View Full Version : Generation III External Engine
  1. What 4' muffler for mufflex type exhaust
  2. loudmouth true duals
  3. What pulley is this??
  4. Will I make it
  5. Engine oil weight wright-up!..???
  6. Nick Williams 102 Throttle Body
  7. Who has the best deal on a ls1 underdrive pulley to fit camaro/GTO
  8. car running rich and stalls
  9. 99 formy lowered on eibach what lt headers for ground clearance .
  10. Victor Jr Efi V.s Super Victor Efi?
  11. FAST 90 mm TB. TPS reads 0% at all throttle positions. Which wire? Sensor?
  12. bbk vs ls2 intake
  13. Y pipe Exhaust hanger
  14. Guages going haywire
  15. 99 M6. Opinions on making a good DD????
  16. difference in ls1 throttle bodies is 98 different
  17. call me dumb...
  18. LS1 1999 Z-28 Valve Cover Gasket Replacement
  19. 98 into a 99
  20. New Edelbrock Stainless LTs
  21. Best exhaust sound
  22. Non-Mandrel bends, but larger diameter
  23. Who sells a replacement throttle body gasket for a 92mm fast intake?
  24. 100mm MAF - Does it require a retune
  25. Bout to buy ss... Maybe
  26. help with mods?
  27. SLP Cat Back, VS. BORLA Cat Back!
  28. Water Ingestion lol
  29. high idle problems
  30. Ewp
  31. Damaged muffler?
  32. Help with spark plugs!!!
  33. LQ4 guesstimated HP?
  34. Old electronics, on a new 6.0 engine
  35. How does my P&P TB look? with pics
  36. Is fast lower shell part# 54006 discontinue??
  37. P&P TB problem..
  38. injectors
  39. LS1 Overheating
  40. CME on a Loudmouth
  41. LS1-LS6 Swap
  42. looking for good p/n and supplier for ls1 idler pulley
  43. ls3 intake?
  44. 2000 trans am headers
  45. LS1 Valve Cover Breather/// PCV Valve (NEW DESIGN)
  46. Exhaust, intake, headers tune
  47. ls1 wire harness plug diagram
  48. 10 bolt rear end wont cut it..
  49. NGK plug question
  50. I have a FAST 102
  51. Anyone using a 100mm mass air??
  52. LS1 Headers
  53. intake bolt question
  54. TSP or Pacesetter O/R Y pipe
  55. Who makes the best intake setup
  56. Ls6 : Whats a good intake manifold? Edlebrock proflo?
  57. Massive exhaust leak..
  58. Intake Manifold and Cam ?'s
  59. Will a 2005 ls6 corvette harness work with a 2006 gto ls2 engine?
  60. Plastic Hose Intake?
  61. Tac Issues (throttle body)
  62. Intake/injector question
  63. impact plastic behind bumper
  64. PS install, rather post install pics of passenger side please
  65. SLP underdrive pulley.. need different belts?
  66. Kooks y-pipe with non kooks headers?
  67. Get Kookin With Kooks Contest
  68. Slave cylinder question
  69. Header question?
  70. Best true dual package!
  71. Dont know where to post, but here goes.... 99 Camaro SS.. Need advice!
  72. 02 ss a4 misfire
  73. ls1 dead cylinder Help
  74. Breather tank
  75. driveability issues please help...
  76. fuel
  77. Finished FAST 102 install. Have some issues
  78. mufflex owners please step in
  79. Daily Driver exhaust questions!
  80. Paint Stock Coil Packs?
  81. msd coils
  82. Fluid Dampr or ATI?
  83. HELP: what lid and MAF???
  84. Anyone Installed an Edelbrock Carb Kit??
  85. Can you safely weld headers?
  86. Vacuum With Larger Cams
  87. lil Help Please. What does this plug into???
  88. question about exhaust tone. . .
  89. what a freakin night! :/
  90. anyone got a good clip of a BorlaMouth
  91. TSP forget a pipe?
  92. FAST 102 Vacuum Leak problem
  93. Which head is worth porting
  94. What did you use for block off plates?
  95. what power adder works best with a tourqer v3
  96. Have you ever heard a raspy, catted ls1?
  97. ls6 intake swap
  98. Quiestest Mufflers to weld into catback?
  99. Headers... Shorty, mids and lt's
  100. meziere street pump question
  101. ls1 underdrive pulley differences?
  102. Starter grinding after trans swap
  103. No Spark!
  104. Springs- Comp, Patriot, Lunati Are they all pretty much the same ?
  105. few little extras to the car over winter
  106. Hooker catback install question
  107. True Duals dumped after axle like old 1st Gen Camaros?
  108. cooling helpp!!
  109. Alternator bolt?
  110. 1.75" to 3" headers to 2.5" y to 3" I pipe
  111. Where to get hi flow cats online?
  112. 4" Flowmaster race mufflers
  113. Slp cme?
  114. Header Removel need help
  115. Will not start on first try!!!
  116. coil pack wont come off
  117. Do I gap these plugs? *Iridium
  118. Wiped down the INSIDE of my lid (K&N Argument)
  119. TD Question
  120. will removing egr reduce fuel milage
  121. 2000 C5 Corvette supporting mods the same as F-Bodys 4 Cam swap?
