View Full Version : Generation III External Engine
  1. G2 Y-pipe from L-G Motorsports
  2. Par # for short belt to use with ASP pulley?
  3. Any problems or tuning after LT install I should be aware of?
  4. Tubes and hookups on the back of an LS1 intake manifold
  5. Why isn't there a freer flowing intake manifold?
  6. Whats the best catback to run with FLP's and high flow cats?
  7. Hooker LT's on 02 Z28
  8. True Dual users... c'mon in!!
  9. Urgent!!! SES LIGHT??
  10. SLP linelock install...dont work....
  11. FLP+LOUDMOUTH=WHAT
  12. lenght for O2 Sensor Extensions ???
  13. Update...relocation of coil packs...
  14. whats louder???
  15. QTEC Mounting question
  16. please share your exhaust sound files
  17. anyone from ARE please respond
  18. Custom 1 7/8" to 2" stepped headers vs. QTP 1 7/8" headers
  19. 160 thermo.... questions w/ install
  20. no oil touches it...
  21. 1.75 inch long tube LS1 truck header will be available February 2003!!!
  22. Anyone modify an SLP 3" Y pipe to fit their Grotts?
  23. cutout in I pipe????
  24. Stealth airbox v. regular airbox
  25. Is there any difference between the Fast Toys and Whisper ram air kit?
  26. Why the special y pipe.
  27. Aluminum Intake Bolts
  28. Whats the best exhaust set up with FLP's?
  29. 98,99 ORY on 00 car???
  30. What size fuel injector...
  31. Advice on setups
  32. where can i find a good hooker long tube header install document??
  33. Magnaflow.....
  34. Just bought New 30lb SVO Injectors, ??? though
  35. SLP Bellow collapsed??
  36. Planning on buying a bellow, what are the sizes on the ends?
  37. Does anyone have trouble with FLP's being too long?
  38. Steering wheel shakes when braking..HELP
  39. Stealth Lid--Horrible MAF placement??
  40. STEALTH and FTRA (Good Combo???)
  41. SS front end alignment..
  42. which merge collector?
  43. Does anyone know how to get a truck intake manifold to fit in a Camaro?
  44. Fan Switch Problem
  45. DELCO battery = leaking piece of junk.
  46. Where can I get a block off plate for the EGR?
  47. Is it bad to overfill oil?
  48. Why does my car.....
  49. help with getting true dual setup...
  50. Car surging after o2 simm install
  51. Bullet install and hacking off stock muffler?
  52. current times
  53. CRANK PULLEY
  54. spark plug install
  55. Any input on the Quicktime dual cutout Y?
  56. --since we dont have a section dedicated to tools--
  57. Problems With Free Mods
  58. mac headers
  59. Header question
  60. AIR and EGR gasket part numbers??
  61. Mac 98/99 ory pipe to fit a 2000 what mod's are needed
  62. Holy MisShift Batman!!!
  63. Borla exhaust vs stock WS6 exhaust
  64. is the catback worth it ?
  65. help with LT welding
  66. Post pics of your custom y-pipe
  67. Battery dead...rear hatch won't open
  68. Q, what to expect for tenths and mph in quarter with these mods
  69. Where do I go to delete EGR and AIR code???
  70. Steering link removal questions.
  71. still problems with my TB
  72. Do headers "always" richen up an LS1?
  73. cat gone bad?
  74. Hi flow cat??????
  75. 160* vs 180* Thermostats
  76. california emissions....
  77. Will my car pass emissions without EGR provisions?
  78. Hooker Vs. QTP quick help
  79. Questions pertaining to tuning with maft on stock MAF vs. Aftermarket MAF.
  80. MAF ends
  81. Why isnt the Magnaflow Catback More Popular?
  82. just got magnaflow
  83. Plugs and Wires....
  84. Buying new tires.....
  85. 91 octane?
  86. ls6 intake port sizes
  87. Any special tricks to applying header wrap?
  88. QTEC cutout vs Loudmouth
  89. Q about MAC headers or Hooker LT's
  90. Help with Valve covers, coil relocation, and PCV
  91. Will NGK TR55's void a factory warranty?
  92. What would happen if I "removed" the PCV system?
  93. Help......spark plug in wrong!!!!
  94. got my intake bellows
  95. mac headers on 2000
  96. which injectors???
  97. What should i have my G/F get me for my birthday/chsitmas?
  98. 2000 mac headers on 2001 is it possible???
  99. how does the PVC system actually work or what does it do?
  100. where to get 42 lbs injectors???? need help.
  101. MAFT requires w/ ZO6 MAF?
  102. Who has tried the sweet-thunder bullet on their true duals?
  103. EGR pipe on Grot's broke - fix?
  104. SVO INJECTORS
  105. hp and fuel sys
  106. Dynatech Y?????
  107. what injector size and what brand??
