View Full Version : Generation III External Engine
  1. Any Borlamouth clips on cameras that don't suck?
  2. ASP Pulley Belt Sizes and Bolt size...
  3. gaskets
  4. Recirculating Catch Cans?
  5. Are chambered mufflers (bullet style) restrictive & does anyone have flow #s on them?
  6. Squeaking Cooling Fans?
  7. Y-Pipe Clearance
  8. help installing asp crank and alt pulleys
  9. Question about "ram air" mod on an SS...
  10. Rumbler Video Clip!
  11. pics of my new catch can....
  12. Lt's for lowered Z, stock heads and cubes
  13. Installed Air Flow Smooth Bellow
  14. Best header for these requirements
  15. Heat damage from headers??
  16. pacesetter y with flow collector?
  17. broken exhaust bolts
  18. Installed a Accurate Mach. Works Catch Can!
  19. Which provides better power results? aftermarket CAI or stock WS6 intake with K&N
  20. Fast intake(90MM) and BBK TB
  21. colored plug wires
  22. How hard to install off road pipes
  23. ram jet Intake
  24. Will this be too loud for a daily driver?
  25. bbk intake and throttle body?
  26. Headers: Pain in the butt to Install?
  27. Anyone have a list of bolt hole sizes on the block?
  28. Random Tech VS Hooker VS Loudmouth
  29. Will a billet belt tensioner help?
  30. Rasp, what can be done??
  31. QTEC owners!
  32. thermostat comparison - pics
  33. Thread for asp pulley (3 bolts for removal)
  34. Would you recommend Stage 8 Lock Bolts?
  35. Your thoughts on Kooks Headers?
  36. My FAST came in
  37. need help to see if this an LS6 intake!!
  38. How effective are Bullet mufflers?
  39. 02 PCV converted to old style?
  40. Removing Cats...few questions
  41. header help
  42. Looking for Headers!! Help!
  43. Cut-Off Date for LS1 Intake vs. LS6
  44. $2575, Kooks LT's, x-pipe & true duals good/bad?
  45. new headers
  46. LT Headers For a 84 vette..
  47. slp loudmouth or something else
  48. Any Complaints with new Corsa Cat?
  49. Guys running a vacuum pump instead of PCV?
  50. cut out?
  51. How much should it cost for a shop to fabricate a Y-Pipe
  52. Header Gaskets
  53. Autometer water gauge for a 98'
  54. Need opinions of SLP D/D with Long Tubes and OR Y.
  55. Help, have problem, details inside.
  56. Just got my X-pipe and Flowmasters installed
  57. Questions About Electric Cutout Install
  58. custom exhaust
  59. Track only exhaust? This make or loose power?
  60. PCV valve?
  61. Is this the right ASP Pulley for my car?
  62. Headers/ORY questions?!
  63. how hard is it to change spark plugs
  64. ? about LS1 Speed's true dual setup
  65. Pacesetter LT Troubles
  66. LS1 o2 sensors?
  67. simple question regarding: z06 pcv MOD
  68. gmmg website
  69. Forum Director - Marker
  70. Is 160 T-stat worth it?
  71. 01 ta intake
  72. Need help with driver's side kooks headers
  73. Custom Headers - Do O2 sensors NEED to be in the collector?
  74. Do I need O2 sims?
  75. LS1 Headers
  76. Anyone drive uncap all the time?
  77. how can i make my engine run cooler?
  78. Problems running cut-out open on Daily Driver
  79. Intake for heater blower motor?
  80. Ceramic coating
  81. Cars done and now need an exhaust. need opinions
  82. TSP 85mm lid
  83. Ground Clearance between Mufflex 3" Y pipe and Hooker 3" y pipe
  84. I need a QUIET Exhaust
  85. porting the ls6 intake?
  86. True Duals - muffler selection?
  87. What is the EVAP for? and can i get rid of it?
  88. slp fan switch install?
  89. Hows this look to you guys
  90. So what did Elanor have besides Hollywood enhancing the sound??
  91. AIR Removal Question (With Pic)
  92. bullet mufflers
  93. New Writeup: Air pump to vacuum pump converstion.
  94. LG Motorsports Super Cool Radiator - First track experience
  95. Anybody have the MAC headers MAC Hi-Flow Cats??
  96. Removing AIR/EGR equipment ....
  97. Crank threads are stripped? need help here..
  98. Taking motor mount off. I need help!!!!
  99. Which Headers with True Duals???
  100. Help With Mac Headers
  101. Anyone know what amprage the alternator is on a 2000 ws6?
  102. How do you get the MAP sensor out?
  103. Anyone make stainless steel cutouts and/or bullet mufflers?
  104. Is it worth it to ret the 02' fuel rails and injectors with an LS6 intake?
  105. just installed my pacesetters.
  106. asp pulley.
  107. am sold on the cutout
  108. My Magnaflow muffler is developing cracks,check yours.
  109. Unbelievable Question
  110. new pcv theory and easy fix
  111. Check out my new Edelbrock Competition Headers..
  112. Band clamps vs 3-bolt flanges?
  113. Hooker y-pipe and rust?
  114. MAF question
  115. Power steering cooler has slight leak
  116. Adding catback, what combo next ?
  117. replacement headers?
  118. Holley Intake worth it??
  119. What's the sturdiest lid out there
  120. A few Q's before the cam goes in..
  121. diffrence between ls1 and ls6 intakes
  122. How many 02 extensions?
  123. Where can I buy stainless steel chambered mufflers?
  124. Why all the talk about just the LSx?
  125. intake decisions???????
