View Full Version : Generation III External Engine
  1. Obx headers(repost maybe)
  2. slp 85mm maf harness
  3. New Exhaust System. Help!
  4. New 80mm throttle body :)
  5. Professional Products Damper
  6. Use crayon to tune exhaust length?
  7. stock valver covers big cam?
  8. Opinions what is a good sounding exhaust.
  9. Throttle body?
  10. PCV Setups with sheetmetal valve covers....???
  11. 85mm MAF
  12. Removing MAP sensor plug from LS6 intake
  13. 346 shortblock or 408?
  14. Broke the fuel rail bolt, stuck inside manifold HELP!
  15. Alternator wire
  16. vacuum/egr port on back of LS6 intake manifold?
  17. Bad maf?
  18. Tuning issues with fast 102
  19. slammed camaro, what headers to get?
  20. Decorative cover for water pump threads
  21. 90mm plus lids?
  22. Which spark plugs for truck coils?
  23. Ls1 with lq9 harness
  24. bbk intake
  25. LS1 Oil Pan with Different Oil Filter Adapter
  26. FTP 98mm lid and SS Hood clearance?
  27. 3" to 2 1/2" Pipe
  28. 85mm MAF rewiring to USE IAT
  29. What do you use to port?
  30. Hey you running those ebay headers...
  31. trimming throttle plate hat ?
  32. TPS IAC screws?
  33. FIX ls1 or 6.0 swap?
  34. What vacuum lines do you actually need???
  35. need a custom engine harness, any ideas????
  36. Tranny Mount
  37. New Catted Y-Pipe and I Pipe done today!!!
  38. Oil Catch Can, what else...?
  39. 4 barrel tb's
  40. Intake cleaning question
  41. Fast Intake question..
  42. can an exhaust change the way ur car lopes?
  43. Wireing harness?
  44. Any one have an ASA LS1 Underdrive pulley/ATI Dampner?
  45. Msd wires not clicking
  46. can i run it?
  47. Does anyone else KEEP changing their mind on spring mods?
  48. What to spend the tax refund on? NEED HELP
  49. LS6 intake upgrade quest!
  50. New slp lid! No emmissions, whata I do about the hole?
  51. LS6 rods strength
  52. 03 C5 ls1 in F-body - Questions
  53. does anybody use magnaflow spun cats??
  54. MAF sensor or delete it?
  55. Which exhaust gaskets?
  56. 2000 ws6
  57. Hp!!
  58. Pacesetter Y pipe restriction
  59. A "how to" port and polish
  60. Upgrade fuel system with cam?
  61. under drive pulley
  62. would a bad temp sensor/connector be the cause for all of this?
  63. Engine Covers for FAST 102???
  64. Opinions on Pacesetter longtubes?
  65. Pressure from driver's side valve cover vent
  66. Making my own throttle body?
  67. Any other Y pipe to fit SLP LTs?
  68. Cheapest SLP LS6
  69. arp bolt help
  70. Anybody know anything about hooker's stainless headers?
  71. Fast 92 Question
  72. Question about Corsa Catback Exhaust with headers
  73. OR-Y or Catted Y-Pipe?
  74. Where do you think I am now?
  75. wideband bung
  76. few more questions on exhaust.
  77. Deciding on a clutch set
  78. 98 headers with egr/air tube HELP
  79. Fluidampr 740102
  80. FAST 102 confusion
  81. Anyone running the LPP Catted Y Pipe?
  82. What else should i do.....
  83. pacesetter lt header o2 sensor question
  84. VDO temperature sender on right passenger head?
  85. 92mm TB on 90mm intake?
  86. a/c block off plate
  87. LS6 Intake?
  88. Mufflex Off Road Y-Pipe
  89. Cutout placement and how it affects sound
  90. Need in help.... P/s pulley
  91. What are stock WS6 cats worth?
  92. Exhaust question
  93. Fast 90 Cathedrial On LS3 Head
  94. what cars have ls6 intakes stock
  95. Do i REALLY need LS6 valley cover/steam tubes with LS6 intake?
  96. Induction Advice
  97. S10 Lq4 swap questions.
  98. wierd smell without cats and which Y to buy
  99. LT1-LS1 swap fuel pump wiring(need help)
  100. HP loss with dana 60s?
  101. anyone ever use Porfessional products?
  102. BIG upgrades on the way...Any suggestions???
  103. lt header help... tsp headers....
  104. tsp rumbler vs powerflo
  105. help me out with exhaust
  106. Will my L92 WCCH Stg2 be enuff head for....
  107. Quick sound clip for those looking at Borla
  108. Are Spintech mufflers any good?
  109. Best price on a lid?
  110. Help with heads
  111. which gear set???
  112. New member of the American Racing Header crew!
  113. TB for TBSS intake.
  114. This upgrade is kicking my ...
  115. 98 ls1 egr/tuning question
  116. Needing fittings for plugging corvette filter to fuel rail
  117. Quick Starter Question....
  118. Need help with more hp
  119. stepped clamps
  120. Which motor mount to get?
  121. which tb is best for me?
  122. Shortys or Long Tube
  123. Lsxr vs lsxrt
  124. Hmmm exhaust pickle..
  125. squeel coming from upfront belt
  126. SLP air lid help
  127. good street Stall converter?
