PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 [277] 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315
  1. Looking for your exhaust recommendation....
  2. Which XR1 for LM
  3. newbie here, what should i do?
  4. Spark plug gap for n/a cars
  5. Magnaflow Pics
  6. Will putting on my LT headers richen up my Air/Fuel??
  7. Pretty set on hooker catback. Any others worth considering?
  8. Running battery to back of car?
  9. Proposed exhaust setup...
  10. full length pacesetter headers on ebay?
  11. MAC vs Grott dyno #s
  12. Dual owners, anyone have 2 1/2 inch pipe?
  13. Electric Cutout pass Emissions(visual test)
  14. Edelbrock true duals preliminary pics
  15. Thought it was suspension squeaking, but its motor related
  16. Water Pump Stuck to Block
  17. Air Bag
  18. Headers
  19. Checking wiring
  20. Spark plug #8
  21. O2 extension locations
  22. What Plugs should I get??? NGK TR##IX????
  23. Super Sucker Ram Air scoop for the FTRA
  24. borla
  25. Could a ported TB cause a low/rough idle?
  26. Tips for disconnecting the steering linkage?
  27. Bought a dyna battery like the one on thunders website HELP!
  28. FLOWDISASTER!!!!!!!!!!!!!!!!!!!
  29. Need help with header install quick
  30. Thanks for everyone's help on Exhaust....
  31. What compnay has the premade true duals?
  32. Crank AND alternator pulleys, or just go with the crank?
  33. What belt to use without the power steering pump/pulley
  34. Those using Dr. Gas X Pipe, need help ASAP
  35. Impressions of Magnaflow over Flowmaster 80 series......
  36. Installing cats
  37. Loudmouth
  38. Pics of TSP Lids?
  39. air/fuel pod hat shows ratio????
  40. headers
  41. Hey Silver TransAm those dual/duals.....
  42. Stock Throttle Body Hole Size
  43. Re-position MAF?
  44. Next mod???
  45. MTI vs. TSP lid: Which is best
  46. Lokar throttle cable
  47. Forum Director - Marker
  48. Who runs FLPs with the dual dual and CATS v. OR pipes
  49. Pacesetter Y-Pipe: am I missing something?
  50. My new PPC headers
  51. Valve Adjustment on LS1
  52. Be Cool Radiator Has Arrived
  53. Best entry level ignition system?
  54. How to check a plug wire to see if its bad?
  55. To dieletric grease or not to, that is the question
  56. which Y-pipe to use with the edlebrock headers
  57. TB drill hole size
  58. I need to add a muffler to LM . where and which one?
  59. Another good day!!!!!
  60. Where to put water temp gauge sender?
  61. People that have installed tranny coolers, IN HERE.
  62. cold air intake
  63. LS6 intake????????
  64. Questions on TR6 spark plugs
  65. PCV modification, what are my options?
  66. Can a mismatched set of plugs cause Knock Retard??
  67. Opinions on cats needed.... Please!!
  68. Relocating fuse boxes?
  69. Guys with Mufflex Y pipe....
  70. Check out this Electric water pump!
  71. Just Installed FLPs On A Vette...
  72. Anyone have the TSP intake package?
  73. Got my T.B back From Bauer.........
  74. New Corsa exhaust and HUGE gains in gas milage!!!
  75. ORY + O2 simms = knock???!!! help...
  76. Can Anyone Help?
  77. I F***ing HATE Dynatech headers!!
  78. Knock Sensor Install - Help Please!!!
  79. Installing coil packs???
  80. Magnaflow...
  81. Stock exhaust?
  82. crankcase vacuum
  83. Is a Corsa Exhaust loud????
  84. What gap for NGK TR55s?
  85. Electric water pump?
  86. mac y-pipe with cats
  87. Are 2 1/2 inch duals enough ?
  88. Lowest price for a new AC compressor???
  89. New LS1 intake.. Coming Soon!!
  90. best mid-length headers and y-pipe combination?
  91. GMMG Muffler
  92. Header Install ????
  93. Plug gaps
  94. Banks Exhaust
  95. The very cheapest youve seen the LS6 intake....
  96. best Sounding Muffler?
  97. True Dual People - What Muffler you using?
  98. Where to buy 18" Dynomax Bullet Muffler???
  99. Dynomouth or Muffler
  100. Cats or NO Cats
  101. All possible reasons for a cylinder not to get spark?
  102. Low end loss w/ LT's????????
  103. Header y-pipe install prep
  104. 160 T stat......worth it???
  105. DIY Manual fan switch.
  106. Cooling problems!
  107. Pacesetter headers?
  108. SLP Cold air as good as FTRA or SSRA
  109. Exhaust system inquiry
  110. racing use only (?)
  111. spark plug gap, whats the deal??
  112. 1 7/8" Kooks sound AWESOME. No more rasp!
  113. Electric Cutout vs. SLP LoudMouth...
  114. Corsa Premium Pro- Series Tips ?????
  115. Smooth Bellows: The cheap way
  116. dual exhaust
  117. Anyone have a Corsa Exhaust Clip?
  118. Just curious...what is the exhaust popping at cold start
  119. harlan light and battery swap
  120. Macs
  121. Thanks for your opinions, what about air out now.....
  122. lingenfelter intake manifold question
  123. Those who have SLP headers......
  124. High flow cats?
  125. Putting together a QUIET high flowing exhaust...
  126. hooker cat-back exhaust for sale
  127. Hot Rod Power Tour 2003
  128. GMMG exhaust question
  129. Part numbers for stock and truck PCV setups?
  130. Pictures of Pacesetters Coated and installed!!!!
  131. Header and loudmouth
  132. Please help me out with gauges
  133. Airbox opening on WS6 vs Firehawk?
  134. Need Site Information for Cats
  135. What was your gain from adding headers?
  136. what's the deal with the A/M intakes?
