View Full Version : Generation III External Engine
  1. PTV results
  2. Need a bit of assistance - trying to troubleshoot the AIR system.
  3. Catback mounting points please?
  4. true duals with cats?
  5. cutout question??
  6. PS Pump hose choice, and broken tube? Need suggestions.
  7. Help on AIR vaccum hoses?
  8. Help me out guys.
  9. Lashway Motorsports Catch Can Special
  10. 1 3/4 headers vs 1 7/8 headers
  11. intake help h/c/i build
  12. ls6 pcv (04 version) - plug heads, or connect?
  13. MAF Question
  14. True Dual Setup Suggestions
  15. how can you tell if you have prc heads
  16. will y pipe fit??
  17. pypes x pipe???
  18. noises
  19. Which Y pipe will fit?
  20. ORY vs Catted Y
  21. Strange or moser 12 bolt housing & axle package
  22. Eliminating Header Tick..??
  23. question for a set of heads i have
  24. Electrical help
  25. Any idea what to do with this intake? no egr fresh air
  26. need cam/crank sensor voltage specs pullin my hair out here
  27. I did it!
  28. Are heads for a ls1 on a lq motor restricting?
  29. oil pressure sensor relocation kits for ls1 camaro's?
  30. PCV System for Stroker DIFFERENT???
  31. Low coolant sensor issue
  32. underdrive pulleys
  33. Header install checklist.
  34. hooker headers
  35. Carb LQ4, which ignition is best??
  36. Procharger now it over heats
  37. Want to make 500wheel with ms4 92 ported fast and heads
  38. throttle body question
  39. will the iron 6.0l heads work on an ls1?
  40. Did 03 Corvette ZO6 Valve Springs Come In black?
  41. Sputters at WOT
  42. Motor Mount Question
  43. Bolt-on's - which one next?
  44. Power Steering Pump
  45. Blackwing vs SLP vs Factory Lid
  46. Norris catch can routing?
  47. LS6 PCV conversion worth it?
  48. Shorties vs LT's
  49. does the DMH e-cutout fit on the QTP cutout?
  50. Correct steam tube to use with a FAST 102?
  51. LS6 intake ?
  52. Cutout self-install question...
  53. Blow through carb bonnet on NA engine?
  54. Which throttle body can I use for my intake?
  55. Bbk headers
  56. Lost Spark Plug
  57. LS6 vs. LS3 intake manifold
  58. I know, another header thread, but different question
  59. Help! where do these vacume lines go??
  60. How many have or had true duals dumped?
  61. true dual hanger locations???
  62. CTS-V vs. Z06 LS6
  63. Best idea for heads with this combo
  64. Exhaust Help/Advice
  65. Are SFCs visible from the side?
  66. ASP/Powerbond Underdrive Pulley Belt P/N# for A/C
  67. Lost Bolts Need Help
  68. cme stock muffler?
  69. Dumped borla
  70. Mamo Fast92 - Shaved/Smoothed/Painted
  71. Fuel Injector Connection, injector performance?
  72. Mounting LM7 to engine stand
  73. Exhaust Question!!
  74. cheap AND dependable heads
  75. Chambered on a budget (help)
  76. Skipping 99 T/A
  77. headers?
  78. New Ls6 with NO EGR! HELP!
  79. Cam in my car an got slower
  80. Question on tuning and headers!!!!
  81. please help asap. lq4 pcv routing.
  82. what GM injectors work on an LS1 that are bigger than stock
  83. dyno tuned...will new heads improve the power?
  84. Not the usual bullet muffler/Loudmouth thread
  85. LS6 vs 90/90: H/C 346
  86. truck heads, max valvespring lift
  87. Would you say this is too loud?
  88. reuse headers bad y-pipe?????
  89. GMMG Exhaust vid up!
  90. What to put in front of an LS3 intake on a 408?
  91. Battery relocation bracket vs relocation box
  92. out of balance water pump?
  93. boltons = loss on power
  94. Mast Motorsports Fully Ported Custom Cast CNC Intake Manifolds
  95. fast 92 intake?
  96. Help deciding on parts
  97. So thinking pacesetters LT/ HP?
  98. TB install question...
  99. Spark Plug's time to change !!
  100. tsp header install
  101. is it worth it to swap the bbk for a fast 102 for my set up
  102. stainless works catback
  103. odd question but curious
  104. ac delete
  105. OEM water pump removal
  106. help
  107. Whats the deal with Rev Extreme????
  108. Picked up an 02' Z06 85MM MAF, already have a tune. How to re-tune?
  109. Lt's from 04 gto,will they fit 04 vette?
  110. cheapo ebay header install question
  111. Ls7 427 camaro which catback?!?!?
  112. Any difference between a Zo6 and a F-Body LS6 intake?
  113. Need kooks header help
  114. eBay Throttle body???
  115. Which mufflers for tsp tds?
  116. Steam Tube Location
  117. ORY pipe size?
  118. 3.8 obx headers whos got them and results
  119. 160 t-stat ?
