- best muffler/xpipe to use with custom dual system?
- Headers & EGR
- Cutout size: same for stock as Magnaflow?
- Best Swap?
- SLP Loud Mouth question
- PS cooler for my camaro ss
- Anyone running OBX headers and Y pipe?
- slp lid....k&n filter or paper?
- Misfire with no dtc's
- Battery relocation help!!!
- Alternator after alternator, any builders here ???
- FAST 102 TB +MAF question.....help please
- Can i use Ford racing 47lbs (EV14) ??
- Bolt pattern dimensions for FAST 90/92mm TB or other aftermarket TB
- true duels
- Loudmouth 1 Resonator
- TB slack won't fully open butterfly?
- Full bolt on's
- CAI vs lid and filter?
- gasket kit
- Header Install
- Pacesetter LTs with 3 inch X pipe into Magnaflows dumped
- 02 sensors?
- header install today... need help fast
- whats the best high flow cathletic converter
- My final exhaust review!!!
- Volant CAI
- Where to tune after H/C/I/LT's
- Best FAST 92 port job??
- Anyone bought TSP headers w/ these flanges?
- LPP headers Hitting Motor Mount
- Ls6 Intake Fab work !! Opinion's !!(PIC'S)
- why would they use 2.5" pipe from LT headers
- lq9 bolt ons
- ac compressor pump
- help removing ac
- anyone runnin a Q45 throttle body???
- How much HP do you loose installing CATS? (i've searched)
- muffler to flow well but be quiet
- head gaskets
- Mods for street/strip DD!
- Headers and starter heat reflective wrap.
- Texas Speed Headers
- Exhaust on ls1 cars
- how much louder?
- What is LS1 Tech's opinion on exhaust cutouts?
- LS6 intake and stock MAF on a 370
- 02 5.3 with 06 5.3 wiring and comp ?????
- What Intake/TB Combo?
- pcv system question
- which muffler with loudmouth1
- I need help with my exhaust
- Need some info
- Alternator relocation help
- Rear-end
- SLP LoudMouth 1
- LM7 serp belt options...?
- Vehicle speed vs fan speed question
- Over axle exhaust pipe
- LSx engine diaper
- LS1 starter on LM7?
- sensor help
- Ignition Wiring Error
- Map Sensor Question
- lq4...lq9.. but what truck is it from.. help
- Exhaust... several questions.
- Finally got the 6.0 done!!!!
- upgrading to ls6 intake
- Motor Firing On Half the Cylinders???
- Would car misfire if plug wire wasn't on all the way?
- Fast intake re-assembly question Any Help?
- New Dynomax VT Mufler
- LS2 Crankshaft bolt! **Please Read**
- Best Catted Y pipe for Jet hot headers?
- removing epoxy from tb
- idler hits bracket
- SLP Smooth Bellow
- summitt racing 3" x pipe kit
- Which ls6 intake to use?
- ever see someone hack a muffler like so?
- Passenger side o2 distance
- Need help picking out oil catch can!
- Problems with full exhaust install
- y-pipe banging.
- Got Cam?
- Unsolved mystery!!! 01 z28 problem plz help!!!!
- anyone using 6LE stainless CME tips? got a question
- thinking about powerflo's w/o the lm?
- Fresh LT install and now car won't idle
- Repeat Offender P0136
- Purchasing a short block... which gaskets needed to complete the build?
- help o2 sensor problems!
- new f.a.s.t. lsxr 102 intake
- JEGS Electric Exhaust Cutouts
- QTP Headers Help.
- Are these cats any good?
- damn intake gaskets!!
- Lids other than slp?
- LS6 or F.A.S.T Intake???
- Okay stupid question!
- ws6 with these tips..help..
- intake gaskets
- Electric Cutout....
- Huge coolant leak now, please help!!
- Is it possible to identify this bullet?
- What is this hose? Please help!
- ebay valve covrs
- ***4" mufflex finally installed!!!***
- You know this is a good setup
- LS6 intake vaccum line plug
- O2 ?
- MSD Blaster coil packs
- Test Fit
- transmission ?
- tips or no tips (i got the tips pics inside)
- Chambermouth length question
- Bad stuff in crankcase?
- March Underdrive Pulley - Belts?
- Oil Pressure Sending Unit
- Is this normal?????
- SLP vs. PACESETTER
- Questions to install headers
- SLP Lid + Bellows Results on DYnolicious (iphone)
- block hugger headers
- Long tubes without tune for clutch break in?
- A/C problem has me stumped...
