View Full Version : Generation III External Engine
  1. buying 02 SLP ramair kit, but i have a 98 TA.
  2. what size injectors will I need
  3. problems after MAC install FIXED! :)
  4. where can i get an x pipe
  5. Jet Hot Headers emission question?
  6. PAGING Bret Bauer
  7. This is probably a stupid question...
  8. Fuel System Help ASAP
  9. Who has Grots & SFC's?
  10. QTP Catalytic Y Pipe Info and Pics
  11. Which Cat-back?
  12. Gauge Questions??
  13. Horsepower upgrades? Best options for new body 2002 Trans-Am
  14. Does the SLP aftermarket Lid out perform the OEM Blackwing Lid??
  15. what to do with $2000?
  16. Need cut-out advice.......
  17. Has Corsa fixed the problem???
  18. Need a quick, educated response please.
  19. Exhaust Question
  20. would headers hurt me
  21. Steering funny after Header install...
  22. Roughly how much more power with Grotts over Jet Hot or Hooker LT's?
  23. Headers
  24. What makes the Grott design (QTP&PPC) headers worth $500 more than Jet Hot LT's?
  25. True duals...2.5 or 3"?
  26. High(er) Octane
  27. Alternator relocation bracket
  28. How did you hook up your catch can? Pics?
  29. How to gut cats or know someone who will
  30. Will Dynatech headers help me or hurt?
  31. 99 and 01 engine differences?
  32. Hooker cat-back problems
  33. Question for you QTP Electric Cutout users
  34. Minimal gains with Mac headers and MAFT
  35. Car won't start, need help diagnosing the problem.
  36. Anodized Red TB PICS!
  37. C5 Exhaust...
  38. If you have TRUE DUALS, please come in!
  39. SLP Header corrosion?
  40. How much lower down coating REALLY lower header temps?
  41. How much lower down coating REALLY lower header temps?
  42. Eng Sensor Fuse under the hood???????
  43. DTC P0128 - Engine Coolant Temp (ECT)
  44. Porting LS1 intake
  45. CAM SWAP HELP
  46. Y pipe cutouts
  47. For those with dynomouth...
  48. What does the MAP sensor do? How to hook up to new intake?
  49. NGK tr-55's?
  50. Any experiences with PPC Headers?
  51. I live in Chicago, if I remove EGR, do I pass EMISSIONS???
  52. How to get belt to stop squeaking?
  53. Quick question about cooling system....
  54. turbo kit for camaro
  55. Disconnecting fuel line, with no tool
  56. Whats the difference in Holley/LPE intake revisions...
  57. FLP Headers complete kit, or Hooker Coated Headers?
  58. Headers?
  59. car in garage, wires everywhere, tach needle D.O.A. please help
  60. AIR INTAKE MOD.
  61. LT's help!
  62. Disconnecting fuel line without a tool
  63. how do i rid of EGR?
  64. QTP cutout & Borla
  65. problems after MAC install
  66. Difference in 96-97 and 98-02 catbacks?
  67. Strange Intake Question
  68. LS6 Part # Confusion (???)
  69. headers and muffler question
  70. headers and muffler question
  71. My 2 cents on my bolt-on's so far
  72. WHAT IS VATS
  73. factory driveshaft Q's.......
  74. Dynatech LT's, cat delete, true dual, dynomax bullets.. NO GAIN??
  75. stock ws6 rim key? how to get one if you dont have one
  76. Need to gain 4/10 in quarter, what will it take?
  77. Paging sheet metal intake owners
  78. mac headers no track gain????? help please
  79. Need help on Not LS1 Problem 5.0 camaro
  80. Please help, car is acting up.
  81. Spark plug install. How long typically/
  82. Ported TB's generally richen a car right?
  83. How much will loose.
  84. How to Dyno a Car with vig 3200 stall
  85. Can someone TOTALLY explain GM top engine cleaner
  86. Air/Fuel Gauge install ?????
  87. K/N FIPK ???
  88. What is the meaning of WOT run ?? please
  89. Car won't start, need some help.
  90. Part number or where to find gasket for K&N Filter
  91. FTRA & BG Ram Air kits
  92. Fuel Pump question
  93. HEADERS INSTALL ON LS1?????
  94. Dropping Cradle... A few quick Q's
  95. I need a quiet 3.5" muffler
  96. ac compressor
  97. intake manifold bolts
  98. Best Ported TB? Shaner S2? Bauer? Thunder Racing?
  99. Dynomouth or Borlamouth?
  100. OK to paint ASP pully?
  101. Any AC experts here?
  102. Where can I.........
  103. Spark Plugs
  104. park Plugs
  105. ASP Pulleys? Pros/Cons?
  106. My new Siemens Deka injectors came! (pic)
  107. Coat cat-back to protect from road salt?
  108. Need help with vaccum problem when I removed AIR and EGR
  109. Fuel pressure regulator question(s)
  110. Any of you guys runing Custom Fuel Rails?
  111. Any differences between 01 LS6 intake manifold and '02-03 Intake manifold?
  112. Anyone running the PPC headers?
  113. QTP or McCord?
  114. GUTTING OUT THE CATS..
  115. LT Headers & no cat question?
  116. Got True Duals today!!!
  117. ASP pully insallation question.
  118. Is a ORYP to stock 2002 Hawk exhaust w/ LS6 motor worth it?
  119. What can I expect to see from an LS6 intake and Pulley on my H/C setup?
  120. What can I expect to see from an LS6 intake and Pulley on my H/C setup?
  121. Stock exhaust manifolds - room for improvement
  122. Quick ASP Pulley (crank only) question...
  123. Headers
  124. Unplugging engine wiring harness?
  125. "TICK, TICK, TICK" go my headers....
