- Suggests on the Loudmouth..........
- Going with LT's and fabbing up true duals, lots of question within.
- Sounds!!!!!
- Where to get GMMG??
- Smallblock adapters
- CA Emissions Compliant Longtube Headers
- AC overcharged - compr. shut down?
- New topic category - Air conditioning
- Need info on SLP pulley, anyone have one?
- Which flanges should I use to connect end of headers to x-pipe?
- What to get...ARP header bolts or Stage 8?
- Anyone Try This Single Setup
- Short headers?
- SES with manifold swap
- Gettng rid of my flowmasters
- Horrible Luck Must Read
- Are these Headers and ory good
- Would anybody be kind enough to remind me how the motor mount heat shield goes on?
- Quick noob exhaust questions.
- Uncoated Flowtech Headers
- revised pacesetter LT tubes
- aluminum for block-off plate?
- o2 simms and !AIR
- Kooks vs Jet Hot
- Another LSx intake install turnout
- Front or Rear O2 Sensors?
- Guys with Poly motor mounts
- will 2001 SLP LT headers work on my 99?
- What The Best Sound Catback For Stock Car
- Looking for a good tach
- Jet Hot Longtube question.....
- Bassani pipes??
- Oil filler neck
- turn signal problem
- My Flowtech Header install with Loudmouth on a Convertible
- redesigned Pacesetters fit well
- Building 3" rear section for my Corvette(mufflers)
- LT1 with GMMG
- Bought another motor. What do I need to make the swap???
- is there a gasket in air-manifold connection?
- cutout questions
- Sand in the radiator
- Where can i get the flp header clamps?
- Help if u can please
- rove car today with the LSx intake on it.....
- When putting in a motor from the top is it easier too.....
- LS1 Intake Manifold, what is it actually made of?
- Royal Purple (Purple Ice), How to add?
- Headers - Stainless Works vs. QTP
- Whose exhaust is this?
- Redline WaterWetter opinions...
- Just ordered my AMW Catchcan
- 02 TB compatible on a 98?
- I'm starting a True Dual Photo and Part Database
- what do you guys think of these . . .
- help please
- Need pics of true duals with the Spohn torque arm.
- Well...FLP kit is off and sold, what to buy?
- Do you put anything on the header bolts before installing them?
- weird exhaust question...
- Super Sucker Ram Air
- exhaust prob
- Water Pump
- help, girlfriends car wont start
- anyone running the lanes X pipe to 3" duals?
- Plugs And Wires
- maf sensor went bad.... wtf
- Part #'s for belts??
- Borla Question?
- Muffler coming apart inside?
- LS1 headers & LM on my 97
- What does the line from TB to Valve Cover do?
- Wiring Help...
- just recieved my 90 mm f.a.s.t. intake "wtf"...
- What could be causing my AC/CRUISE fuse to keep burning out?
- AMW Catchcan Results
- 71 Chevelle oil dip stick tube problem!
- Help ASAP header bolts problem
- Going from Borla to Dual/Dual?
- QTP cut out wiring?
- Qtp
- Closest system sound wise for TA that sounds like Corsa Pace Car exhaust
- Edelbrock Catback?
- Will 01' Pacesetter LT's fit a 99 car?
- Donaldson air filter question...
- Can you use a Catch can and a metco breather together?
- Rumbler
- Is 3" duals to big?
- adding true collector to a jethot y pipe?
- Why BUY a ORYP?
- Installing Cats
- How to determine what size primaries you need for longtubes headers?
- Cut-out????
- Anyone running Polyeurathane Motor Mounts ?
- Ypipe for Edelbrock 1 3/4 to 1 7/8 headers?
- Collector gasket?
- Is this supposed to be there?
- FAST LSX Manifold results
- Wonder if my X pipe will fit right if i swap to Kook long tubes?
- Magnaflow Cat-back
- True duals with stock manifolds and cats!!!
- Loudmouth and GMMG
- Kooks or QTP Headers???
- Katech Relocation Kit
- Waterpump/T-stat?
- Magnaflow Crossover on F-Body??
- Cheapest MARCH Pullies?
- induction hp #'s??
- Weird engine noise
- 2001 ls6 intake onto 2000 z28
- Stock gm header bolts
- LS6 Intake install question.
- Flowtech Headers
- Will this fit?
- i bent my short fuel line today taking my intake off?????
- One more Borla XR-1 Question (size and fitment)
- borla and cut out ???
- Soundclips of the SS and Z28
- moddifed LS6 to EGR
- anyone have FLP headers???
- Porting my LSX 78mm
- Distance from motor to Catch Can?
- F'in sweet!! Lead tolerant o2 sensors!!!
- spintech muffler replacing loudmouth resonator?
- Any difference in power, sound, flow, etc. between the 12" & 18" bullet muffler?
- MaC Question
- Ignition wires?
