- Exhaust quieting down?
- weird a/c issue
- 2.5" or 3" headers?
- Worthless or Not
- trying to troubleshoot cooling problem
- Home made polly mounts?
- Band clamps???
- lt header ?
- 3" TD's over the axle question
- Dismantling PCM connector HOWTO
- help pls..
- Mechanical or Electrical?
- Where to buy wire loom connectors
- gmmg?
- cfm
- sheet metal vs. lsx intake
- my ls1 motor?
- FlowTechs?
- Anyone port their stock MAF housing's?
- GMMG+LT's vs. GMMG+stock
- Anyway to force the fans to high speed when they are on ?
- Mechanical Water Temp. Guage
- Stock Inlet Hose size from MAF to TB?
- Prob after header install HEELP!
- Header / Power Problem
- Header's, which one?
- I need an overdrive pulley for the Alt
- Need Help
- LS6 Intake : Worth it for my ride ?
- Question on exhaust setup
- Thunder coil relocation?
- Quick disconnects for AC condenser?
- AIR! and EGR! questions?
- question:AMW catchcan
- Different duals.
- AC problem
- Where is the low coolant sensor on a 99?
- will the hooker ory fit pacesetters?
- TSP New Duel Exhaust !!! What Do U think ?
- What are these connectors?
- Loudmouth question
- Catback Pics
- Pulley questions
- PPC LTs and Catted Y are in...
- LSX install part question
- o2 sensor p/n differences
- poly motor mounts. Install this week.
- Header Problem!!!
- Stock gutted cats VS Slp high flow cats
- need some whisper lid dimensions
- just installed pacesetters lt's..........questions and comments
- Vararam (plastic TP "port" item) - comments?
- Cutout cap?
- PVC question
- problem putting cheapy plugs in my c5 for some testing?
- avoiding the pace setter yp ipe
- Spark plugs
- LS6 Intake Manifold, Which is best?
- SSRA vs. Competitors
- What type of gains from my new LS6intake manifold?
- need clip of the TSP true dual
- Best place to get O2 sensors?
- are they FLP or Dynotech LTs
- Do the electric cutouts leak still?
- Anyone lowered with dual cutouts in the Y?
- Going back to Y pipe set up
- rasp still pissing me off
- Looking for a new x/y/h-pipe
- three cutouts?
- headers sticky question....
- What size are the boltholes in the front of the passenger side head?
- Is a 90mm FAST inatake and tb overkill for this setup??
- Coolant Hose?
- GTO exhaust manifolds
- LT1 true duals? Magnaflow muffler....
- Oil and Spark Plug Change
- Duals with or without Cats
- ground clearance issues
- Are QTP's and Kook's LT's the same design?
- Myths about backpressure
- stock manifolds and cats
- Mufflers for Duals
- PaceSetter ORY vibration and banging remedied
- how loud will it be
- fan is squeeling
- Custom "FTRA"?
- Somebody point me in the right direction
- HELP. Vette won't start.
- Flowmaster muffler on a SLP dual/dual?
- ASP Pulley Removal
- Porting my TB ... any tips
- Pics of my custom dual 3" cutout install on my 99 C5 FRC.
- Radiator Plumbing
- Any tricks to reducing resonance? (vette)
- how many header bolts do i need for lt install? dealer says 16?
- When will there be a true dual system...
- exhaust question
- Oil drain bolt not budging!!
- need help
- How Much Hp Will 2.5" Td Support?
- Alternator R&R Question???
- Under-axle true duals problems
- how 2 hollow my borla??
- Help on exhaust!
- tsp dual x system installed on qtp headers
- What do I need to remove ASR?
- Dynomax Bullet or not?
- EGR + AIR Help
- size or diameter of harmonic balancer?
- off road y,2 quick questions...
- O2 sensors?
- GMMG and Corsa
- Header Advice Needed
- TSP's true duals tubing size
- 100$ for header install............
- Question about custom made Underdrive Pulley with pictures
- LSX Intake & TB - Surge/Idling Issues ?
- C5 Throttlebodies: 90mm
- Installed the Jet Hot LTs and ORY
- REtaRded Squeal
- Pacesetters and TSP TR set up
- March Underdrive Pulleys for my 2001 Z28
- Question about the Donaldson Lid
- Anyone replace muffler in stock catback?
- Oh Crap, I've Done It Now!!!!!!!!!!!!!
- Custom Fab True Duals
- Cheapest cats for SLP headers?
- After header/exhaust install.............
- Stay with the D/D
- Hooker ORY....my thoughts...
