- LS6 Headers vs. aftermarket when limited
- Silverado 5.3 Best induction
- Any one using the Fluid Damper Pully kit?
- O2 Simmulators
- Hooker exhaust
- Exhaust Noise!!!!
- Exhaust Noise!!!!
- Injector duty cycle ?'s
- Who carries the Muflex 3" y-pipe and Flowmaster collector 3"x3"x4" ?
- Stock alternator pulley WHERE in this world can i find one??
- Do your FLP's bang the floor
- big blocks in 4th gen f-body
- Which jet-hot header .....help
- Headers with no air tubes
- Who makes the best lid?
- burning wires
- need help engine pulsing!?
- 400+hp suggestions
- TB years?
- Porting Holley Intake .... Modifying Runners?
- I need help with belt sizes when using an ASP crank pully.pully.
- Cheapest place to get SVO 42 injectors?
- Power steering whining
- Horsepower with this setup?
- Need help: Dealer prodding around
- Installed JetHot LTs ...
- My car puked something...
- how many people are tens or lower without true duals?
- Witch is the best mod
- guys that are using the 6 liter block?
- Lou's short stick
- How long can you let your battery charge?
- Dynatech headers who has??
- Need help installing Vacuum Guage
- EGR HELP!
- Who has "Dynomouth" exhaust??
- SES Light - HELP!!!
- True Dual Exhaust diameters
- Thoughts on Y-pipes
- Hooker Exhaust
- HVAC question
- Worth buying air tubes for 2000 mac install?
- SLP MAFs
- How safe are MAF porting mod and EGR mod???
- need opinions on exhaust set up.
- DO YALL THINK THIS IS POSSIBLE
- SLP Y-pipe
- where can i find SS CME tips
- SLP longtubes and Eibach pro kit, possible?
- Fuel System Plumbing Question
- questions about loud mouth with ORY
- bolt ons
- Paging Justin Sutton...
- Holley Intake....is there an EGR block-off plate?
- Hooker LT vs Jet Hot LT
- Underdrive Pulley ?s
- So who's making the best ported TB's now?
- PCV traps - another option
- 3" y-pipe with flowmaster collector
- Anyone running a sheetmetal intake?
- Where is the cheepest place to get exhaust components?
- Where to mount the air hose
- GMMG Horsepower ?
- Magnaflow catback FYI
- Best place to buy dynomax bullets
- Holley Power Shot sold out..... Donaldson ok?
- Ground clearance with Hooker LT
- 3rd time i posted this with no response...
- Mounting Holley intake...what mod's are needed?
- SLP CAI or Fast Toys Ram Air System??
- Air Lid Installation Problem
- Y-pipe ?'s
- What exactly do o2 simms do?
- Best Headers
- LoudMouth im Mi anyone have one I can check out?
- which one's
- Mufflex 4" catback
- oxygen sensors
- where to get hi-flow cats?
- Whos got headers, no cats, and a GMMG "chambered" cat back??
- Sparkplugs for T/A
- y-pipe versus true dual sound?
- Whats the best catback for a F-body Ls1 H/C M6 w/ OR y-pipe?
- Fuel Pressure Drop On Acceleration
- Borla muffler???
- Intake Warranty
- Hotrod at MMs tested Hooker LTs
- In 3rd & 4th gear around 5k rpm, the car feels like its loosing power! Please help!
- What do I need to do next???? For more horsepower!!
- Extra Fuel Tank?????
- New Dynomouth!!!
- Whats up with my 02 sims?
- Casting # on a 01 LS6 intake manifold
- MAF Sensor
- balancer position.
- Anyone have any GOOD install instructions for a SLP CAI?
- service engine soon
- Stock car , better get Short headers or LT headers ??
- GMMG, LT headers, and highflow cats Come Inside for Sound Clip
- Project Car Question
- Lifters
- Another true dual question
- intake manifold
- intake manifold
- Fuel tank on a 3rd gen
- tr-55's
- AIR for ORP?
- AIR for ORP?
- Choosing the right headers
- lid problem... help!
- Can i swap a 98 camaro LS1 intake and a 02 LS6 intake across??
- IAC motor becomes a projectile!!
- Ls1 intake with H/C..vs LS6
- Fuel pressure is droping during acceleration
- Oval exhaust, true duals. Anyone try this yet?
- True dual question
- At what point do you upgrade fuel system?
- WHat is an LS1 intake worth???
- What is the RIGHT part number for poly motor mounts?
- Adjustible fuel regulator LS1
- 2nd Fuel Pump ON Switch Trigger?