- coolent crossover tube?
- turn key and nothin?!
- What You think about not using a tunnel bracket?
- UMI solid motor mount question
- anyone ever done a td setup, dumped, without an x or h pipe?
- Tune with bullets?
- Edelbrock Water Pump pulley OD?
- Voltage maxing on car
- What Size Injectors Recommended for FAST 90 (or 92)
- Suggestions on cam
- I got my headers
- Texas Speed Rumbler Vs. SLP Loudmouth
- 3" radiator too thick??
- old style slps or pacesetters
- question on headers
- Poll: Which plug wires? MSD or Granatelli?
- Bolt "snap" when torquing heads
- 85mm tb blade
- Need Help ASAP!!!
- Is the Corvette worth it?
- Which header gasket do you like?
- WHat's the Biggest Roller rocker possible on a stock LS1
- Weird situation
- Crank pulley install... What method did you use?
- AC Problem
- LT's collector leaking, fix with epoxy for metal?
- Plug wire boots??
- Lq4 or LS1
- gonna be gettin some headers in 5 min, quick question
- Probably A Dumb Question
- Pcm ground question, engine will not fire up.
- got my hooker headers in today.....did i get ripped?? pics*
- FAST intake questions
- Knock Sensor
- looking for modification suggestions
- Help with slipping belt!
- LS1 idles great but very rough under load condition
- headers
- Seems you can't buy just a PCV valve anymore.....
- what size headers?
- Backfire when trying to start
- snapped header bolt
- Best place to get injectors
- Battery relocation wiring...Pics needed...
- LS1 Coolant flow... For aftermarket gauge.
- Need some input
- Questions on duel electric cutout location
- Questions about a cam
- Spark Plugs for Carbureted Ms4 Ls1
- Anyone have this cutout
- Help with new parts
- Catback hp numbers
- LS Swap From The Top !
- underdrive pulley
- Cutout could get ripped off exhaust? wtf?
- headers, cat back, cold air intake
- Aftermarket exhaust specialist come on in. Need help asap.
- Titanium C5 Z06 Type Exhaust On FBODY?
- WEIRD PROBLEMS...never seen nothing like it.
- Ground wire on wiring harness question
- Leaky header tick at idle or wot?
- HELP P0154 O2 Sensor Circuit No Activity Detected
- SLP Lid/air pump hose
- Y pipe install
- cam help please
- Has anyone done this?
- LS1 bolt ons
- The most RWHP from an LS6 w/ just bolt-ons?
- 408 Engine Swap [What else to upgrade]
- ls6 intake modify
- lt/ory install ?
- Exhaust and Clamp question, and only a whopping 8hp increase with full exhaust.
- Hooker ORY (sux) pix added
- 01-03 LS6 Valley Cover vs 04 Valley Cover
- Question about Headers
- Ls2 intake into LS1
- Tune Up?
- Bassani true duals
- Typhoon intake/Injectors...
- Someone school me on the valley cover issue?
- My belt keeps moving???
- what exhaust
- 4" exhaust. PHB relocation and other ?'s
- Swapping V6 with LS engine.. Thoughts?
- Which catback?
- Quick TPS voltage vs idle question
- AIR delete
- Gut out my catalytic converter
- first thread
- which of these to get..
- best headers for the buck??
- maf for fast setup??
- Good Exhaust/Muffler
- Unburnt fuel after frequent idle?
- SLP Dual Dual
- coolent air tube
- Installing True Duals
- victor jr intake questions
- Borla Non Adjustabel catback???????
- Some quick newbie questions
- No acceleration even with pedal floored
- C5 P0343 code
- Anybody know the make of these headers?
- 5.3 puter question
- 550 for a catted y pipe ouch
- anyone have truble with there magnamouth exhaust draging on ground
- Question about my fan settings/ should I get a 160 t-stat
- FAST 102 cathedral Port and 42lb Bosch Style Injector Question
- New O2's or extend the old ones
- Volant intake kit
- how much power will I lose going from SLP longtubes to BBK's
- Intake Question
- TSP 1 7/8 header install
- How does this sound?
- MSD Starter Video
- Just installed: AR 1-7/8" long tubes on the T/A
- Driving on Clogged Injector
- how much is a used ls6 intake worth?
- help with headers
- New/Existing Diagram for Catch Can (Stock LS1)
- SLP Loudmouth's New Tips
- okay gurus which cat back is on my car?
- LS6 intake issue
- Anyone use corvette fuel rail covers on a carbureted motor!!!?!?!
