- coolant level -- sensor info.
- porting a waterpump?
- Where to get a 2.5" lap joint exhaust clamp?
- Were to put a cut out on a corsa stainless steel exhaust?
- loud y-pipes
- Too Loud???
- Horespower gain or no??
- Do it yourself mods
- Catalytic converter question
- True Duals on Stock Internal Motor?
- why cant true duals exit . . .
- Better gains?
- The Wonder Can
- Duals or a clutch?
- Y Pipe Or True Duals
- 90mm bellows to fit the 90mm FAST???
- QTEC question?
- hollow cats? or not
- LT/ true dual hp gain
- How to remove rust off coated Pacesetter headers?
- weird vibrating feeling through gas pedal
- LT's and y pipe???
- headers for a convertible/help
- Slp Ls6...
- Gained 35rwhp/30rwtq with Jethots/Hooker ORY
- Electric cut out guys
- Drilling holes in 180 thermo?
- Poly engine mounts?????
- March pully and short belt
- I need a host...
- Macks out new longtubes in
- Short duals
- thanks pacesetter
- exhaust backpressure issue!
- Remove muffler for the track?
- FAST LSx Intake
- How do I test the knock sensor harness?
- need advice on exhaust flanges..
- Brand of O2 Sensors, does it matter?
- Give me the Pacesetter Low Down!!
- Rumbler "X" pipe too loud...NOT!!!
- Hooker LTs on a 2000...emissions?
- Sucked down an EGR seal
- What do you guys think about the sound of my duals? Movie inside.
- What does the "raspy" sound sound like that everyone hates?
- TSP true dual question?
- !AIR with Cats, bad idea?
- Thank you JetHot !!!
- Idle Problems with Ported TB...Anyone have any?
- How hard is it to install a poly motor mount ?
- Custom Exhaust Setup, What do you guys think?
- Gaskets for the weiand LPE intake
- 85mm MAF the same for vette, f-body, and caddy??
- place to get my headers coated?
- CAN I RUN THE SSRA & HOOD RAM AIR ?
- problem # 723453
- Shake, Rattle, and Roll my eyes...
- Wiring for starter
- Borla catback
- No more "Y" pipe banging
- Merge Collector???
- Looking for a nice deep exhaust on a stock 98 TA
- Flowmaster on Duals
- anyone have random tech exhaust
- Poly motor mounts...
- 02 sensor questions
- Need help replacing radiator fan 2k C5
- Long Tubes..what to get??
- My TSP lid sucks in tons of junk...
- Mack mid length on a 422?
- Help me save my tips
- Borla True Dual setup (pics)
- oil pressure and water temp gauges
- CME owners, need assistance with tip placement
- LS6 intake swap.... need tuning??
- Stock Throttle Body?
- New Intake Lid
- Raspy sound
- Smoking tailpipes!!!
- when you put in the ls6 intake manifold, how was your engine effected?
- Will Kooks LTs scrape if?
- Slp Lt's W/ Cats And Ses?
- 90mm throttle body
- AntiSeize on crank pulley???
- Is a truck throttle body the same?
- BBK Shorty owners, come in!
- tci's Torsional Vibration Absorber
- intake-blackwing:volant
- Stock Manifold removal...
- Making Weatherpak connections, T splices?
- My car sounds like it could suck up small children if they get too close
- Cam Swap Drilled TB mod?
- Anyone using an aftermarket or truck oil pan?
- ls1sounds.com update, please read!
- newbie question BUT...sealed airbox or no?
- 90mm Intake Vs. 80mm
- Tapping into block for mechanical temperature and oil pressure guages
- Overheating causing me to "OVER HEAT"!!!
- part number for higher capacity AC Delco oil filter?
- the perfect exhaust tone finally!!!!
- To Those W/ SLP LS6 Intake
- Open Headers?
- Whats the best way to go about port matching the lsx?
- longube and clutch change
- QTPs, now what combo?
- drilled thermostat
- What parts do i need for LS6 intake install.
- Sounds like miss after plug change?!
- 5.3 throttle body same as ls1
- What are they worth: driveline vs air flow?
- Cut-out????
- SLP pulley
- pinging and black smoke??
- Guys Help!
- glasspacks instead of bullet in i pipe
- Best way to pull engine and tranny? Top or bottom??
- A little story about exhaust...
- Last min tips please!?
- who here has true duals and is lowered?
- Flowmasters have bad flow? Please explain this result?
- Cool catch can relocation for Firebirds
- Jet Hot headers
- X-pipe questions
- Dampener/pulley position...
- hooker headers,02 extensions?
- No power getting to the "S" Starter pole of starter solenoid
- sounds like i have crickets under my hood!
- ARP balancer bolt torque...
- question about intake manifold swap
- Does the VR Velocity stack from tbyrne.com work?