- Hooker LT on stock internal, Befor 13.98@110 After 13.50@114
- comments - suggestions WANTED! on installing MACs
- good bolt ons for 02 SS
- CME with "loudmouth," possible?
- what sparkplugs are best?
- Diagnostics Code P102? Has my MAF Sensor Gone Bad?
- Loudmouth vs. Hooker catbck
- do 98's respond to MAF different than 99-02?
- Do you have to change the oil after spraying AmsOil Power Foam into your engine?
- Hard to put this in a sentence
- Car feels slower without cats...
- Mac headers on my 2000 Z?
- Paging Colonel...
- MAC True FitŪ Header Systems
- SLP LoudMouth too loud?
- Any Help Appreciated
- LoudMouth to Dyno Mouth conversion
- Throttle response?
- UH OH!!! I got an SES light this morning!!!
- I got an SES light the morning(after spraying it last night)
- Factory Y-Pipe
- Screeeeeming pump
- Where to get the cheapest fuel pump?
- Not sure bout Radiator
- Exhaust
- Gain from mac+cats to TTS Lt's with off road pipe
- Tick, tick, ticky-tick of my lifters...
- LS6 Manifold Question.....
- Throttle Body and MAF Air Sensor
- 00-02 lids require a breather filter? What is this all about?
- Where do I need to go next
- Since the FTRA is made of stainless steel...does it have the heat soak issue?
- Drill Mod Question
- A way that might stop PCV oil problem!
- macs?
- Does anyone make a x-pipe for the LS1??
- GM top end cleaner?
- PCV valve??
- Who has run a short belt on an ASP pulley???
- Filter Oiling Question
- Educater guessers chime in...winner gets a cookie.
- I want Loud mouth but I have CME any ideas?
- Where to buy collector for custom y-pipe?
- I had true duals installed yesterday!!!
- WILWAXU
- Clunking sound from rear over bumps...
- Opinions on Magna Flow cat back???
- Idle Question After Boltons
- Help!!!!
- Hooker y-pipe banging floorboard?
- who ports throttle bodys
- Borla: No plate vs. Capped off
- Easiest Way to clean the MAF?
- for guys that did all the "mac mods"
- Injector Requirement Formula
- which spark plugs?
- modifications for fuel pump?
- Has anyone changed from FLP's to.....
- Porting Maf Ends and Throttle Body
- Need Help Diagnosing a Problem!!
- MAF question????
- ford racing injectors or..?
- So is a lid a lid, or what??
- what is the next mod??
- PPC Headers?
- Which belt??
- What's the short belt mod?
- Holley Filter Oiling Question
- Broken Wiper Arm.......Help
- Inline v.s. intank...
- Please HELP!!! Fuel System
- Short Belt Mod?????
- Y-Pipe Comparison
- Ran FLP open headers today; results
- Throttle body hole size help
- Which Headers?
- stock cats on MAC ORP
- TBB equipment
- 15W-50 oil too thick??
- MAF
- Part number for gm tri-metal head gaskets
- Does anyone elses car smoke at WOT with headers?
- does you LS1 smell when you turn if off?
- what sounds better w oryp gmmg or borla
- Did some dyno runs.. wrote small reviews
- who has installed a intake fuel pump on a 2000?
- Ported TB ported massair, ASP worth how much
- Stock crank pully Q
- Reinstalling stock pulley...
- Is it possible for headers to cause oil consumption?
- mufflex 3.5" catback
- pics of true duals
- Donaldson vs K&N?
- 30lb inj. yes or no?
- do ls-1 use a different kind of pully puller? Where can i get one.
- Got some new Stage 8's
- Pinging
- My supersucker is different than my friends?
- spark plugs
- should i get asp underdrive pully with my heads and cam
- Questions about stock fuel line and 50 lb injectors
- Replacing knock sensors
- Battery
- Help with removing crank pulley
- Fuel Fitting Adapter?
- Lakewood driveshaft loop for Camaros
- 160 thermostat what should....
- Ported TB on stock LS1????
- Underdrive pulley????
- What thermostat should I go with?
- Faulty catalytic converter causing detonation?
- 02 ss warranty
- Anyone that has had their master cylinder off on their Clutch, I need help!!
- Random Tech or SLP Y-pipe ?
- Another place to re-locate coil packs...
- TR 230 guys which exhaust twin 2 1/2" or twin 3"
- Who said you can't change plugs from theTOP?
- bought hooker lt's and i need a y-pipe i dont want to use theirs
- What are the flow numbers for CNC stage 1 LS6 heads compared to Stage 2 LS1 heads
- Ported Holley or LS-6 intake???
- Jet Hot LT Dyno #s in here!!!
- BG Ram...do I also need a lid?
