View Full Version : Generation III External Engine
  1. hi i want to know some thing?
  2. car backfires alot!
  3. Recommend some headers
  4. Bellow/CAI/LM
  5. throttle body bypass question
  6. Big thumbs up to MAC mid's
  7. Those with Meziere WPs
  8. What will dealer do for leaking freeze plug?
  9. Next?
  10. DynoMouth Install
  11. Low beams quit working
  12. ASP pulley problem/question
  13. Oxygen Sensor problem???
  14. Ticking sound coming from underneath the car
  15. Does the slp/borla replacement y-pipe make much difference w/performance??
  16. 160 degree thermostat question
  17. shorty's vs. long tubes?? which is better!?!
  18. Best place to bolt engine hoist chain..
  19. Help... car just shut off no fuel.
  20. Recommendation for Type/Mfg External Oil Cooler?
  21. Connection from top of TB to passenger valve cover?
  22. true duals with cats?
  23. Any serious problems/issues with LTs?
  24. Having problems after FLP install!!!!!!!!!!
  25. anyone port the hooker ory?
  26. I have a y pipe question
  27. 02' LS1 Intake Manifold Question...
  28. Been checking ebay.
  29. tb question
  30. Canton Oil Pan
  31. water temp gauge hookup
  32. Opinions on Duals w/o an X or H
  33. Those with the BG Ram Air
  34. EGR Valve fix question...
  35. heat shield banging?
  36. Jet Hot catted Y Pipe install pics? Jet Hot guys inside please!
  37. H-pipe ????
  38. Hooker Long Tubes/ Help!
  39. Those with TRUE DUALS come in
  40. Installing motor quest? where does the chassis/battery ground go? Starter or block ?
  41. Q about AIR removal - read the sticky
  42. How to tell if check valves are burned???
  43. Which O2 goes where?
  44. Oil Filter relocation adapter size??
  45. anyone else had this problem???
  46. true duals rock!
  47. SLP LM popping?
  48. Question about AIR and Cats
  49. GMPP LS1 Intake - Availbility Update
  50. Post your 1/4 or hp gains with Hooker lt's...
  51. black or ceramic coated headers?? whats the defference??
  52. Will I have to run o2 simulators?
  53. where to get true duals
  54. Anyone have true duals/x-pipe w/chambered mufflers dumped?
  55. mac's
  56. Gmmg + no back seats = too loud???
  57. Just got a cutout put in...
  58. MTI lid
  59. Powder Coat or Nickel Plate?
  60. corsa, ORY, & pacesetters, how to get rid of rasp above 2K????????
  61. ARP crank bolt torque specs?
  62. Y pipe question
  63. Removing AIR
  64. Air Filters (Oiled vs. Paper)
  65. whats louder? lt/cats/slpdd, or stock/stock/gmmg?
  66. ASP Pulley worth it or not?
  67. Intake swap ?
  68. Descreened MAF
  69. Question about lids
  70. Ticking noise near collector...normal??
  71. Pacestter Headers what y-pipe?
  72. cooling issues...
  73. Jet Hot catted Y pipe clamps?
  74. Removeable cats in custom y-pipe
  75. Anyone ever get an EVAP code
  76. Ditching PCV
  77. Shaner, LSX, or MTI Throttle Body?
  78. Powerband comparison between ls1 and ls6 intake?
  79. drilling the throttlebody? (?) car not running well
  80. Anyone replace their ignition cylinder?
  81. Cant stop oil leak!
  82. Flowtech?
  83. Accurate Machine Works catch can
  84. What makes one set of longtubes different/better than another?
  85. Must choose between theese 2 mufflers (already have them ).
  86. Ls6 Intake
  87. hooker header question????
  88. MACs Questions
  89. true dual suggestions
  90. Will LT's solve the problem?
  91. Any info on hedman LT and hedder back system
  92. Mod'd OEM valve covers
  93. Help with flowtech headers
  94. a.i.r.removal
  95. fans not working...help
  96. Got My GMMG installed !!!
  97. LSX work with stock/ported throttle body?
  98. Idler Pulley Removal Procedure? Just a bolt?
  99. Question about bullet muffler???
  100. how much power loss from a stock catback on a h&c car??
  101. Nobody has Hooker catback in stock what are similar options?
  102. Problems after header install
  103. FLPs bang the floorboard
  104. Drivers Side Header bend angle
  105. can i run w/o cats in PA
  106. stock ported TB VS fast 78MM TB w/ lsx?
  107. whining noise?
  108. Loudmouth removed, time for duals...need suggestions on what mufflers to use.
  109. Headers and Exhaust?? need a little help
  110. mac headers with 3 inch x-pipe pics
  111. GMMG Exhaust new tips
  112. cutouts
  113. MAF installed backwards??
  114. Y pipe for Jet Hot headers
  115. FAST 78mm TB : Pics inside
  116. unplugged IAT sensor...
