install????
  76. Quick Header Install ???
  77. would i gain anything?
  78. I OWE TSP AN APOLOGY: Their true duals fit Kooks LT's
  79. spitting and sputtering whenever first driving
  80. people with tsp true duals
  81. QTEC wiring
  82. Car shakes worse than a harley at idle Please help.
  83. New SLP pulley?
  84. Cutout or Diff. Muffler?
  85. Strange Idle after TB install
  86. Qtec
  87. True Duals with No Mufflers?
  88. o2?
  89. After 6 years,finally installed Pullies and Ported TB
  90. Windsheild Wiper Problem. Kinda wierd !
  91. magnaflow with no cats
  92. Need help- HEADER INSTALL
  93. Water Pump Question
  94. header tick ?
  95. off road Y pipe for a 2001?
  96. Will TSP Rumlber cat back rust?
  97. Headers / Plugs
  98. anyond with an MSD DIS4 ignition yet?
  99. pics of true duals
  100. header gasket ?
  101. How many people run ory? Too loud?
  102. Pacesetter Install Problem
  103. Best none dual set up??will it work??
  104. Muffler question?
  105. Changing plate on my Borla Exhaust
  106. tb or not tb
  107. street pro cut out installed
  108. What SLP options does my car have?
  109. headers?
  110. Magnaflow installed... weird things happening...
  111. SLP Longtube Opinions...Experience is helpful
  112. question about intake
  113. Gmmg Installed....
  114. Installing a tb
  115. Confused with piping for TD's
  116. tb bypass issues
  117. Installing Jet Hots and Hooker ory this thursday!!!
  118. How will this Sound?
  119. Quick Asp Pulley Question
  120. How to get rid of slight rasp with hooker and ory setup???
  121. Thunder racing headers?
  122. Anyone with SLP LTs , y, and cats
  123. SLP Lid fitment issue! need help
  124. What to Expect From LS6 Intake/Ported TB?
  125. EGR/AIR removal???
  126. Header install, need help ASAP!!!
  127. Where can one find this??
  128. Need info for Weiand\LPE\Holley Intake Users 98-00 F-Bodies.
  129. lost torque after cat removal..
  130. Anyone seen these problems?
  131. Tucking exhaust tips?
  132. well i finaly did it 3.5x3 inch x pipe installed
  133. Need Help ASAP Pulley install
  134. Thundermouth
  135. 2000-2002 custom y-pipe w/magnaflow collector!!
  136. Flowmaster Y Collector
  137. when I remove engine from top does the intake absolutly have to be removed? on an 02
  138. Need help with identifying manifolds and tensioner
  139. Freaking incredably loud with LT with ORY, a few questions
  140. I'm convinced MAGNAFLOW!!!
  141. Cats or ory?
  142. pacesetter ory
  143. SLP LM and Y pipe
  144. Y-pipe gains
  145. x pipe question
  146. LSX 90mm issues... car hangs BAD at 2400 rpm
  147. FYI: #'s after Headers and Duals on Stock Car.
  148. Small question about LS6 Install
  149. Gutted Cats
  150. will a throttle cable off a lt1 fit a ls1?
  151. How Can I tell if I have a Vacuum Leak on a LS1?
  152. Misfire after LS6 Intake Install
  153. Idle problem after backfire
  154. Kook's install help needed
  155. Just installed my LT & Cam And it SUCKS!
  156. need some exhaust help
  157. Exhaust Clamp
  158. O2 Sensor Extensions
  159. FLp Y pipe?
  160. Jeg's DS loop for duals?
  161. Magnaflow Round Race Mufflers???
  162. Anyone with edelbrock brag headers...
  163. Electric Cutout Placement
  164. Header questions
  165. LT Headers
  166. TSP installed!
  167. A/C PSI readings for low and high side
  168. Alternator wires? Ground strap?
  169. what's the best flowing muffler
  170. Pacesetter LTs and 02 Extensions, Can I get away with just one?
  171. GMPP singleplane tested in the new Popular Hotrodding mag.
  172. Size Pipe?
  173. Help!!!
  174. Exhaust question
  175. Slp Ram Air Induction Package
  176. Tiny plastic vac. line on back of intake manifold?
  177. Panhard bar
  178. 90 mm Fast TB problems
  179. Will a lid and Trans Am lower airbox fit under the stock Formula hood?
  180. coils?
  181. Sorry, another LM question
  182. another header question.
  183. Who makes an ORY that will bolt up to stock manifolds?
  184. What coolant overflow cans are you guys running?
  185. shift light hook up
  186. Sheetmetal Intake Owners Post in Please
  187. Header Gasket Suggestions?
  188. shorty header install
  189. I need pics of true duels with cats
  190. Headers or LM?
  191. I have Borla, thinking about the LM though
  192. More LS6 intake questions (well, just one)
  193. Help ID this SLP intake mod?
  194. Limited $$: Which bolt-on?
  195. Plase help with RWHP numbers! :(
  196. TSP true dual
  197. Y-pipe with GMMG?
  198. Best flowing muffler for 3 inch Y pipe???
  199. Terrible Header Install..... Need Major Help.
  200. AIR system gaskets
  201. Exhaust cut out
  202. Car doesn't want to start now and then
  203. one quick question
  204. Got my Jantzer Ported TB........PICS
  205. What is this noise? Download MPG
  206. 78mm LSX Intake
  207. mystery vacuum line
  208. What exhaust?
  209. Gatorback Belts
  210. true duals with cats? looking for some input
  211. another pulley question.
  212. QTP C5 Tri Y Header Dyno Numbers!
  213. Do the new flowmaster super 40 muffelers really flow any better??
  214. is anybody having problems with pacesetter lt's
  215. Better Cooling?
  216. How to remove hose fittings on back of intake manifold?
  217. hp question?
  218. Installed Jet Hot headers
  219. Corsa Cat back goes best with what header?
  220. A Few LS6 Intake Questions
  221. Headers slowed my car down .3+ tenths, White plugs?
  222. Cats for 98 and 99
  223. Help? Used GM SS muffler
  224. Sfi Or Asp Pulley?
  225. True Duals? Anyone ever use Summit Racing?
  226. will TSP-X fit with SLP SFC?
  227. Hyfire 6a ignition box w/pertronix points replacement
  228. Trans/Lock Line In Way of LS6 Install
  229. True dual Exhaust opinion's, please help
  230. specs on over the axle?
  231. ASP Pulley ?/please help
  232. Replacing power steering pump?
  233. Intake, pulley, and ported TB
  234. keep TDs or GMMG????????
  235. Cats add torque?
  236. Some help please!
  237. FYI on Fram Air Hog
  238. Free ram air and sealing the airbox?
  239. Can you put the O2's in header primaries?
  240. MAF Error ( On my conversion )
  241. my exhaust setup
  242. Will the Hooker ORY pipe slide onto Kook's long tubes?
  243. Header Install Problem
  244. Need some help
  245. what was once gone, is back again, could use some help
  246. Question on Valve cover install
  247. No spark or injectors pulsing, need help!
  248. AC PROBLEM "PLEASE HELP"
  249. Anyone have this setup? Opinions?
  250. How hard is it to R/R b1s1 and b2s1