  108. Anybody have dyno #'s for hooker LT w/O.R duals compared to stock headers and borla??
  109. NGK TR-6's or NGK-Iridiums????
  110. ported my own throttle body today
  111. SLP CAI worth the $
  112. Question about 2002 Ram air
  113. Odd hooker long tubes????
  114. Misfiring, HELP!
  115. Few true dual questions, especially for Chicago area
  116. SLP headers.....rwhp gain?
  117. Remote Start
  118. Radiator question
  119. Fuel Pump......
  120. Any estimate on what Im pushing to the wheels?
  121. LOUDMOUTH EXHAUST
  122. ??? on y pipes
  123. What size injectors...
  124. Dual exhaust w/ cats
  125. Eliminating the cats
  126. Hooker LT
  127. JetHot vs hooker collector design
  128. New Jet Hot Header pics
  129. Fuel Pump issues...
  130. Mac header worth $500?
  131. Maf Ends?
  132. Anyone have SES after header install?
  133. Best gauges??
  134. Questions on TR Whisper lid pack w/SLP cold-air, PowerShot or K&N...
  135. Ported MAF ends price
  136. Just curious about the pcv in a 98?
  137. Any difference in N/A performance between TR-55 and TR-6 plugs?
  138. Alternative to GMMG?
  139. What should be my next mod?
  140. Oil Pressure ...PLEEEZ Help
  141. Plugs and Wires
  142. Garage Size
  143. BBK 80mm Throttle Body ?
  144. Why has any one not asked this question yet?"
  145. How do i tighten the throttle cable? TB stop mod
  146. ? on free mods.
  147. idel
  148. LS1 to LS6 H/C Swap, LS6 MAF?
  149. Edelbrock
  150. Nitrous plugs hurting power N/A??
  151. Whats a good throttle body cleaner that won't damage plastic intake?
  152. help on deciding which headers
  153. What kind of REAL-LIFE gains with ASP pulley?
  154. throttle body spacers
  155. advice on headers
  156. Paging NICK FILPPIDES (Kooks LT)
  157. sealing airbox......????
  158. Autometer gauge, roll cage mounts
  159. Stupid question...were's the PCV ?
  160. The Ultra Z hood will give me more hp ?
  161. Kooks Headers and custom exhaust
  162. Changing generator bracket???
  163. Shorty headers questions
  164. ned help on litle bro's LT1 problem...
  165. Need Help Fast!! Got crank pulley half off and...
  166. Will it hurt performance if I don't have all 3 bolts in the Borla plate?
  167. slp y pipe
  168. #'s on new Jet Hot's
  169. CLUTCH STICKS to the FLOOR
  170. New to the board, just ordered SLP headers.
  171. Fuse cover
  172. Bad O2 or Bad wire or wtf just break stuff
  173. Tips On Spark Plug Install
  174. dual or single??? w/LT's
  175. What Good Factory Bolt-ons Can Do
  176. Borla wide open vs. Loudmouth
  177. Where to find the Loudmouth for the cheapest price?
  178. Which resonator has the best flow and sound?
  179. Can i run cats on my exhaust if i get EGR and AIR deleted and removed?
  180. Need all info on Hooker LT's !!!
  181. Stealth air box vs. BG ram air
  182. RTV silicone sealant and 02 sensors dieing
  183. Best Fuel Pump
  184. question about re-oiling holley
  185. HELP after Hooker LT install
  186. I have no idea where to post this, but...
  187. Backfiring! WTF
  188. Bauer racing throttle body
  189. TR-55s or Champion spark plugs?
  190. Muffler or full cat back system?
  191. how do you get the spark plug and wire for the #8 cylinder out
  192. Does anyone have flow #'s for different exhaust pipe sizes ?? Searched with no luck..
  193. Difference in coated or plain headers?
  194. fuel pump and injectors?
  195. Quick question > What are TR-55s gapped at?
  196. Hooker LT's and Y-Pipe ??
  197. aletator pulley
  198. short belt part number?
  199. Question on Hooker headers and automatics
  200. Home Ported TB
  201. Got Baseline dyno numbers from Speedtek today!
  202. Fuel Rail Surge Damper mod question????
  203. What plug wires for relocated coil packs?
  204. 346 cid, 430rwhp+, what plugs/gap?
  205. Am I running lean/rich with my mods?
  206. How to install a LS6 intake?
  207. Pulley Puller?
  208. need some help please
  209. one qustion please..!
  210. Running Lean and Rich questions
  211. Ported throttle body
  212. MAF ends?
  213. Dual Cutouts....Yay or Nay
  214. Whisper owners-check your lid!
  215. Is it worth changing out a SLP D/D muffler for a B&B muffler?
  216. Difference between 98-99 and 00+ Throttle Bodies
  217. Fuel Filter change?
  218. Is the loudmouth the best?
  219. pulley ???
  220. TB Question
  221. Why is my car so slow ?
  222. I want some 12's w/out conveter, gears, or headers..... read on.
  223. TB Bypass
  224. Coolant Type - What to use
  225. Complete EGR system removal questions.
  226. H pipe
  227. billingsley a/c delete plate???
  228. Ravin Exhaust
  229. Preparing for JET Hot LT Install (advice plz)
  230. Anyone try putting the XR1 muffler on the LM?
  231. whats the size of the thread on a O2 sensor?
  232. Need help on pulling motor from top.... quick!!
  233. gutted cats, now the motor is pinging?
  234. Grots (QTP Headers)
  235. FLP dual turndown option (picture)
  236. Vacuum leak???
  237. FLP header dual cutout option (picture)
  238. Removing MAF screen????
  239. Baker hose for K&N FIPK system.
  240. hesitation between 2000 and 3000 RPM
  241. LSI Crank Pulley
  242. What's the diameter of the primaries on Mac Headers?
  243. Where can I find 02 ZL1 replica front grille?
  244. Where can I find 02 ZL1 replica front grille?
  245. High Flow Cats?
  246. Spark Plug Gap????
  247. Does anyone's lid make a whistle sound?
  248. Factory water pump who's lasted the longest?
  249. Cat Swap
  250. Finished x-pipe duel today!!!