- StainlessWorks Longtube Headers, Feedback & Dyno Results
- WTF?!! Engine miss at idle I can see a spark between coil pak and valve cover
- Forum Director - Marker
- Jet-hot LT's and ORY installed, got a Q
- exhaust gas temp gauge help!
- Throttle Body Bypass Installation
- Texas Speed True Duals Install Pics--->
- Those with 3" TD and/or lowered, please come in
- Loudmouth guys?!?!
- What kind of gains from pace setter long tubs and catless y pipe?
- Will YPipe make it louder?
- lowering car debating going back to y pipe
- Cat Question
- What mufflers have been used with TSP True Dual set-up
- Air conditioning lost?
- estimated ponies & ft-lbs?
- Installed Magnaflow 4x9's on True Duals
- Fast 90mm is a POS
- Can I retain AC from 3.4 in LS1 conversion?
- headers,exhaust question?
- Question
- Anyone use "muffler tape"...???
- Secondary air injection problem, Need Help
- c5+dynamax headers=no et gain, info +timeslips within
- SSRA and Radiator Shrouds
- Installed Pacesetters, ORY sucks!
- Have a problem...Need help Quick (Exhaust)
- True Duals on a BMR X-Treme Duty Trq-Arm?
- Changing compressor tention pulley? Need picture!
- LT ground clearance
- Removing AC - now system frozen?
- PLEASE help,pcv problems
- which should i do?
- Texas Speed True Duals???
- Ready to shoot myself
- R134a ? for LS1's
- who's using the 90mm fast and 90mm TB??
- LTs installed, Problem. Help!
- Anyone have primary & collector lengths of popular longtubes?
- will these bolts work for header bolts? please help
- Hissing sound after off road pipes? HELP
- LT's, ORY, GMMG not so bad
- Gains from Cattey Y to ORY??
- Exhaust Question
- Alternator pulley removal/install Q's
- Intake Manifold
- Tsp rumbler vs cutout
- Question about Flowmaster 1 series?
- Has anybody done this?
- hellllp....please??
- Put the Hooker catback on today
- Header question
- Any important tips for a ported throttle body install?
- possible new intake setup, would like opinions
- Header tune question..
- True Duals?
- Exhaust Question??
- ASP belts
- ALL experienced exhaust guys in here...
- suggestions..trueduals not loud enough
- Is there a way to safely clean cats?
- Why do my new Pacesetters.............
- Pacesetter Gasket Leak
- Another gauge question... Where do I wire the tach?
- slp loudmouth vs. cutout
- Anyone with an electric water pump already, install underdrive pulley?
- Help
- Help! How do I get the plug out of the pass. side head for a temp gauge?
- LT's, TD's, all the way out. Muffler???
- QTP LT's With Catted Y, Best Catback For It??
- want to run duals but need some help
- Weird Noise just started
- Any large cube guys running a 78mm LSX
- Fitment ? with SuperMaxx header system
- O2 Sensor Problems I Guess?
- braided hoses and earls fittings?
- 02 sensor extensions...
- Borlamouth??? Which Muffler?
- Drill bit size for 1/8" NPT threads
- Intake Mainfold Swap, NEED HELP right away
- race LTs for 99 model/stock manifold
- Painted headers in TX?
- Stage 8 locking bolts....
- X-pipe or H-pipe...... Pro's and Con's????
- I want proof,LSX/90 MM TB!!
- camaros w/ duels w/tips
- Tips on header install
- plug wires
- Will I see any gains?
- How would my car sound with Chambered Dual's.
- Clips - TSP true dual's "X" behind a 427
- Which exhaust is this?
- Pacesetter Coating Question.
- Mac mid length
- Y pipe banging/cheap fix?
- Anyone have TD with Edelbrock Mufflers?
- Wierd rattling sound from Hooker ORY....wtf????
- 3"overaxle duals, how?
- zed cutout
- headers?
- Dyna Tech Headers worth it?
- 1 wire alternator
- TB bypass mod= loss of gas mileage???
- can i use hi temp silicone on the egr hookup on my longtubes?
- SLP Cold Air, not FTRA or SSRA?
- LS6 85 mm Maf
- Magnaflow vs. Hooker AGAIN...sorry!
- Need the external diameter of stock MAF and the length
- ASP pulley???
- Hooker w/ TD or Kooks w/ ORY
- gains from Mac mid length
- LS6 Intake??
- K-Member
- Magana Flow muffler is on>
- coolant level -- sensor info.
- porting a waterpump?
- Where to get a 2.5" lap joint exhaust clamp?
- Were to put a cut out on a corsa stainless steel exhaust?
- loud y-pipes
- Too Loud???
