PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316
  1. LS6 Upgrade Path
  2. Oil catch can install
  3. Fast 92 vs 102
  4. UD Pulley question/problem?
  5. power steering pump swap. now belt squeaking
  6. diff between o2 sensors?
  7. Fuel Pressure Gauge installation.
  8. SLP long tubes vs. ARH/kooks long tubes
  9. Decrease Exhaust Volume on Existing System
  10. GUYS!! help out a rookie with his pcv routing
  11. Where's the TAC on a Rainier/TBSS?
  12. 5.3 ls suggestions
  13. A.I.R. removed
  14. Coil Pack Chaos
  15. face lift
  16. Bad oil pressure sensor
  17. Need starter for my 99 ls1 formula tomorrow. 5.3 or 6.0 truck
  18. Need help asap, DD
  19. Help me beat my wife...
  20. Looking for feedback from owners of Hooker Blackheart True Duals
  21. Gear/vacuum type noise in accessory area (video)
  22. What Lid and Coupler to NW92
  23. PCV option with LSX454 NW102TB fast 102
  24. kooks driver side header won't go in.
  25. Size of headers
  26. Holley Hi-ram for appearance only? What injectors?
  27. Best Website to Purchase Headers
  28. Advice on installing LT headers and tuning
  29. PCV hose size?
  30. Summit RacingSFI Harmonic Dampers any one using them?
  31. car tuned with LT/ORY, so what exhaust?
  32. Hooker blackheart duals and s60
  33. Need help choosing engine management system
  34. Solved: CS130 Alternator Wiring
  35. Thermostat/fan setting question
  36. Ported 92 on trickflow fitment. Help!!
  37. Erratic Vacuum Gauge... what's causing it?
  38. Lsx cooling
  39. Injector O-rings for MSD intake
  40. AIR/EGR Removal Help
  41. New bullet/muffler for SLP Loudmouth--opinions!
  42. Getting rid of power steering
  43. ASP pulley throws timing chains?
  44. ported fast 92 fitment HELP
  45. Fast 102 map sensor issue
  46. replacing motor in 2001 pontiac trans am
  47. Ported 92 on trickflow kit
  48. Lq4 build, what size throttle body
  49. Chaned IAC, now extremely high idle.
  50. mounting fuel pressure gauge
  51. LT Header Swap, what else should I get done? List inside
  52. Intake madness!!!!
  53. **UPDATE**I might be the only one to have done this... True dual setup with Madhammer
  54. Harmonic balancer problems
  55. Newbie with idle issues looking for help
  56. Running 33lb injectors can I go to 42LB?
  57. bets on headers? on 403 ls2....
  58. 98 LS1 computer mount
  59. Gmc sierra truck single cab 6.0L iron block
  60. PCV set up.
  61. Fast 102 on an LQ4
  62. injector hat for stock LS1.....possible ???
  63. Oil pan options
  64. Lowest profile intake hose options
  65. Crank pulley
  66. Slave Cylinder Issue
  67. Problems after tuning
  68. 5.3 Steam tube with ls6 intake
  69. Oil Pan question
  70. Throttle Body and Cruise Control
  71. Screwed up position here need help!
  72. 90mm TB/intake, 85mm MAF... worth LS7 4" MAF upgrade?
  73. Relocated Battery Alternator Wire
  74. Yet another LS1/LS6/SLP Intake Question:
  75. Air pocket at the T-State :-(
  76. Coil Relocation Kits
  77. Oil pan removal?
  78. Opinions on a ITB setup on a 408
  79. Alternator dropping voltage at high RPM?
  80. P0155 code - tearing my hair out.
  81. O2 Sensors for LTs - Denso 2344617 & 234-4025
  82. LS6 Intake,lid and exhaust
  83. replaced valley cover, now no Tach?
  84. New LS1 build, looking for info on best parts for performance.
  85. Autometer playback tach
  86. Starter for 5.3 and T56
  87. Need some help understanding Borla exhausts
  88. FAST Intake seals
  89. Factory 5.3 intake manifold maxed out?
  90. Ls1 smoking fast 102 full of oil!!!!! Need help!!
  91. Holly 92mm snioper intake
  92. How/Best way to vent this thing...
  93. Sooooo I did a Thing.. With My WARR Performance TB....
  94. proof that cut out lowers 1/4 mile time?
  95. needing some info please
  96. MAF part#'s
  97. Dumped borla xr1 thinking of changing, few ???
  98. Mini Race bullet worth it ?!?
  99. Center Exhaust question
  100. Is this Ported FAST 90 worth it?
  101. '99 SS Power Steering Pump - Need Help
  102. SLP Blackwing Lid on 99' WS6
  103. What's my machined ls1 worth?
  104. Anyone have a good solution to a lower mount alternator bracket?
  105. Ftp clear air lid
  106. two little vacum air hoses in the which goes on top and bottom?
  107. What electric water pump
  108. Need Help relocating a coil!
  109. LS6 vs FAST 78
  110. 4150 setup vs FAST
  111. Anyone using a catherdral port msd intake? (ported)
  112. Identify these valve covers please
  113. Temp gauge works at startup up, but then goes to zero
  114. Can a poor TPS connection at the TB cause loss of idle?
  115. What kind of headers are these? *pic*
  116. 102mm drive by wire throttle body
  117. OEM LS starter power level?
  118. Looking to Upgrade LS1 Camaro
  119. air "egr" question
  120. Tsp ORY
  121. Any one modify a Moroso 21150 oil pan
  122. Removing PCV and Installing Breather
  123. FAST 102 Setup - Complete build info
  124. Help with vacuum lines
  125. Down and Forward headers with fbody alternator
  126. Giant Air Pocket in Slanted Radiator
  127. 102mm TB on 90mm Intake?