  117. Is there a better MAF then the SLP 85mm? Pro-M???
  118. LSX 78MM tb
  119. How much loss thru WS6 vs Magnaflow?
  120. need help
  121. lt install
  122. EGR Gasket slipping
  123. Need help on choosing next mods
  124. AIR pump disable question...
  125. QTP Headers Installed!
  126. Harmonic balancer pin kit needed
  127. MACs midlength....
  128. Removing AIR pump howto?
  129. SLP Dual Outlet or Magnaflow?
  130. Open headers + flashing SES light?
  131. Will a LT1 y pipe fit on my car?
  132. Fixed an exhaust leak and now I idle rough.
  133. FLP vs. Jet-Hot LT headers??
  134. 02 sensors
  135. MAC headers collector mod
  136. Will this intake/exhaust setup work?
  137. Y-Pipe ?
  138. What is the most power anyone has made through a Hooker catback?
  139. SSRA Cai and SLP lid
  140. Hooker Y-Pipe
  141. Look what I caught in my catch can!
  142. Cut out questions...
  143. Suggestions to quiet down car??
  144. Power differences between lt & st headers
  145. Duals??
  146. Removing cats - pros and cons
  147. Bought a magnaflow 14267 Muffler is it the right one?
  148. Least expensive LT's and Y..and why?
  149. Problems with Crank Shaft Bolt!!!!!!!!
  150. Borla/Dyno Mouth Owners here
  151. Just installed Jet-Hot long tubes.
  152. ? about vacuum pump
  153. Opinions on exhaust setup please
  154. Pacesetter Y-pipe owners come in.
  155. ASP pulley wont stop squeaking. Help.
  156. Coolant
  157. Where do you buy GMMG Exhaust
  158. Crankcase Vent
  159. Hooker Y-pipe banging, leaking...clamps the culprit???
  160. Does anyone with WS6 use the BG Ram Air setup?
  161. SDPC Ported Throttle Body?
  162. IAT Sensor
  163. O2 delete plug?
  164. Good Aftermarket PS Pump?
  165. LS1 Meziere install help
  166. Who makes a sheetmetal intake that works
  167. No spark to passenger side
  168. Volant Cold Air Induction Owners, Any good verses a new air lid
  169. Which header should I get-$$ no issue
  170. Need quick answer Short belt.
  171. pulley install problems
  172. Engine missing-plug #8 is clean
  173. Low Coolant light ????
  174. electric waterpump?
  175. March Fluid pulley ?
  176. any of you C5 guys have electic cutouts on a stock exhaust?
  177. No cats or no muffler
  178. Installed Hooker LT w/ORYP...add cutout??
  179. What Driveshaft safety loop w/ true duals?
  180. whistling again
  181. Weight of Stainless Headers
  182. How do I test a Idle Air motor?
  183. rubbing SLP lid???
  184. lt install?
  185. Hissing from the exhaust
  186. 90mm, but stock maf
  187. LSX intake
  188. SLP Headers, Cats, and Loudmouth
  189. Port matching a LSX intake
  190. SLP Loudmouth Muffler
  191. Can't wait for the UPS guy !!
  192. mac header's installed now Im hitting the rev limiter
  193. Belt size?
  194. LSX on a 2000, coolent vent tubes?
  195. Removable Cats
  196. lg long tubes
  197. Quick question
  198. 90mm LSX install complete...pics within
  199. LS6 Manifold Install?
  200. Hose Clamp Tool
  201. Do I need O2 sims or can I delete rear codes?
  202. March = 11lb , ASP = 6lb , stock = 10.5lb
  203. Breathers
  204. jet hot rubbing
  205. anybody using the holley ls1 aluminum intake
  206. Spark Plug Holder
  207. Bassani header install
  208. ? about wiring meizere
  209. Question about the FTRA & SLPs deal
  210. ORY Installation???
  211. CarSound High Flow Cats.....any good?
  212. Wow this is a doozy.
  213. loud as I can get!!!!!
  214. Do i need tuning? Opinions please
  215. Just installed Moroso spiral flow
  216. what new bolt do i need with the ASP pulley?
  217. Ported Throttle body worth it??
  218. Pully Problems
  219. Should I buy the relay kit for the Meziere EWP, or just wire it up the way it is?
  220. stock header bolt?
  221. qtp elec cutout bolt to hooker cutout yah or nah??
  222. Is this dent in header ok, buying soon!
  223. Pretty General problem...
  224. Muffler volumes & tone / suggestions?
  225. Which plug to pick??
  226. It never ends...
  227. lt headers
  228. Anyone else see Jett Hott pics??
  229. Hey FAST!
  230. LSX intake manifold?
  231. New Pulley, Do I need a Tune?
  232. Ok I got the B1 cam and Muffler, Would gain any power by putting a borla on
  233. Raising Idle in an A4.....how??
  234. Weird buildup inside lower coolant hose !
  235. guage mounting
  236. help me decide, gmpp intake or ls6
  237. I don't have EGR Pipe?
  238. Anyone powder coated their intake yet?
  239. What size cutout do i need?
  240. Ordering a Lid, do i need Filter?
  241. Cleaning the intake... got a couple q's
  242. Complete Exhaust System Recommended
  243. header question... please help
  244. Pics of my new TPIS 90mm TB
  245. Voltage fluctuates at idle only after new alternator?
  246. my macs with loud mouth is way to loud
  247. question about throttle body bypass mod
  248. 78 or 90 mm intake for cam only soon to be H/C car?
  249. air intake question...
  250. Gutting Your Cats???