  126. SLP Blackwing Lid vs SLP Air-Box Lid
  127. What's a good replacement for stock headers?
  128. Which Intake
  129. ls6 intake install
  130. Sounds clip of SLP LT's with Loudmouth
  131. Is the FAST LSX worth it for all bolt-on cars?
  132. FTRA Kit.....does it really works ?
  133. LS6 intake a gain on an LS1?
  134. Bbk Ls1/ls6 Manifold
  135. Corsa muffler hanging low?
  136. What kind of power to expect with bbk 80mm throttle body
  137. what is the most quietest catback on the market?
  138. I need better Clamps for Hooker Ypipe
  139. Who sells an X Pipe?
  140. BORLA owners come
  141. velocity stack.
  142. LS1 Hedman Headers
  143. Introducing Texas Speed's Rumbler Cat-Back Exhaust System!
  144. Where do I go to get some quality swiches w/LEDs?
  145. Lighter crank pulley cause HP loss (read within)
  146. What cat/y-pipe are you Pacesetter people using?
  147. Y-Pipe fitment.....
  148. Annoying noise.....
  149. Cats comparison???
  150. Just installed FTRA and Moved tranny cooler
  151. MAF opinions
  152. Sorry another S2/S3 question
  153. I might be getting a set of MACS
  154. belt noise question
  155. 78 and 90 mm fast intake question
  156. Wanna go Deeep. How to get the bass note?
  157. Who's running duals on LOWERED cars?
  158. Whats the TRUTH about MAC headers?......
  159. Stock catback with 410ci + big cam...too much back pressure?
  160. 90mm fast lsx manifold w/ 85mm maf
  161. Do you need o2 extensions with Macs
  162. Throttle Cable Slack
  163. X-pipe and Some bullet mufflers???
  164. Fast toys ram air
  165. Anyone hear of VeForce Mufflers?
  166. buying used hooker LT question
  167. Why not Flowmaster?
  168. Link needed for Jet hot
  169. Will I need headers with 224/224 114 cam?
  170. When is it time for new O2s?
  171. If I Bought A Stock Maf...
  172. Can i run the QTP Ypipe (electric cut outs) with SFC's?
  173. Magnaflow Question
  174. any real difference in the 85mm lid?
  175. How to get exotic sound
  176. Header bolt broke off , will it leak ?
  177. Catch can Question
  178. LT Headers-what HP increase?
  179. combo LS6 PCV and Catch Can comments/ideas
  180. What do you think???
  181. Looking for dual-dual chrome oval tips. Anybody seen a sexy pair?
  182. How do you attach the seperate header on Hookers?
  183. How do you ID Jet Hots?
  184. PCV Oil Catch Can
  185. Most important bolt ons with my setup?
  186. K & N intake??
  187. FAST 90mm TB Update
  188. My fix for Pace Setter Y pipe (pic)
  189. LS6 Intake Manifold, Good to go?
  190. ARE Aluminum valve covers
  191. do you need to use 02 simms
  192. Anyone with a dual/dual over 420rwhp, wondering how much a cutout will help?
  193. Anyone running true duals with chambered mufflers?
  194. Drumroll please.....NOT
  195. Anyone using corsa exhaust?
  196. TTS vs Kooks
  197. hooker vs pace vs macs
  198. stainless header bolts
  199. Guess The HP Gain on These Mods!!!
  200. best affordable Y-pipe
  201. to ceramic coat or not?
  202. Exhaust Question
  203. Some interesting reading on stepped headers
  204. Any 4th Gen's with True Dual side exit Exhaust
  205. meziere WP not making power?
  206. SLP Y-pipe ?'s
  207. Hookers And Slp
  208. Cutouts before the Cats?
  209. anyone?
  210. Gains from Hooker LT Headers
  211. Bellow Dimensions
  212. Light weight battery ?
  213. Quick ?
  214. What Type Of Header Should I Use
  215. Volant and LSX?
  216. Ls6 Intake Casting Numbers?
  217. Would this exhaust setup flow enuf?
  218. Heated O2s?
  219. True dual question
  220. Any high flow cat recommendation?
  221. Power Steering Pump and hoses Part#s
  222. Gut Cats and Stock Manifolds
  223. red bellow?
  224. 90 mm t-body to fit fast intake
  225. Cam is in but not sure if I got the ASP torqued tight
  226. Are high velocity merge
  227. Anyone have their intake off? Need wire color code info for..
  228. OEM Gen IV parts to try out 1st... intake manifold with 90mm TB , hi-flow water pump
  229. P/S pump delete?
  230. Best sounding mufflers for true duals?
  231. <PICS> My new bling Elec Water Pump Race Model
  232. What size collector?
  233. what do u guys think of the BBK throttle body
  234. Who knows something about underdrive pulleys
  235. HOOKER from heads to tips?
  236. question about throttle bump stop mod
  237. Exhaust tips
  238. bellows for new throttle bodies??
  239. Will any torque arm work with true duals?
  240. open headers
  241. Where can I get a new K&N filter/cheap
  242. afs 97 and afs 98 - which is which?
  243. Shaner S2 or S3?
  244. Is there a way to clean 02 sensors?
  245. Alternator: What's required to move it up top?
  246. exaust recomendations
  247. EGR and AIR block of kits?
  248. Dual exhaust installed and dynoed
  249. Stroker 4**ci people, header questions
  250. Zo6 exhaust manifolds?
