View Full Version : Generation III External Engine
  1. FTRA or Ram Air?
  2. Drivers side coil pack removal help!
  3. How to wire AIR pump to come on all the time (or with a switch?)
  4. magnaflow
  5. SUGGESTIONS
  6. What do you use to seal a slip fit header?
  7. AIR Tubes???
  8. AIR Tubes???
  9. SUGGESTIONS FOR NEXT MOD.
  10. Ws6 just hooker muff or cat back??
  11. Please Help!
  12. Anyone try those new Edelbrock race headers yet?
  13. I need a sound clip.
  14. Fast Toys Ram Air Installation
  15. Removing alternator
  16. Old School short block to an LT1
  17. slp maf vs. grenalti maf
  18. fast toys cold air.. good or bad?
  19. baffles removed??
  20. asp pulley puller?
  21. Ported MAF or SLP 85 mm,, you pick !
  22. Coolant Temperature sensor
  23. Best quadtip exhaust? Corsa or B&B?
  24. ASP crank pulley problem!
  25. Bassani cat-back ??
  26. True duals with flowmasters sound clips anyone?
  27. Introducing the Austin Bellows: The best looking with no ribs. Pics inside
  28. What next?
  29. GM only or any power steering fluid?
  30. Is this normal for my hookers to rust
  31. What is the part number of the TR 55 plugs?
  32. Mac Header Owners ....??
  33. San Jose guys...need good place to get cutout installed
  34. K&N FIPK
  35. Difference between dash gauge clusters 98, 99, and 00-02
  36. Need Help Getting Driver's Side Header Off
  37. O2 Sensors - front/rear the same?
  38. need true dual sound files....
  39. Katech Solid belt Tensioner (cost?)
  40. Hooker header People HELP ASAP
  41. Would this flow as well as a 4" exhaust?
  42. Where is LS1.com????
  43. Broke the %#&@ oil sending unit off.. HELP!
  44. Carsound HI-FLOW CATS
  45. Stock pulley diameter?
  46. IN NEED OF GUTTED CATS
  47. Cutting EGR tube...
  48. New QTP's a snap to install!
  49. Water Pump Siezed at Track
  50. ls6 intake
  51. ls6 intake
  52. Are Mac cats as bad as they say?
  53. My own FRA contraption
  54. Quiet True Duals?
  55. throttle problem - totally lost
  56. Car WON'T start
  57. MAF vs. Speed Density question(LT1)
  58. NEED HELP PLEASE:Water temp and oil press gauge install???
  59. Header tube dents repaired on car?
  60. nascar type exhaust
  61. whats the best muffler.for this setup
  62. Worried about Raspy Exhaust? > Try the SLP dual/dual
  63. Underdrive Pulley bolt ?s
  64. Having trouble with MAF, keep throwing low freq. input code.
  65. LOUDMOUTH!!
  66. CAI kit - hydrolock?
  67. Lets hear a Meziere update!
  68. Header coatings?
  69. ASP pulley question....
  70. simplify air intake?
  71. Best gap for TR55's going in tomorrow.. help.
  72. BAD VIBRATION
  73. Went from cats to no-cats!
  74. electric water pump
  75. Bolt in Motor Mount...
  76. Yella Terra 1.7 rockers?
  77. LS1 throttle enhancer
  78. long tubes....what else
  79. LS6 intake part numbers
  80. Cutout + Exhaust Question
  81. please help, rasp after LT install
  82. How does stainless steal deal with heat vs. coated headers?
  83. hooker lts
  84. Exhaust Question
  85. new tpis throttle body????
  86. STOCK size of hole in tb blade??
  87. 85mm MAF's? Gains on cars with tuning?
  88. QTP or Thunder race headers
  89. TTS headers and LS6 intake question???
  90. Part of the front bumper where license plate is? Where to get it?
  91. dual exhaust using stock manifolds
  92. Trick LS1 Valve covers
  93. Custom Fuel rails
  94. What is different about the Mass Air Sensor?
  95. Help my hookers please
  96. Help my hookers please
  97. What to do next?
  98. Ack!! is this everything??
  99. Dynomax from Jegs..?
  100. Need some help -- car problem
  101. doin cam, chng belts & hoses (30k Mi)
  102. Went to the exuast shop today (DYNOMOUTH)
  103. Magnaflow a go?
  104. Cylinder #8 misfire after B1 cam install, please help!
  105. Z06 intake and LS6 intake....
  106. maintenance ? - rear end
  107. Plugs change, cut plug wire
  108. weird exhaust sound
  109. 99 shorties fit an 00
  110. Where can i find a list of LS1 Part #'s?
  111. question about BBK
  112. where are the cheap bolt-on's?
  113. Will stainless steel headers discolor badly?
  114. Has anyone tried Predator tuner. Results....
  115. running true duals with stock exhaust.
  116. *Hooker LT headers*
  117. Anyone running Thunder longtubes?
  118. Indexing plugs......
  119. QTP or Thunders Lt's race style...
  120. LT's on lowered car???
  121. Hawker or Dynabatt/etc battery
  122. How to set correct gap on spark plug?
  123. What am I in for??????
  124. A Bolt On Spree!!
  125. need help with exhaust
  126. True dual blues
  127. DENSO IRIDIUM PLUGS
  128. Thoughts on Spiral Flow Mufflers?
  129. Warranty Worries???
  130. Dyno #s on new lid... Jason99TA?
  131. HELP! Header install gone bad?
  132. holley intake won't seal? HELP!