  128. oil sandwich adapter with holley 302-1 oil pan?
  129. 98 z -28 idle surge issues
  130. Gmc 6.0 hard starting
  131. Alternator connection
  132. AEM 30-4110 A/F gauge & E85?
  133. Charcoal canister
  134. mounting the p1sc onto my ls1
  135. Stock throttle body blade screws
  136. Cherry red headers
  137. FM 3"-4" Merge with 4" Cutout Build
  138. HELP: Car runs like crap now!!!
  139. 500+ N/A guys what is your exhaust setup videos would be helpful!
  140. LS3 coolant crossover on LS1?
  141. New steam lines with AN hose and Fittings
  142. Help selecting spark plugs
  143. MAF mounting location LS3/F-body/Holley Hi-Ram
  144. TPS issues HIGH idle
  145. B1 and B2 O2 sensors and fuel trims arent the same - O2s reading at different rates?
  146. PCV valve hose split, would that cause...
  147. Help! Anyone Have a Flowchart for these Injectors?
  148. Knock sensors not working
  149. Ls1 into 94 t/a won't start
  150. PSA: Don't descreen your MAF!
  151. need part numbers for Power Steering lines
  152. How much will a 3.5" catback exhaust flow before being a restriction?
  153. Beating headers with hammer
  154. Mavns WARR Performance 102mm TB Review/write up. + Nic Williams 102 for reference!
  155. FIC vs DeatschWerkz injectors?
  156. SSRA Mega Mouth
  157. MSD Airforce on 5.3 with truck drive system
  158. Stock lq9 throttle body
  159. Valley cover bolts for Fast intakes.
  160. Leaking Out of my slp lm1 exhaust
  161. Huge shout out to Pacesetter
  162. Slp loudmouth exhaust with tsunami cam
  163. Exhaust system for 550rwhp and no rasp or drone????
  164. Headers
  165. Is my current exhaust adequate for my setup!?
  166. Re-Routed catch can, now gerring blue smoke
  167. ZL1/CTSV idler pulley on corvette water pump?
  168. Hotter Spark Improved ignition MSD ?
  169. Engine harness clip. What does it do?
  170. No oil pressure!!!???
  171. Carven mufflers ????
  172. Pontiac V8 + LS1 EFI. Feasible?
  173. Pulley question!!!!!!
  174. Are my brake hoses on right?
  175. CHRS1313 modified questions
  176. Question about which muffler is used on kooks duals
  177. Exhaust leak tricks?
  178. PCV routing any good?
  179. TB intake manifold Question/ suggestion.
  180. A pretty dumb harness question
  181. Opsu or cps oil leaks?
  182. I'm confused EO/IC
  183. Redundant and over-asked question... LoL
  184. Solid Plate Motor Mounts
  185. Installing new roller tip rockers, which bolt??
  186. Is this Exhaust Rattle? Or what the hell?
  187. New LS7 lifters in LS6, 1 bad out of the box?
  188. holley sniper sheet metal intake
  189. Throttle Body conversion
  190. 450-500rwhp from a n/a 5.3l
  191. LS stumbles under acceleration
  192. these new parts worth it?
  193. Iron 408 ls3 top end with stock ls1 water pump and accessories?
  194. size of the 4 bolts for fuel rail
  195. Getting lost with swap, TBSS, truck coils and blue/green harness
  196. Tsp dual proving question?
  197. what is the bolt torque sequence for intake manifold?
  198. remote oil filter location
  199. MAF Question
  200. Help with Flywheel balance
  201. Having trouble getting torque arm bolts back in
  202. LS2 into a Fbody?
  203. 2.5" true duals compared to 3"
  204. NW 90mm TB blade
  205. Steam tube/cross over setup question...
  206. Trick Flow coolant crossover
  207. IAC Question
  208. need help with lq4 catch can routing
  209. Radiator for a 289 cooling a 5.3?
  210. 2002 trans am just shuts off
  211. Heads to compliment...
  212. Professional products coils?
  213. What thermostat do I need?
  214. Pn for harness with LS2 cam in an LS1
  215. Fast 102
  216. Still eating oil
  217. TSP New catback with cut out
  218. Need help with picking a exhaust system?????
  219. need oil pan help
  220. At what point N/A do you need bigger injectors?
  221. 12v fuse distribution block setup? Let me see yours!
  222. Do I need a longer belt?
  223. PLZ HELP What pushrod length is needed for milled .020 243s?
  224. Frost tune or Dyno tune????
  225. Speed Engineering Headers/Y pipe and Prothane Motor Mount install experience
  226. American Racing Headers Installed
  227. PIC REQUEST: "New" LS6 Valley Cover Installed
  228. Catch can routing for MY particular car please look and advise
  229. Motor Mount Orientation?
  230. no longer use a lid, where to get rad support
  231. Knock sensor caps for LS6 valley cover?
  232. standalone harness question???
  233. Air filter
  234. Question about catback to y-pipe fitment
  235. Best Way to Disable Fuel Pressure Regulator in Tank
  236. LS6 Top end possible to sell Feeler
  237. Dorman 615-183X intake
  238. Wiring help 5.3 harness for ls1?
  239. Night fury sound from ls1 or lq9?
  240. Where to start LM7 Swap
  241. LQ9 Swap PCV
  242. Egr/air delete
  243. Feel like i lost some low end tq with Slp loud mouth 1
  244. Underdrive pulley install. Need to replace the seal?
  245. Car STINKS, bad cats?
  246. Final Plumbing
  247. Power Bond Balancer Problem
  248. Does muffler placement matter in a single exhaust with multiple mufflers?
  249. dbc cruise control to 90mm throttle body dbc?
  250. Cats on a cammed LS1 w/LTs?