  120. How does this look?
  121. looking to upgrade my intake on 02 trans am
  122. I Need Some Opinions....
  123. LT Headers: Am I good to go?
  124. Cooling problems, Help!!
  125. Lost power steering in burn out contest??
  126. Exhaust removal advice.
  127. [need some help] .. Borla ProXs with LS1 engine
  128. i need new mufflers
  129. Cutout question that everyone can answer!
  130. Need the size of the oil pan bolt used to drain oil. Mine snapped
  131. LT and mounts
  132. confused on exhuast
  133. Electrical problem
  134. what is the biggest throttle body and maf that can go on an stock ls6 intake
  135. Charging issue
  136. Worth the money to switch???
  137. Header bolt fiasco
  138. Denso Vette o2 Sensor part #?
  139. 5.3L from a 2006 Hybrid Sierra...Differences?
  140. LS1 Vette Covers to Fast Fuel Rails
  141. GTO Ignition cylinder failure...
  142. Went for a Tune
  143. So my muffler crapped out on me.
  144. Anyone have info on how to P&P a TB?
  145. 3.8 multiple misfire helpppppp?
  146. 2000-2002 y pipe on 98
  147. Next Best Headers After Pacesetter?
  148. Midlengths VS LT for a 224/224 cam
  149. Anyone know of a good TB
  150. O2 senors
  151. Hooker Headers Rubbing
  152. Y-pipe options on Kooks 3.5" collectors
  153. Will running open headers to the exhaust shop hurt the O2's?
  154. Modular modified TSP Dual Exhaust
  155. Help me plan my next induction upgrade (LS1)
  156. PVC Catch Can Qs
  157. broken header bolt in head. What would you do?
  158. Help on wiring for DMH e-cutout
  159. Fast 102 What Throttle body
  160. Stupid Thermostat question.
  161. how to get rid of rasp in exhaust?
  162. Ls6 Intake install help
  163. 4" round muffler
  164. Ls6 Intake vs Full Street and Dyno tune
  165. Does GM claim any noise level on stock exhaust?
  166. BBk intake manifold which one do i get?
  167. clarification...
  168. Motor Mounts
  169. gmmg or sweet thunder true duals?
  170. Throttle Body spacers?????
  171. 90mm ls6 intake
  172. Please help with this DTC Code.
  173. Exhaust part numbers
  174. Best price on Edelbrock 71403?
  175. Exhaust/header question
  176. Dual QTP Cutouts
  177. water pumps
  178. Finishing up my exhaust, need opinions.
  179. running lean?
  180. anyone using sureflo headers
  181. O2 extensions..?
  182. Are all QTP cutouts the same?
  183. Anyone fitting 24" or 30" Sweet Thunder or similar mufflers?
  184. tsp true duals
  185. Starter Problem HELP!!!
  186. what to plug hole in lid?
  187. Which one would you run??
  188. best plug????
  189. What valve covers do I need?
  190. Lid Question
  191. engine need to breath better.
  192. headers
  193. Best throttle body for a bolt on car
  194. 3 inch x with Trak Pak is official
  195. AFR 215 Preliminary Dyno #'s C5 Corvette Auto with a Stall
  196. Where to find Cheap injectors??
  197. Removing a/c grooves off harmonic balancer- who's done it before???
  198. ceramic headers?
  199. Finally did it!
  200. LS3 intake VS FAST 102??
  201. Very annoying noise/feeling in pedals and steering wheel
  202. Header Wrapping??
  203. Disconnect MAF = Harder Shifts
  204. What does this mean....
  205. Need help getting intake manifold off
  206. Charging System NIGHTMARE 04 GTO
  207. Engine Cranks, BUT WON'T START, NO FUEL PUMP POWER, NO SPARK!!!!!
  208. Exhaust Install - Realistic Gains?
  209. 2.5 x with the rest 3in?
  210. So Spohn Solid motor mounts really do raise the motor...
  211. Race Headers Clarification
  212. 5.3 truck upgrades
  213. probleme cold air mode camaro
  214. TSP Cats
  215. LT Header tune?
  216. Where to start ? ?
  217. Tach and Speedo single the same
  218. LS6 vs. Fast Intake
  219. Need Modding Advice!
  220. Anyone ever had problems with obx headers?
  221. TSP Catted Y Knock
  222. helix power tower results?
  223. How much is a complete LS1 worth
  224. Muffler right off the header?
  225. Running rough after muffler swap.
  226. 2009+ LS3/LS7 Throttle Body in a c5 question...
  227. FS: Center Mount Exhaust Valance + Corsa Tips
  228. slp maf question plz help
  229. Can't remove the key - problem with the shifter's spring? (see photo)
  230. Sound Normal For Headers?
  231. F Body Exhaust Manifold flanges
  232. Hp gains from ported Tb and Ls6 intake?
  233. Preparing for LT's
  234. Fuel pressure guage help!!!
  235. truck alternator upgrade
  236. Would this require a re-tune?
  237. Power loss for 1 second while driving...
  238. Picture Gallery, halfway through a major overhaul
  239. My fans won't come on!
  240. SLP Y pipe Opinions please
  241. Tb porting
  242. GTO power steering pump in Fbody
  243. 5.3L in 79' camaro.. ?s
  244. For Sale
  245. for those of you with fabbed x pipes
  246. Larger MAF to go with a 98mm Fast Toys Lid
  247. I think I know the answer but I'll ask to be sure...LS2 intake?
  248. Posted this Hypothesis in AET no real answer!
  249. GM MLS exhaust manifold gaskets P/N??
  250. what i should tune when installing Trick Flow® 515 HP GenX ™ Top-End Engine Kits for
