View Full Version : Generation III External Engine
  1. anyone running the lanes X pipe to 3" duals?
  2. Plugs And Wires
  3. maf sensor went bad.... wtf
  4. Part #'s for belts??
  5. Borla Question?
  6. Muffler coming apart inside?
  7. LS1 headers & LM on my 97
  8. What does the line from TB to Valve Cover do?
  9. Wiring Help...
  10. just recieved my 90 mm f.a.s.t. intake "wtf"...
  11. What could be causing my AC/CRUISE fuse to keep burning out?
  12. AMW Catchcan Results
  13. 71 Chevelle oil dip stick tube problem!
  14. Help ASAP header bolts problem
  15. Going from Borla to Dual/Dual?
  16. QTP cut out wiring?
  17. Qtp
  18. Closest system sound wise for TA that sounds like Corsa Pace Car exhaust
  19. Edelbrock Catback?
  20. Will 01' Pacesetter LT's fit a 99 car?
  21. Donaldson air filter question...
  22. Can you use a Catch can and a metco breather together?
  23. Rumbler
  24. Is 3" duals to big?
  25. adding true collector to a jethot y pipe?
  26. Why BUY a ORYP?
  27. Installing Cats
  28. How to determine what size primaries you need for longtubes headers?
  29. Cut-out????
  30. Anyone running Polyeurathane Motor Mounts ?
  31. Ypipe for Edelbrock 1 3/4 to 1 7/8 headers?
  32. Collector gasket?
  33. Is this supposed to be there?
  34. FAST LSX Manifold results
  35. Wonder if my X pipe will fit right if i swap to Kook long tubes?
  36. Magnaflow Cat-back
  37. True duals with stock manifolds and cats!!!
  38. Loudmouth and GMMG
  39. Kooks or QTP Headers???
  40. Katech Relocation Kit
  41. Waterpump/T-stat?
  42. Magnaflow Crossover on F-Body??
  43. Cheapest MARCH Pullies?
  44. induction hp #'s??
  45. Weird engine noise
  46. 2001 ls6 intake onto 2000 z28
  47. Stock gm header bolts
  48. LS6 Intake install question.
  49. Flowtech Headers
  50. Will this fit?
  51. i bent my short fuel line today taking my intake off?????
  52. One more Borla XR-1 Question (size and fitment)
  53. borla and cut out ???
  54. Soundclips of the SS and Z28
  55. moddifed LS6 to EGR
  56. anyone have FLP headers???
  57. Porting my LSX 78mm
  58. Distance from motor to Catch Can?
  59. F'in sweet!! Lead tolerant o2 sensors!!!
  60. spintech muffler replacing loudmouth resonator?
  61. Any difference in power, sound, flow, etc. between the 12" & 18" bullet muffler?
  62. MaC Question
  63. Ignition wires?
  64. need info on cats.
  65. AIR help, fast please
  66. Seperate Intermediate Pipe?
  67. Any word on the "new" Pacesetter design?
  68. VR Velocity Stack Track Results Inside
  69. Who has the best fitting air lid???
  70. LS6 intake??
  71. Just got True Duals fabbed and put on.....
  72. How will this sound?
  73. How do you connect the end of the headers to the x-pipe?
  74. need pics nice story warranty fight
  75. New Pacesetter Header Pics!!!
  76. Rumbler Catback Sound Clips With Camshaft!!
  77. Does this look like a quality x-pipe?
  78. steering wheel shaking....maybe from headers hitting??? help!!!
  79. I did something bad! (O2 sensors)
  80. Jet Hot coating has rusted off. Now what??
  81. 160 tstat a good decision??
  82. Pacesetters Lt's installed
  83. Squeky noise!!!
  84. getting LT headers and Y. do I need O2 sims?
  85. Need some advise please....
  86. Got My LS6 today, got some q's
  87. borlamouth peeps inside please...
  88. Need help right NOW! plz post quickly!
  89. ? chambered muffler in place of resonator on loudmouth ?sound?
  90. Would 2.5" carsound cats on a true dual system be too restrictive? ASAP
  91. My LSx problem hopefully fixed!
  92. asp crank pully and now slower?
  93. ATR Pitbull Exhaust system
  94. THose with Kooks headers andan Xpipe setup, please post pics.
  95. Anyone have the Stainless Works Xpipe setup?
  96. Factory Tensioner Pulley or MBA Tensioner Pulley?
  97. Edelbrock Performer Intakes
  98. QTP LT's ROCK !!!
  99. catch can?
  100. This months Super Chevy intake tests
  101. Help! I'm Confused!
  102. Best way to check for bad coils?
  103. QTP ORY & Corsa Cat Back
  104. Any custom intakes making significant power over the LS6?
  105. help with steering shaft connection
  106. exhaust sounds?
  107. race tips needed here
  108. belt tensioner
  109. Texas Speed Rumbler
  110. magnaflow owners inside
  111. Chevy High Performance Intake Shoot Out
  112. different exhaust
  113. Is the Dr. Gas x-pipe worth the money?
  114. loudmouth
  115. help with ORY fitment
  116. Installing non-EGR LS6 intake.
  117. Fast Toys Ram Air Tid Bit.
  118. Lock-Tite on ARP crank Bolt?
  119. wont be buying from flowtech anymore!!
  120. LS1 underdrive pulley Identification???????
  121. March Underdrive pulley Fluid balanced
  122. remove hood baffles or no?
