PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 [280] 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315
  1. will LS1 borla fit on a LT1
  2. If your post is locked - Read Here
  3. What is the best LTs for a lowered car?
  4. need "Top End Cleaner" advice
  5. Are my dyno numbers up to par?
  6. Tore up FLP clamps with iron block setup....
  7. Headers......on Ebay, but still.....it's a killer price
  8. Anyone running the Jeg's harmonic damper
  9. Crank pully size...what is better?
  10. What are the best times for A4s w/ bolt ons and DRs
  11. Just added Jet hot header and off road Y & dropped 2mph
  12. back of serp. belt wearing away after asp
  13. Where do these ground wires go?
  14. SLP loudmouth Duel/ Duel yea or nay
  15. True dual pictures
  16. Starter Solenoid HELP!!!!!!!!
  17. Car is Running WAY to Hot Hot Hot..........
  18. Has anyone problems with justin sutton sending parts??
  19. How do I know if pully needs machined??
  20. what muffler is the best...X-pipe involved...Opinions please
  21. HOLY Crap listen to this exhaust by GMMG inc.!!!
  22. Pulley replacement......
  23. Need info on short belt for our cars
  24. What have you heard about ported MAF ends
  25. Exhaust collecters?
  26. Purpose of the EGR?
  27. Kooks or Jet Hots GP???
  28. Extreme Volume Video of QTP Headers
  29. Corsa on the ground, need some advice...
  30. will a 01 whisper lid fit a 99
  31. Need help with smooth bellows FAST!!!
  32. Exhaust backpressure???
  33. aftermarket valve covers
  34. Bad coil pack......What are the symptoms....................
  35. No AIR/EGR Race headers and VET testing?
  36. Disable the converter lock-up
  37. EGR or no EGR, that is the question....
  38. Y pipe/cats with dual cutouts
  39. Gains from LT headers inside
  40. Okay to Get LS6 Manifold at a Junkyard?
  41. Can header and Off Rd Y cause my car to ping (run lean)
  42. Ported Throttle Body ???
  43. Error DTC P0782 2-3 Shift Malfunction?
  44. looking for ideal location for Autometer water temp sender.
  45. FLP Install
  46. update...
  47. How can I block off the EGR on my intake?
  48. help with pullies
  49. Hesitation / Bounce Problem HELP!!!!
  50. Where is the link to the "free" thermostat mod?
  51. Wahoo!!! LS6 Intake Manifold
  52. Are 99s different
  53. bauer TB
  54. home made smooth bellows
  55. Electric Water Pump
  56. SLP headers or Hooker headers or Jet hot headers
  57. GMMG.......
  58. What do you guys think about the new ls1edelbrock longtubes
  59. Line lock question?
  60. Pressure test coolant system; need to remove thermostat???
  61. Which air lid?
  62. WHERE TO GET LINE LOCK?
  63. McCord Powerplate
  64. What bolt to seat stock crank pulley?
  65. 1 3/4 or 1 7/8 headers
  66. Where is that post that has weights of everything
  67. My belt squeeks bad when I shift at high RPMs
  68. First time on dyno
  69. need to swap out my SLP LM....SLP DD or Hooker???
  70. SLP Air Lid Rubbing, HELP!
  71. Where can I get TR55's and LS1 edit fast
  72. BRINGING CAR IN FOR PISTON SLAP NOISE!
  73. Anyone running the CAT damper??
  74. LS6 Intake Leans Car
  75. how much power am i missing ?
  76. New dyno #s with the better exhaust 707.0 rwhp 721.8 rwtq
  77. Pulley install,.. remover tool "nipple" is stuck in crank
  78. exhaust exiting in front of rear wheels
  79. Mufflex Y-Pipe and Hooker LT question.
  80. thre belt off without spinning high rpm's???
  81. Belt is walking off pulleys......
  82. Electric Supercharger? Do they realy work?
  83. where do i get coil relocation brackets?
  84. Problem after TB Bypass HELP!!
  85. Which Stock MAF Would You Buy?
  86. GUYS WIT
  87. For those of you that have Hooker LTs
  88. x-pipe
  89. Solid motor mounts, pros and cons
  90. the best set-up
  91. How important is the MAP sensor?
  92. removing WS6 Hood Baffles
  93. went to track last night..WTF!! pleaassee HELP!!
  94. just put a new catback kit on a murcielago
  95. true duals with stock manifolds??
  96. Volant induction VS aftermarket lid
  97. How to Re-Fill Coolant
  98. Ls1 Coil Packs
  99. name this part
  100. How to remove the wiper motor, and linkage?
  101. Anybody try the new Edelbrock headers yet?
  102. ASP pulley wobbles at idle
  103. Long Tube Headers
  104. New Member
  105. Poly motor mount question
  106. QTP's over JetHots - Is it worth it ???
  107. exhaust question, fast replies please
  108. Just received QTPs, that collector on the Y is huge!
  109. ASAP: Which Wire is the Signal Wire for the Oxy Sensors?
  110. Are Ram-Air Systems Worth the $$$?
  111. spohn torque arm doesnt fit!!!!
  112. Another TB Question: CFM?
  113. Anyone with the SLP 345 lid remove the AIR pump?
  114. Anyone ever heard a Bassani ???
  115. Carsound Cats
  116. What would I benefit more from??
  117. Bolt ons
  118. Hooker Aerochamber
  119. GUYS WIT HOOKERS OR JET HOT LT'S
  120. looking for loudness
  121. Anyone Have ATR Exhaust on SS?
  122. Where can I get a new gasket for Weiand/Holley intake ?
  123. need info on C5 intake installed on a f-body.