- What the best 90mm Throttle Body?
- TB bypass mod question...
- Good/Bad?....lt's+no cats+dynotmouth?
- SLP Loudmouth with headers and y pipe
- Cutout question...
- oil coolers
- Have Longtube Headers ever made you foul plugs???
- Flowtech's VS. Hooker
- Ls6 Intake Hp?
- Dynatech Headers GOOD OR BAD?
- What is the best exhaust for a 2000 WS6 that is pretty cheap and adds the most HP?!
- Truck Starter???
- What exactly do I need to install a water temp gauge in my 99?
- Need an Idler Pulley and new Tensioner
- Idle & Misfire Codes after an LS6 Intake Install??
- EGR and AIR block off plates for headers
- ses after plugs?
- spark plugs and gaping
- Cutout Gains or not?
- Another Guage Problem
- What is the technical name for this part?
- whats the best spark plug wires, Taylor?
- cats or no cats.
- Custom X or Flowtech X
- Worth the swap?? Dual/Dual to Magnaflow....
- LS6 intake + TPIS 90mm
- many xr-1 options
- Everyone w/ LT's HELP!
- Cant decide if I would be wasting my money..
- Home made ram-air.
- Help rewiring the cigerette lighter
- Y-pipe banging driving my crazy
- Will a custom (equal length) Y-pipe stop the dreaded Mac header rasp?
- slp lid trade
- How many times have you re-used old stock bolt to seat pulley?
- considering some pacesetters....
- SLP Lid?
- Header ?
- Gmmg
- Check out my custom 2 piece intake...
- Favorite cat-back poll...
- Im tired of being told "duals arent for an Fbody"!!!
- Fastest car with SLP dual/dual
- Pacesetter headers / y-pipe with Carsound cats welded in?!
- LSX and FI
- A Newbie Header Question
- 85 mm lid and bellows ???'s
- Pacesetter Y-pipe?
- has anyone designed their own headers?
- To MAF or not to MAF...that is the ???
- Pics of my PPRH Heads, and QTPS I will install soon.
- things needed with Headers
- need to quiet car
- Rusting issues with longtubes
- Video C5: LG Pro Long Tubes Modified 3" Dual setup....
- Modification Plan...Thoughts
- Question about ORY banging fix
- Best Muffler To Get???
- Just ordered BBK Headers!!!
- Electric Cut Out wired to plug into cigarette lighter?
- Anybody use Street Pro's electric cutout?
- any gains with underdrive pulley?
- trouble with corsa install
- Exhaust help?
- Is my exhaust adequate????????????
- LTs+ORY+magnaflow+18" bullet=perfect
- need header gaskets...
- what is the site for the qtp catted y pipe for jethot longtubes
- will mufflex y pipe with carsound cats work with my jethot longtubes?
- up voltage to coils?
- NEED HELP, i have a tick???
- Need Quick Help with Leaking Hoses
- Eldebrocks LT's are in!!
- Will removing all AIR equipment with apropriate tune make significant power?
- Gutted Cats?
- Ugh...please someone give me some input on headers..
- Question about GM steel header gaskets..
- Looking for part # for plastic piece that is cut for FRA
- Did Magnaflow quote me the correct PN ?
- True duals on a stock car..
- MACs 1 3/4 + ORY are in
- LSX and 90MM TB---- what MAF?
- War Intake Injector Questions
- Uh ohhhh...Loudmouth??
- Platinum vs. Iridium spark plugs????
- Replacing Corsa with "American Thunder" Flowmaster
- Magnaflow 4x9's or Flowmaster 10 Series....for duals
- H2 6.0l intake? Should I use it?
- custom made true duals?
- BBK SSI intake manifold
- Install time on Jet-Hot LT's and O/R y-pipe?
- best exhaust?
- loudmouth to magnaflow????????
- spark plug??
- i got my jet hot catted y pipe, my thoughts inside
- Smallest Catalytic Converter?
- Fram Air Hog
- Water Temp Guage
- PaceSetter LT installation tips?
- Pulley install from hell!
- Shorty Install Pics...
- '04 GTO/Corvette 160* T-Stat
- Those that were asking for pics of my QTPs and XR1 TDs...
- QTP's coming in this week!
- LT Headers need Tuning
- Idler Pulley
- Can a magnaflow muffler be swapped
- Borla XR-1 True Dual Video
- Hooking up thermostat(race water pump)
- Power Steering Pump compatability... help!
- Quick Questions on Exhaust
- Jet Hot headers installed.......pics
- Race collecters,4-2-1 or merge???
- if you have stainless headers....
- Which Headers Would You Rate The Best ?
- All alternators created equal?
- Length of various cats?
- Another moment in brilliance...
- will better headers be worth it???
- 1500 miles of AMW Catch Can