  128. Deleting AIR w/cats?
  129. MTI throttle body
  130. LS1 pulley the same from Fbody to Vette?
  131. Exhaust drone, rasp etc......
  132. Sloppy shaft... Need to find one
  133. Need help On my ls1
  134. My Tru Duals Questions.
  135. What size cutout for stock exhaust? And where did you put your toggle?
  136. Full bolt-ons.. but I still have money, advise?
  137. Intake manifold advice?
  138. Heh...so I was doing the A.I.R. delete, right...
  139. New water pump for cam swap
  140. Anybody running dual cut outs?
  141. Making my car A PROJECT, NEED ALL THE HELP I CAN GET GURUS WELCOME
  142. Bullets on long tubes yes or no
  143. Need Help With radiator Fans.. Please come in!!
  144. ported maf
  145. BR6EF plugs back to TR55...is it needed?
  146. qucik oxygen sensor questions before long tube install?
  147. How does the GMMG flow?
  148. idle prob need help
  149. Question on Cutout Wiring
  150. best header/y-pipe combinatino to add to a borla catback exhaust system?
  151. Dumped off the y
  152. best header/y-pipe combo to add to a borla catback system??
  153. deleted the pcv on my camaro ??
  154. Exhaust question, what do you think...?
  155. Cracked ls block
  156. ARH headers and aftermarket starters
  157. got my hooker longtubes today, Drilling out o2 sensor?
  158. How do you know when you need a catch can setup?
  159. confused
  160. Need help deciding please help pic
  161. underdrive pulley ?
  162. FAST 90/90 V's PORTED STOCK
  163. straight pipes or LM1?
  164. what lower mounting bracket for Alt. on 6.0 with stock accessories?
  165. High mileage LS1 questions...
  166. knock sensor covers
  167. Custom y-pipe
  168. question about mods on z28
  169. Idea : LM1 + Sweet Thunder
  170. New exhaust, ground clearance questions..
  171. Third Gen Swap header size need some help
  172. SLP lid and 85mm MAF dimensions.
  173. Hood clearance with carbureted lq4 in A-body
  174. 90mm tb
  175. Intake and TB
  176. which one?
  177. will a fast 90 fit on a ported weiand intake
  178. mufflers
  179. Adding Dynomax Bullet to Exhaust?
  180. Shortys and LM1
  181. Where to get Spintechs???
  182. 5.3 LS1 swap
  183. Best place to get a catch can???
  184. Exhaust Backfire, Major Loss In Power, Low Idle
  185. B&B vs GMMG
  186. McCord vs. DMH cutouts?
  187. best exhaust
  188. po131 and po151, whats going on?
  189. LPP TD's and Headers, or TSP TD's and headers? Question...
  190. How restrictive is the factory dual-dual?
  191. ls6 valley cover swap on lq4
  192. Magnaflow fitment sucks! (Pics)
  193. LT's and ORY/Noise Question
  194. URGENT - starter dragging
  195. Car has absolutely no electrical power
  196. How to get rid of rasp with Corsa/no cats
  197. Vette and F-body underdrives different?
  198. I found your motor lol
  199. tsp 1 7/8 headers
  200. Ls3 swap @ questions
  201. LS1 TB vs stock 5.3 truck TB
  202. gutting cats passing inspection obdII
  203. Cheapest way to do catback
  204. Cat Conv.
  205. Anyone know where to get a air pump plug for the slp lid?
  206. MAF Screen in/out
  207. runnin lean
  208. temp sensor location
  209. What alternator bracket to run????
  210. help!! must read asap!!
  211. true duals I built....
  212. mods/ws6
  213. TBSS intake.
  214. How long
  215. Speed Daddy Throttle Body Question
  216. Pics of TSP Catted-y?
  217. intake question
  218. Fast 92mm throttle body coupler size?
  219. TSP True Duals Question?
  220. cruise control delete? how
  221. magnaflow muffler question
  222. exhaust/suspension is rattling/clanking(video)
  223. How long are Magnaflow Tips?
  224. New Product: 304 Stainless Race Mufflers
  225. Motovative Solid Motor Mount Install
  226. removing crank pulley...pulley turns a bit. normal?
  227. MSD-8733 2-Step
  228. Question about mandrel bends
  229. Alternator disassembly
  230. cam break in time ?
  231. ls1 engine harness
  232. Info On LS6/Fast 90/Fast92/Fast 102
  233. who ports FAST intakes?
  234. Cylinder #3 not firing, clean spark plug.
  235. clutch problems help!!!!!!!!
  236. LPP Y pipe
  237. ABS Problem
  238. ls1 Alternator not charging
  239. Looking for high flow cats
  240. Suggestions for some new headers and y-pipe
  241. lq4 with block hugger or long tube headers?
  242. Best Street Cam
  243. comp 975 lifters
  244. LS2 or LS6
  245. Can I use the factory fuel rails/setup on the FAST 90
  246. Intake Help
  247. Looking for opinions on 3.5" inlet mufflers
  248. Slp maf
  249. Tsp 1 7/8
  250. Stock y pipe question?
