View Full Version : Generation III External Engine
  1. shop tuned or hand held tuner
  2. exhaust leak...again, PLZ HELP!!!!
  3. Motor Mount Thread Size (LS1 Block)
  4. My car is missing on cylinders 4 and 5 primarily.. NEED HELP!
  5. Does anyone know what underdrive pulley this is?
  6. Exhaust Clamps Size Question
  7. quick Q
  8. Purpose of epoxy on ported TB's
  9. headstuds which ones HELP!!!
  10. yes, another 2K idle thread...
  11. LS6 valley cover question
  12. Should I sell my Corsa catback?
  13. $300 mod
  14. Vapor canister broke off
  15. arh 02 extensions
  16. Dumb question about headers
  17. Prof. Products intakes
  18. lookin to quiet my duals up some
  19. Header ?
  20. Stock cat question...
  21. timing cover??
  22. EGR/AIR delete help
  23. Exhaust opinion
  24. Needing Alternator Mounting Ideas....
  25. broken oil press sending unit
  26. Help-Stripped wire out of Alternator
  27. ls1 lokar dipstick on 5.3 ???
  28. Vacum Map?? LQ4
  29. LPP or BBK Headers and Y-Pipe
  30. What is the best Drag Radial to drive in rain.
  31. Alternator wires picture please
  32. O2 Sensor Question
  33. ls1 and ls2 pwr steering/ alterantor bracket same?
  34. looking to trade my borlamouth for a magnaflow catback
  35. 'TV-Car' Quiz!!! "Test your might!"
  36. what to do?
  37. Are you smarter than a 5th grader? a/c question
  38. Anyone try Jegs plug wires?
  39. Need to quiet down GMMG, options??`
  40. Tsp true dual cabin noise
  41. SLP lid and MAF a restriction?
  42. Moroso oil pan
  43. Exhaust hangers!
  44. Edelbrock Xtreme RPM Heads #61949
  45. plug wires for tall valve covers and truck coils?
  46. Trying to calm my "dynomouth" down some
  47. LS3 steam vents work on an LS1?
  48. Need Help With Pilot Bearing
  49. Oil, Spark Plugs and Coolant for Motor Install
  50. is a morroso oil pan needed for LS6??
  51. Replacing LM I Resonator with other muffler
  52. Block powter coating?
  53. LS1 valve covers
  54. Belt squeal?
  55. Gimme feedback
  56. How to clean K&N filter in 7 stips !!
  57. Bad O2 sensors
  58. how to hook up tach to 95 camaro
  59. hot to fit a muffler underneath car????
  60. Best way to make my car quiet(er)?
  61. More accurate O2 sensor than stock?
  62. Canadian built or US built 5.3?
  63. Steering column help!!
  64. ARP Flexplate bolts
  65. what do i need to run a vic jr?
  66. Performance Spark Plug Wires
  67. 42lb injectors on bolt-on car? yay or neh
  68. What does Basic Operating RPM Range on an intake mean?
  69. LS1 to LS6 intake, PP or Fast Intake
  70. Should I keep it or not!
  71. Should I keep it or not!
  72. pcv ?
  73. TSP catted y-pipe..wtf?
  74. 02 extensions
  75. which heads?
  76. Flowtech headers
  77. Opinions on this setup.
  78. Quietest muffler options for cammed car
  79. Billet Power Steering Pulley
  80. Needing some GM Part #'s...
  81. Worth porting an LS6 int with my setup?
  82. PRC 215s vs PRC LS6 stage 1 Heads
  83. White "X" on back side of cylinder head?
  84. ARH exhaust manifold gaskets with stock manifold
  85. Noob question
  86. anyone had experience with ls2 intake manifold?
  87. Which is better ls6 or ls2 intake
  88. Question on the LSX Block
  89. SLP MAF question with tune
  90. Milky Anti-freeze. Oil is clean.
  91. installing duals.. any tips
  92. SLP LTs touching harness... HELP!
  93. Tsp true duals
  94. 99 ls1 with mac headers , egr and air delete tips
  95. Fast 102 untuned
  96. Different types of mufflers
  97. Custom Y-pipe...cut used? or buy bent pipe?
  98. Oil pan bolts... all the same?
  99. where should it be?
  100. Headers/Exhaust
  101. Which would be faster in THEORY???
  102. New lid suggestion
  103. exhaust loud
  104. Looking to buy hooker headers.
  105. underdrive pulley and mps gains?
  106. Cats and y-pipe
  107. Help with intake install!!
  108. 4150 TB users, step inside.
  109. Freeze plug!!
  110. Smoke in engine bay after L/T header install..?
  111. LS1 & LT1 maf
  112. Where to get a new Fast 92mm Intake?
  113. !!!!EDelbrock SUper Victor or Victor jr???????
