View Full Version : Generation III External Engine
  1. Ignition and plugs....
  2. Car SLOWER after headers installed?
  3. 1 3/4 v.s Stepped v.s 1 7/8
  4. anyone have Pacesetters w/ carsound cats?
  5. need pics of 99+ PCV system on car
  6. help me, what kind of exhaust?
  7. Y-pipes
  8. NEED some headers,HELP!!
  9. granetteli maf
  10. elbow for after MAS?
  11. bought FTRA used...what am i missing?
  12. ?????(Headers)??????
  13. true duals over the axle?
  14. Pics of the 90mm LSX manifold and comments
  15. Ducting for 90mm TB's
  16. Passanger side back spark plug?
  17. AIR system modification for MAC's
  18. Cleaning a Maf????
  19. Negative to start car up w/o o2 sensors in?
  20. Need Plug Gap advice
  21. need help -someone with no motor in car
  22. Kooks Headers" 1 3/4 or 1 7/8 ???
  23. autometer oil press guage install
  24. It's TOOO Loud...
  25. AMW catch can
  26. !AIR now smell...
  27. Weird problem
  28. Nice Replacement Alternator?
  29. sealing front of air box w/ CAI?
  30. map sensor quest????
  31. swappin for da smog checks
  32. Magnaflow cat back louder right side ? (2001z28)
  33. Annoying Exhaust noises after SLP header install
  34. LSX w/ Nasty Perf Fuel Rails (Pics)
  35. LS6+homemade EGR
  36. Pictures of Wegner Automotive Research's GMPP LS1 intake & Distributor drive
  37. Are stage 8 header bolts really needed?
  38. Best intake option
  39. throttle cable adjustment??
  40. lingenfilter EGR adapter for LS6 intake.
  41. tuneing after LT and intake swap?
  42. car will not start
  43. What's involved in making a 98 lid work on an 02?
  44. Volume & Power dilemma
  45. Hooker catback vs. Stock SS Exhaust??
  46. best bang for the buck hi-flow cat???
  47. Low oil Light Never comes on?
  48. Header Kits..?
  49. (3) 15MM Alternator Bracket bolt pitch and thread ?
  50. my true dual exhaust, OVER the axle!
  51. Who makes individual runner setups for LS6 Heads?
  52. '98-'99 vs '02 heads - exhaust ports any different?
  53. Duals
  54. Will a regular "GM" drop in 160 thermostat work?
  55. CARB EO: D-215-58 - Edelbrock long tubes legal for '98-'99 ???
  56. GMMG or Supermaxx header package
  57. How much is the FAST LSX intake and 90mm TB????
  58. How many mm does a ported stock TB end up being..........
  59. headers/true duals - video inside
  60. Damn
  61. PiSSED RAWR!!!!!!!!!!!
  62. True duals,x-pipe thru the TA positions
  63. LSX 90mm acc q's
  64. ordering LSX tommorow 78 or 90?
  65. Installing headers
  66. Anyone using the Borla ProXS Muffler?
  67. If you have the QTEC come in!
  68. Just bought the borla
  69. knock sensors rusted *pictures
  70. Jet Hot Headers & Catted Y
  71. NastyPerformance Aluminum catch can
  72. Headers, CARB approval?
  73. Adjust Throttle Cable.?
  74. What can I replace the LM resonator with?
  75. What Is Needed To Hang Exhaust?
  76. Does the LSX intake come with a new MAP Sensor installed?
  77. GMMG + Factory CME?
  78. Exhaust temp gauge sensor mounting.
  79. Moroso Bullet Muffler
  80. Why the heck does my serpentine belt keep coming off at WOT ?
  81. What size Qtec to order for Borla plate?
  82. problem after putting on intake
  83. Are Dynomax Bullets Coated?
  84. Any1 received their FAST 78mm TB yet ?
  85. wanna get a cutout but have a question
  86. Fan problem?
  87. Water Pump & Alternator install/write up needed.
  88. What bellows to run with the 90mmTB?
  89. oil filter?
  90. Hooker LT's and O2 sensors!! THEY DONT FIT!
  91. 3 inch x pipe with mac headers?
  92. Hooker headers
  93. Any idea when Fast 90mm TB's are ...
  94. TB bypass good/bad?
  95. Exhaust Setup Question
  96. Catted y's for LT's
  97. SLP 2OTL vs Hooker - Quieter?
  98. MSD or Taylor thundervolts???
  99. AARRGGGGG power steering mount
  100. Removing the steering linkage. FELP
  101. Super Maxx Headers. Need Opinions.
  102. porting ls1 intake manifold?
  103. can you bust a screen out in a cat?
  104. How much $$$ for a 90mm TB and who sells them?????
  105. Question about Moroso Spiral Flows...
  106. who makes a 1 7/8 header and lets compare prices
  107. ASP Pulley
  108. Change Oil Light?
  109. Anyone running the new 6.0L coil packs?
  110. Service Engine light
  111. Removing smaller serpentine belt/ any HP
  112. Flowtech coated y-pipe
  113. What else to change?
  114. PCV vacuum question
  115. Something doesnt Sound Right
  116. Bump stop mod - went from 3.40mv to 4.68mv at WOT, will I notice a difference?
  117. Little help please
  118. LS1 Coolant Direction?
  119. need exhaust help
  120. will ported TB mess up tuning?
  121. Where to purchase O2 sensors?
  122. LT's ory and bullet or LT's and catted Y?
  123. Header diff/ coated,uncoated,stainless
  124. im starting to think twice...
