- what should i expect at track and dyno..
- Pully question
- front sump oil pan
- how do PPC headers match up to cooks or thunders?
- part#
- Dual Tips
- V6 exhaust on V8?
- Potential of LS1 coils?
- low end torque
- A/C Problems, anyone ever deal with this?
- exhaust install
- Help Help Please
- What exactly does the Injector Impedance Converter do?
- Custom Sheet metal intake's
- Hum on startup...
- What are the adv/dis of the SSRA Super Sucker Ram Air Kit?
- I found some 3 inch stainless, Help me out with duals
- Velocity Stack
- New product - VR Velocity stack
- do pulleys? yes or no?
- FLP's vs. MAC's...
- ??'s for guys running TR6's
- What headers??
- Pacesetter photos and overveiw
- Header Install Question...please
- What's Wrong with my car??????
- Lost Power going from MACs to FLP's!! both ORYP's
- Installed Jet-Hot LT's and catY
- 348 RWHP & 356 RWTQ .....w/PPC Headers >>>>
- Exhaust
- 1 3/4 vs. 1 7/8
- best header on the market ?
- Whats all needed with Longtubes (Hooker/Jet Hots)?
- Corsa or GMMG?
- Power windows going out. Which ones are best, fast?
- Need help fast with Grotys
- Urgent, easy exhaust question...
- Meziere EWP
- QUICK ANSWER needed...MSD plug wire boot sitting on header..
- hooker OR Y work with SLP'S
- Magnaflow Soundclips
- ls6 intake ???
- lookin' for a good cat-back system
- Installed ATI Super Damper and/or Pin/Key Kit for LS1?
- first dyno!
- Finding SLP exhaust ground effect with dual tips
- BIG Problem after FLP install! can a EGR pump create a miss?
- Pacesetter Headers?
- How to ID LS6 intake manifold
- To run a Tstat or not to?
- ls6 intake ?
- Everyone with the BG Ram Air kit, come inside!
- Meizere Street Pump On! WOW... Pics
- O2 sims...codes for efficiency problems....
- Need some suggestions
- Link for Lane's? ..for dual exhaust
- A/C Compressor Rebuild?
- Diff leaking...
- GMMG vs Cutout
- HELP! Trans? Motor mount? Trans mount?
- LS6 Valley Cover Mod...
- im 1k mi. from lanes..do they build and ship to your door?
- X-Pipe In and WOW!!!
- Weld the cutout?
- True dual setup
- Vette manifold on f-body
- First Dyno #s
- weight of a stock 2000 WS6???
- Installing headers for the first time
- Free Ram Air Mod!! Do you actually gain from it??
- any info on JEGS SFI crank pulley?
- people with true duals, please read
- Any Shops Install True Duals in Detroit Area?
- MAF screen.... good or bad?
- cat question? cheating the system?
- Help! Need LS6 Coolant Pipe & Plugs!
- Who carries sheet metal intakes???
- Tinging Exhaust-HELP!!!
- lsx intake
- Duals without the X-pipe?
- BBK 1 3/4 shorties.
- Will an electric waterpump kill my lightwt odyssey battery?
- o2 sensor extentions with hooker LTs
- Anyone with these exhaust sound clips
- Any tips on exhaust pipe removal?
- Input on my true dual exaust design appriciated...
- Elec. cutout OR cat-back
- LS6 intake or not everyone give me your opinions
- Need some help removing dash. PLEASE!
- ordered my pasesetter headers and oryp
- ATI crank pulley
- What Mileage, Ignition Wires??????
- Who sells block off plate for FTRA?
- MAC Header Install
- Meziere EWP: Thermostat or switch?
- pics with egr and air removed
- wire agains heat shield...after header install...
- Any pics of dual cutouts?
- Dual cutouts in the Y pipe, good as true duals?
- Got Random Tech Cats Today
- stripped threads on ASP pulley --- any other way to remove??
- SLP LS6 Intake vs. Holley LS1 Intake
- Electronic Cutout from QTP
- Best quality and performing headers
- Slp maf????
- Any Kooks in here.
- what is the advantage of stepped headers?
- DETREADED OIL PAN
- gains from ported/polished throttle body?
- LS6 Intake Questions
- SLP, BORLA, MAGNAFLOW, ETC.
- ARG! Help with Noise!!!
- Diameter tubing from headers
- PLEASE HELP!!!!!!!!!!!!!!!!CAR MISSING AFTER HEADER INSTALL?
- o2 sims...
- Crossmember w/ LT's?????
- Borla Catback vs. other catbacks???
- Who makes a sheetmetal intake for the ls1?
- Removing A/C housing from fire wall..need help.
- Y-pipes
- changing a 00 MAF for 01
- Who sells IAT adapter harness for upgrade to '01 up MAF ?