  126. Best way to weld cats onto ORP?
  127. Tuning after LS6 manifold?
  128. loudmouth ??
  129. Its been asked before.... but lets see if we can get a final answer.
  130. SES light = Messed up CATS?
  131. SS Tube Size
  132. AHHH! Exhaust leaks still?
  133. How to hook up stock air pump for evac system?
  134. 16volt battery question
  135. Need thoughts on whats wrong with my car.
  136. LS6 intake part number?
  137. tuned length header extensions???
  138. anyway to 100% leak-proof LT headers?
  139. so now what does everyone think about their supersucker?
  140. Throttle body bump stop mod done
  141. Running rich after Ported TB installed
  142. mac's vs uncoated hookers
  143. removing coil packs..
  144. Having problems with Idle?
  145. Can't maintain fuel pressure at WOT or turning right?
  146. EGR and Air...if u deleted it inside
  147. QTP cutout question?
  148. Dual Cutout question
  149. All those with the SLP 85MM within
  150. Y-PIPE RUBS
  151. Plug ? w/ new setup.........
  152. Having idle issues with new ported TB
  153. Anybody have an AIR pump go bad????
  154. Access to generator "sense" terminal
  155. removing WS6 hood baffles
  156. What is with the K&N FIPK
  157. ceramic coated vs uncoated headers?
  158. Where to get Corsa Tips?
  159. Car idles good when cold, rough when warm
  160. PARTS QUESTIONS, PLEASE EVERYONE TELL ME WHAT YOU THINK!!!
  161. Loudmouth Sound Clips?
  162. Everybody with asp pulleys please read.
  163. Anyone ever modified headers...
  164. where to get the hose/bellow to connect MAF and Lid?
  165. Help me out with '01 MAF to a 97-98 LS1
  166. Guys with true duals in hre PLEASE!!!
  167. Removing the power steering pulley...
  168. **oil leak help**
  169. Will true duals make a big cam sound bigger?
  170. True dual ground clearance pics needed.....
  171. Do you think this will help me pass emissions?
  172. Kill Switch ???'s
  173. New product - 1998-'00 SLP long tubes with NO AIR or EGR fittings
  174. Duals over axle?
  175. AIR block off plates
  176. what mods next?
  177. LS6 MAF question..
  178. Used a NON-GM top end cleaner...is my intake okay?
  179. Lou Short Stick Help
  180. Non - EGR LS6 intake on a 98' ?????? smog????
  181. what is EGR?
  182. Paging: BAUER - TB info needed
  183. O2 Sensor question
  184. what size injectors to use?
  185. NEED HELP!! Please
  186. FYI > Good info for folks needing to remove crank pulley + P/Ns
  187. what to use for fuel lines
  188. Anyone have pictures of their MACs before install?
  189. Help me out and vote
  190. TB...Yea or Nay...Would I benefit???
  191. Help!!! with Bump Stop mod
  192. header bolt torque
  193. How 2 block off WS6 airbox for Ram air induction
  194. 2000-'02 Hooker long tubes available soon!
  195. Shift Light Install
  196. Jet Hot Ls1 Long Tubes!!??
  197. Jet Hot Ls1 Long Tubes!!??
  198. Jet Hot Ls1 Long Tubes!!??
  199. normal idle speed?
  200. Magnaflow Catback...
  201. What are your experiences w/ the "free" IAT mod?
  202. Fram vs Holley w/CAI kit
  203. FLP off-raod cutouts
  204. Where to get true duals done??
  205. air conditioner dryer???
  206. airbox hood seal
  207. dyno numbers?
  208. SLP LS6 intake????
  209. I have the ls6 intake now what???
  210. quick!!!! What injectors are these?????
  211. What fuel pump and regulator ?
  212. Center Bolt Valve covers
  213. Estimated Power from my mods?
  214. Does the search feacher work?
  215. Great Results from LS6 Intake on H/C car
  216. SES P0302 Misfire after Headers
  217. K&N FIPK with 85mm MAF
  218. Which Thermostat???
  219. Corsa or GMMG
  220. Who has GMMG with an X pipe???
  221. Tranny Cooler install
  222. Coolant Problem
  223. Header leaks
  224. what size dynomax bullet
  225. Thermostat mod
  226. Thinking true duals. Any Exhaust shops in SC?
  227. Relocated coil packs. Show me your pics:
  228. Paging everyone that has put their battery in the rear of the car
  229. Idle hunt questions
  230. car is dieing
  231. bosch fuel pump part #s
  232. Are Stage 8 header bolts worth it?
  233. MAF Sensor
  234. Help! Mac headers rubbing steering linkage
  235. Is the coolant sensor bad????
  236. LS6 Intake part number w/o EGR
  237. Helix TB Spacers... ..Any Input?
  238. BBK TB owners please come in...
  239. Cats with the QTP/Grotty headers and y-pipe
  240. Stock Exhuast = LOUD!!!!
  241. Spark Plugs
  242. MAC HEADERS...help needed please
  243. MAC HEADERS...help needed please
  244. Wanna know what QTP, ORP, Cutout, and QTP Y will give you?
  245. The Ultimate Catback
  246. factory Ypipe
  247. Quick A.I.R. System Q?
  248. Line Lock help?
  249. Car Over hEating... Dead Radiator fans?
  250. Filter Swap