  125. LOOK whats going under my air filter!
  126. Flowtech Y-pipe install
  127. Removing power steering pump???????
  128. Help with X-Pipe Set Up
  129. elec water pump doesn't fit w/ big TB?
  130. Just dumped the flowmaster for texas speed rumbler!Oh yeah
  131. Trouble changing waterpump.. stock for stock
  132. dielectric grease
  133. Are LT's allowed where you live??
  134. Volant customer service rocks!
  135. Testing coilpacks
  136. Considering going from X back to Y
  137. pulleys???
  138. 2.5" or 3" X pipe
  139. Hooker Catback+Headers
  140. 3 inch y pipe clearance...
  141. How to remove Stage 8 locking header bolts
  142. Can't get drivers side Hooker LT in
  143. How NOT to break the Oil Press. Sender ??
  144. everyone that has removed their A/C
  145. GMMG RWHP gain??
  146. How much power will my MTI 427 Motor pick up by upgrading my TPIS header to Kooks17/8
  147. need help with my mac install stupid AIR tube
  148. GMMG Group Purchase
  149. temp guage?
  150. how loud is too loud?
  151. Sound clips of duals with BIG cams?
  152. a.i.r removel
  153. Exhaust
  154. TSP Rumbler X True Duals Information & Pics
  155. GMMG exhaust to LOUD!
  156. installed asp pully
  157. 98 WS6 Borla exhaust ?
  158. BBK 80mm TB Seized & BBK will not honor Warranty!!
  159. SLP "Loud Mouth" catback question?
  160. Just bought Edelbrock LT's, what emissions do I need to remove???
  161. LT's 1 7/8 or stepped 1 3/4 - 1 7/8
  162. Long tube headers question
  163. Who has done their install?
  164. fast 78 mm TB
  165. Meizeire water pump hp & tq gain?
  166. Which Cat-Back?
  167. Ls1 Ignition Wires
  168. Kooks Headers
  169. spin tech products
  170. Catted Y for Flowtech LT's
  171. Those Of You That Have LT's and Loudmouth
  172. which muffler to use?
  173. SuperMaxx header package
  174. corsa cutout, welding, and SS #'s help
  175. New exhaust setup for T-Rex Cam - opinions
  176. GM now warns about K&N TYPE (oiled) air filters!
  177. Help with TTS headers
  178. Spark plug wire came loose.
  179. Which is more difficult?
  180. Flow? Sound?
  181. VPlus Volt Booster Install Questions ?????
  182. Anyone Install Their Evans WP Yet?
  183. Any differences between OEM and aftermarket SLP dual/dual cat-backs?
  184. Reusable air filter warranty issue?
  185. 25 Megaton Thermonuclear Backfire
  186. TPIS 90mm F-BODY THROTTLE BODYS ARE AVAILABLE NOW!
  187. Are oil pan gaskets reusable?
  188. installing macs this weekend how hard is it going to be
  189. Share Some Info With me on SLP Headers!
  190. Pacesetter Header Fitment Problems?
  191. I need a new cat back
  192. installed headers now stumble at idle
  193. how do you get good exhaust sound w/LTs
  194. QTP or Kooks
  195. What muffler will i need for my true dual setup?????
  196. pop sound when shifting
  197. Pics of TSP Tips
  198. LT's and LM with a Catted-Y
  199. what needed for a ls6 swap?
  200. K&N filter fitment issues?
  201. true duals
  202. evans pump pic!
  203. Electric Water Pump or factory pump?
  204. removing A/C
  205. Which poly motor mount company?
  206. Exhaust Assistance Please.
  207. Accurate Machine Catch Cans
  208. Mids Vs. LT's
  209. Pace setter Problems??
  210. TB Question, Will an 02 TB work on a 99?
  211. GMMG ?'s
  212. What are the 2001 Z06 fuel injectors rated at? And is the fuel pump bigger than F-bod
  213. Costly Mistake? Please Help
  214. TSP Rumbler Video.. (link fixed..check it out)
  215. Jet Hot headers
  216. Hold off on coating Macs?
  217. Flowtech LTs
  218. Which bolt to remove to loosen the motor mount?
  219. Could this be hurting my times?
  220. Any performance gains switching from SLP factory D/D to MAgnaflow catback?
  221. MTI Clear Lid
  222. wont idle at startup after shaner>??
  223. FTRA Owners Come In
  224. Think my alternator is going bad....
  225. anyone get the new 4" QTEC yet?
  226. Quick question ( LS6 manifold)
  227. NEW Under Axle Pics are HERE!!
  228. What is this sound
  229. 90mm T-Bodies in stock at MTI!
  230. Hooker Muffler
  231. comparison between these two headers brands... opinions please!
  232. Ordered Mufflers for TD's: Where Should I Place Them
  233. Do I need to take off my FRC's to change my spark plugs?
  234. SES Light after LT Header install
  235. FLP LT's
  236. which 3 in y pipe with pacesetters?
  237. cheapest place to buy a starter?
  238. Who sells header/manifold gaskets???
  239. Moroso Spiral Flows Vs. Dynomax Bullets
  240. SLP loudmouth "resonator" vs. dynomax bullet
  241. SSRA Owners Please Come In...
  242. Cats Removed ?
  243. Need Opinions: True Dual Set-Up
  244. Anyone with a homemade Battery Relocation?
  245. Any 6.0L iron blocks running a shortbelt.
  246. qtec's and y-pipe
  247. Tell me everything about the QTEC
  248. update:went to the track after switching from borla to lanes true duals
  249. Pacesetter Y-pipe
  250. Lsx Sound question?