  123. Damn rasp gossip....
  124. LS1/LS6 intake manifold swap to 5.3
  125. Anyone know how to remove the AC?
  126. Pics of my Kooks with engine out of car
  127. Anyone have side pipes??
  128. Torctite Exhaust Clamps
  129. question on cats going bad
  130. Best sounding exhaust I've ever heard on an LS1.
  131. Little Pissed about this LsX, called FAST..FYI
  132. ASP Pulley FELL OFF!
  133. kinda disappointed in headers.....
  134. Porting the LSX manifold
  135. Removed Cats = Rough Idle.
  136. SES light after header install
  137. Can Someone Educate Me on EGR?
  138. true duals+CME=???
  139. Is the battery tray removable from the coolant overflow?
  140. Need a favor from someone with a Helms manual
  141. Ebay Headers
  142. Exhaust cutout
  143. Help Please
  144. earl's header gasket?
  145. Knocking Sound on IDLE!
  146. Question about my 98 trans am
  147. Need some Help... LM/no cats.. Major Rasp!
  148. edelbrocks new carbed ls1with msd ignition
  149. what are the best spark plug wires to use
  150. Flowmaster Exhaust
  151. How can i get a TB quick?
  152. Home ported MAF vs. aftermarket??
  153. Crankcase Pressure
  154. Gutted Cats.. Pass emissions?
  155. AC compressor
  156. Intake casting #'s? Fastchip programming?
  157. Torx bit size for AC evaporator holder?
  158. Header install....no codes, but strange sound...please help
  159. Witch throtle body to get for 2001
  160. DS Loop with FLP Headers?
  161. Pacesetter LT's question
  162. CHP Intake Manifold Tests.........
  163. FINALLY got a Borla
  164. Anyone have a little rust on there stainless headers?
  165. Confused? Is the Kooks Ypipe Stainless?
  166. Noise is driving me crazy!!!
  167. FAST 78mm I HAVE BIG ISSUES!
  168. LS6 Intake Install... Bad to WORSE
  169. Headlight problem, both high and low on at the same time
  170. TPIS 90mm TB.... Has anyone tested this with LS6 Intake?
  171. Coil Re-Location Installation ?
  172. How Much To Knotch The K Member
  173. which spark plugs to run?
  174. Locally Made X-Pipe vs. Mass-Market X-Pipe
  175. Installed catback...fitment concerns...pictures inside
  176. Need Help with AC
  177. Which headers tuck the highest?
  178. going w/duals..
  179. Anyone pass smog w/o cats?
  180. TB spring not hitting bump stop
  181. Hooker Header Track Improvements
  182. tr6 plug number
  183. 90mm LSX & TPIS T/B & H/S roller rockers install
  184. QTP Y pipe better than Kook's Y pipe?
  185. welded or clamped??
  186. OK for rubber in ASP pulley to be cracked
  187. Pacesetters suck
  188. Help with exhaust for trans am
  189. Little header install help, will take 2 secs to answer
  190. meiziere install snag
  191. Does anyone use a Evans waterpump?
  192. Borla People
  193. Engine to Bellhousing Bolt Pattern
  194. True duals installed...
  195. which is better? a stock ls6 intake manifold or Holley Aluminum LS1 intake manifold?
  196. Edelbrock stepped headers
  197. Breslin Split-Lock header bolts
  198. Alternator or Alternator plug?
  199. Cheap 3" cats
  200. Removing Wiper Blades
  201. Would these Flowmaster's work for true duals?
  202. Impression of Flowtech headers within
  203. Where can I buy a Dr. Gas x-pipe?
  204. true duels with tips in back
  205. Ported my LSX 78mm........
  206. Who sells Hooker Aero chamber mufflers?
  207. How would this sound?
  208. Anyone running LT's/no cats/ with a flowmaster?
  209. QTP on production vehicle?
  210. How come everyone reccomends Copper Plugs?
  211. rattling exhaust driving me to kill.
  212. Turn down pipe for Q-TEC electric cut-out!!
  213. Help Car wont start!
  214. New Taylor 10.4mm wires = rough idle
  215. Be Cool Radiator and Meziere EWP ?
  216. 1 or 2 cutouts?
  217. Coil pack relocation!!!
  218. Questions about heads and valve covers???
  219. Would bad crank sensor cause random misfire and rough starts (non-LS1)?
  220. Cut-out Question?
  221. FlowTech headers any good
  222. need instant header install help
  223. full size oil pan
  224. cutouts???
  225. You guys using ASP UD Pulley is your Power Steering harder to turn?
  226. true duals with a cut out?
  227. Advice on some LT'S
  228. Why true duals when they aren't?
  229. I need a catted-Y that fits the Hooker LT's....
  230. Calling all Kooks owners
  231. Getting ready to buy headers????
  232. can an ls1 intake fit on a lt1
  233. Going with true duals..
  234. Please help me decide
  235. Cutout before LT install a problem?
  236. 78mm FAST & Shaner or LS6 & Shaner ?
  237. BakerElectronix O2 Sim... Anyone using one?
  238. where can i get X peice for true duals?
  239. How many of you true dual guys.......
  240. how to wire o2 wires with jet hots?
  241. WAR Intake, Accel Teaser pictures
  242. Volant Intake
  243. Wiper Removal???
  244. A/C compressor reinstall ???'s
  245. Horrific Idle after ASP Underdrive
  246. K&N tell me how bad is it???
  247. QTEC Cut-Out Toggle Switch
  248. Headers/Exhaust...??????
  249. Quick MAC question....
  250. Removing Air