- need info on cats.
- AIR help, fast please
- Seperate Intermediate Pipe?
- Any word on the "new" Pacesetter design?
- VR Velocity Stack Track Results Inside
- Who has the best fitting air lid???
- LS6 intake??
- Just got True Duals fabbed and put on.....
- How will this sound?
- How do you connect the end of the headers to the x-pipe?
- need pics nice story warranty fight
- New Pacesetter Header Pics!!!
- Rumbler Catback Sound Clips With Camshaft!!
- Does this look like a quality x-pipe?
- steering wheel shaking....maybe from headers hitting??? help!!!
- I did something bad! (O2 sensors)
- Jet Hot coating has rusted off. Now what??
- 160 tstat a good decision??
- Pacesetters Lt's installed
- Squeky noise!!!
- getting LT headers and Y. do I need O2 sims?
- Need some advise please....
- Got My LS6 today, got some q's
- borlamouth peeps inside please...
- Need help right NOW! plz post quickly!
- ? chambered muffler in place of resonator on loudmouth ?sound?
- Would 2.5" carsound cats on a true dual system be too restrictive? ASAP
- My LSx problem hopefully fixed!
- asp crank pully and now slower?
- ATR Pitbull Exhaust system
- THose with Kooks headers andan Xpipe setup, please post pics.
- Anyone have the Stainless Works Xpipe setup?
- Factory Tensioner Pulley or MBA Tensioner Pulley?
- Edelbrock Performer Intakes
- QTP LT's ROCK !!!
- catch can?
- This months Super Chevy intake tests
- Help! I'm Confused!
- Best way to check for bad coils?
- QTP ORY & Corsa Cat Back
- Any custom intakes making significant power over the LS6?
- help with steering shaft connection
- exhaust sounds?
- race tips needed here
- belt tensioner
- Texas Speed Rumbler
- magnaflow owners inside
- Chevy High Performance Intake Shoot Out
- different exhaust
- Is the Dr. Gas x-pipe worth the money?
- loudmouth
- help with ORY fitment
- Installing non-EGR LS6 intake.
- Fast Toys Ram Air Tid Bit.
- Lock-Tite on ARP crank Bolt?
- wont be buying from flowtech anymore!!
- LS1 underdrive pulley Identification???????
- March Underdrive pulley Fluid balanced
- remove hood baffles or no?
- Damn rasp gossip....
- LS1/LS6 intake manifold swap to 5.3
- Anyone know how to remove the AC?
- Pics of my Kooks with engine out of car
- Anyone have side pipes??
- Torctite Exhaust Clamps
- question on cats going bad
- Best sounding exhaust I've ever heard on an LS1.
- Little Pissed about this LsX, called FAST..FYI
- ASP Pulley FELL OFF!
- kinda disappointed in headers.....
- Porting the LSX manifold
- Removed Cats = Rough Idle.
- SES light after header install
- Can Someone Educate Me on EGR?
- true duals+CME=???
- Is the battery tray removable from the coolant overflow?
- Need a favor from someone with a Helms manual
- Ebay Headers
- Exhaust cutout
- Help Please
- earl's header gasket?
- Knocking Sound on IDLE!
- Question about my 98 trans am
- Need some Help... LM/no cats.. Major Rasp!
- edelbrocks new carbed ls1with msd ignition
- what are the best spark plug wires to use
- Flowmaster Exhaust
- How can i get a TB quick?
- Home ported MAF vs. aftermarket??
- Crankcase Pressure
- Gutted Cats.. Pass emissions?
- AC compressor
- Intake casting #'s? Fastchip programming?
- Torx bit size for AC evaporator holder?
- Header install....no codes, but strange sound...please help
- Witch throtle body to get for 2001
- DS Loop with FLP Headers?
- Pacesetter LT's question
- CHP Intake Manifold Tests.........
- FINALLY got a Borla
- Anyone have a little rust on there stainless headers?
- Confused? Is the Kooks Ypipe Stainless?
- Noise is driving me crazy!!!
- FAST 78mm I HAVE BIG ISSUES!
- LS6 Intake Install... Bad to WORSE
- Headlight problem, both high and low on at the same time
- TPIS 90mm TB.... Has anyone tested this with LS6 Intake?
- Coil Re-Location Installation ?
- How Much To Knotch The K Member
- which spark plugs to run?
- Locally Made X-Pipe vs. Mass-Market X-Pipe
- Installed catback...fitment concerns...pictures inside
- Need Help with AC
- Which headers tuck the highest?
- going w/duals..
- Anyone pass smog w/o cats?
- TB spring not hitting bump stop
- Hooker Header Track Improvements
- tr6 plug number
- 90mm LSX & TPIS T/B & H/S roller rockers install
- QTP Y pipe better than Kook's Y pipe?
- welded or clamped??
- OK for rubber in ASP pulley to be cracked