  124. Any need for vacuum lines on intake with no HVAC?
  125. t'stat ?
  126. TR6 gap on 422ci+power adder??
  127. Anyone know the sound of SLP Dual/Dual with headers?
  128. pacesetter?????
  129. Who makes larger radiators?
  130. Cats Gone Bad
  131. Hooker headers and Y-pipe
  132. SSRA vs. Downpour
  133. pulley squeak????
  134. People that have had your car dynoed...
  135. DMH ELECTRIC CUTOUT OR MPP2
  136. looking for soundclip, (x-pipe and borlas)
  137. So here's my new dyno...
  138. Flo header install
  139. Changing Cat's to o/r pipes question
  140. Should I.....
  141. high flow cat or O2 SIMS?
  142. What's the stock Throttle Body size?
  143. new headers, now new problems...
  144. 3 BOLT FLANGED ON JET HOT LTS?
  145. Dealership found "nothing wrong".... Advice?
  146. i must be stupid. cant install airlid :(
  147. How to replace front 02 connector?
  148. FTRA- WTF did I do wrong??
  149. Flowmaster Collector
  150. going to track soon. need help quick
  151. Part # for Goodyear Gatorback serpentine belt for our cars?
  152. any new dyno or track info from that new lid?
  153. Need quick info on vacuum hoses for LS6 intake....
  154. Dual Exhaust..Best Place to Buy???
  155. How to spend $450-$500.
  156. Best pulley kit to get?
  157. are you guys still running with your warranty
  158. Thoughts on FLP electric cutout?
  159. Anyone running Borla XR-1's?
  160. GMMG Install?
  161. Help me kill the rasp!
  162. NO EGR on 01-02 Reasons?
  163. Underdrive Pulleys bad according to HPP
  164. heavy voltage drop???
  165. Ideal Location for Cutout
  166. deleted
  167. how much gain for removing cats?
  168. Throttle Body "Drilled & Epoxied"
  169. Ported TB review: Thunder Racing vs Katech
  170. Pipe sizes?
  171. My new Y pipe is in.
  172. exhaust question
  173. I had no clue where to post this...
  174. Where is the Drivetrain Forum???????????????????????
  175. Anyone know the bolt size for M6 shifter bolts?
  176. I gutted the CATS should I get rid of the AIR system?
  177. is this dangerous...
  178. Dual exhaust, no x-pipe??
  179. best xsaust set up
  180. Want more mods and keep factory warrany
  181. Noise From Pulleys??
  182. muffler question
  183. Sparkplug Indexing Questions?
  184. Do I really NEED headers?
  185. Do the Dynomax Ultraflow and Ultraflow SS sound the same?
  186. Wideband O2 ?
  187. Exhaust Tips Hitting Bumper
  188. Aluminum Flywheels Worth the Money??
  189. Need Help with ASP pulley
  190. ATTN: JUSTIN SUTTON
  191. Installing Longtubes Now: Have a Quick Question
  192. Where to get Oval Tubing?
  193. Do i need the alt pulley with a 6 speed
  194. LT's in california
  195. finally! my qtp merge headers are on their way!
  196. Whats a new LS6 crate motor...??
  197. ARP balancer bolt spec?
  198. Fixed banging LTs
  199. Need quick help with 02 Simulators...
  200. Manifold question...
  201. Definitely Smoother
  202. If I remove the AIR
  203. Hooker or Dynatech (kicking the dead horse)
  204. top or bottom??
  205. Homemade coldair, how much piping? where?
  206. Just installed Hooker LT's with no fitment issues !
  207. Hookers or Jet-Hots
  208. A/C STILL LEAKS!!!
  209. Help with rumors.....
  210. SLPheader install..
  211. Where could i buy 2-1/2" or 3" nice exhaust turndowns?
  212. direct flow lid and SLP air temperature module
  213. LS1 LM conversion kit
  214. Stainless Works Headers
  215. Best intank pump for 550+ rwhp?
  216. Duals vs. Y Pipe on Cam & Bolt on car???
  217. 130 amp alternator??
  218. loudmouth,gmmg,or true duals?
  219. Changed my plugs for the first time...
  220. Going for the full Mufflex...
  221. EGR...keep/not to keep?
  222. Would this be a good start?
  223. need help quick - security in car cut off fuel pump
  224. Best Headers Are?
  225. those who live in texas or san antonio area
  226. What is in the slp header installation kit?
  227. How to's for LT install?
  228. mid length headers
  229. Edelbrock Longtube ?s
  230. FINALLY!!! Got my exhaust built- 4" Mufflex, SpinTech, LONG
  231. high velocity merge collector
  232. Will Macs and ORY rasp?
  233. Anyone running the WS6 lower air box on a Camaro?
  234. Removed AIR system, what to use to plug the vacuum line?
  235. Anyone running hooker LTs with a Loudmouth?
  236. Car is surging,dying, Please HELP!!!
  237. Thunder Racing headers- custom y-pipe?
  238. Pacesetter O2 Bungs
  239. ls1 intake
  240. pcv for reduced oil consumtion
  241. external engine
  242. suspension upgrade??
  243. drill thermostat???
  244. What are all the bolt-ons and how much do they help?
  245. Shift Light
  246. Pacesetter Long Tube Dyno Results >>>>>
  247. what are the headers to get?
  248. NGK Plugs
  249. Dampner/Pulley Installation...?
  250. valve cover breathers
