- 2003 Vortec 5.3 - Torque specs the same as LS1?
- Descreen or don't descreen
- After market "Y" pipe with factory manifolds
- realized why the LM is so loud....lol
- stripped headerbolt journal
- Ls6 heads-cam package trouble
- Adapters for gauges, location @ oil filter
- H-pipe mounting
- knock sensor prob any suggestions
- Gasket list?
- ARP HEADERS now i'm confused
- Where to get knock sensors and harness?
- RPMs dropping.. any ideas?
- what to get?
- MSD Coil packs
- Anyone have a '98 V8 ECT diagnostic procedure?
- What Underdrive Pulley for an LS1?
- BBK SSI Intake manifold question?
- Spintech 3in catback
- 145 amp F-body alternator?
- sponser that sells catted y pipe for hooker LTs
- Motor mounts for header clearance
- best plug for me?
- Mr. Gasket Thermostat
- New flywheel grinding on starter... help
- Looking for a new exhaust setup....
- ac shuts off at idle?
- needs pics guys
- Edlebrock intake elbow
- better pulleys?
- quiet dwn exhaust in the car
- Bullets dumped right off of headers?
- Chambered exhaust?
- These cats any good?
- thinking about supercharging my V
- Ls/6 intake Vs Edelbrock victor jr intake and elbow.
- TSP 1-7/8 header install - help!
- "Need ls1 expert Advise only"
- Clattering noise at acceleration?
- Exaust band clamps
- beck sheet metal intake
- Alternator question
- Fast 92 w/ Fast fuel rail hookup
- lq4 with l92 heads
- LS6 spark plugwire part#
- Wiring gauges
- Have any of you guys had to cut on your TSP duals to get them to fit?
- Throttle body open to much throwing code
- E-Cutout...Maybe?
- lm2 bullet muffler vs magnaflow vs dynomax bullet muffler?
- Test a COIL?????
- true dual over the axle measurements/angles
- Header paint
- Need help with header collector clamps for Pacesetter LT's
- Anyone tuned a cutout before?
- Old mangamouth sound clip i dug up
- This guy is on crack right?
- Long Tubes + Emissions = EVAP not ready?
- Fan Control and 160* Stat
- Need help porting my Fast intake.
- cruise cable retainer clip
- header question
- intake manifold EGR block off plate?
- Question on TSP duals
- Best and lightest UD pully !!
- Loudest muffler to fit as stock replacement
- WTB : LQ9 Bare Block
- ASA LS1 Wiring Diagram to Share??
- 99 rs parts to 98 z28?
- LS6 intake manifold and EGR?
- Header and Y Poll inside
- Catch can or Delete PCV?
- TH350 behind my LS1 engine
- HO Alternator
- LT1 Radiator Question (for swap)
- vette vs camaro exhaust
- Headers..what to do plz help!!
- Starter brands
- Pacesetter headers
- Right part???
- Couple head questions??
- lid to TB 90mm- how long for tube?
- Fast Intakes
- TPS issue
- headlight and guage dimming problem, need assistance
- Exhaust questions
- alternator replacement questions.....
- TPS wire colors?
- Anyone know what size this bolt is???
- VOLANT cai
- True Duals With SLP LTS
- injecters?
- TSP C5 Corvette Longtubes?
- HELP: My ATI Supredamper has hex head cap bolts on it. Clear the PS rack (C5)???
- Need help finding an exhaust gasket like this
- What pully is this and where can i get one
- Cam selection
- HELP! will a 1997 cat back fit my 1999 f body?
- borla exhaust system question
- High Idle, TPS issue
- 241/243 casting ?
- Help with exhaust
- e-cutout question
- engine temp gauge
- Exhaust hanger?
- pulleys
- how much would a used exhuast cost
- Would a GMPP 376LSX work in a 4th gen....
- Stock question about ls1
- Now an alternator problem
- What is the name of this piece?!
- Something banging under quick acceleration.
- SLP lid vs customizing stock lid. UPDATE and quick question
- Identifying a 5.3 Flex fuel motor?
- P&P Throttle body on a 98?
- 12V + dash lighting
- which plug
- What is the part number for the stock LS1 F-body harmonic balancer?
- Engine test bench
- Anybody else have this issue with TSP's new Y-Pipe??
- Should I Buy A FAST Throttle Body or ASP Pulley First?
- So I just swapped over to poly mounts in about 30 minutes...
- Anyone use Green FIlters ??
- What could this be?
- Whats the best engine oil cooler to buy
- FAST 102 too big?
- best ignition wire deal????
- Getting ready for LT install
- How to unplug truck style fuel injector???
