View Full Version : Generation III External Engine
  1. Black Headlights
  2. Pro Flo XT
  3. Red Meziere Water Pump
  4. best balancer/pulley set up
  5. trying to choose a muffler for my setup, opinions please!
  6. rod clearancing oil pan issue.. any ideas?
  7. my car won't start! whats wrong?
  8. Opinions on Fast intake install on a MS4 car
  9. PB UD pulley install
  10. o2's confused front and rear
  11. comp roller rockers input please
  12. Intake manifold for my setup. Questions
  13. My True Dual build
  14. Speed limiter delete without tuner?
  15. problem after LT's, ORY
  16. Throttle body question
  17. E. cutout switch
  18. Quick o2 install question
  19. Idle issue after LT, ORY, LS6 intake install.. Need help.
  20. just got headers
  21. exhaust to loud and raspy help
  22. Do I have the correct pacesetter y pipe? (pic)
  23. were can i pick up a fast 92/92 setup
  24. finished my exhaust... let me know what u guys think!! vid*
  25. need alittle help with tsp offroad Y pipe
  26. Where to find center mount exhaust tips
  27. Exhaust backfire/stumble
  28. Manual fan switch
  29. Where to find these resonators?
  30. Flipping Fuel Line Brackets
  31. Installed Fast 102... Big problems... FIXED!!
  32. Best choice for my goals?
  33. SLP harmonic balancer Slotted?
  34. What is this part
  35. ls6 heads ?
  36. Where to buy stainless steel flanges?
  37. Is wondering which is correct about headers?
  38. Gains from LS6 intake vs LS1 in terms of MPH
  39. what water pump replacement
  40. Noob question, stock PCV routing
  41. what do i need
  42. Suggestions on a LQ4 build?
  43. H/C N/A LS1, going crazy, tr55 or tr6 plugs!!
  44. o2 help please
  45. a/c compressor
  46. WTF, Y Pipe Install Help!
  47. thermostat question!
  48. What's the difference b/t the 4.8 and 5.3L motors
  49. Question on O2 Simmulators!
  50. Different exhaust?
  51. wheres is ur manual cutout
  52. Cleaning Intake Questions??
  53. need some help locating a part
  54. exhaust shops in nashville
  55. here's what I think of earth day
  56. msd 5096 aps mini starters?
  57. corsa muffler
  58. typhoon 85mm vs fast 90/90?
  59. Alternator bracket bolts
  60. Engine stand bolts on a LQ4
  61. Both SLP catbacks
  62. step by step on how to check pr length?
  63. intake and tb problems
  64. a4 stall
  65. wrapping coated headers?
  66. ....02 sensors...
  67. Idle high right after bbk tb install
  68. American racing y-pipe
  69. Ported Fast 92/92 on bolt-on 346=tune?
  70. Firecore50 Wires now available in a 45 deg boot
  71. what size bends for over axle exhaust pipe?
  72. battery relocation how to?
  73. Keeping from locking stereo ?
  74. what u guys think bout this
  75. headers
  76. 99 TB on an 02
  77. LS6/Weiland intake
  78. TSP 100mm MAF integrated IAT not working
  79. Plugs and Wires
  80. 97-98 Z28/Trans Am gauge clusters...
  81. plug wires needed
  82. Are all starters the same?
  83. 383 rotating assembly????
  84. New Exhaust product (4" single, 3" duals w/TIPS), interest and comments needed!
  85. best place online to get msd wires?
  86. Rumbler vs loudmouth ?
  87. Help! Can someone take some measurements on Mac Mid lengths for me?
  88. catch can
  89. Does porting the Edelbrock Pro-Flo help?
  90. engine mounts
  91. New FAST 102 w/78mm tb
  92. will 13" o2 extensions work on longtube headers
  93. Stainless Works Headers?
  94. Basic ls6 Throttle Body question
  95. cheapest way to LT's and TD's???
  96. Head Question???
  97. Need Head Gaskets and Head Bolts!! Help
  98. LS6 Intake??
  99. Newbie help
  100. 1 3/4 LT vs 1 7/8 LT
  101. Melted Motor Mount???
  102. Longtubes for 78 Camaro LS1 ??? Pacesetters worked great
  103. The true cost of a header install. Done right.
  104. MAF Trade
  105. Need help with air lid
  106. cb pipe to y merge temp?
  107. weld it over or remove old weld and clamp?
  108. Need help finding headers...for a boat.
  109. LS1/LS6 intake coolant/steam tube torque spec?
  110. Replace both O2's??
  111. Header install check list
  112. long tube headers vs short tube headers
  113. Just bought ls6 intake!!!
  114. Is the ls1 camaro a pressurized coolant system?
  115. Fixing a sticking FAST TB
  116. Making a stock ls1 exhaust sound better
  117. Headers and cat y
  118. Anyone with dynomax super turbo catback?
  119. Help!! Choosing a Cat-back
  120. gto valve covers
  121. help me please!!!!!!!
  122. Underdrive Crank Pulley
  123. Is 3.5" exhaust a real problem?
  124. Got in race class, want street class. Restrictive cat/muff tune question with cutouts
  125. Dont know how to re-set throttle cable tension- HELP!
  126. Weird Hessitation at 2500rpms
  127. Need cat recommendation for rumbler on lowered car
  128. Magnaflow + long tubes
  129. Uh-oh! Hole in my pacesetter!
  130. help please asap!!!!!!