  137. Are there any aftermarket belt tensioners?
  138. electric cutout on stock exhaust
  139. LS6 Intake...Never expected...
  140. 1 3/4 vs. 1 7/8 kooks headers
  141. Will this be too loud
  142. SLP maf Vs stock maf
  143. Reading Spark Plugs..need some help
  144. 3" True Duals + G2 Super Springs = no ground clearance
  145. Anyone have a picture of a stock LS1 power steering pump?
  146. Blackwing Lid?
  147. JetHot's new Y pipe for Hookers with Cats - details?
  148. Question About New Exhaust Setup....
  149. Finally took some pics of my exhaust
  150. Serious Serious Problem!!!! Please come in
  151. Serious Serious problem!!! PLEASE COME IN
  152. Loudmouth with dual QTEC's
  153. what should I gap the NGXTR55IX?? at..... 50 ?? 55???59???
  154. Externally balanced 382 stroker + ASP pulley???
  155. The Big Brown Truck dropped off a present for me
  156. Need new battery, which one
  157. Header install question, involving oil dipstick
  158. Is this a LS6 intake......pic inside
  159. Problem with car...
  160. Kooks headers
  161. Gages in A/C vents
  162. Does this car have headers on it?
  163. Header install question
  164. Dynatech Weld-on Collectors
  165. need somebody to fabricate exhaust
  166. Need a Muffler
  167. stiffer steering???
  168. Which spark plugs to use?
  169. Header Bolts
  170. Need help with Header,Cat, Y-Pipes.......
  171. First Modification to my 98 Trans Am
  172. Serpentine belt flying off...
  173. Headers dyno sheets? 1-3/4 vs. 1-7/8???
  174. Spark plug install question
  175. CSI LS1 Waterpump
  176. LSS installation ?
  177. Is it worth changing from 2.5 to 3 inch dual exhaust pipes?
  178. magnaflow exhaust
  179. PROBLEMS WITH A LEAK ON THE STEERING PUMP!!! H E L P !!!!!!!
  180. Iridium plugs....
  181. Having problems with rough idle,help please
  182. Will the new LSX intake be considered a bolt-on?
  183. LT's with Bullet too raspy/loud?
  184. Have to tune computer with header install?
  185. Headers & Dyno sheets
  186. bolt up dual exhaust???
  187. does anybody make a "Bolt up" dual exhaust for ls1??
  188. post pics of your custom X pipe
  189. LoudMouth with Dynomax Bullet-At the same time???
  190. Hooker's are on!!!
  191. Header addition ? power
  192. Edelbrock LTs...
  193. Plain duals vs duals w/X pipe
  194. Anyone hear of ravin mufflers???
  195. Short Belt Question - Pro's vs Con's
  196. Which platinum plug?
  197. cutout on a 2001 SS QUESTION
  198. Which mod next?
  199. What are good clamps for the exhaust?
  200. 1 3/4 or 1 7/8
  201. Kooks-Dyna Tech- QTP
  202. Sensor Connectoe Help required ASAP!!!!
  203. Bump Stop Mod Question
  204. Decisions, Decisions...Intake or Exhaust.
  205. dynomax or magnaflow to put on loudmouth
  206. TSP Carbon Lid question
  207. LoudMouth vs. True Duals
  208. Bad Fitment-Kooks Y-pipe
  209. Question about the DYNA BATTERY from ThunderRacing.
  210. Service Engine Soon Light
  211. QTEC headers & Dyno sheets
  212. maf housing question
  213. TCI 3800 stall w/ stock 3.23 10 bolt, too loose for street?
  214. SLP headers
  215. More evidence that good Y-Pipe matters
  216. Electric cutouts?
  217. Throttle Body ?
  218. FIPK
  219. Stock vs. SLP Loudmouth RECORDINGS HERE
  220. Bauer T.B question?
  221. Random Tech vs. SLP or Borla Y-pipe...any suggestions?
  222. got my QTP LT's
  223. Cant decide on exhaust:Loudmouth or Magnaflow
  224. When are we going to see a header shootout??
  225. Hooker Headers Install Tips
  226. MAF ?
  227. Discussion: Fuel system cleaners
  228. Exhaust leak??
  229. How easy did your FLP's go in?
  230. Long tubes vs. shorties vs manifolds
  231. Headers
  232. Radiator fan/shroud?
  233. Radiator - Low Coolant Sensor Location
  234. magnaflow true dual setup?
  235. True dual setups and muffler clearance
  236. Anyone running WIde Band O2s?
  237. anyone have charging problems after pulley?
  238. NO more rasp w/ mt mac's & ORY
  239. Is this intake a LS6 intake?
  240. Looking For audio Clip Hooker LT headers w/SLP Loudmouth
  241. KooKs header Group Purchase
  242. Is a 2000 MAF the same as a 2002 MAF??
  243. Kooks 1 7/8" header install a breeze!
  244. loud exhuast??? gears??? wut else???
  245. MAFS ?
  246. Compression Test: What is a normal reading for LS1?
  247. Autometer coolant temp gauge install ?
  248. o2 Simulators
  249. stainless vs coated vs ...
  250. Spark plug wire; metal shield around boot...