  133. SVO 30# Injector Part Number
  134. true duals before axle or after?
  135. AIR valve?
  136. Spark Plugs and Wires
  137. Did Grotyohann make more than one header size?
  138. Any issues with running customs true-duals?
  139. what is the best spark plug for the ls1???
  140. O2 Sensor question
  141. Someone tell me the best short shifter!
  142. Installing engine from bottom...with heads & headers??
  143. Results from Cat Shootout!
  144. Installing Magnaflow
  145. GMMG OR TRUE DUAL?
  146. How to tell if cats are bad?
  147. Clearance with Pro-kit and Jet-hot/hooker headers?
  148. Random Tech Cat-Backs
  149. where to get cutout cover plate??
  150. Loudmouth vs. Magnaflow
  151. Now my cutout sounds good. B4 it sucked.
  152. Best LT's
  153. o boy....need some help guys?
  154. Stick a fork in me, I'm done.... Friggin' Mac Rasp w/ loudmouth...
  155. question about cut outs? need help!!!
  156. Wisper Lid Install on a 2000 Z28
  157. Misfires
  158. Grotohann Full Lengths
  159. Dynomouth vs. loudmouth
  160. does off road y pipe fits shorty header and l/t headers
  161. Yet another bad Corsa muffler
  162. What should be my next mod?? HELP!
  163. True duels---Any pre-made setups out there?
  164. Opinions on running cats or not......
  165. Exhaust Poll-Please help determine my fate
  166. Easiest way to get water pump gaskets off???
  167. If I do not hook up the AIR system (on race style headers) will it trip a code?
  168. SLP Cold Indection Kit question
  169. EGR VALVE with LONG TUBES?
  170. throttle body issue (bbk)
  171. What about the Stealth Super Intake?
  172. What aboout the Stealth Super Intake.
  173. Car gets power but won't start
  174. true duals --> how loud?
  175. Mac Collector mod question?
  176. last x-pipe related question for me
  177. GMMG vs. Borla
  178. Fuel rail covers
  179. Headers (average hp gain?)
  180. Edelbrock rpm series muffler
  181. 4'' TO 3'' REDUCER WHERE TO I FIND ONE?
  182. Chambered muffler in place of LM resonator, anyone have a dyno or time slip??
  183. Hooker/Jet-Hot Header install pics
  184. NGK Iridium plugs?????
  185. LS1 Intake Manifold ?
  186. What wires do I connect the tachometer to on a 99 Trans Am Ws6
  187. What wires do I connect the tachometer to on a 99 Trans Am Ws6
  188. What did I do to my car?
  189. What wires do I connect the tachometer to on a 99 Trans Am Ws6
  190. Edelbrock Drag Race Headers
  191. LS6 intake Q&A
  192. Full Rt/Lft wheel turn from stop > Front wheels jump & skip
  193. Proform Valve Covers?
  194. ATT: hooker LT people.....
  195. Does this sound like the idler pulley may be the culprit?
  196. Lingenfelter LS6 EGR Intake Adapter
  197. need true dual pictures
  198. SLP CAI?
  199. my hooker lt's??? smoke?
  200. "Zed" cutout !
  201. stock crank pully ** NEED HELP **
  202. ported TB concern
  203. Ok...gotta little cash...which one?
  204. pulley ?'s
  205. Crank Shaft Position Sensor ?
  206. Problem taking off the Ls1 intake
  207. Im an idiot. What happens when I do this.
  208. Spohn TA & True Duals???
  209. Help with dyno #'s
  210. true dual setup?
  211. Pulley question?
  212. help! what do i gap my plugs to?
  213. Anyone make a shorter shifter shaft for the Pro 5.0?
  214. EGR system and Backpressure
  215. Whats the weight of most 3 inch catbacks and a 4 Inch Mufflex?
  216. website on parts/steps on relocating coils???
  217. parts to install ls6
  218. Hooker cat-back w/ORY sound clips?
  219. Fast Toys Ram Air ,, Worth IT ??
  220. Collector Mufflers?
  221. hey guys puttin some gauges in.....??????
  222. hey guys puttin some gauges in.....??????
  223. head light problems on 98 ta
  224. HAL Shock Question
  225. how does dyno max bullet sounds with stock ss muffler ...?????????
  226. SS grille??
  227. Cams, headers, or Cat-backs?
  228. Any websites for changing the manifold???
  229. Custom Bellows
  230. Custom Bellows
  231. TORNADO ??? Does it work??
  232. Max oil pressure after intake install?
  233. One wide band O2 bung or two?
  234. Spark Plug Wires
  235. Will this sound bad?
  236. O2 Simulater ?
  237. ls1 truck plug wires longer?
  238. LS6/LS1 heads- different header gaskets?
  239. Hooker catback sounds GREAT!
  240. Need help with vacume line
  241. Introducing QTP Stainless Steel Long Tube Headers Part II
  242. Wobbling stock crank pulley?
  243. Wobbling stock crank pulley
  244. 02 simms & extensions
  245. AC Delco Rapidfire Question
  246. WIRES AND PLUG?&OPINION
  247. exhaust dumping
  248. Installed Bauer TB today!
  249. blowers?
  250. Pics of SLP Dual Dual Tips on a Camaro