- Gutting High Flow Cats with a rich tune
- TD's vs. GMMG
- Rebuilding PCV system
- 2" Primary Headers...
- need help car is misfiring
- Muffler Q's
- Ignition Fuse keeps blowing
- exhaust question
- Are you guys (T) the back vc ports or caping the pass for catch can??
- head ?
- attaching cme from magna muffler???
- Car died
- kooks header and catted y install question
- What mods to do now??
- Decent welder for simply tacking?
- Speed Inc. Alt relocation help
- LS1 + cutout = awesomeness
- Anyone got pics of ther tsp td's under car?
- Manufactured Y-pipe vs. Muffler shop Y-pipe
- Whats the best way to make my exhaust deeper?
- bad backfire after lt install please help....
- Texas Speed Headers
- What would your first mod be?
- best mufflers off the collectors
- Where would you go from here?
- Strange electrical issue (maf,cags,oil pressure)
- Alternator Wiring Help!
- what type of exhaust will????
- Getting more air?
- Cracked ls1 block looking to swap to an lq9 block need advice
- What kind of headers are these?
- Underdrive pulley
- SLP traction control module
- 98 T/A LS6 install almost complete - Any suggestions for next stage(s) of project ?
- Who's got the best deal on.....
- MS4 cam?
- Which is most likely to fail 1st
- exhaust tips for ws6 catback
- need help with o2 extensions
- Alternator upgrade
- Just got done with mods....
- For Headers Can I
- coil relocation wires???
- Anyone heard a flowmaster 50 series on a LS1?
- Burkhart or MW chassis torque arm ??
- D585 coils - necessity of changing dwell tables?
- Engine Fire
- 240sx project
- Wideband Installation Question
- Input on small lift with decent (112) lsa cam?
- Any tricks to changing a power steering pump on 2000 5.3
- Do Pacesetters Bolt Up to LPP TDs?
- Exhaust over the axle. What angles and pipe?
- FAST 102mm too big?
- full exhaust
- Removing MAP Sensor?
- Best header gaskets?
- Solid motor mounts! Please read!
- Stupid A/C Question. Will The System Re-Charge
- LS2 Fast102 NPP Vacuum fitting
- any difference in o2 extensions
- Why Does My Trans Am Run On The Hotter Side?
- What's not needed in the engine bay? Trying to clean it up a bit...
- Traction control switch, custom
- LS1 Intake next to a FAST 102mm Intake and 102mm T/B ALSO INSIDE!!!!
- Flanges/Clamps for Header Collectors?
- LS1 vs LS2 heads
- 4150 Edelbrock or Accufab
- Snapped a bolt off of the stock manifold, what now?
- i got this codes p0134 and p0154
- FTRA vs. SLP vs. Free mod.
- Cooling exhaust temps by using A.I.R.?
- Ordered My Longtubes...Prepping for the install
- Cme ?
- washer fluid option
- Removed EGR and now I have an off idle hesitation when I blip the throttle.
- intake identification
- dmh electric cutout
- help with head choice guys...plz really good deal i dont want to let slide
- Thoughts on stainless works LT's
- Headers installed. Now how to keep headers from hitting floor and ratlling?
- location of x pipe
- GTO manifold power numbers
- Exhaust flanges, what do you like?
- Would FRA mod defeat purpose of WS6 hood?
- 4 Cats, better emissions???
- motor on my elec cutout got knocked off
- spohn solid mms
- What is this?
- I have no ses after race headers and ory???
- quieter muffler on loud mouth
- which coil packs work with 99 LS1 harness?
- Headers on need help now
- Help with parts
- catch can??
- Full exhaust question
- how much will tune help with my headers?
- over heating
- Question on ud pulley install
- What sponsor has a good price on American Racing Headers?
- Grottyham headers, what y pipe fits???
- Question about my 02' Z28 exhaust hanger
- How much HP from a carbed LS6?
- 5.3 Coil Pack Upgrade and Wires = ???HP
- Koolsox - Prevent Melting Plug Wires?
- Oil Neck.
- Y-Muffler vs Y-Pipe?
- y-pipe for ebay headers?
- ARH Headers and ARH Y pipe
- QTP LT Headers really THAT good?
- QTP Screamer Exhaust on LS1 F-Body?
- Got my headers in!!!
- carbed intake with elbow OR LSXR 102mm?????
- Exhaust Question
- tires
- Does Anyone Make Y-Pipes Like This?
- Custom Exhaust
- LS1 coil pack harness pins?
- FTP 98mm lid..no hole
- Y-pipe question
- anyone with td's and borla xr1 need help