  122. 4" mufflex question
  123. deleting muffler question
  124. Aluminum PS Pulley
  125. TB probelm
  126. What to use for lid gasket?
  127. Catted Y-pipe.?
  128. Possible PCV issue? Need insight
  129. How much would you pay for a used LS2..
  130. 04 gto ls6 inake?
  131. Feedback on TSP Longtubes with ORY!!!!
  132. Noob question about exhaust diameter
  133. Is there an aftermarket YPipe (connecting to cats) that doesn't cost ANY clearance?
  134. Slp maf
  135. Long tubes and loudmouth
  136. ud pulley worth it?
  137. Random vacuum line?
  138. Fast Rope Seals
  139. Just trying to learn
  140. new exhaust,what should i get
  141. LSXtreme headers and y-pipe installed, finally.
  142. Bbk ssi vs pro products typhoon
  143. GMMG is in da house!
  144. Royal Purple makes synthetic oil filters, has anyone seen them? [VIDEO]
  145. Wanting to get my TB P&P
  146. powerflow conversion fit on dual/dual??
  147. Need Mandrel Bent Duals for '98 WS-6
  148. decelerating at high rpms..smoke issue
  149. oil leak being caused by pvc
  150. Weird surge under acceleration. HELP?
  151. Help!!Can't remember the wiring for coils
  152. HKE 427 Valve Cover Help Fast 92MM
  153. Exhaust wrapped headers ?
  154. world of a difference!
  155. SSRA? still available??
  156. Easiest Engine swaps into LS1?
  157. forged piston options & rods for STANDARD bore lq9
  158. MAF Question
  159. LS1 Charging Problem
  160. Alternator DIY?
  161. Can doing just headers & no tune cause Misfire?
  162. Pacesetter's w/ Jet Hot coating
  163. exhaust loudness with new cam
  164. Bbk intake
  165. Are Some Mufflers Interchangeable?
  166. Biggest/best TB for LS6 intake??
  167. Headers into 16in mufflers?
  168. My new LS1... cracked block...
  169. What is this connector for???
  170. FAST 92/92 vs LS6 on an SI car ?
  171. Needing an ls2 harness, coils, and computer
  172. need help ouick pcv i researched and didnt get nodefinate answer
  173. GMMG or go dual
  174. 99 valve covers
  175. 99 TA alternator
  176. question about pacesetter headers
  177. Oil pressure sensor
  178. SES light.. Place your bets..
  179. ? about performance loss, bullets vs anything else
  180. Do QTP stainless headers keep there polished look forever?
  181. 5.3 heads
  182. Someone measure the AIR plug hole on intake lid PLZ !
  183. dead
  184. fresh motor heads retorque?
  185. Who uses an underdrive crank and Alt pulley with there upgraded fuel pump
  186. Catch Can Install PCV Location
  187. plug wires
  188. Average RWHP for a FULL bolt-on + H/C/I LS1?
  189. Cutting out in higher RPM's
  190. need to make sure before i buy
  191. Engine removal lift points?
  192. Stock Manifold pics
  193. how to remove plug on back of ls1/ls6 intake???
  194. C5 and F Body Balancers quick question
  195. Rough Idle & Slow O2 Sensors
  196. Ported TB questions
  197. Throttle cable slack
  198. Stainless replacement stock Y-pipe...?
  199. Lq9+l92 heads what cam?????
  200. Bassani Catback - Is It REALLY 50 State Legal?
  201. TSP ory
  202. Everything I need for full dual exhaust
  203. hooker longtubes
  204. Hooker LT's and TSP ORY pipe help
  205. Stock MAF a restriction before I get her tuned?? (See mods)
  206. Pro-Flo XT LS1 EFI Intake Manifold
  207. cutout
  208. LS3 Intake Manifold & Small Rear Vacuum Line and Map Sensor Compatibility
  209. exhaust too loud..
  210. L&R Motor mounts the same?
  211. Quick Open Headers Question
  212. Ignition coil wiring harness for 98 model heads
  213. bullets or single chambers
  214. Is this air fuel ratio gauge reading normal? Video inside!!!
  215. Header Installation Issues
  216. What Plugs do you run?
  217. Cold, Spinning noise above 3k rpm..
  218. What springs should I run?
  219. LPP clearance pics
  220. Exhaust newb question: ARH headers Y
  221. True Duals
  222. Professional Products Typhoon 96mm?
  223. Spark Plugs fouling
  224. Starter circuit wireing diagram
  225. Anyone using this intake?
  226. Borla Catback/Changing Tips?
  227. Light Starter
  228. O2 Sensor Help!
  229. How will my new setup sound?
  230. Looking for the rear passenger side exhaust tip hanger...
  231. Question on 243 castin heads??
  232. Bogging When Accelerating Out of Turns
  233. extensions and gasket ?
  234. Fast 102 & NW 96mm TB fitment
  235. Ehaust Questions/Help
  236. Ls1 to Ls6 Advantage?
  237. Spark Plugs and gap?
  238. Throttle body question
  239. Flowmaster catback question
  240. Thrush 2 chamber
  241. installing fabricated valve covers, what to do with pcv?
  242. Magnaflow on SLP DD
  243. Header Install Parts
  244. Canister under passenger frame rail?
  245. Summit Borla True Dual?
  246. What bellow for 100mm MAF?
  247. Borla XR-1 Racing muffler
  248. Oil leaking issue on LS2
  249. Water pump leaking from back panel???
  250. Phab Catback?