  131. Cut to fit LSx plug wires
  132. ls1 wont start
  133. stupid question but...can i fit 2000+ longtube headers on a 98?
  134. AC Delco Iridiums Gap????
  135. Need an X-pipe
  136. Porting a Fast 90
  137. big fitment problem after header install... has this happened to anyone else?? *pics*
  138. Is my PCV setup wrong???
  139. easiest way to to get AIR pump out of car?
  140. Half shaft sticking
  141. header bolts
  142. lq4
  143. Intake porting Ohio
  144. So Lost ! I dont know what to do !
  145. 2000 pcm and harness in 1998 body
  146. Got my 1 7/8 headers
  147. hp/tq estimates?
  148. coil pack ground
  149. FAST 102 w/LS2 fuel rail
  150. K&N Cold air intake, or No?
  151. C6 exhaust manifolds + 317 heads?
  152. Catch can install. A useful tip for hook up...
  153. Will the truck steam vent fit a LS3 Intake
  154. what to expect?
  155. Exhaust Backfiring after Header install?
  156. Borla cut outs?
  157. Anyone have a wiring diagram?
  158. throttle body 85mm??
  159. ls6 intake
  160. what else needs to be blocked off?
  161. How much power out of a cam only L33?
  162. bolt size on end of heads?
  163. striped out the o2 sendor bung! what tap size to use
  164. How do you fix exhaust leaks?
  165. Gasket Question
  166. just changed my wires and...
  167. Electric problems after new rockers ???
  168. SLOW tach
  169. Over heating
  170. Are LT's/ORY/catback really worth it?
  171. Mount install - Need Advice
  172. retune with bigger headers?
  173. can you reverse coil packs?
  174. need ls6 intake pic
  175. rear oil pan bolt
  176. gmmg
  177. has anyone had any problems with MSD Coil Packs??!!
  178. replacing LM muffler with chambered muffler...
  179. What threads are the coolant plugs and oil sender?
  180. radiator info
  181. Which extensions to get/plug and play extension ok??
  182. Will BBK LT's and a TSP 3" ORY fit no problem?
  183. Need New PCV lines
  184. O2 sensors
  185. Help asap!
  186. mezerie race water pump
  187. Is my 1/8 mile time ideal ?
  188. Magnaflow 16723
  189. rough idle after jumpstart?
  190. Crank Snout Tap????
  191. Rough on start up
  192. installed lt's and ory.. question about ses
  193. Aluminum Intake
  194. Any cons to running a catless wide open exhaust?
  195. o2 sensors too short, help please
  196. best lid for ls juan
  197. Can i run an off road y and lm1 catack on stock manifolds?
  198. Anyone cut there non ws6 lower airbox to have a bigger opening
  199. Aftermarket Water Temp Gauge Reads On The Cold side????
  200. ideas on a nice way to fix this fuel line problem
  201. adjusting throttle cable? Help?
  202. help! wierd azz 02 sensor question
  203. what else do I need for lt install.
  204. coil brackets
  205. BBK Setup need to no what maf you think is good
  206. SLP 2OTL vs Magnaflow H/C Sound Clips
  207. car backfiring after header install
  208. Anybody Have Problems With Threading Their ARP Crank Bolt?
  209. do these 02's look shot?
  210. So, about the Edelbrock Pro-Flo Intake
  211. Yes, a headers question....
  212. 12" Dynomax Bullets vs. 16" Dynomax Bullets
  213. Adding cat to ORY
  214. LS6 intake install - change Knock sensors?
  215. thermostat problems!!
  216. Catback vs. True Duals
  217. ATI Super Damper, what size?
  218. PORTING ls6 intake ?
  219. How can I launch better? LCA's and what?
  220. Anybody have ory for 99
  221. which is prefered and why?
  222. best muffler/xpipe to use with custom dual system?
  223. Headers & EGR
  224. Cutout size: same for stock as Magnaflow?
  225. Best Swap?
  226. SLP Loud Mouth question
  227. PS cooler for my camaro ss
  228. Anyone running OBX headers and Y pipe?
  229. slp lid....k&n filter or paper?
  230. Misfire with no dtc's
  231. Battery relocation help!!!
  232. Alternator after alternator, any builders here ???
  233. FAST 102 TB +MAF question.....help please
  234. Can i use Ford racing 47lbs (EV14) ??
  235. Bolt pattern dimensions for FAST 90/92mm TB or other aftermarket TB
  236. true duels
  237. Loudmouth 1 Resonator
  238. TB slack won't fully open butterfly?
  239. Full bolt on's
  240. CAI vs lid and filter?
  241. gasket kit
  242. Header Install
  243. Pacesetter LTs with 3 inch X pipe into Magnaflows dumped
  244. 02 sensors?
  245. header install today... need help fast
  246. whats the best high flow cathletic converter
  247. My final exhaust review!!!
  248. Volant CAI
  249. Where to tune after H/C/I/LT's
  250. Best FAST 92 port job??