- Removing the small red wire to the alternator...
- Looking for a tip on CME removal:
- bottom line on flowmasters?
- fast help! how to properly seal egr hole in intake
- AC delco oil Filter # change???
- ESP NEW SHEET METAL VALVE COVERS
- How much HP will this add?
- Any difference? In Waterpumps that is...
- TCS servo cluster removal
- coolant tubes
- Is there an airbox made to work with the SS hood?
- New Aussie 8 throttle body manifold.
- Hooker????
- Motor out the top
- DAMNIT I'm NOT getting any SES lights or codes...
- Where to find a 2 into 1 Y-collector (3")???
- cutt cats??
- O2 sensor wire routing
- True duals vs y pipe and catback dyno results
- Yanked Pwr. steering kept stock pulley...which belt???
- slp header question ...did you loose top end power?
- Help Me Build a 350
- to cut the egr tube or not cut the egr tube...
- which muffler to stop rasp
- headers to buy?
- What Bolt on's am I missing?
- 00' SS wont turn over, dunno what to do...
- Intake choices
- f body throttlebody work on 5.3 truck?
- Anyone know the size hole for the header bolts?
- Car dies when headlights turn on!?
- Dual Cutouts & SLP LT's
- Cutout.......?
- EGR and AIR question
- Throttle Body Liners? WTF?
- SLP Headers and true dual
- subframe connectors
- Have any of you have problems with this
- cut out
- MagnaFlow Muffler
- 28x10.5x15 ET Drag?
- I changed my belt, and now it whines and throws it off...
- Engine covers for 02 F-Bodys?
- Do I really need an MAF?
- Help!! Header install tach not working?
- muffler delete
- Help me with Rasp!!!
- paging dynatech LT headers users
- Q-TEC exhaust cutouts
- can you reuse intake gaskets????
- Spark Plug Change
- lid and filter?
- PaceSetter Coated Long Tube Headers
- QTech pics inside........
- 911 Please help now!!
- DIY True Duals
- LSX
- tts headers?
- Macs --> Kooks (FI)
- How often do NGK TR-55s need to be changed?
- True duals with BMR Extreme T/A setup?
- Got My True Duals Put ON!
- Merge Collectors
- Crappy Idle
- Who makes a true dual setup for FLP Headers???
- Air restrictor mod
- Dynomax Bullet Installed
- getting some rasp? listen to the clip and let me know
- O2 extenstions
- HELP ME STOP THE RAPPING !!!!!!
- Recommended LT's for custom cam/heads?
- Summary of the new intake offerings coming out?
- NGK TR5 OR NGK TR55 spark plugs
- what plugs to do with?
- Who all makes1 5/8" tube headers?
- Car is idling rough
- The blue air filter?
- Mid Length Headers
- should i get a 160* stat ??
- should i take off my egr valve? pros and cons?
- if i remove the motor mount bolts?
- removing my stock air box?
- Quietest Possible Exhaust
- any tips on installing my exhaust.
- im removing my AIR system,what to do about vacuum tree?
- AIR blockoff?
- Meziere Pics on Milled Heads
- Mandrel Vs. Crush Bends
- any word on the LSX intake yet?
- who sells coil pack relocation kit??/
- Installed Headers had it tuned now we have multiple 02 senso
- What are some symptoms of a bad
- Catalytic Converters
- difference between 98 and 2001 radiator
- Macs on a 2000?
- exhaust sound with no cats? let me know if its normal
- Anyone have pics of polished or chrome meziere pump
- New Jet Hot Y Pipe w/ Cats - Not what I expected
- How much hp gain?
- Muffle down the SLP LM
- PPC dyno numbers
- What do I need to put 01-02 FLP's and Y on my 99?
- Headers
- Kook's Headers For C5 Available Soon!!!!
- Q about Pacesetters and ORP
- True Duals
- what is a good exhaust, header combination
- ? about the SSRA for whoever has it on their car...
- Throttle Body Compatability 99 to 01?
- Underdrive and Alternator Pulleys?
- Pulsing Electrical System??
- Cutout installed today.....HOLY SH!T!!!!!!!!
- any problems with the slp 85mm maf?
- Dynomax Bullet vs the SLP LM vs Hooker
- POR-20 instead of ceramic coating on a y-pipe?
- quietest high flow muffler
- Which of these two setups will work best?
- Hooker Headers AIR Connection popped off on the freeway...
- Part number for the oil gally plug w/ 0-ring...
- Which motor mounts to get?
- Meziere pump come with new gaskets????
- Poly Motor Mount install?
- Flp Headers and Loudmouth?
- Difference in ported TB
- For those looking for an exhaust ......look inside.....
- Dyno Results...........good or bad???
- Header mufflers?
- So i installed the headers finally...