  114. All right, guys. I need some help with my on dash BRAKE light.
  115. Vendors: Norris Catch Cans in Stock?
  116. LT y-pipes...inside
  117. Headers on a 383
  118. Crank pulley wobling??
  119. Whats the story on these headers
  120. MSD plug wire issue with 01 WS6
  121. adding a cutout to 2otl catback
  122. Which intake for 90mm tb?
  123. My Budget Exhaust (with track results)
  124. Best y-pipe for my setup
  125. drive belt setup..no a/c or P/S
  126. What 3.5" muffler?
  127. Intake oil leak?
  128. NEED HELP car wont start
  129. ls6 exhaust manifold and plugs
  130. who sells the best cold air kit
  131. 90mm throttle body on BBK Question
  132. maf
  133. CORSA vs MAGNAFLOW
  134. anyone got a stainless works 3.5 inch catback
  135. Next mods?
  136. What RPM should I be shifting at?
  137. New duals finished
  138. More accurate O2 sensor than stock?
  139. Worth it to port LS6 intake?
  140. Motor mounts!!
  141. LS1 Coils
  142. how much HP?
  143. Ls2 maf
  144. oil pressure sensor/ guage
  145. Looking for a LS1 tech in Hawaii
  146. KooKs True Duals
  147. I just picked up a used Meziere water pump, how do I test it?
  148. Truck Manifold w/o turbo
  149. relocated coil packs now what wires?
  150. what are my options - larger maf & lid
  151. Swapping to LS6 pcv got a quick question
  152. Catch Can question
  153. mods to use victor jr manifold and low elbow
  154. harness and computer newbie question
  155. Headers and Daily Driving
  156. issues after minor "modifications"
  157. Crossflow Muffler Questions
  158. wtb 1.85 rockers
  159. LQ4 Identification
  160. picked up a 6.0 got a question
  161. anyone with a starter from kragen?
  162. quick question...
  163. Dual Cutouts Behind Headers?
  164. aps intake?????????????
  165. SLP PowerFlo CB I-pipe?
  166. PICS OF CUSTOM TRUE DUALS with BMR TRAK PAK TQ ARM???
  167. Catch Can and PCV Routing
  168. Low Profile 5.3 vortec oil pan
  169. Any hp gain from modifing TSP y?
  170. About to pull the trigger on TSP duals...last minute advice
  171. Header Q's
  172. Card style MAF
  173. Q about over axle cb pipe
  174. How much tuning required to run an off road Y?
  175. whats this crap in my catch can! help
  176. question about cold air/ ram air installation
  177. junkyard LQ4 or LQ9 for 6.0 w/ .030" milled L92
  178. Stutter or stumble under slow acceleration?
  179. Best headers/y pipe for an eps cam...?
  180. Engine Cuts Out
  181. overheating issues change stat
  182. LH8 oil pan for LS1 engine swap???
  183. Guys Running regular Y's no coating..
  184. IAT sensor?
  185. 92MM Throttle Bodies
  186. Any idea where I can find this? (exhaust)
  187. fel pro intake gaskets?
  188. Throttle body flange dimensions? 4150 Dimensions?
  189. overheating issue
  190. gmmg out of business?
  191. is my pcv set up correctly? (pics)
  192. LQ4 Throttle Body
  193. HELP! 2000 Z28 turns over but no start.
  194. would a hole in the oil dipstick tube...
  195. LS3 Manifold on 317 heads
  196. 1 solid motor mount
  197. oil breather element, yes or nah??
  198. new exhaust, magnaflow true duals
  199. Has anyone purchased from speed tweekerz
  200. HOW do you install Solid Motor Mounts!!??
  201. used FAST 92mm intake
  202. Header paint/coating question
  203. whistling noise all of a sudden
  204. LS7 LUK OEM unsprung Clutch disk? Help ID
  205. Qtp headers problem with secondary air injectionsystem
  206. spintech true dual
  207. Easiest way to turn motor over??
  208. Best Catch Can??
  209. What 4' muffler for mufflex type exhaust
  210. loudmouth true duals
  211. What pulley is this??
  212. Will I make it
  213. Engine oil weight wright-up!..???
  214. Nick Williams 102 Throttle Body
  215. Who has the best deal on a ls1 underdrive pulley to fit camaro/GTO
  216. car running rich and stalls
  217. 99 formy lowered on eibach what lt headers for ground clearance .
  218. Victor Jr Efi V.s Super Victor Efi?
  219. FAST 90 mm TB. TPS reads 0% at all throttle positions. Which wire? Sensor?
  220. bbk vs ls2 intake
  221. Y pipe Exhaust hanger
  222. Guages going haywire
  223. 99 M6. Opinions on making a good DD????
  224. difference in ls1 throttle bodies is 98 different
  225. call me dumb...
  226. LS1 1999 Z-28 Valve Cover Gasket Replacement
  227. 98 into a 99
  228. New Edelbrock Stainless LTs
  229. Best exhaust sound
  230. Non-Mandrel bends, but larger diameter
  231. Who sells a replacement throttle body gasket for a 92mm fast intake?
  232. 100mm MAF - Does it require a retune
  233. Bout to buy ss... Maybe
  234. help with mods?
  235. SLP Cat Back, VS. BORLA Cat Back!
  236. Water Ingestion lol
  237. high idle problems
  238. Ewp
  239. Damaged muffler?
  240. Help with spark plugs!!!
  241. LQ4 guesstimated HP?
  242. Old electronics, on a new 6.0 engine
  243. How does my P&P TB look? with pics
  244. Is fast lower shell part# 54006 discontinue??
  245. P&P TB problem..
  246. injectors
  247. LS1 Overheating
  248. CME on a Loudmouth
  249. LS1-LS6 Swap
  250. looking for good p/n and supplier for ls1 idler pulley
